[(K)Ubuntu] Vprašanja in težave
26 / 26
polozweii ::
polozweii je izjavil:
broken/link je izjavil:
windows 11 iso fajl prepiši na ventoy usb.
Hočeš reči da samo v Downloads mapi z miško primem ISO fajl in ga prenesem v USB ključ?
Pa je res. Pri Rufusu je drugače.
https://www.ventoy.net/en/doc_start.htm...
Copy Image files
After the installation is complete, the USB drive will be divided into 2 partitions. The 1st partition was formated with exFAT filesystem (You can also reformat it manually with NTFS/FAT32/UDF/XFS/Ext2/3/4 ... See Notes). You just need to copy iso files to this partition. You can place the iso/wim/img/vhd(x) files any where. Ventoy will search all the directories and subdirectories recursively to find all the image files and list them in the boot menu alphabetically. Also you use plugin configuration to tell Ventoy only to search for image files in a fixed directory (and its subdirectories).
Po zgornjih navodilih nastaneta dve particiji. Jaz vidim samo eno particijo. Je druga particija skrita al sem narobe inštaliral?
https://ibb.co/C39Gh5Cp
Bo delalo če iso fajl skopiram v to particijo?
uspelo je
polozweii ::
Težava: Prenosnik ne zažene OS Linux Mint.
Na par let starem malo rabljenem prenosniku ki sem ga prižgal po dveh mesecih neuporabe se ne zažene operacijski sistem Linux Mint.
Najprej sem priklopil polnilec.
Ko prižgem se pojavi logo prenosnika in zatem na vrhu naslednji napis ki se je če se ne motim pojavljal že prej:
[ 0.290292] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GPP6.W
LAN], AE_NOT_FOUND (20210730/dswload2-162)
[ 0.290310] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20210730/ps
object-220)
Ko napis izgine tako ostane dokler ga ne ugasnem s tipko za zagon.
Tipkovnica ni zablokirana - lučko za NumLock lahko prižgem/ugasnem.
V prenosniku je HDD disk z naloženim Linux Mint.
Je težava v HDD ali OS?
c23po ::
Ne HDD ne OS. Začne se z WiFijem.
Si mogoče kaj sam poguglal?
Računalniki nimajo spominov.
polozweii ::
Misliš za tiste hieroglife?
Nimam dovolj računalniškega znanja, še posebej na Linuxu.
Zakaj bi bil težava WiFi saj se niti OS še ni naložil?
  • spremenilo: polozweii ()
errhec ::
Najdi katera tipka je za izbor zagonskega pogona(F12?). Potem izberi disk na katerem je linux.
Izgleda da sploh ne pride do diska.
dd
polozweii ::
errhec je izjavil:
tipka F1
Mislil sem da je hdd pa zdaj vidim v biosu NVME SSD Samsung MZALQ256....
Če ga preberem v biosu pomeni da ni crknil?
Nekateri biosi imajo preizkus diska in podobno. V tem nisem našel. Ni to tisti pravi bios ampak je bolj grafičen- Thinkbook, barven logotip, belo ozadje,..
polozweii ::
Če priključim usb ključek za inštlacijo linuxa, lahko na grobo vidim stvari na disku vendar nimam dostopa da bi jih poiskal in prenesel na drugi disk.
Je vzrok za težavo torej v Linuxu ki ga nisem prižgal dva meseca?
Se bi dalo obnovit na ta način da ga povozim z novo inštalacijo linuxa iz ključka? Bodo podatki ki so shranjeni na disk ostali kot je to možno pri inštalaciji Windowsa?
Če ja, moram inštalirati isto verzijo Linuxa, ali je lahko novejša?
Zvezdica27 ::
zagnati moraš live USB, ne inštalacijo. Potem boš lahko dostopal do diska.
Lahko bi se tudi chrootal v originalni sistem, če se ti live USB zažene, potem si v resnici nazaj v svojem sistemu in rešiš vse podatke. Sam ni potrebe, ker je live usb lažji naćin. Je pa ta način OK, da popraviš kaj v sistemu (heavy dependency hell recimo).
Če boš inštaliral, lahko narediš tako, da podatki ostanejo, sam ti svetujem, da ga daš na ne vem, nek drug disk ali novo particijo - potem bi ti podatki ostali,s am ful pazi... tudi jaz sem že zbrisal particijo, po pomoti, potem pa ooops... V bistvu je to isto kot live usb - zato je live usb boljša opcija (če imaš kak res hiter usb ključek, v bistvu sploh ni potrebe, da linux še daješ na disk...)
Live usb torej. Ali pa disk vun in priklop nekam, ni torej panike.
zz
aja. če imaš nvme, palčko, daj jo ven pa v ohišje in boš vse podatke lahko rešil.
polozweii ::
Podatki vseeno niso tolk pomembni, bolj balast zato sem se odločil da na novo naložim Linux.
Na usb ključu imam starejšo verzijo Mint Mate 21.2. Zadnja je 22.3.
Če inštaliram to staro jo lahko nadgradim na novejšo verzijo kot pri win 10 na win 11?
mtošev ::
Prebral sem zadnjih par zapisov od polo dvojke in pomislil samo na tole:
polozweii ::
Preden inštaliram na usb naloženo zadnjo verzijo me zanima to... USB image writer ni vprašal če želim MBR ali UEFI. Se to določa v biosu z izbiro med Legacy ali UEFI?
Mimogrede, v biosu sem imel pri Boot Mode in Boot Priority nekaj izbrano UEFI nekaj pa Legacy. Eno sem spremenil in je zdaj oboje Legacy. Ob zagonu je malo drugače ampak OS dela.
Vedran ::
Pri posodobitvi KEK CA certifikata mi Ubuntu izpiše naslednje obvestilo:
Failed to install firmware!
org.freedesktop.fwupd.InvalidData: failed to write-firmware:
failed to write (null): failed to write data to efivarsfs:
Error writing to file descriptor: Invalid argument
Ali ima mogoče kdo podobno težavo in kako problem posodobitve rešiti?
bosmla ::
Star prenosnik z Mint 20.3 sem po dolgem casu prizgal... Timeshift je zacel delati sinc, cez cas je ugasnil ekran in se ni hotel prizgati nazaj, zato je zena ugasnila prenosnik... Ko sem ga ponono prizgal pride lepo do tam ko je potrebno vpisati geslo, geslo vpisem, malo pomelje in je spet isti ekran z geslom... Geslo je pravilno (prepozna tudi napacno).
Kaj bi bilo lahko narobe?
Nihce? Dopusti vnda...
  • spremenil: bosmla ()
26 / 26
Ubuntu vprašanja (strani: 1 2 3 4 … 19 20 21 22 )
Oddelek: Operacijski sistemi
1061250538 (119377) poweroff
Ubuntu 12.04 Precise Pangolin (strani: 1 2 3 4 … 21 22 23 24 )
1194279391 (214525) Zvezdica27
Ubuntu 10.10 - 10 Out Of 10 (strani: 1 2 3 4 … 19 20 21 22 )
1093206083 (163676) Icematxyz
Ubuntu Oneiric Ocelot 11.10 (strani: 1 2 3 4 … 14 15 16 17 )
813226771 (192710) Icematxyz
Ubuntu 10.04 LTS - Change is coming (strani: 1 2 3 4 … 17 18 19 20 )
999173732 (136618) Icematxyz
