Forum » Strojna oprema » intel penryn quad release date preložen
phenom ::
Intel has recently adjusted its product strategy and will postpone three 45nm quad-core CPUs that were originally scheduled to launch in January next year, according to sources at motherboard makers.
Intel has already notified its partners that it will push back the launch of the three CPUs to February or March next year, depending on AMD's schedule for triple-core and the upcoming Phenom CPUs.
Launching the CPUs now will not benefit Intel much in its battle with AMD, while they could cause damage to Intel's 65nm quad-core CPUs, therefore the company has decided it is in no rush to release new products until AMD is able to present more of a threat.
The three CPUs that Intel plans to delay are the Core 2 Quad Q9300, Q9450 and Q9550, added the sources.
Intel commented that its launch of 45nm quad-core CPUs for desktops is on track for first quarter 2008, but declined to disclose a specific time-frame.
Globoko razočaranje!
Calligulla ::
Ampak dober indikator kaj se zgodi, ce nekdo nima konkurence v nekem trenutku. Razvoj se upocasni, price/performance pade.....
Horsechoker ::
NE :D
x45: v resnic ma intel probleme in so tole lažne informacije za javnost
But I don't want to be dead. I want to be alive. Or a cowboy.
OChack ::
jap, buggiji ih matrajo, sploh mraz :D
in morjo do spomladi počakat
Int€l inside, IDIOT Outside
jimyboy ::
Darkolord narobe razmišlaš. Če je price/performance visok to pomeni da za manj denarja dobiš več. Če pa je prace/performance majhen pomeni da za določen denar dobiš manj.
- spremenil: jimyboy ()
borchi ::
a si šprical ulomke, al kaj?!
sicer bo pa jobs lastnoročno zadavil otellinija... kaj bo apple dal v nove mac pro-je? modre ledice
l'jga
phenom ::
ja penryn ma baje neke težave trunutno in ni zgovor da čakajo na amd ampak neki druzga. Pa neki je tud res da ma stvar v seb implementirane sse4 instrukcije kar večina današnjih programov sploh ne uporablja. Rvno te instrukcije so čar penryn poleg izdelave in ravno te naj bi dale 40 % pohitritev od ostalih procov.
destroyer2k ::
phenom
In kake taževa? Ker penryn high-end je zunaj sedaj če ta dela normalno ne vem zakaj nebi drugi. Tudi notranji viri so govorili da je to apsurdno da so prestavli, ampak pomojem so tudi res za amd samo zaradi anti-monopola zakona naredili da se amd malo opomoga.
phenom ::
ja sam kokr jz vem je samo serverska verzija uzuni. Na yorkfielda še čakamo. Sam bi blo pa res lepo če bi se amd postavil spet na noge.
mogoce je to krivo?
phenom ::
ja možno da je, sam je pa kle spet vprašanje a si bo amd opomogel. Ker ne mormo lih pričakovat da bo amd lahko kar naenkrat z 3 jedrniki konkuriral intelu, lahko pa upamo da bodo začel ljudje kupovat amd ker bi se jim bolj splačalo, finančno vsaj mislim. Rešitev amd jeve težave bi bil, dvignit frekvence phenomu. V takem primeru bi ga šel takoj kupit. Ker ni vprašanje ker proc je boljši, ampak za kaj ga boš rabu. Če je za igre si lohk srečen že z dvojedrnikom, če pa rabš za procesiranje nekih računskih aplikacij k ti zabijejo proc v nulo pol rabš res močn proc. Sam pač človeški ego je pač tak.
destroyer2k ::
phenom
In kaj je pa tale procesor potem intel QX9650. Drugače Dr_M ne vem kaj tem ni jasn a so za časom ali kaj intel QX9650 je zelo zbirčen glede plat če ni na pravi plati je katastrofa 2 stvari se zgodijo ali ne zazna ali pa kaj takega kot si ti podal link. Drugače pa ni res to imam kolega ko ima navitega na 4gHz in dela zelo dobro. In tudi na youtube je dosti o tem procesorju navitemu ki dela brez problema.
phenom ::
ja pardon, tega sem pozabil, sam je pa zanimiva zadeva zakaj ga ni moč zasledit v velikem številu trgovin. Sam si reku da če ni na pravi matični. Kakšna je po tvojem mnenju prava matična.
- spremenilo: phenom ()
tocno to morajo popravit, da bo na vsaki maticni delu procesor, ne pa na dveh. treh....
| » | AMD Phenom- uporabne informacije: CPUji, plošče, BIOSi, izkušnje- držite se teme, pro (strani: 1 2 3 4 … 19 20 21 22 )Oddelek: Strojna oprema | 67402 (30912) | Meizu |
| » | AMD Phenom (strani: 1 2 3 4 … 24 25 26 27 )Oddelek: Strojna oprema | 63691 (39149) | Brane2 |
| » | Kdaj pridejo phenomi X4 9x50? (strani: 1 2 3 4 5 6 )Oddelek: Strojna oprema | 16672 (12889) | gruntfürmich |
| » | AMD predstavil nove procesorje (strani: 1 2 )Oddelek: Novice / Procesorji | 11959 (9318) | Azrael |
| » | Kakšne komponente se splača zdaj kupit? AM2, 2gb rama DDR2, 3870/8800gtOddelek: Kaj kupiti | 2415 (1934) | tilinho20 |
