Forum » Operacijski sistemi » Ubuntu 12.04 Precise Pangolin
Zvezdica27 ::
ko ne dela:
xrandr
Screen 0: minimum 320 x 200, current 2966 x 1200, maximum 8192 x 8192
LVDS1 connected 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 194mm
1366x768 60.0*+
1360x768 59.8 60.0
1024x768 60.0
800x600 60.3 56.2
640x480 59.9
VGA1 disconnected (normal left inverted right x axis y axis)
HDMI1 connected 1600x1200+1366+0 (normal left inverted right x axis y axis) 708mm x 398mm
1366x768 60.2 +
1600x1200 60.0*
1280x1024 75.0
1280x960 85.0
1360x765 85.0
1024x768 85.0 75.1 70.1 60.0
832x624 74.6
800x600 85.1 72.2 75.0 60.3 56.2
720x480 59.9
640x480 85.0 72.8 75.0 66.7 60.0
720x400 70.1
DP1 disconnected (normal left inverted right x axis y axis)
in še ko dela:
xrandr
1366x768 60.0*+
1360x768 59.8 60.0
1024x768 60.0
800x600 60.3 56.2
640x480 59.9
1366x768 60.2 +
1600x1200 60.0*
1280x1024 75.0
1280x960 85.0
1360x765 85.0
832x624 74.6
720x480 59.9
720x400 70.1
blaz@pango:~$ xrandr
1366x768 60.0*+
1360x768 59.8 60.0
1024x768 60.0
800x600 60.3 56.2
640x480 59.9
1366x768 60.2 +
1600x1200 60.0*
1280x1024 75.0
1280x960 85.0
1360x765 85.0
832x624 74.6
720x480 59.9
720x400 70.1
xrandr
1366x768 60.0*+
1360x768 59.8 60.0
1024x768 60.0
800x600 60.3 56.2
640x480 59.9
1366x768 60.2 +
1600x1200 60.0*
1280x1024 75.0
1280x960 85.0
1360x765 85.0
832x624 74.6
720x480 59.9
720x400 70.1
in še ko dela:
xrandr
1366x768 60.0*+
1360x768 59.8 60.0
1024x768 60.0
800x600 60.3 56.2
640x480 59.9
1366x768 60.2 +
1600x1200 60.0*
1280x1024 75.0
1280x960 85.0
1360x765 85.0
832x624 74.6
720x480 59.9
720x400 70.1
1366x768 60.0*+
1360x768 59.8 60.0
1024x768 60.0
800x600 60.3 56.2
640x480 59.9
1366x768 60.2 +
1600x1200 60.0*
1280x1024 75.0
1280x960 85.0
1360x765 85.0
832x624 74.6
720x480 59.9
720x400 70.1
- spremenil: Zvezdica27 ()
Zvezdica27 ::
no name china crap. HAAN LC-40IEA3 Je pa proizvajalec Viewpia, pač nalepka čez)
No System76 nasvet ne dela.
Prav tako ne pomagata kernel 3.3.5 ter 3.4 rc4 (je pa 3.3.5 hitrejši in ga bom obdržal).
Po parih drkanjih nastavitev levo desno resolucij, lokacij itd, včasih rata. 100% dela samo suspend.
jutri dalje. Če ne bomo pač shutdown skrili in bo samo suspend tam, haha.
zz
zz
Icematxyz ::
Poskusi še za test:
sudo apt-get install arandr
Alt + F2 in vpiši arandr.
Vključi/izključi HDMI zaslon, spremeni ločljivost...
Zvezdica27 ::
bom, sam ne vem če danes. otroci... banda. mi je pa smešno ker sem očitno edini v vesolju s tem problemom. Dobr, se bom vsaj kaj naučil glede linux.
OK. Kje točno bi jaz lahko preveril module (ali so samo packages?) za intel driver? Predvidevam, da kar je novega je v 3.3.5 ane? Ampak če bi dal kak dev notri... Ajde, gremo me učiti.
Torej za driver predvidevam da lshw -c video in potem modinfo za kar vrže ven in preko synaptica gledati kaj je novega.
Kateri X server (kateri del Xorg?) točno krmili grafiko oz. multi monitors (ali pač cel X nadgradim oz. drezam?)
zz
zz
Zvezdica27 ::
arandr na moč uporaben, žal magenta ne odpravi.
Vmes sem upgradal x in linux kernel in linux driver za x... nič. Sam še dev probam.
ni jasno.
zz
ni jasno.
zz
Icematxyz ::
V bistvu morava ugotoviti, kaj je drugače, ko preide prenosnik iz stanja pripravljenosti, tukaj se skriva odgovor. Prilepi še enkrat izpis ukaza za delujoče/nedelujoče stanje:
xrandr --verbose
xrandr --verbose
Zvezdica27 ::
mimogrede: tudi dev PPA (x-edgers) ne spremeni ničesar. Vse latest, X server je 1.12.1
nedelujoče:
xrandr --verbose
LVDS1 connected 1366x768+0+0 (0x45) normal (normal left inverted right x axis y axis) 344mm x 194mm
Identifier: 0x41
Timestamp: 22302
Subpixel: horizontal rgb
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 1
CRTCs: 1 0
Transform: 1.000000 0.000000 0.000000
0.000000 1.000000 0.000000
0.000000 0.000000 1.000000
filter:
EDID:
00ffffffffffff0030e4dc0200000000
00140103802213780a09159d5f599b27
19505400000001010101010101010101
010101010101581b567e50000e302430
350058c2100000190000000000000000
00000000000000000000000000fe004c
4720446973706c61790a2020000000fe
004c503135365748342d544c41310009
BACKLIGHT: 7 (0x00000007) range: (0,7)
Backlight: 7 (0x00000007) range: (0,7)
scaling mode: Full aspect
supported: None Full Center Full aspect
1366x768 (0x45) 70.0MHz -HSync -VSync *current +preferred
h: width 1366 start 1402 end 1450 total 1492 skew 0 clock 46.9KHz
v: height 768 start 771 end 776 total 782 clock 60.0Hz
1360x768 (0x46) 84.8MHz -HSync +VSync
h: width 1360 start 1432 end 1568 total 1776 skew 0 clock 47.7KHz
v: height 768 start 771 end 781 total 798 clock 59.8Hz
1360x768 (0x47) 72.0MHz +HSync -VSync
h: width 1360 start 1408 end 1440 total 1520 skew 0 clock 47.4KHz
v: height 768 start 771 end 781 total 790 clock 60.0Hz
1024x768 (0x48) 65.0MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1344 skew 0 clock 48.4KHz
v: height 768 start 771 end 777 total 806 clock 60.0Hz
800x600 (0x49) 40.0MHz +HSync +VSync
h: width 800 start 840 end 968 total 1056 skew 0 clock 37.9KHz
v: height 600 start 601 end 605 total 628 clock 60.3Hz
800x600 (0x4a) 36.0MHz +HSync +VSync
h: width 800 start 824 end 896 total 1024 skew 0 clock 35.2KHz
v: height 600 start 601 end 603 total 625 clock 56.2Hz
640x480 (0x4b) 25.2MHz -HSync -VSync
h: width 640 start 656 end 752 total 800 skew 0 clock 31.5KHz
v: height 480 start 490 end 492 total 525 clock 59.9Hz
Identifier: 0x42
Timestamp: 22302
Subpixel: unknown
Clones:
CRTCs: 1 0
filter:
HDMI1 connected 1600x1200+1366+0 (0x4d) normal (normal left inverted right x axis y axis) 708mm x 398mm
Identifier: 0x43
Timestamp: 22302
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 1 0
filter:
EDID:
00ffffffffffff0025c4303200000000
0a0f01038147288c0afd7ca554459b24
12484bbfef00a94081598bd961594559
315901010101982156b051001b304890
1300c48e2100001c8c0ad08a20e02d10
103e9600c48e21000018000000fc004c
434454560a20202020202020000000fd
0037551e5b10000a2020202020200191
02031cf2490102038405111293142309
07078301000065030c0010008c0ad08a
20e02d10103e9600138e21000018011d
8018711c1620582c2500c48e2100009e
011d00bc52d01e20b8285540c48e2100
001e0000000000000000000000000000
00000000000000000000000000000000
000000000000000000000000000000ab
Broadcast RGB: Full
supported: Full Limited 16:2
audio: auto
supported: off auto on
1366x768 (0x4c) 86.0MHz -HSync +VSync +preferred
h: width 1366 start 1438 end 1582 total 1798 skew 0 clock 47.8KHz
v: height 768 start 769 end 772 total 795 clock 60.2Hz
1600x1200 (0x4d) 162.0MHz +HSync +VSync *current
h: width 1600 start 1664 end 1856 total 2160 skew 0 clock 75.0KHz
v: height 1200 start 1201 end 1204 total 1250 clock 60.0Hz
1280x1024 (0x4e) 135.0MHz +HSync +VSync
h: width 1280 start 1296 end 1440 total 1688 skew 0 clock 80.0KHz
v: height 1024 start 1025 end 1028 total 1066 clock 75.0Hz
1280x960 (0x4f) 148.5MHz +HSync +VSync
h: width 1280 start 1344 end 1504 total 1728 skew 0 clock 85.9KHz
v: height 960 start 961 end 964 total 1011 clock 85.0Hz
1360x765 (0x50) 124.6MHz -HSync +VSync
h: width 1360 start 1448 end 1592 total 1824 skew 0 clock 68.3KHz
v: height 765 start 766 end 769 total 804 clock 85.0Hz
1280x720 (0x51) 74.2MHz +HSync +VSync
h: width 1280 start 1720 end 1760 total 1980 skew 0 clock 37.5KHz
v: height 720 start 725 end 730 total 750 clock 50.0Hz
1280x720 (0x52) 74.2MHz +HSync +VSync
h: width 1280 start 1390 end 1430 total 1650 skew 0 clock 45.0KHz
v: height 720 start 725 end 730 total 750 clock 60.0Hz
1024x768 (0x53) 94.5MHz +HSync +VSync
h: width 1024 start 1072 end 1168 total 1376 skew 0 clock 68.7KHz
v: height 768 start 769 end 772 total 808 clock 85.0Hz
1024x768 (0x54) 78.8MHz +HSync +VSync
h: width 1024 start 1040 end 1136 total 1312 skew 0 clock 60.1KHz
v: height 768 start 769 end 772 total 800 clock 75.1Hz
1024x768 (0x55) 75.0MHz -HSync -VSync
h: width 1024 start 1048 end 1184 total 1328 skew 0 clock 56.5KHz
v: height 768 start 771 end 777 total 806 clock 70.1Hz
832x624 (0x56) 57.3MHz -HSync -VSync
h: width 832 start 864 end 928 total 1152 skew 0 clock 49.7KHz
v: height 624 start 625 end 628 total 667 clock 74.6Hz
800x600 (0x57) 56.2MHz +HSync +VSync
h: width 800 start 832 end 896 total 1048 skew 0 clock 53.7KHz
v: height 600 start 601 end 604 total 631 clock 85.1Hz
800x600 (0x58) 50.0MHz +HSync +VSync
h: width 800 start 856 end 976 total 1040 skew 0 clock 48.1KHz
v: height 600 start 637 end 643 total 666 clock 72.2Hz
800x600 (0x59) 49.5MHz +HSync +VSync
h: width 800 start 816 end 896 total 1056 skew 0 clock 46.9KHz
v: height 600 start 601 end 604 total 625 clock 75.0Hz
720x576 (0x5a) 27.0MHz -HSync -VSync
h: width 720 start 732 end 796 total 864 skew 0 clock 31.2KHz
v: height 576 start 581 end 586 total 625 clock 50.0Hz
720x480 (0x5b) 27.0MHz -HSync -VSync
h: width 720 start 736 end 798 total 858 skew 0 clock 31.5KHz
v: height 480 start 489 end 495 total 525 clock 59.9Hz
640x480 (0x5c) 36.0MHz -HSync -VSync
h: width 640 start 696 end 752 total 832 skew 0 clock 43.3KHz
v: height 480 start 481 end 484 total 509 clock 85.0Hz
640x480 (0x5d) 31.5MHz -HSync -VSync
h: width 640 start 664 end 704 total 832 skew 0 clock 37.9KHz
v: height 480 start 489 end 491 total 520 clock 72.8Hz
640x480 (0x5e) 31.5MHz -HSync -VSync
h: width 640 start 656 end 720 total 840 skew 0 clock 37.5KHz
v: height 480 start 481 end 484 total 500 clock 75.0Hz
640x480 (0x5f) 30.2MHz -HSync -VSync
h: width 640 start 704 end 768 total 864 skew 0 clock 35.0KHz
v: height 480 start 483 end 486 total 525 clock 66.7Hz
640x480 (0x60) 25.2MHz -HSync -VSync
v: height 480 start 490 end 492 total 525 clock 60.0Hz
720x400 (0x61) 28.3MHz -HSync +VSync
h: width 720 start 738 end 846 total 900 skew 0 clock 31.5KHz
v: height 400 start 412 end 414 total 449 clock 70.1Hz
Identifier: 0x44
Timestamp: 22302
Subpixel: unknown
Clones:
CRTCs: 1 0
filter:
Broadcast RGB: Full
audio: auto
trenutek...
nedelujoče:
xrandr --verbose
Identifier: 0x41
Timestamp: 22302
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 1
CRTCs: 1 0
filter:
EDID:
Identifier: 0x42
Timestamp: 22302
Subpixel: unknown
Clones:
CRTCs: 1 0
filter:
Identifier: 0x43
Timestamp: 22302
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 1 0
filter:
EDID:
Broadcast RGB: Full
audio: auto
Identifier: 0x44
Timestamp: 22302
Subpixel: unknown
Clones:
CRTCs: 1 0
filter:
Broadcast RGB: Full
audio: auto
trenutek...
Zvezdica27 ::
xrandr --verbose
Identifier: 0x41
Timestamp: 22302
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 1
CRTCs: 1 0
filter:
EDID:
Identifier: 0x42
Timestamp: 22302
Subpixel: unknown
Clones:
CRTCs: 1 0
filter:
Identifier: 0x43
Timestamp: 22302
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 1 0
filter:
EDID:
Broadcast RGB: Full
audio: auto
Identifier: 0x44
Timestamp: 22302
Subpixel: unknown
Clones:
CRTCs: 1 0
filter:
Broadcast RGB: Full
audio: auto
jaz sem out of ideas. Razen če še konzolo brez X probam pa out na HDMI (se to sploh da brez x?)
zz
Identifier: 0x41
Timestamp: 22302
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 1
CRTCs: 1 0
filter:
EDID:
Identifier: 0x42
Timestamp: 22302
Subpixel: unknown
Clones:
CRTCs: 1 0
filter:
Identifier: 0x43
Timestamp: 22302
Subpixel: unknown
Gamma: 1.0:1.0:1.0
Brightness: 1.0
Clones:
CRTC: 0
CRTCs: 1 0
filter:
EDID:
Broadcast RGB: Full
audio: auto
Identifier: 0x44
Timestamp: 22302
Subpixel: unknown
Clones:
CRTCs: 1 0
filter:
Broadcast RGB: Full
audio: auto
zz
pi pawr ::
Helou!
Jaz imam en čuden problem; svežo inštalacijo sem naredil na dan izdaje, vse je delalo lepo in dokaj tekoče.
Čez dan ali dva (ko sem inštaliral precej programov) pa je kazalec obremenitve začel kazati poln odklon in ventilator ves čas tuli na polno, procesor je obremenjen 10 do 40 % (dve leti star, i5 430M). Če mu spremenim frekvenco z 2,27 na 1,2 GHz se pa umiri. Po pritisku super tipke se dash pokaže po sekundi ali več, gladko drsenje ni gladko, filma z blu-ray plošče pa tudi pri nazivni frekvenci ne prebavi več, pri 10.10 in 11.10 je delal brez problema. Nameščen je ATI/AMD lastniški gonilnik.
Tamperature so normalne, ni pregrevanja.
Pri nižji frekvenci torej ne tuli, kazalec obremenitve pa je do konca.
A bi se dalo to kako rešit? Če bo treba lahko tudi na novo inštaliram zadevo.
LP!
LP!
poweroff ::
No, meni se je zgodilo par dni po upgradu, da je prenosnik začel zmrzovat.
Sem že hotel začeti kleti novo verzijo, pa sem za vsak slučaj pognal še memtest. Rezultat:
Je pa zanimivo, da ni takoj pokazal napake. V tretjem passu jo je pokazal, v kasnejših potem ne.
No v glavnem, RAM sem zamenjal in sedaj zadeva deluje.
sudo poweroff
- zavarovalo slike: poweroff ()
Zvezdica27 ::
lp,
sys76 uradno odgovoril, da je to stvar kalibracije. Mamicu jim pokvarenu... Ok, gremo nek najdit to hardware zadevo in probat, čeprav ne vem... tolk off pa spet ne more biti.
Drugače pa je 12.04 zakon, HUD pa seka, neverjetno kako uporabno.
zz
zz
poweroff ::
Ja, zdaj bo pa darkolord rekel, da se UI izboljšave pri Ubuntuju delajo brez premisleka...
sudo poweroff
panteist ::
A obstaja možnost zjebane drsnike v gtk programih spravit nazaj v normalno stanje, kot smo jih navajeni že 25+ let?
panteist ::
+ za vse, ki pogrešate Scale All Windows funkcijo -> stvari se premikajo, danes se bi znali pojaviti že prvi patch-i, če ne pa v kratkem :)
pi pawr ::
Icematxyz ::
Nevermind, na novo inštaliral, vse dela kot namazano!
Ubuntu pawr
Super. Da, če se je težava pojavila naknadno je verjetno šlo za kakšno dodatno nameščeno programsko opremo, morda celo ti razno razni "gadgeti" za ročno upravljanje s porabo?
Še dobro, da se najde vnos v Grub 2... ;)
V bistvu se načeloma strinjam z njimi po vseh informacijah, ki si jih podal, se pravi morda bo v prihodnosti pri izdelavi privzetega .icc profila iz EDID uporabljena spremenjena "formula", oziroma bo tvoja strojna oprema, gonilniki... na vse skupaj vplivalo drugače, oziroma bo kaj drugače podprto, ampak v tem trenutku je privzeto stanje takšno, kot je. Torej umerjanje zaslona in izdelava profila bo verjetno rešilo težavo.
Na primer za kakšen hiter test, če prižgeš prenosnik in priključiš TV preko HDMI bo ti verjetno samodejno nastavilo zaslon in TV tako:
xrandr --output LVDS1 --mode 1366x768 --pos 0x0 --primary --output HDMI1 --mode 1366x768 --pos 1366x0
Če boš testno "ročno umerjal", na primer:
xrandr --output LVDS1 --mode 1366x768 --pos 0x0 --primary --output HDMI1 --mode 1366x768 --pos 1366x0 --gamma 1.05:0.95:0.95 --brightness 1.05
In boš po tem v nadzorni plošči pod Barva na seznamu naprav izbral TV zaslon in mu dodal privzet .icc profil (ime naprave) in ga uveljavi in boš videl, da bo preglasil tvojo nastavitev s privzeto. Ko boš tukaj dodal .icc profil izdelan pri umerjanju predvidevam, da potem težav več ne bo.
P.S. Verjetno bi ti v tem trenutku prav prišel ColorHug.
BigWhale ::
komu hud pomaga, bolj zacetnikom, bolj power userjem?
Če povem po resnici, ga še enkrat nisem uporabil. Že za izhod iz programa se razlikujejo ukazi: quit, close, exit, itd. in potem ne vem kateri je pri katerem programu :)
Za HUD je v pripravi izboljsava kjer se bo lahko za posamezne ukaze pripravilo tudi aliase. Tko da bo lahko quit, exit, close in tako naprej naredil eno in isto.
panteist ::
Sporočam čudovito novico in sicer Bruno Santos je skompajlu Compiz s patchem za Scale, tako da sedaj preverjeno deluje.
Več na: https://launchpad.net/~bsantos/+archive...
pi pawr ::
Jap, možno, toda s tem gadgetom sem ga "ukrotil".
10.10 je bil bomba...tale se pa skoraj minuto prižiga, pa iz spanja se prebuja 15 sekund
A to tudi vas matra; (?) Disk (5400, sata) zmore v Window$ih 80 MB/s pretoka. Ko pa sem v Ubuntuju premikal nek velik backup je bila najvišja hitrost okoli 20 MB/s, pa še vse ostale funkcije so obstale, računalnik je bil med kopiranjem kratkomalo neodziven. No, saj kopiranje se je končalo, potem ni bilo več tko grozno.
Zdaj sem inštaliral
Uporabnost HUDa, npr. dodajanje zaznamkov, ali pa če ne veš v katerem meniju se nahaja ukaz.
Zdaj sem inštaliral
preload
Zvezdica27 ::
lp,
ah, škoda časa. Hvala Ice, lej če bi kdaj šel na pivo pošlji zs, LJ pa to, ker si si ga zaslužil.
bom poročal ko dobim kalibrator od bratranca. Isto se dogaja tudi na Fedori. Igral sem se tudi z Xorg.conf, disablan EDID itd, nomodeset, vse živo, brez učinka. Hec je v temu, da tud če "zaribam" xorg, je black screen magenta, torej...
Ugotovil sem tudi, da RGB, torej analogno, dela b.p. In pa da HDMi zvok pada (treba restart da dela zvok in pol še suspend da je slika ok ;), tko da to je skor gotovo intel driver issue.Zdaj se mi pa ne da več, tko da pač do nadaljnjega bomo suspendali. Starega driverja pa ne bi downgradal, ker drugače sedaj ful boljše in hitreje del grafika (prej so bili včasih artefakti itd.)
zz
zz
šernk ::
Verjetno bo to zaleglo:
gsettings set org.gnome.settings-daemon.plugins.power button-suspend "nothing"
Povrnitev na privzeto nastavitev:
gsettings set org.gnome.settings-daemon.plugins.power button-suspend "suspend"
danes prišel temu do dna...clean install 32 bitne verzije in zadeva je delovala...gumb je neodziven
poleg tega rešenih tudi par drugih nejasnosti in vse deluje spet po starem...nobenih čudnih napak itd., izgleda da je ena komponenta občutljiva na 64 bitni sistem, ker isto je bilo z vsako verzijo 64 bitni enkripcija home particije...ne dela...64 bitni brez enkripcije home dela bolje ampak ne dela...32 bitni dela odlično. Torej ostajam na 32 bitnem sistemu :)
sedaj pa ker vem da vas je nekaj tukaj, ki uporabljate Siol TV, a vam je uspelo na kak način spravit signal do VLCja? Static route izgleda da deluje, pa tudi če ne deluje, bi moralo ob fizičnem izklopu interneta signal iz druge mrežne priti na VLC...sumim nastavitve v VLC 2.0.1, ker so kar konkretno spremenili reči in recimo izključno IP za ipv4 ne najdem nastavitev pa za udp port tudi ne...
Icematxyz ::
@pi pawr
Zagonski čas ne bi smel biti bistveno drugačen, kot pri različicah od prejšnjega LTS naprej, morda v kakšnih specifičnih primerih, rang nekaj sekund +/- na enaki strojni opremi je normalno stanje, ostalo pa že nakazuje, da nekaj ni OK.
-Si pri namestitvi Ubuntu izdelal Swap razdelek ali si glede tega kaj spreminjal naknadno?
-Preload lahko seveda podaljša zagonski čas.
-Ubuntu ima že vgrajene mehanizme na tem področju in potrebno je le nekaj časa uporabljati Ubuntu, da začne mehanizem opravljati svojo nalogo!
Imaš Ubuntu 12.04 nameščen na enak podatkovni nosilec, kot si imel prejšnje različice?
@Zvezdica27
Da v prihodnosti je možno, da bo kaj drugače, morda (razen umerjanja) še zadnji nasvet zaenkrat s tega področja z moje strani, če poskusiš sledeče, kakšen je rezultat?
xrandr --output LVDS1 --mode 1366x768 --pos 0x0 --primary --output HDMI1 --mode 1280x1024 --pos 1366x0
TV zaslon pa nastavi na samodejno prilagajanje slike zaslonu, če bo to delovalo OK razmisli zaenkrat o tej opciji.
@šernk
Super, prvič ponavadi takšna stvar pač "ne sme" delovati, ker potem ne bi bilo zanimivo.
Glede SIOL TV pa je res, da boste uporabniki morali spisati kakšen vodič z razlago, ker po tem je v vsaki temi povpraševanje.
@Zvezdica27
@šernk
- spremenil: Icematxyz ()
šernk ::
Saj sem imel tokrat namen spisat navodila za siol tv v celoti ravno po postopku ki si ga linkal,...pa me je hudič ustavil kjer me od kar uporabljam siol tv na ubuntu ni še nikoli
skratka igranje dalje dokler se kdo ne oglasi z uspehom :)
pi pawr ::
Particija na kateri se je vse odvijalo odkar imam dual boot (52 GB) se je zdaj razdelila na del z ext4 (48 GB) in na del, ki se imenuje izmenjevalni prostor (4,1 GB). Pri prvi inštalaciji 12.04 sem kliknil kar tisto možnost, naj odstrani 11.10 in namesti 12.04 (verjetno se je ustvaril takrat), včeraj, ko sem namestil še enkrat sem pa "ročno" določil kam naj se inštalira. So pa na disku že 4 particije.
Preload odstranjen
Ja, na isti.
Swappiness sem nastavil na 10.
Sleep je ozdravel!
Preload odstranjen
Ja, na isti.
Sleep je ozdravel!
- spremenil: pi pawr ()
OttoParts ::
Zdravo!
Imam problem z posodobitvijo sistema.
Torej sistem se je posodobil in me opozoril, da ga naj zaženem znova, da se posodobitev zaključi.Po ponovnem zagonu je sistem sporočil neko notranjo napako (ne vem katero) in zahteval ponoven zagon. Po ponovnem zagonu se mi čez čas "kolešček", s katerim se mdr. upravlja vklop in izklop sistem obarva rdeče in spet zahteva ponoven zagon, da se posodobitev zaključi.
Kljub že 7 ponovnem zagonu se to še vedno ponavlja.
Kaj naj naredim?
Kaj naj naredim?
Icematxyz ::
@pi pawr
Če si pri namestitvi izbral / in /swap razdelek, kot opisuješ, potem se je vse uredilo "samodejno" in to torej ne vpliva na zagonski čas, kot bi morda lahko, če bi to počel naknadno ročno.
Super, sicer nisem se poglabljal v to zakaj je temu tako, ampak če deluje bolje lepo, da si to uredil.
@OttoParts
Vpiši v terminal sledeče:
sudo apt-get update
sudo apt-get upgrade
Predvideva, da bo se pojavila kakšna napaka, katero kopiraj in jo prilepi sem.
Sleep je ozdravel!:)
@OttoParts
sudo apt-get update
pi pawr ::
Razen zagonskega časa trenutno nimam pripomb :D
Ubuntu je res "pameten"
Če komu iz neznanega razloga po igranju z dostopno točko nič več ne dela:
sudo rfkill list all
sudo rfkill unblock all
OttoParts ::
Nobenih napak ne javi.
update najde in prenese vse stvari na internetu
upgrade pa izjavi, da ni posodobljenih , ni instaliranih, ni odstranjenih in ni upgradanih stvari.
Icematxyz ::
Poskusi sledeče, na vprašanje, če želiš znova zagnati računalnik izberi opcijo, da boš to storil kasneje in potem izvedi postopek ročno, kjer ne boš izbral ponovnega zagona, ampak izklop.
OttoParts ::
O.K.
Problem rešen.
Ročni izklop me je vrgel v prijavni zaslon in tudi tam opcija izklopi ni delovala, zato sem računalnik izklopil fizično. Po zagonu sedaj normalno deluje.
Hvala!
Problem rešen.
Hvala!
Icematxyz ::
Icematxyz ::
mogoče kašna informacija kdaj bo owncloud client za 12.04?
Pa smo ga dočakali.
Sicer dela z verzijo za debian6/xubuntu11.10, ampak preko SSL ne deluje?
Začasen "fix":
Snemi ročno sledeč paket:
32 bit: libneon27_0.29.6-3_i386.deb
64 bit: libneon27_0.29.6-3_amd64.deb
Klikneš s miško in Programsko središče Ubuntu ponudi nadgradnjo. Nadgradiš.
Povrnitev na privzeto stanje:
sudo apt-get remove libneon27
sudo apt-get install libneon27
Oziroma, če je nameščen tudi ownCloud odjemalec:
sudo apt-get install libneon27 owncloud-client
Aston_11 ::
Kaj vse se človek ne nauči. Če si dva 12.04 delita isti /home, potem se spremembe programov poznajo v obeh.
Kako bi si spremenil /home? Sedaj je na sda2, spremenil bi ga na sdb2. Po netu vidim samo neke dolge procedure...
js osebno ::
Prekopiraš celoten home na sdb2, nato urediš /etc/fstab, da ob zagonu avtomatično mounta tisto zadevo pod /home mapo. Meni je vzelo kaki 2 uri časa, ker sem se zraven nekaj mudil. /fstab lahko najlažje urediš s Storage device managerjem
sudo apt-get install pysdm
poweroff ::
10.10 je bil bomba...tale se pa skoraj minuto prižiga, pa iz spanja se prebuja 15 sekund![]()
Ne vem, meni po nadgradnji na 12.04 boot dela hitreje, enako shutdown.
sudo poweroff
kanzyani ::
Zdravo.
Pri nadgradnji iz 11.10 na 12.04 je prislo do nekih tezav (ubuntu je sporocal neke notranje napake itd) vse je stekalo, se miske se ni dalo normalno premikat. Zato sem se odlocil narediti clean install (home imam locen in sem ga sedaj spet uporabil).
Vendar je spet prislo do neke notranje napake (ki si je takrat nisem izpisal) in spet ni dobro delalo. Namestil sem vse mozne posodobitve. Sedaj pa imam problem, da ne morem kreirati novega uporabnika. Pod uporabniski racuni ga ustvarim, mo dolocim geslo, vendar kadar hocem preklopiti med uporabniki me pricaka samo crn zaslon in stvar ne gre naprej. Kreiram pa uporabnik, ki je v 11.10 ze imel svoj home razdelek (ker bi rad da podatki ostanejo tko kot prej). Pa tudi ko ustvarim testnega uporabnika se vanj ne morem prijavti pricaka me black screen...
Prav tako ne morem instalirati zaprtokodnega amd gonilnika... napise, da je spodletelo (sicer sem v verziji 11.10 uporabljal kar odprtokodnega, ker je deloval dovolj dobro).
kaka ideja kako to resit?
Icematxyz ::
@pi pawr
ALT + F2 in vpiši palimpsest in ko se program zažene izberi podatkovni nosilec, kjer je nameščen Ubuntu OS in potem klikni še na vse razdelke. Se pojavi kakšno opozorilo?
@kanzyani
Če deluje dobro uporabljaj preprosto odprto kodnega, drugače pa lahko poskusiš:
sudo mv /etc/X11/xorg.conf /etc/X11/xorg.conf.old
sudo apt-get purge fglrx*
sudo apt-get autoremove
sudo apt-get install fglrx fglrx-amdcccle
In znova zaženi računalnik.
P.S. Ko bo to urejeno in tudi delovalo dobro pa izdelaj novega testnega uporabnika in se poskusi z njim vpisati v sejo!
@kanzyani
Icematxyz ::
Na voljo je nova različica priljubljenega zvočnega strežnika PulseAudio 2.0 (release notes).
kanzyani ::
Ok. driver sem namestil, uporabniki se vedno ne delujejo... sistema tudi ni mozno ugasnit. vedno se obesi pri ubuntu logotu. (kje bi lahko pogledal log da vem kaj ne dela... )
matic@matic-F7Se:/var/log$ tail auth.log
May 14 22:36:27 matic-F7Se lightdm: pam_ck_connector(lightdm:session): nox11 mode, ignoring PAM_TTY :0
May 14 22:36:28 matic-F7Se lightdm: pam_succeed_if(lightdm:auth): requirement "user ingroup nopasswdlogin" not met by user "krneki"
May 14 22:36:28 matic-F7Se dbus[838]: [system] Rejected send message, 2 matched rules; type="method_call", sender=":1.27" (uid=104 pid=1570 comm="/usr/lib/indicator-datetime/indicator-datetime-ser") interface="org.freedesktop.DBus.Properties" member="GetAll" error name="(unset)" requested_reply="0" destination=":1.16" (uid=0 pid=1250 comm="/usr/sbin/console-kit-daemon --no-daemon ")
May 14 22:36:46 matic-F7Se lightdm: pam_succeed_if(lightdm:auth): requirement "user ingroup nopasswdlogin" not met by user "matic"
May 14 22:36:56 matic-F7Se lightdm: pam_unix(lightdm:session): session closed for user lightdm
May 14 22:36:57 matic-F7Se lightdm: pam_unix(lightdm:session): session opened for user matic by (uid=0)
May 14 22:36:57 matic-F7Se lightdm: pam_ck_connector(lightdm:session): nox11 mode, ignoring PAM_TTY :0
May 14 22:36:58 matic-F7Se polkitd(authority=local): Registered Authentication Agent for unix-session:/org/freedesktop/ConsoleKit/Session2 (system bus name :1.49 [/usr/lib/policykit-1-gnome/polkit-gnome-authentication-agent-1], object path /org/gnome/PolicyKit1/AuthenticationAgent, locale sl_SI.UTF-8)
May 14 22:36:58 matic-F7Se dbus[838]: [system] Rejected send message, 2 matched rules; type="method_return", sender=":1.3" (uid=0 pid=861 comm="/usr/sbin/bluetoothd ") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.50" (uid=1000 pid=1826 comm="bluetooth-applet ")
May 14 22:37:01 matic-F7Se dbus[838]: [system] Rejected send message, 2 matched rules; type="method_call", sender=":1.61" (uid=1000 pid=1984 comm="/usr/lib/indicator-datetime/indicator-datetime-ser") interface="org.freedesktop.DBus.Properties" member="GetAll" error name="(unset)" requested_reply="0" destination=":1.16" (uid=0 pid=1250 comm="/usr/sbin/console-kit-daemon --no-daemon ")
ce to kaj pomaga...
ce to kaj pomaga...
Zvezdica27 ::
OK, zadevo sem rešil. na dva načina. Sam noben ne dela popolno.
hehe... naj pojasnim
1)
Zadeva se reši, če dam starejši kernel. Recimo 3.0. Potem zazna in prikaže pravilne barve. Zdaj... novi kernel ima nove wireless module, tko da potem neki nekje gre navzkriž in wireless ne dela, če je kernel 3.0. Poleg tega - priznam, igram Urban terror - je grafika precej slabša na 3.0, zatikajoča se. Novi 3.3.5 kernel je precej boljši, tudi v Google earth se to vidi, bolj tekoče vse. Poizkusil bom še z zadnjo verzijo kernela pred 12.04 pa da vidimo.
Torej, taktika "naprej v srednji vek" deluje. Namesto napredek, nazadovanje (hm... da nima kje naša vlada prste vmes ?)
2)
zadeva se reši, če nastavim gammo. Torej gre res za napačen poljub ljubezni med TV in kernelom (ubuntu nima nič, isto dela fedora 17).
Tu moram napisati malo več - na začetku, pred tednom, sem takoj probal z gammo v xorg.conf (ki ga ni bilo in ga je X sam napisal - precej čuden, sam... dela). Ker ni bilo efekta se s tem nisem igral.
Zdaj vem zakaj ni bilo efekta.
Računalo napačno zaznava HDMI oz. TV preko HDMI.
to sem ugotovil danes ko sem se igral z xgamma ukazom. xranrd sicer vse lepo prikaže, tudi drugi programi, recimo monitors ali arandr. Samo ko pa grem v terminal ni variante da bi xgamma nadzoroval HDMI, sami errorji ne najde sreena niti displaya, prbal vse ukaze. Edini način je, da izklopim laptop in upam da TV ne bo preklopil v prave barve (arandr še najbolje to nardi, da ostanejo barve fucked up). Ko imam edini display na HDMI (laptop pa off) potem xgamma prime. Če delata oba ekrana potem xrandr ne more nadzorovati HDMI izhoda, torej ko preklopim oz. vklopim nazaj je isto.
Ali pa sem jaz nesposoben.
V tem primeru je rešitev banalna - startup skriptica. Sam kaj, ko xgamma enostavno ne more nadzorovati HDMI. Našopat je treba zeleno pa je skor popolno.
Zato mi tudi ukazi v xorg.conf niso prijeli - enostavno jih nekaj overrida. Danes sem se igral, no go. Za četrt sekunde prime gamma na laptop screen, pa se overrida, na TV še te četrt sekunde ne. To me je vrglo v zmoto ... še dobro da se ne pustim je*at neki kišti...
Isto s profili (ko sem se nekaj igral z argyllom). Zdi se mi da argyll ne prime, četudi ko naložim icc profile se vidi sprememba. Čudno.
Sedaj moram torej samo najti profil icc ki ima našopano zeleno in to je to (ali pa xrandr skriptica)
Tko da sedaj vemo nekaj novega, nekaj v kernelu nekaj naredi z gamma oz. barvnimi nastavitvami. Zdaj pa spat, juti bo dolga do MS.
Idemo dalje za iste pare.
zz
1)
2)
zz
Zvezdica27 ::
lp,
za foro se probal xgamma po suspendu, ko vse dela OK. Še vedno ne pošlje čez HDMI. Če dam HDMI, spreminja ekran od laptopa, isto kot če dam LDVS.
Torej zdi se, da oba ekrana zaznava na isti stvari, torej med sabo se očitno nekako tepeta.
Hm... škoda da sem že pobrisal 3.0 kernel da bi še tam probal. Ah... bom z novim. Čez kak dan.
čao,
zz
čao,
zz
Icematxyz ::
@kanzyani
Kakšno pa je stanje če izvedeš:
In znova zaženeš računalnik.
Icematxyz ::
@Zvezdica27
Poskusi sledeče:
xrandr --output HDMI1 --gamma 1.0:0.8:1.0
Poskusi sledeče:
d4vid ::
Pozdravljeni!
Imam en problem, ki ga ne znam rešit. Imam Genius Soundmaker 5.1 zvočno in 5.1 zvočnike. V Win dela bp, tukaj pa imam težave. Ko hočem znižat glasnost zgoraj pri uri se utišajo samo woofer in dva zvočnika. Drugi pa špilajo naprej. V nastavitvah dela to bp, ampak vsake toliko pozabi da imam 5.1 in mi ne dela woofer (crkne, čeprav je v nastavitvah še vedno vidno 5.1), pravtako pa ne znam nastavit uporabe 5.1 zvočnikov in mikrofona naenkrat.
Ima še kdo take probleme?
Drugače pa... saj je ubuntu stabilen, ampak unity2D (jbg, PCI (da, PCI) grafiko mam notr, ker nimam napajalnika z dodatnim napajanjem) se mi je zameril, ne dela kot hočem :)
| ! | [(K)Ubuntu] Vprašanja in težave (strani: 1 2 3 4 … 23 24 25 26 )Oddelek: Operacijski sistemi | 411386 (10946) | bosmla |
| » | Ubuntu 12.10 Quantal Quetzal (strani: 1 2 3 4 )Oddelek: Operacijski sistemi | 59990 (50614) | MrStein |
| » | [Ubuntu 10.04] Problem z zvočno kartico (mikrofon)Oddelek: Operacijski sistemi | 2648 (2549) | Icematxyz |
| » | Izšel Ubuntu 12.04 LTS (strani: 1 2 3 )Oddelek: Novice / Operacijski sistemi | 47702 (40845) | panteist |
| » | Ubuntu Oneiric Ocelot 11.10 (strani: 1 2 3 4 … 14 15 16 17 )Oddelek: Operacijski sistemi | 225869 (191808) | Icematxyz |
