Forum » Loža » F1 2006
F1 2006
BigWhale ::
Jaz pa komaj cakam, da Microsoft zacne dobavljati ECU skatle.
Bodo se bolj pestre dirke, dva postanka za bencin in menjavo gum in en postanek za reboot..
[ New Hardware Found: Intermediate tyres, do you want me to search for new drivers or even driver? ]
Daedalus ::
Fresh fuel detected, please reboot the system to complete installation
[J.P.Sartre]
[J.P.Sartre]
Alexius Heristalski ::
Pravzaprav bo ECU-je izdeloval McLaren Electronic Systems, ki je v lasti McLarna (jasno). Kaj ima Microsoft zraven, ne vem.
Zakaj je Montoya šel v NASCAR:
McLaren company wins ECU bid
By Jonathan Noble Thursday, July 6th 2006, 14:48 GMT
McLaren Electronic Systems, an independent developer within McLaren's group of companies, is behind the successful bid with Microsoft to supply ECUs in Formula One from 2008, autosport.com can reveal.
Although the exact identity of the 'Microsoft MES' company that was announced by the FIA yesterday was unclear, sources have confirmed that the firm involved with Microsoft is McLaren Electronic Systems.
The company has been an independent developer of systems for more than 15 years, and supplies all the current competitors in F1 with different products.
Although MES shares its name with McLaren, and operates from the McLaren Technology Centre in Woking, there are no direct links between it and the Formula One team.
MES's company statement claims: "McLaren Electronic Systems is an independent company of the McLaren Group of Companies. It is a leading exponent of the group's technical prowess and design philosophy.
"Its goal is to provide the automotive electronics customer with a complete range of products that are reliable, yet at the very limits of technology.
"Our reputation is built on a record of success obtained through our constant pursuit of excellence. McLaren Electronic Systems aims to become the world's premier supplier of advanced automotive control and development support systems where small to medium quantities are required."
MES supplies engine and chassis control units in all categories of motor racing, including F1, the World Rally Championship and sportscars.
TribesMan ::
FIA spreminja pravila...
Tretji del kvalifikacij je sedaj samo še 15 minut dolg, in v petek ni več dovoljeno testirati s tretjim avtomobilom (to je bilo dovoljeno moštvom ki so bila lani slabša kot 4.)
TribesMan
TribesMan
Tilen ::
Sicer ne vem koliko sprememb kaj prinasa teh 15 minut zdaj ampak meni je pa res vseeno ce gledam 15 ali 20 minut na koncu. Itak se vse odvije v 5 min.
CHAOS ::
Za enkrat vse po starem.
'They have computers, and they may have other weapons of mass destruction.'
mavec ::
Letos bo še akcija v F1. Ron hoče, da "razbijač" oddela pogodbo do konca. Torej bo še napeto na dirkah
matjazx ::
mogoče bo pa sezona vendarle še do konca napeta - boj za naslov prvaka
in še celo na kvalifikacijah dve prehitevanji pa mini štart
OrlyTM ::
spet vse rdece ... fajn
OrlyTM
OrlyTM
<b>Fear is in The Eye Of The Beholder. Don't let it be You!</b>
mavec ::
Schumi in Alonso stojita na idealni liniji, medtem, ko Massa ne in upam si staviti, da bo jutri Alonso prvi na štartu. Že tako ali tako je na prejšnji dirki ali še pred to, če se ne motim je pridobil 5 mest na štartu...
Samo čudež bo jutri lahko preprečil "standard" ...
CHAOS ::
Jaz upam na pameten štart obeh Ferrarijev, tako da zapreta Alonsa.
OrlyTM ::
ce ne bo Sumi kej ornk ukenjal, jutr Alonso ne more na prvo mesto ... bomo vidl
Forza Ferrari!
OrlyTM
Forza Ferrari!
OrlyTM
Good Guy ::
itak šumi jutr raztura alonsotu bo pa prekurl tista renoja in to bo to
http://goo.gl/7ItKpU
Naj računalnik dela za vas^^
klemen22 ::
Zgleda da imajo potem pri Ferrariju zmagovalno kombinacijo za drugo polovico sezone.
Moje napovedi za prvaka: eno tekmo pred koncem Schumacher z manevrom v zadnjem ovinku prehiti Alonsa ter ga prehiti v skupni razpredelnici za 3 pike.
Motiti se je človeško, odpuščati pa božje. Torej ti odpuščam ;)
CHAOS ::
Žal ne popolna.
DonPierre ::
Hja se strinjam, kaj so vsi slo-techovci na zasluženem dopustu al kaj... Pa se ne, da vam ne bi privošču, samo...a je razplet problem?
BigWhale ::
Med postanki v boksih je Alonso pridobil eno celo mesto! Ja. Ne vem no, toliko o zanimivih dirkah....
mavec ::
Do konca prvenstva bo tako, da bo Schumi zdaj vse zmagal, Alonso bo pa vedno 2. Še hujša monotonija...
BTW: Včeraj je Ališič nekaj rekel, da naj bi bilo iz določenih krogov v F1 slišati, da naj bi si Alonso premislil oz. premišljuje o tem, da bi odkupil svojo pogodbo pri McLaren Mercedesu in ostal pri Renaultu.
- spremenil: mavec ()
njok ::
Se strinjam, gotovo ena najboljših dirk (po intervjujih sodeč tudi za dirkače). Ampak te moram popravit, da je bil tisto MotoGP (1000ccm, naslednje leto pa 800).
zile ::
Uff pa res nism vedu
Se vidi, da unadva na EUsportu samo nakladata kolk je 148kg težek pa da ma okoli 250konjev.
Hehe pa glih spraševal sem se, kako hudiča spravjo v pol litra 250 konjev.
No anyway, pol so razredi 125ccm, 250ccm, pa 1000ccm ?
Superbike je še 750ccm ? Učas smo prov na Grobnik hodil gledat te dirke.
- spremenil: zile ()
njok ::
Hmm... res si ne bi upal trditi, ker superbike bolj poredko spremljam, ampak mislim, da so motorji ravno tako literski (Yamaha R1, Suzuki GSX 1000-R,...) supermoto (ce se sploh tako klice) pa 600ccm.
ripmork ::
ne vem ali se sam meni zdi ali je vsaka dirka f1 večji dolgčas...
ker jest enostavno ne morem gledat dosti več kot prvih nekaj krogov.
Tisto da si Alonso želi ostati pri Renault-u pa kar verjamem ja, bo pa kar jeba če se na to temo začne javno pranje perila, ker pomoje Alonso nima šanse da se izvleče iz te pogodbe brez finančne katastrofe in odškodnin, že tako slaba karma v Mclarnovi garaži pa bo še hujša če bodo imeli dirkača, ki v bistvu niti noče za njih vozit.
matjazx ::
Ni šans da se bo Mclarn odpovedu tko Alonsu kt Kimiju
Enga bojo mogl zadržat in glede na to da jih Kimi 90% zapušča bo Alonso težko kj dosegu.
CHAOS ::
Da vas malo prebudim.
Vikend je naokoli, na Montoyo so že vsi pozabili. Današnji trening je bil kar obetaven za Ferrari (zgleda, da bo vseeno nekaj iz Bridgestona). In na vidiku je nova afera v katero je tokrat vpleten Renault. Lahko se zgodi, da v primeru, če ne spremenijo avtomobila in dirkajo s takšnim kot je, da se ostala moštva pritožijo in posledično ob morebitnem spoznanju, da bolid ni bil regularen, izubijo točke. Izgleda, da bo še zanimiv vikend.
Tilen ::
Kaj pa ni regularno? Poleg sistema tockovanja seveda :)
Daedalus ::
Sej ni Renault edini s tem. Ferrari je podoben sistem uporablal na nekaj dirkah. Drugače je pa bojda legalen.
[J.P.Sartre]
[J.P.Sartre]
CHAOS ::
Ranult se jim bo opovedal - mass-dampers.
LapD ::
Zanimivo Kimi kr prvi, čeprav bo pomojem jutri enkrat več stal v boksih. Upal bi si stavt na dvojno Ferrarijevo zmago, Renault je pa nerazumljivo padel. Da tistih deset kil nardi tako razliko? Verjetno tud Michelinke spijo zadnje čase. Upam da se jutr razlika čim bolj zmanjša da bo bol zanimivo :)
overlord_tm ::
Mi kdo razloži kaj se dogaja z Renaultom? Pridem z morja pa tkole lepo pade tja kamor spada
To že vem da so se losal teh kvihtov, samo zarad tega verjetno niso izgubil toliko napram Ferrariju in Mclarnu
Daedalus ::
Zdaj pa k temu prištej pospeške na zaviranjih/pospeševanjih in bočne pospeške pri vožnji skoz ovinke, ki so vsi ranga tam do 4G...pa ugotoviš, da je takle premičen balast kr konkretna pomoč. Sploh če je bil avto narejen s tem v mislih, ker Ferrari in Red Bull nista teh dodatkov uporabljala vedno, Renault pa jih je.
Sicer pa McLaren je dobil kr konkretn pospešek...sicer z IMO lahkim avtom, sam rezultat pa je
Upam samo, da pri onem košenju trave ni Kimi dirkalnika poškodoval, ker tole zna biti zanimivo.
[J.P.Sartre]
[J.P.Sartre]
Good Guy ::
kimi če je biu dons prvi al ne jutr bo odstopu(zaletu se bo v ograjo..tko k zmer)
upam na dvojno zmago ferarija tko k zmer :D
Go šumi!!
Go šumi!!
Tilen ::
Jaz bi bil z istim vrstnim redom na dirki prav zadovoljen :)
ripmork ::
misliš, obeso mu bo strgalo/guma pokla kot se mu je ponavadi v Hockenheimu zgodilo?
Res upam da ne.
Avto ima res lahek, a z dobro taktiko in dobro vožnjo so stopničke definitivno realno dosegljive ...
Poleg tega ima sedaj Mclaren tudi prednost napram Renaultu, pa še Montoye ni več in ima Kimi res dosti več šans za konkreten rezultat
Res upam da ne.
- spremenil: ripmork ()
WarpedGone ::
Pedro de la Rosa je bil le deveti. Tam nekje kot ponavad. Kar pomeni da McLaren ni nic kej posebno hiter na tej progi. Tut v prvem delu je bil precej pocasn. Ni nujno da je na postanku vec, je pa zelo lahek in bo mel zelo hiter prvi postanek in padel nekje za oba ferrarija, mrbit tut za buttona. Njegov realn doseg je 3. mesto.
Kaj je spet z Alonsom? Fisichela spet pred njim. Drugic zapored.
Zbogom in hvala za vse ribe
Daedalus ::
Malo nihanja v formi? Nihče ni 100% skozi celo sezono in Alonso je bil do zdaj hudičevo konstanten. Možna tud drugačna taktika, zdaj ko vejo, da majo relativno počasen avto...
Kar se pa McLarna tiče, pa PDLR ne more biti merilo hitrosti. Sploh ne po tem, ko mu je Rolphe IzdelovalecŠuhov Jr™ fino predelal zadnjo desno obeso. Tak da realen doseg McLarna je malo tak... bomo vidli. Taktiko glede kvalificiranja so (končno) spremenili, kak se bo pa to odrazilo na dirki, pa ne vem. Realno je verjetno res kako 3. mesto, menda so pa ja kaj hitrejši od Honde...no ja, če Fisichella doživi kako razodetje, bi znala biti bitka za 3. mesto.
[J.P.Sartre]
[J.P.Sartre]
- spremenilo: Daedalus ()
WarpedGone ::
Nihče ni 100% skozi celo sezono ...
Kolikokrat je MSa na kvalifikacijah prehitel Irvine, Barichello ali Massa? Govorim po spominu, ampak mislim da je to do sedaj enkrat uspelo Massi. Letos.
Sam kvalifikacij nism gledu tko da ne vem kaj točno se je dogajal. Vidm le razvrstitev. Kjer je KR doživel razsvetljenje v Q3. GF je bil dvakrat hitrejši od FA, le v Q1 ne, kar ne šteje velik. Psiha?
- spremenilo: WarpedGone ()
| ⊘ | Formula 1 2010 (strani: 1 2 3 4 … 21 22 23 24 )Oddelek: Na cesti | 215067 (178312) | WarpedGone |
| » | Formula 1 2009 (strani: 1 2 3 4 … 23 24 25 26 )Oddelek: Na cesti | 96422 (58801) | ABX |
| » | F1 2007 (strani: 1 2 3 4 … 21 22 23 24 )Oddelek: Loža | 86702 (59022) | 'FireSTORM' |
| » | F1 - sezona 2005 (strani: 1 2 3 4 … 49 50 51 52 )Oddelek: Loža | 92789 (51704) | Alexius Heristalski |
| » | F1 sezona 2003 (strani: 1 2 3 4 … 21 22 23 24 )Oddelek: Loža | 46107 (30768) | balocom |
