Forum » Loža » Umetna inteligenca
Umetna inteligenca
LiquidAI ::
Zdej ima Qwen 3.8-27B z 30 tokens na sekundo brez grafične samo na CPU in ne rabi kupit Nvidije.
The flagship CPU Xuantie C950, released by Alibaba DAMO Academy in March this year, has recently achieved a significant milestone in its development history--successfully running the Tongyi Qianwen 3.8-27B large model natively.
As a 64-bit server-grade processor, the Xuantie C950 is manufactured using TSMC's 5nm process technology and integrates up to 64 computing cores internally. These cores are interconnected via a high-speed AMBA CHI bus, with 8 cores grouped together. The chip can reach a maximum clock speed of 3.2GHz. In terms of hardware architecture, it not only features an 8-instruction decoding width and a 16-stage pipeline design, which increases memory bandwidth by more than four times compared to its predecessor, the Xuantie C920, but also directly integrates matrix acceleration engines and vector acceleration engines optimized for AI inference workloads. Thanks to its outstanding design, its single-core general performance has exceeded 70 points in the SPECint2006 benchmark test, successfully setting a new performance record for RISC-V CPUs worldwide.
In practical performance, when driving the Tongyi Qianwen 3.8-27B model, the Xuantie C950 achieves a decoding speed of 30 tokens per second, with the first token latency stably controlled within 1.9 seconds. Traditionally, running such a large-scale model would require 16GB to 24GB of dedicated GPU memory. However, the Xuantie C950 can complete the entire inference process independently using just the CPU itself and the on-chip acceleration engine, eliminating the need for external dedicated graphics cards.
ni glih nek achievement. BC-250/PS5, slednja kartica se je prodajala tudi za pod 100€, bp doseže čez 30tok/s z MTP...
Samael ::
OVH je zagnal svoj LLM na evropskih tleh: Olala mini 7A1B
Strojno preveden članek https://x.com/olesovhcom/status/2122573... iz francoščine:
OVH Announces Olala Mini 7A1B
OVH introduces its first family of Large Language Models (LLMs). The first entry in this family, Olala Mini 7A1B, is a compact model built on a novel architecture.
Olala: An Innovative Model Featuring Hybrid Attention
Olala Mini is based on a 7-billion-parameter (7B) architecture, with one billion active parameters distributed across 256 experts per layer. It utilizes a hybrid attention mechanism--incorporating Differential-TPA and Mamba-3--and is formatted in BF16. Because only a fraction of the model is engaged for each request, it is faster and more memory-efficient. Consequently, the model can run on a GPU with as little as 8 GB of VRAM, achieving 160 tokens per second on an RTX A4500; even without a GPU--running solely on a standard CPU--it reaches 50 tokens per second. It currently supports a context window of 32,000 tokens. Olala Mini will be available as open source on Hugging Face under the Apache 2.0 license.
Trained with European Public Funding and Currently in Use at Qwant
Olala Mini was trained on three European public supercomputers--Jupiter, MeluXina, and Jean Zay--equipped with GH200, A100, and H100 GPUs. This support, equivalent to €7 million in computing time, was instrumental, and OVH extends its gratitude to the public authorities. This public initiative has proven successful on multiple fronts: it fostered an exceptional artificial intelligence team and led to the creation of OVH's "Agentic Lab"--OVHai LLM. Olala Mini is being released alongside its model weights, the pre-trained base model, a technical report, and documentation regarding its compliance with the EU AI Act. Qwant has already adopted it for its "flash response" feature, yielding significant gains: responses are 20% faster, and operating costs have been reduced to one-third of what they were with the previously used model.
On the road to v1.1, and then v2.0
Expected by the end of the year, version 1.1 will expand the context window to 128,000 tokens and improve performance in mathematical reasoning. With version 2.0, OVHai LLM aims to develop models specialized in three areas. First, agentic AI for enterprises: eventually, "Olala" will power OVHai Workspace, which--in its encrypted version--will require models capable of running locally, directly on the workstation. Second, cloud DevOps, with variations tailored for developers, architects, and operations teams responsible for ensuring 24/7 service continuity. Finally, cybersecurity, covering both defensive and offensive aspects. Olala v2.0 will exceed 100 billion parameters.
Samael != Samuel
32k konteksta? 7B parametrov in MoE arhitektura?
Giving 2024 qwen vibes. Z drugimi besedami, useless v času, k mamo qwen 3.8 in k je 4.0 tik pred vrati. Bolš da bi nardil kakšn finetune instead.
- spremenil: iloveboobz ()
LiquidAI ::
Qwen4-Max je bil včeraj izdan.
Qwen4-Max: Your New Teammate Has Arrived
Today, we are introducing Qwen4-Max, your new AI teammate for work, creativity, and discovery. Qwen4-Max is built on the new Qwen4 architecture, with a 2.4-trillion-parameter backbone, native vision capabilities, and a one-million-token context window.
Qwen4-Max advances real-world productivity through greater proficiency with professional tools, stronger long-horizon task execution, and higher-quality deliverables. It can take on a wide range of creative and professional work, spanning 3D modeling, game development, precision manufacturing, finance, law, healthcare, and frontier scientific discovery. As a 24/7 AI teammate, Qwen4-Max keeps the big picture in view and moves projects forward, bringing ambitious ideas closer to reality and opening new ways for people and AI to work together.
Token efficiency and cost. Qwen4-Max outperforms Qwen3.8-Max with fewer tokens: on Work360, token usage drops by approximately 24% and 35% at Xhigh and High effort, respectively; on Terminal-Bench 4.0, the reductions are approximately 48% and 49%, respectively. We have also lowered API prices compared with Qwen3.8-Max, with particularly large reductions in cached-input pricing. In our Work360 evaluation, the average cost per task drops from $4.43 to $1.67 -- a 62% reduction.
Pre-training
Qwen4-Max is built on a new architecture for the Qwen4 series, with 2.4T backbone parameters, 71B activated per token, and an additional 328B N-gram Embedding parameters. The architecture systematically upgrades the sparse MoE model across attention, residual connections, and embeddings, improving computational efficiency, model capacity, and training stability:
GDN + Qwen Sparse Attention (QSA): Three Gated DeltaNet layers compress history into fixed-size states for every QSA layer. QSA uses a lightweight indexer to select relevant context at micro-block granularity, reducing both attention and indexing costs for long sequences.
Gated Residual (GR): Four parallel residual branches use dynamic read and write gates to strengthen information flow across layers and improve training stability.
N-gram Embedding: Context-based lookups provide representations of local token patterns at the second layer, expanding model capacity with little additional computation.
c23po ::
Cela arrive lorsqu'on traduit du français vers l'anglais et non vers le slovène. Malgré le règlement du forum, que les modérateurs ne respectent pas.
Računalniki nimajo spominov.
LiquidAI ::
Microsoft je 17.11.2026 izdal 7 novih modelov , ki so precej cenejši kot primerjalni Open AI/Anthropic.
MAI Cyber 2 Flash beats GPT-6 Astra's quality at less than 2% of the cost per task on the CyberGym-E2E benchmark.
MAI Code 2 reaches 98% of the coding quality of GPT-6.1 Sol at about 40% of the price. And against Opus 5.5, it reaches 96% performance for just 5% of the price.
MAI Code 2 Flash shows comparable performance GPT-6 Luna at 65% of the price, and Haiku 5.5 at 20% of the price.
MAI Image 2.7 is #1 on Artificial Analysis image editing, outperforming GPT Image 2.6 Sunburst (max) at just one-fifth of the price.
MAI Realtime 1 outperforms GPT-Realtime 2.1 and starts at just $0.01 per audio minute.
Dragon Copilot Transcribe is built on MAI Transcribe 2, the world's fastest and most accurate multilingual transcription model, and already powers 10 million patient encounters a month with multilingual error rates halved.
Decision 1.1 is the latest decision model from Microsoft, 50x faster and 79x cheaper than GPT-6.1 Sol.
Maia 200, Microsoft's second-generation AI accelerator, is now in production running our largest models, achieving 1.7x more tokens per watt.
Ponuja pa še "open weights" na njihovi Azure infra za velika podjetja.
MAI Licensed Weights brings Microsoft's frontier AI models into your own Azure environment, where you can adapt them to your business and safely integrate your proprietary knowledge and expertise. Your data and adaptations remain yours, with Microsoft only using them to train its models with your express agreement.
AT&T used MAI models to analyze 5G networks. For standard tasks, MAI outperformed GPT-6.1 Sol at just 1/50th of the cost.1 For more complex tasks, it achieved frontier-level performance at a significantly lower cost.
- spremenilo: LiquidAI ()
LiquidAI ::
Jezikovni modeli lahko sami spreminjajo svoje uteži
Jezikovni model na podlagi lastnega sklepanja sam spreminja svoje uteži in se izboljšuje, brez gradientov in brez učenja. To imenujemo samodejno spreminjanje: model je svoj lastni optimizator.
A language model can rewrite its own weights to make itself better, by its own reasoning and in one conversation, and this ability emerges with scale. A language model is trained once, frozen and deployed. Improving it again takes people who know pre-training and post-training, large clusters and a training pipeline; what a user can change by talking to it is its prompt, and a prompt is gone once the task changes. A human does not separate the two: the same brain that does the work changes itself, from each success and failure, with no separate training run. A frontier model has been shown to edit the weights of a much smaller one, work that names a model editing its own weights as future work [25]. We show, to our knowledge for the first time, that a large language model (LLM) can do this to itself: it diagnoses its own failure and rewrites the weights behind it, with no gradients and no training (Figs. 1, 2 and 3). Its own edit makes a 27B open model 6.6 points more accurate on 490 problems it never saw, in a paired test fixed in advance (Fig. 1). The edited model needs no new prompt, no harness around it and no extra computation per answer: the improvement lives in its weights.
enavlaka ::
"Drinking your own piss" Ai Style
Take skrite degenerativne spremembe ti lahko pokvarijo cel model.
Zanimiv pogled fizikov na trenutno stanje ai:
Tldr; ai je že uporaben za posamezna ozka področja, do splošne uporabe v fiziki bo pa še malo trajalo.
IgorCardanof ::
Tako so matematiki govorili 6 mesecev nazaj.
Ne odgovarjam na DM.
https://thinkingmachines.ai/news/inklin...
še en odličn model, k je pršu ven ta vikend za domače poganjanje. Dela kamot na 16GB kartah in je vsaj 2-3x hitrejši od gold standarda -- qwen3.8-27B
IgorCardanof je izjavil:
Tako so matematiki govorili 6 mesecev nazaj.![]()
Najprej so prišli po džuniorje, potem so prišli po matematike.
Samo resnično: trenutna situacija se lahko opiše zgolj kot "matematiki na aparatih", eni prav hiperventilirajo.
To vidiš ti ... jaz vidim matematike, ki se veselijo, da jim bo ai odpravil kup ovir v razvoju novih vej matematike in fantazirajo, kakšni novi svetovi se odpirajo :)
Perfection has been reached not when there's nothing left to add but when there's nothing else to take away.
Govna je v softver svetu že dovolj, ne rabimo dodatnega. Želim si, da folk začne uporabljat ai za peglanje obstoječih zadev in čiščenja vse nepotrebne navlake iz njih.
Ker je najboljsi lokalni model da fura na nvidia 5090. Sprašujem za frenda
qwen 3.8 flash-next z ram offloadom preko strate.
