Izrael in palestina
Izrael in palestina
3 4
5
Thomas ::
Hurricanes occurred at far lower frequencies in the last half of the 20th century than they did in the preceding five 50-year periods at the three locations studied. From 1701 to 1850, for example, when the earth was locked in the grip of the Little Ice Age, major hurricane frequency was 2.77 times greater at Bermuda, Jamaica and Puerto Rico than it was from 1951 to 1998; and from 1851 to 1950, when the planet was in transition from Little Ice Age to current conditions, these three locations experienced a mean hurricane frequency that was 2.15 times greater than what was characteristic of 1951 to 1998.
Thomas ::
Podatki samo za USA.
quantiles
total of the mean
Years number mean variance max min 5% 95%
All U.S. hurricanes
1851-1900 88 1.76 2.349 7 0 1.42 2.14
1901-1950 92 1.84 1.770 6 0 1.54 2.16
1951-2000 72 1.44 1.558 6 0 1.16 1.72
Major U.S. hurricanes
1851-1900 26 0.52 0.500 3 0 0.36 0.68
1901-1950 36 0.72 0.696 3 0 0.54 0.92
1951-2000 27 0.54 0.458 3 0 0.38 0.70
perci ::
Nisem zadovoljen. Prvi copy paste sploh ni edu link ampak si ga dobil tule. Poleg tega je notri en velik If: If the frequency of occurrence of major hurricanes along the eastern seaboard of the U.S. and the Gulf coast states is related to global warming...
Za drugi link nisem nikjer našel jasno zapisanega stavka, ki bi hotel povedati, da obstaja precej visok korelacijski količnik med temperaturo ozračja in hurricani.
Poleg tega hurricani niso edini viharji.
Kaksni so npr. ugodnejsi pogoji za tvorbo tornadov? Vročina ali hlad?
Thomas ::
As noted, not all regions or all peoples benefit from a shift to a warmer climate. Some locales may become too dry or too wet; others may become too warm. Certain areas may be subject to high pressure systems which block storms and rains. Other parts may experience the reverse. On the whole, though, mankind should benefit from an upward tick in the thermometer. Warmer weather means longer growing seasons, more rainfall overall, and fewer and less violent storms. The optimal way to deal with potential climate change is not to strive to prevent it, a useless activity in any case, but to promote growth and prosperity so that people will have the resources to deal with any shift.
perci ::
Stanford praviš - Že OK, samo jst se nisem obesil na to kakšen bo celoten vpliv segrevanja ozračja, ampak so me zanimali striktno viharji. O teh pa nic kaj dosti ne pise na tej strani.
Sem tečen, kaj? Vem, samo se vedno me nisi preprical.:)
Je pa drugače zanimivo branje tole.
Do polnoči imaš čas, da navališ z linki, potem grem spat, jutri me pa zal ne bo ;(( .
  • spremenil: perci ()
Zanimivo bo, ko bomo imeli tu tolk toplo, da bodo lepo uspevali komarji, ki prenašajo kako malarijo...
Thomas ::
Se bomo pač cepili. Kot vsi, ki gredo v trope.
Če smo že res nesposobni iztrebit komarjo zalego.
To da letno umre 2 milijona ljudi zaradi malarije, je vprašanje revščine - in ne medicine.
Bo pa smrtnost zaradi "zimskih" bolezni bistveno manjša.
Sid Izprijeni ::
Hehe, Thomas. :D
Kako je po tvojem vse enostavno.
Če te boli glava, ko se zaletavaš z glavo v zid -
- se pač ne prenehaš zaletavati ampak si kupiš boljšo čelado!
>:D
The true challenge of Creation lies not in the engineering...
...but rather in the ability to control one's project.
l_jst ::
Jp smo jih res nesposobni. Če pa ti mislš drugač mi pa sam povej način pa ti pr njemu pomagam, ker jih ful sovražm. Sam res nevem kako boš uniču use komarje in jim zatru vse možnosti razmnoževanja, ker nevem, če se zavedaš kolk jih je.
Bi blo dobr ce bi kej pocel. (http://www.slo-p2p.tk)
Vice ::
Malo out samo ker je debata ravno o tem: verjetnost da so pri nas anofelesi ali komarji, ki prinašajo malarijo, je 90%, glede na to da so se začeli na veliko pojavljati tudi pri sosedih v Istri, vendar dokler ni povzročitelja malarijske mrzlice so nenavarni, probleme bolj predstavljajo TE druge vrste komarjev, da lahko povzročajo določene alergijske reakcije za katere ni cepiva, razlog je zato ker se s "faktorjem komar", določene bakterije razvijajo samo v določenih okoljih in vremeskimi vplivi, ki so spacifična za neko območje in s pomočjo tuje vrste lahko pride do problemov, dokler obstaja Pipss se mi zdi da se ni ravno za bati.
Koliko ima to veze z Izraelom in Palestino ne vem, mogoče le to da je kakšen komar imigriral k nam ali kontra :D
Thomas ::
Palestinski policisti, ki so ravno v nekem puntu, so naterali EU opazovalce na menjem prehodu Gaza - Egipt v mišjo luknjo.
Zato je prehod zaprt.
Link.
Thomas ::
Če je pa treba obračunati s črnci (begunci) iz Sudana, od koder jih preganjajo Arabci, pa Arabska policija tudi ne zamudi rada priložnosti.
Link.
UN se pa zgraža. Mah, komej kej, da se zgraža. Ne bi reku, če bi šlo za Arabce Hamasovce, ubite od Izraelcev. Potem bi še v naših cajtngah in TV/radiih, bile vse novinarke objokane.
Pa se je zgodilo kaj so nakateri napovedovali. Ko se Izrael umakne da se bojo začeli palestinci med samo tepst. Nisem to pričekoval rabim rečt. Sem mislo da so bolj "normalni". Očitno sem se zmoto.
  • spremenil: mtosev ()
TineTone ::
Izrael izkorišča Covid19 krizo da nabavlja orožja in krade Palestino medtem ko je svetovna pozornost usmerjena drugam.
stratosD ::
Vedno objektivni Russia Today z pregovorno naklonjenostjo do Izraelcev - 101% verodostojen vir:)...
TineTone ::
stratosD je izjavil:
Jop, karkoli drugega kot hvala Izraela je fejk news in antisemitizem.
Št. Palestinskih otrok v Izraelskih zaporih narašča, če dvomiš da si otroci zaslužijo biti za zapahi si naci ;)
RT je navadno bolj točen od MSM. Kdo je pa naci tam doli, ki krade zemljo, je pa tudi jasno vsakemu racionalnemu bitju.
RT je bil v uk kaznovan 200.000 funtov od britanskega regulatorja ofcom. Zelo dobra televizija ja.
TineTone ::
mtosev je izjavil:
Ja, UK je znana po svoji demokraciji in sposobnosti policije. Vsaj glede talanja kazni če gledaš TV brez licence ali če imaš v predalu preoster nož, malo manj pa pri iskanju pedofilov in napadalcev s kislino :))
No ja, saj o pedofilih v UK je tudi malo kdo kot RT poročal :D
stratosD ::
kaj je antipod naciju? včasih je bil to naci-žid dvojec :)
O neznosni lahkosti etiketiranja pa tudi kdaj drugič.
Vsekakor se zavedam da je palestinsko-izraelsko vprašanje težka zadeva ki je ne moreš rešiti z poenostavljanjem stvari.
A ni že nekdo pred skoraj 100 leti govoril o židih ki jedo majhne otroke?
RT z Wiki-ja
RT (TV network) @ Wikipedia
Political involvement
In April 2017, during his successful run for President of France, Emmanuel Macron's campaign team banned both RT and the Sputnik news agency from campaign events. A Macron spokesperson said the two outlets showed a "systematic desire to issue fake news and false information".[239] Macron later said during a press conference that RT and Sputnik were "agencies of influence and propaganda, lying propaganda--no more, no less".[240] RT editor-in-chief Margarita Simonyan characterized Macron's remarks on RT as an attack on freedom of speech.[241]
In October 2017, Twitter banned both RT and Sputnik from advertising on their social networking service amid accusations of Russian interference in the 2016 United States elections, sparking an angry response from the Russian foreign ministry.[242]
In November 2017, Alphabet chairman Eric Schmidt announced that Google will be "deranking" stories from RT and Sputnik in response to allegations about election meddling by President Putin's government, provoking an accusation of censorship from both outlets.[243]
In March 2018, John McDonnell, the Shadow Chancellor of the British Labour Party, advised fellow Labour MPs to boycott RT and said he would no longer appear on the channel. He said: "We tried to be fair with them and as long as they abide by journalistic standards that are objective that's fine but it looks as if they have gone beyond that line". However, a party representative said: "We are keeping the issue under review".[244]
In July 2019, the UK Foreign Office banned both RT and Sputnik from attending the Global Conference for Media Freedom in London for "their active role in spreading disinformation". The Russian Embassy called the decision "direct politically motivated discrimination", while RT responded in a statement: "It takes a particular brand of hypocrisy to advocate for freedom of press while banning inconvenient voices and slandering alternative media."[245]
TineTone ::
RT z Wiki-ja
To da RT poroča o početju Izraela, kljub temu da je Putin rekel da niso antisemiti nič drugega kot ljudje nevoščljivi uspehu židov res nakazuje da so politično pristranski :))
Vas popolnoma razumem, kritizirati Izrael za svoje početje je danes smrtni greh. Kot je bilo priznati v USSR da si lačen :D
stratosD ::
Nasprotno - kritizirati Izrael je dobra stvar :)...tako kot je opazovati kako že 50+ let Palestince vrtijo in prenašajo okoli praktično vsi na tem svetu - seveda so kot evidentna žrtev v tem sporu deležni simpatij precejšnjega dela svetovne javnosti - ampak žal ne dosti več kot simpatij...
Po tej raziskavi BBC-ja je Izrael 4-ta najbolj osovražena država po Iranu, Pakistanu in S.Koreji
https://www.vox.com/2018/11/20/18080086...
Po Gallupovi raziskavi iz 2020 več Američanov podpira Palestinsko državo kot je proti njej
https://news.gallup.com/poll/293114/maj...
tako da pro-Izrael ni ravno nek trend...
el_bahattee ::
Nihče pač ne mara, da se krši mednarodno pravo, kot to Izrael počne na mnogih frontah, ker si trenutno to pač lahko privošči. Bi bilo pa zanimivo videti, kaj se bi/bo zgodilo, če se nekoč pojavi nek Ameriški predsednik, ki se bo dejansko zavzel tudi za Palestince in nehal slepo podpirati Izrael.
Se pa strinjam, glede izkoriščanja Palestincev za svoje politične agende - tu bi Arabske države lahko storile precej več, kot so storile v zadnjih par desetletij. Tudi Erdogan se je vmes za kratko obdobje kazal kot njihov zaščitnik, na koncu pa se je izkazalo, da je tudi tisto bil bolj nastop za medije.
Come to my center, you enter the winter.
3 4
5
Izrael vs. Palestina (strani: 1 2 3 4 … 15 16 17 18 )
Oddelek: Problemi človeštva
85251917 (35486) Stepni Volk
Iran bi izbrisal Izrael (strani: 1 2 )
688316 (6953) Phil
Arabci (strani: 1 2 3 4 )
15111937 (9860) Barakuda1
Palestisnko-Izraelska kriza (strani: 1 2 3 4 )
18416376 (13829) jype
Bali (strani: 1 2 3 )
1309751 (8256) undefined
