Forum » Znanost in tehnologija » 50-letnica pristanka na luni
Slo0 ::
Pojutrišnjem se praznuje 50-letnica pristanka na luni.
Nekateri še vedno kritizirajo vesoljski program (ker se v ta program vlaga miljarde).
Dejstvo pa je, da prinaša nove rešitve, tudi na zemlji.
1. Memory Foam Was Originally Used To Protect Astronauts (ne bi blo dormea)
2. Baby Formula Was Devised by a Couple of NASA Dropouts (Today, it is found in most U.S. enriched baby foods and as an additive to infant formulas in over 65 countries around the world)
3. The Dustbuster Started Out as Lunar Rock Drill for NASA
ročni sesalec
4. Space Blankets Were the Result of Research by NASA (kjer se podobne snovi uporablja pri podhlajenih osebah in tut pri opeklinah)
5. Food Safety (HACCP) Helps Keep Food Safe for You and Astronauts
6. Nestle's Freeze Drying Process Was Widely Used by NASA (najbrž vse juhe v paketih)
7. Cochlear Implants Have Improved the Lives of Many People (slušni aparati)
8. Infrared Ear Thermometers Let You Check Someone's Temperature from a Distance
9. Invisible Braces Have Saved A lot of Embarrassment
10. The Super Soaker Was Invented by a Former NASA Engineer (najbrž tiste krpe k velik vode vsrkajo)
11. Speedo LZR Racer Swimsuits Were Developed with the Help of NASA
12. NASA Developed CMOS Active Pixel Sensors Are Behind Your Selfies
13. Scratch Resistant Lenses
14. Artificial Limbs Have Become Space Age Thanks to NASA
15. Embedded Web Technology Paved the Way for IoT
https://interestingengineering.com/15-s...
Če bi vsa mesta bila tako učinkovita, pri vodi (in njeni reciklaži), kot je na ISS.
Mesta sploh ne bi potrebovala vodnih virov.
(neki sm hotu povedat, samo ne vem kaj)
Kar je v oklepajih je moje mnenje in ne vem če je to res, dejstva so le za točkami 1-15.
ročni sesalec
Vsi še živeči Apollo astronavti
https://twitter.com/BobbyRayIN63/status...
Fejk njuz, menda niso vsi.
https://twitter.com/marcmcardle1/status...
This isn’t actually all of the surviving Apollo astronauts (8 of 17 in the pic). Left to right, that’s Charlie Duke, Buzz Aldrin, Walter Cunningham, Al Worden, Rusty Schweickart, Harrison Schmitt, Michael Collins, and Fred Haise.
- spremenilo: Pac-Man ()
janezvalva ::
na mesec se ne hodi več, ker je mesec en velik kos mrtvega kamna pa nič od tega. pa še daleč pa nevarno pa drago je.
edina šansa, če slučajno v prihodnosti odkrijejo, da so kakšne rudnine na mesecu, katere jih tu ni pa da se jih nujno rabi, potem se bo spet hodilo gor.
drugače pa, čestitke za obletnico.
- spremenilo: janezvalva ()
Ali se da z močnim teleskopom opaziti zastavo, ki so jo pustili gor?
S tistim v lunini orbiti se da. Ampak je nasin ;)
https://sservi.nasa.gov/articles/apollo...
| ⊘ | Ali je pristanek človeške posadke na luni prevara? (strani: 1 2 3 4 5 )Oddelek: Problemi človeštva | 34011 (23564) | bluefish |
| » | Pristanek na luni s 40 letno zamudo (strani: 1 2 3 4 … 12 13 14 15 )Oddelek: Novice / Znanost in tehnologija | 56466 (6758) | poweroff |
| ⊘ | lažni posnetki pristanka na luni (strani: 1 2 3 4 )Oddelek: Problemi človeštva | 21583 (17303) | Barakuda1 |
| » | Slike Apolla 11 odmrznjene (strani: 1 2 3 )Oddelek: Novice / Znanost in tehnologija | 13469 (13469) | Metabond |
