Forum » Loža » IQ
IQ
Quantum ::
Kaj pravite o William James Sidisu? On naj bi imel IQ nekje med 250 in 300. Pravijo, da je bil najbolj inteligenten človek vseh časov.
AndrejO ::
Pove vse o IQ kar moraš vedeti.
Če imenuješ to za univerzo, potem je tudi vsak samostan univerza.
It's not me, it's UNESCO. Ko boš pa ti svetovno priznana referenca za poimenovanja, pa se oglasi in priloži kopijo certifikata.
Jebiga. Če bi bili pametni, potem bi pač izumili bron. Tako, kot so ga v istem času izumljali po celotnem sredozemlju, bližnjem vzhodu in še kje.
Kako so pa takratni prebivalci britanije "pod ledom" postavljali Stonehenge, boš pa seveda tudi lahko ti povedal.
The Chalcolithic (English /?kaelk?l'l???k/;[1] Greek: ?????? khalkós, "copper" and ????? líthos, "stone")[1] period or Copper Age,[1] also known as the Eneolithic[1] or AEneolithic (from Latin aeneus "of bronze"), is a phase of the Bronze Age[citation needed] before it was discovered that adding tin to copper formed the harder bronze. The Copper Age was originally defined as a transition between the Neolithic and the Bronze Age. However, because it is characterized by the use of metals, the Copper Age is considered a part of the Bronze Age[citation needed] rather than the Stone Age.
The archaeological site of Belovode on the Rudnik mountain in Serbia contains the world's oldest securely dated evidence of copper smelting at high temperature, from 5,000 BCE.
An archaeological site in Serbia contains the oldest securely dated evidence of copper making at high temperature, from 7,500 years ago. The find in June 2010 extends the known record of copper smelting by about 800 years, and suggests that copper smelting may have been invented in separate parts of Asia and Europe at that time rather than spreading from a single source.[3] In Serbia, a copper axe was found at Prokuplje, which indicates that humans were using metals in Europe by 7,500 years ago (~5,500 BCE), many years earlier than previously believed.[6] Knowledge of the use of copper was far more widespread than the metal itself. The European Battle Axe culture used stone axes modeled on copper axes, even with imitation "mold marks" carved in the stone.[7] Ötzi the Iceman, who was found in the Ötztal Alps in 1991 and whose remains were dated to about 3300 BCE, was found with a Mondsee copper axe.
Jeba slabih dokazov je, da moram potem stopiti nazaj in te vprašati, čemu si potem izjavil, da je bilo težko s kamenim orodjem podirati drevesa in obdelovati njive? Očitno so imeli pri roki bron in dovolj znanja za izdelavo sekir. Ampak v civilizacijo se pa niso bili sposobni organizirati. Matero so bili neumni, mar ne?
Sicer je pa tako: če pristaneš na razlago, da je "razvoj" bistveno odvisen od okolja, potem si sprejel razlago, da IQ ne moreš meriti z "razvojem".
Če pa misliš, da "razvoj" ni odvisn od okolja, potem pa sam svoje argumente o težkem življenju pod ledom in neuporabnostjo kamnitega orodja razglašaš za nične in potem pristajaš na razlago, da si bili takratni "evropejci" glupi ko točak.
- spremenil: AndrejO ()
Fojbiran ::
Jaz sem UNEFOJBO
Samocertificiran in potrjen
Samo zate, model ki je v času egipta poznal motorne žage.
V egiptu pa je še danes največji pragozd.
V obeh primerih imaš seveda narobe.
- predlagalo izbris: sandmodnigga ()
Matej22 ::
Prva prava univerza je University of Bologna, ostalo so bile bolj verske šole, kjer si lahko študiral koran. V tisti zgoraj navedeni so matematiko, fiziko kemijo,... uvedli šele leta 1957.
AndrejO ::
Najprej vzpostavi korektno in konkretno primerjavo v istem obdobju. Verjetno nima smisla primerjati "programa" unverze iz 10. st. s programom univerze v 21. st. Mimogrede, tudi Bolonjska uni. je začela kar lepo s poučevanjem kanonskega prava.
Glede širšega vprašanja kaj je in kaj ni "univerza", pa ponavljaš enega izmed argumentov, s katerimi so razčistili že drugi in to mnogo bolj izobraženi, da podajo takšne sodbe, kot bova midva kadarkoli. Kdor si bo vzel nekaj časa, da si prebere komentarje k geslu na Wikipediji si lahko prebere kako je to bilo že do onemoglosti predebatirano.
Sploh pa mi je v kontekstu tvojega komentarja najbolj všeč tole:
There are a number of sources that say that the University of al-Karaouine was founded in 859, and call it a university. Also noted above is the fact that the European universities such as Oxford were little more than a few clerics who took students, generally for quite a bit of money. This effort to claim any Muslim university as being something other than that is very tiresome.
Fojbiran ::
The university is historically notable for its teaching of canon and civil law; indeed, it was set up in large part with the aim of studying the Digest,[9] a central text in Roman law, which had been rediscovered in Italy in 1070, and the university was central in the development of medieval Roman law.[10] Until modern times, the only degree granted at that university was the doctorate.
Današnja, pravna univerza.
Seveda da ti bo všeč. Tebi je všeč vse kar je neevropejskega, živiš pa v evropi.
garamond ::
danielkreg je izjavil:
Hja, saj sem napisal da ne vem -- lahko pa citiraš kakšno raziskavo. Sicer bo težko, ker če so genetske razlike, so po mojem mnenju majhne, ter jih je zelo težko ločiti od vpliva okolja.Genetski vpliv na IQ posameznika izključno zaradi rase je verjetno tako majhnen oziroma ničen (ne vem), da je že zanemarljiv.
Genetski vpliv na barvo kože je tudi ničen a ne? Pa na obliiko las. Pa na strukturo kosti. Pa na obćutljivost na razne bolezni... Na vse vpliva, razen na IQ. Zato pa sta bila 500 let nazaj afrika in evropa isto razvita a ne?
A parody of extremism is impossible to differentiate from sincere extremism.
Fojbiran ::
Tvoje mnenje utemelji s kakšno raziskavo
Matej22 ::
Ta šola je bila ustanovljena kot madrasa ali verska šola, kjer so se poučevale islamske vede, šele kasneje je postala univerza. Če boš dokonca prebral vsebino na povezavi, ki si jo prilepil, ti bo tudi jasno, o čem je tekla debata, zgornji navedek pa je samo majhen del debate, ki je vzet iz konteksta.
The University of al-Qarawiyyin or Al Quaraouiyine (Arabic: جامعة القرويين) is a university located in Fes, Morocco. It is the oldest existing, continually operating and the first degree awarding educational institution in the world according to UNESCO and Guinness World Records[5] and is sometimes referred to as the oldest university.
Če si še vedno mnenja, da se motim, te lepo prosim, da popraviš vsebino na List of oldest universities in continuous operation
In če se že pogovarjamo o šolanju, je smiselno omeniti še osnovno šolstvo List of the oldest schools in the world
garamond ::
Zakaj bi utemeljil, da so verjetno genetske razlike v IQ-ju med rasami majhne, če me to ne zanima dovolj? Popolnoma mirno lahko gledam, kako bi lahko nekdo brez virov trdil nasprotno (kar v tej temi še ni bilo), in sploh ne bi poudaril da je to samo njegovo mnenje. Podtoni so preveč rasistični in zame premalo zanimivo, da bi šel brat o tem.Hja, saj sem napisal da ne vem -- lahko pa citiraš kakšno raziskavo. Sicer bo težko, ker če so genetske razlike, so po mojem mnenju majhne, ter jih je zelo težko ločiti od vpliva okolja.
S tem da nihče ni še navedel virov, ki so pred tem bolj pomembni, to je kakšne so sploh rasne genetske razlike.
Fojbiran ::
Preveč rasistični podtoni. Te je strah samega sebe ?
Poišči si sam kako so genetske razlike v IQ-ju majhne in nalimaj. To je tvoja utemeljitev.
Fojbiran> Poišči si sam kako so genetske razlike v IQ-ju majhne in nalimaj. To je tvoja utemeljitev.
Sem že: http://mitadmissions.org/blogs/entry/pi...
Razlike so statistično nepomembne, če pravilno testiraš. Če testiraš tako, da so beli moški najpametnejši, potem testiraš narobe.
sandmodnigga ::
To sem vam že jaz poiskal. Si pa pač polpismen osebek, ki ne zna iskati/brati informacij.
sandmodnigga ::
Notably, under this scenario, it is unreasonable to posit the direction of any IQ differential if environments were homogenized for all groups. That is to say, on level playing field and with the data at hand, we cannot predict whether African Americans or Caucasians would have higher average IQs.
Pa si trdil, da si prebral študijo. Očitno je nisi. In očitno imaš neke probleme sam s sabo, da tega ne razumeš.
- predlagalo izbris: Rias Gremory ()
danielkreg ::
Nihče ne trdi da so beli moški najpametnejši. To je samo taktika vas antirasistov, ki hočete utišati ljudi z zdravim razumum.
Umsko zdravi ljudje se ne bojimo dejstva, da ima kdo višji IQ od nas. To je problem izključno vas 'vsi smo enaki' kampa.
EDIT: na grafu manjkajo aškanazi židi, ki bi morali biti na vrhu.
- spremenilo: danielkreg ()
"Umsko zdravi" ljudje se bojite marsičesa - beguncev, muslimanov, pametnih črncev, še pametnejših Kitajcev ... Počnete sicer marsikaj, da bi ta strah prikrili, ampak vam slabo uspeva.
_dice7 ::
innerspace ::
Kaj pravite o...?
Tezko je karkoli praviti. Tip je ocitno imel zelo sposobne mozgane za dolocen tip taskov, kar lahko nakazuje, da je slo za neko genetsko specifiko, ki se je pokazala v zelo zgodnjem razvoju.
Umrl pa je zaradi mozganske krvavitve, relativno mlad.
Mozno je, da je imel kako mutacijo mozganske skorje ali cesa drugega...
Mene recimo bolj zanimajo raziskave umetnih nevronov in njihov design za optimizacijo resevanja specificnih nalog, iz katerih bi se morda lahko ugotavljalo kako se cloveski mozgani spreminjajo z ucenjem.
Ali pa povezovanje vezij z mozganskim tkivom, to bo se zelo zabavna rec.
Sam IQ debatiranje o cloveskih sposobnostih glede na raso zajema skrajno omejeno obmocje inteligence in je pretty boring and fundamentally flawed.
Donate BTC here: 35KR84u3rXN3in1kCw9YHRz4WF3r5kfFF4
- spremenil: innerspace ()
dailystormer> Pokaži mi že enkrat to tvojo uspešno multikulturno družbo...
Demographics of Ottawa @ Wikipedia
Oslo @ Wikipedia
Z%C3%BCrich @ Wikipedia
Ljubljana @ Wikipedia
Oslo @ Wikipedia
_dice7 ::
Indian 20,525 2.6%
Lebanese 17,500 2.1%
Black 16,000 2.0%
Ja bravo, dejansko isto multikulturna kot Ljubljana rolleyes.dxf
Torej je očitno Otava uspešna ker ni raznolika.
Se vidi pomanjkanje inteligence ko uporabljate take primere. Daj raje za primerjavo tvoj socialistični raj: Brazilija.
Fojbiran ::
Ne. Levičarji lahko trolajo in vse ostale zmerjajo z nacisti. Ko to reče kdorkoli drug v druščini pa ste vsi proti.
Double standards
Double standards
| ⊘ | Mensa (strani: 1 2 3 4 5 6 )Oddelek: Loža | 82727 (74853) | zee |
| » | IQ in število otrok (strani: 1 2 3 )Oddelek: Problemi človeštva | 26972 (23692) | Matako |
| » | IQ in dedovanje?Oddelek: Loža | 14908 (13742) | garamond |
| » | So konservativci s predsodki res manj inteligentni? (strani: 1 2 3 )Oddelek: Znanost in tehnologija | 18409 (15744) | T-h-o-r |
| » | IQ se z odraščanjem v adolescenci precej spreminja (strani: 1 2 3 )Oddelek: Novice / Znanost in tehnologija | 29786 (26533) | jype |
