Forum » Loža » Nizozemska: 30% znizanje stevila glav zivine
murrieta ::
Nizozemski kmetje so na okopih, zaradi zmanjsanja vplivov amoniaka in metana na okolje, bo potrebno za 30% znizati stevilo glav zivine.
Vir: https://www.euronews.com/green/2022/07/...
Skrajen cas je, da podobne ukrepe uvede tudi Golobova vlada.
At the heart of the protest are targets introduced last month to halve harmful nitrogen compounds by 2030. It is the latest attempt to tackle a problem that has plagued the country for years.
The government says that emissions of nitrogen oxide and ammonia, which are produced by livestock, need to be drastically cut - particularly near a protected network of habitats for endangered species that stretches across the EU.
The reforms are expected to include reducing livestock and buying up some farms whose animals produce large amounts of ammonia.
Farmers argue they are being unfairly targeted, giving them little hope for the future of their profession.
Stikalo ::
Traparija, bo pa imel sosed čez cesto 30% več živine. Tudi to je trapasto da imaš v EU co2 kupone, kitajci pa kurijo kolikor hočejo :D to je samo zmanjševanje konkurenčnosti.
l0g1t3ch ::
Nehajo naj subvencionirat meso pa se bo ršilo samo od sebe.
Ljudje ne rabimo pojest 100+ kg mesa na osebo/leto. Če pa kdo rabi naj pa plača polno ceno.
Wrop ::
Uvesti obvezen obrok žuželk za politike. Nizozemski kmetje naj jih gojijo in naj jim zagotovijo odkup po pravičnih cenah.
oemdzi ::
100 kg na osebo letno je občutno premalo mesa, se strinjam, sem bolj za med 200 in 300 kg na osebo letno!
*Črna grafična kartica z rumeno lučko in varčnim hladilnikom*
Neslišen intel procesor iz lepe modre škatle* 2 enakomerno ploščata rama*
*overclockan napajalnik in varno ohišje z modro lučko* Hofer gamer copate*
l0g1t3ch ::
Dej v rit si vtaknite te žuželke.
To so glupi startupi in hipsterji.
Lahko imamo čist normalno meso, z malo zmernosti.
Obilo užitkov ob raku in ostalih bolezni ti želim.
- spremenilo: l0g1t3ch ()
kuall ::
če že kaj bi uvedel, koliko kvadratov mora biti na glavo in te kvadrate povečat kar konkretno, ker zdej se gnetejo v majhnih smradečih vročih prostorih. saj ne vem kako mislijo zmanjšat 30%, to se da storiti na pameten način, kakršen je moj ali pa neumen. zmanjšanje števila živali tudi ni nujno slaba ideja, ker intenzivno kmetovanje je krivo kr za veliko trpljenja, ker so živali preveč nagnetene. treba je gledat tudi na počutje živali. živali je prav, da redimo ampak tiste, ki jih redimo morajo odživeti karseda uživancijsko življenje.
kuall ::
oziroma recimo raje karseda majhen pekel, ker večina štal je mučilnic, kakor je rekel en veterinar in se 100% strinjam z njim. rešitev je v bistvu to, da bi vsak zadaj na vrtu pasel živli, ki jih bo pojedel, te živali pa imajo velik pašnik in prost vhod v štalo. v bistvu starinski način, kakor imajo npr v zaostali ukrajini, če gledaš kak posnetek, da imajo vrt zagrejen in pasejo na njem razne živali. izgleda mau cigansko ampak živali tako najbolj uživajo.
- spremenilo: kuall ()
janezl ::
... in imajo srečno življenje in en slab dan.
Drugače pa kmetijstvo na naftni pogon (starodavno sončno energijo). Ja, tudi jaz sem se pripeljal na bencin v službo, nosim plastična oblačila, se grejem na plin in hladim na elektriko iz premoga.
Počasi (upam, da ne jutri), bom (v upanju na dolgo življenje in strahu pred smrtjo) postal stranka farmacevtov in drugih upa dajajočih združb. Vse zato, da bi omilil posledice mojih poskusov najti srečo: z vilicami in žlico, ter še kako drugače.
73 de Jani
zobnik ::
V nos jim gre ker eni meso jejo vsak dan in zato treba živino krmit z žiti, namest da bi se na žitna polja sadilo drugo zelenjavo....to moti veliko ljudi.
ginekk ::
mah, to je utopično. Drugač se strinjam, živali bi se morale past okoli, ne pa da se ne more premaknit iz boksa.
Vendar, če v splošnem lahko zatiskaš, zatiskamo, zatiskajo ušesa pred vojnami in mrtvimi - od Ukrajine do beguncev iz Afrike, ki se vsakodnevno vozijo s čolni čez mediteran. Potem je to zatiskanje še lažje za neke anonimne krave ali pa sosedovega mačka.
Začne se že doma, ravno včer sem videl kako je nek foter z najhujšim glasom nahrulil 4 letnega tamalga, ko nekaj ni takoj storil. Pa prejšnji teden mtko, ki je sedela s kolegico v baru. Je kar fajn za lase potegnila 3 letno punčko, ko jo je nekaj motila pri pisanju na smartphone.
- spremenilo: ginekk ()
Večina ne poje 2kg mesa na teden. Tako da to statistiko si nekam vtakni. Povprečna oseba ne zauzije 300g mesa dnevno.
Lol
murrieta ::
IL_DIAVOLO je izjavil:
Lol
Oseba morda res ne, povprecen slovencelj z zblojeno mentaliteto pa zlahka, malo pojdi pogledat izven Ljubljane, kaj jedo med malicami.
Sicer:
https://www.stat.si/StatWeb/News/Index/...
Prebivalec Slovenije je v letu 2020 porabil za prehrano povprečno 129 kg sadja, 119 kg zelenjave, 116 kg žit, 88 kg mesa, 64 kg krompirja, 10 kg jajc in 1 kg medu.
In to je povprecno, v Ljubljani se ga pozre manj, vsenaokrog pa vec, s tem, da so tu upostevani tudi otroci, tako, da gre zadeva pri odraslem prebivalcu kar veselo na 100kg / leto.
Ampak bistvo je zmanjsanje izpustov metana v okolje.
- spremenilo: murrieta ()
link_up ::
Bi ti znal torto zrezati na tri ali sest kosov?
In and Out
Koliko rabiš bio govedine?
Niso, gre za isto skupino, ki je odgovorna za vse pomembnejšie agende v zadnjem času, in teh ni malo.
Zanimivo kako eni takoj zagrabijo agendo. Kaj ni dosti solate al kako?
In to pri profesionalnih trolih.
- spremenilo: 49106 ()
Sej kurijo, zato da se ti deres da imajo vec izpustov, kot zahodnjaki, po drugi strani pa zahodnjaki superativiziramo v izpustih na prebivalstva. Lahko proizvajas tudi v eu, samo potem zelenih v nemciji nebi bilo na oblasti. kot kaze ce bo slo tako dalje, verjetno ob naskednjih volitvah ne pridejo v parlament.
FoxKnox ::
Da bi pa metan uporabili za energijo za napajanje kmetije, vsak za ogrevanje pa ni interesa države on lokalcev.Vsa tehnologija že obstaja in nekaj pilotnih projektov dobro funkcionira, samo ker bi morala država to subvencionirat in od tega ne bi bilo dajatev to ni nikomur v interesu.
TheBlueOne ::
Ali pa so zadeve drage in komplicirane?
murrieta ::
Ne vem, ce ti je jasno. Kmetje bojo sami "subvencionirali" uporabo metana, ali pa bojo znizevali proizvodnjo (30% na Nizozemskem, zelo verjetno bo enako tudi pri nas), za koji kurac bi drzava (se pravi jaz in ti in vsi z drzavljanstvom - saj to razumes, mar ne? Da ni drzava neka famozna tretja institucija iz nebes ampak si to ti in vsi ostali Slovenci in kaj - iz svojih davkov bos placeval za to? Si nor?), subvencionirali odpravo skodljivih posledic dejavnosti nekoga? Ce se ukvarja z industrijo pridelave odpadkov, naj se pospravi za sabo, za to, da mu do zdaj ni treba je lahko samo hvalezen.
TheBlueOne ::
Lahko, da je v interesu vecine. Ce bi vecina imela stabilno ponudbo govedina, potem zna biti, da je treba kolektivno investirati. Ce nam je OK kar prinese mednarodni trg in gremo na riziko, potem ima verjetno manj smisla. Kmetu ta kompleksnost pac ne prinese nobenega plusa, prej je tecno.
Pac moras vedeti, da ce tujina to subvencionira in s casom prevzame trg, potem izgubis branzo, kar pa hitro dolgorocno stane vec kot pa subvencija v pravem casu. Se ne spomnem kateri ekonomist je izjavil nekaj v stilu "Malo denarja pravi cas je vredno vec kot ogromno denarja ko je prepozno.". V glavnem moras poznati stevilke, drugace tezko poves kaj pametnega. Jih poznas?
- spremenil: TheBlueOne ()
murrieta ::
TheBlueOne je izjavil:
Je v interesu vecine, pa je vecina prevec zabita, da bi razumela, da je to v njihovem interesu. Kaj bos pa takrat? Ker poti nazaj ne bo.
Trenutno ne-tujina subvencionira proizvodnjo "mesa" in metana.
TheBlueOne ::
Kdaj jih pa je se kdo uposteval? Zato pa imamo tak politicen sistem. Stiri leta se pritozujejo, vse pozabijo, politika pa jim pokaze koncne stevilke. Za nazaj pa tako ali tako ne gledajo kaksne budalascine so izumljali.
Iz spletnih tehnokratov, politikov in Davos sanjačev narediti kotlete pa bo mesa dovolj za vse.
- spremenil: Miki N ()
murrieta ::
Iz tehnokratov in Dovos sanjačev narediti kotlete pa bo mesa dovolj za vse.
Ja, ampak tvoji otroci bojo vseeno ckrnili v mad-max sceni. Namrec, to, da ti zanikas znanost, se ne pomeni, da nima prav.
Je pa res, da se tebi ni treba bati, da se bos razplodil. Se tista kurba, ki jo bos placeval, bo splav naredila. In zato ti je vseeno.
TheBlueOne ::
kuall ::
krmljenje živine z žiti je ok. večji profit narediš tako, ker več kot ima kg bik ali mleka krava več je profita od njega, ker nek velik procent energije gre za dnevno vzdrževanje življenja, surplus pa gre v mleko/meso. plus živina uživa, ker je to zanje kot sladoled. torej sami plusi. jaz sem letos posadil 30 arov koruze, da bosta 2 bika na velkiko žrla koruzno moko, pač v mejah normale, kolikor je zdravo. letos btw vse raste extremno dobro, ker namoči vsakih 10 dni, ne tako kot lani, ko je ta čas že hudo tolka suša.
TheBlueOne ::
tony1 ::
murrieta ::
Manj mesa je odlicno za vse. Na zivce mi gre financirati operacije ozilja masnojedcem
Cisto mozno, da ti gre na zivce, samo vecina diktira, denar diktira itn. Vsaka drzavna pomoc gre na zivce dolocenem odstotku ljudi, ker preprosti ljudje bi samo to, kar koristijo sami.
Podnebje pa diktira in zadeva vse prebivalstvo, ne samo Slovenije, ampak planeta.
Torej je podnebje bolj pomembno od egoisticnih interesov zivinorejske industrije.
Ce bi bili zivinorejci dovolj inteligentni, da si ne bi sami srali v lastno hrano, bi sami omejili pridelavo.
Pa niso.
Zdaj bojo dobili pa drzavno pomoc, da ne bojo nadaljevali samodestruktivnih praks na skodo vseh, njih in vseh ostalih.
Saj, naj te citiram: "Vsaka drzavna pomoc gre na zivce dolocenem odstotku ljudi, ker preprosti ljudje bi samo to, kar koristijo sami.".
Vem, da se bos rade volje strinjal z lastnim stavkom.
kriptobog ::
Nehajte zret govedino vsak drugi dan, pa ne bo potrebno nobene prisile. Samo nocete, a?
Ne. Jo raje vsak dan.
Bolj bednega ukrepa pa še ne.
Ti si gotovo še premlad, da bi v 90ih gledal ZF serijo SeaQuest, kjer so lepo povedali, da bo zaradi metana v njihovih prdcih v prihodnje govedina prepovedana?![]()
Pa se svinjina in fizol bosta prepovedana, da te ne bo napenjalo po pasulju, da ne bos se ti metana sproscal.
- spremenilo: kriptobog ()
49106 ::
Kmetijske subvencije so smiselne za razliko od subvencij za električne avtomobile ali elektrarne. Pri slednjem zgolj financiramo zelene, ki si zeleno energijo lahko privoščijo, ne pa tiste, ki to najbolj potrebujejo in kurijo odpadna drva, ter vozijo 30 let starega dizelaša.
FoxKnox ::
Verjetno se zavedate kaj sploh je subvencija kmetijstva ? Pomoč države kmetu od katerega sadove dela uživamo vsi državljani.Pomeni kvalitetni izdelki za zmerno ceno.
Kot me ima za norega @ Murrieta zaradi državnih subvencij.Da, se strinjam, pri uvedbi te tehnologije je državna pomoč ključna, ker bo korist za vse nas.Ali pa jej govedino iz vzhodne evrope, ki je nabutana z steroidi.Z zmanjševanjem glav v hlevu se zmanjša tudi dohodek in si hitro na negativni strani.
Sigurno je pa treba zmanjšati industrijske farme z več sto glavami in subvencionirati manjše kmetije z nekaj deset glav živine.
Kar se0 pa tiče stroška koriščenja metana : Investicija se povrne prej kot pa tale maraton s SE .
Da ti kar razlagaj buticno proizvodnjo, ta
Drugace pa je realnost sledeca
Daniel ::
Si pripravljen plačati svojo škodo pri bencinu/letalski vozovnici p0F?
Ampak vseeno je kapitan z veseljem zagrizel v hamburger, preden ga je vrgel proč...
Pa niso.
Hashtah, sem Tele... V Sloveniji proizvodnja pada, isto kot na Hrvaškam, ampak ti tega nisi sposoben dojet, zato tudi taka oznaka.
- spremenil: Daniel ()
Daniel ::
Ta primejava je povsem brezvezna in je zgolje lep prikaz, kam te pripelje čisti kapitalizem. Oni so krepko krepko pretiravali v proizvodnji v bitki za dobičkom, ker jih je sistem silil v to. Na koncu ni problem v pridelovalcu ampak v sistemu, čeprav vsi vemo, da vsi najraje serjete po kmetu, ki je zadnji in obenem prvi v verigi, ker si proti ostalim ne upate.
Da se en ki misli da bo z dvema bikoma in par molznic innnekaj kur zadovolil prodajo mesa v mercatorjevi trgovini. Sem preprican, da merkator proda toliko mesa kot si ga ti s svojo buticno proizvodnjo pridelal v eni generaciji, v roku nekaj minut od odprtja trgovine.
Glugy ::
Nč hudga sej ni živina edini vir kalorij. Bomo pa dvakrat premislil kdaj si bomo za višjo ceno privoščili mlečne izdelke in meso. Dokler ni lakote smo dobri , živimo v luksuzu pa tud če imamo dolgoočasno hrano.
Daniel ::
Seveda ne moremo. Ampak to nas spet privede k izvoru problema. Nočete ameriškega sistema reje, kjer je žival zadnji drek, izpostavljena soncu v praktično puščavi, Slovenski sistem pa je premajhen za naše trgovce.
Ti kar, saj vemo kam ciljaš in da te obide slabost ob mlečnih in mesnih izdelkih... Pač vsakomur svoje.
l0g1t3ch ::
Slovenski sistem je premajhen za razvajene riti, ki bi pojedle 100kg mesa/osebo/leto. To je primarni problem.
Če bi vso meso gojili tako kot na idealiiranih slikah s kravicami na gorskih pašnikih, bi bila kila po 100€ in bi ga jedli nekajkrat na mesec.
Pa ne bi bilo nobenega problema z preveč metana, pa preveč porabe vode, antibiotiki v mesu itd ...
Daniel ::
V Sloveniji že v osnovi nimamo problema s tem, Hrvaška še manj. Ne posplošuj težav drugih držav k nam.
l0g1t3ch ::
Če v sloveniji pojemo 40kg govedine na osebo, to pomeni da 10 ljudi pohrusta enega bika v enem letu.
Ali drugače rečeno slovenci pojemo 200k bikov v enem letu.
Samo z neko idealizirano pašno rejo tega ne pridelamo v Sloveniji.
tony1 ::
"Ampak vseeno je kapitan z veseljem zagrizel v hamburger, preden ga je vrgel proč..."
Res je, ni ga upal pojesti do konca, ker je bil zamrznjen cela desetletja...
Kapo dol, tudi na tako izgubljenem forumu se najde kulturne ljudi
| » | Dva dni brez mesa ? (strani: 1 2 3 4 5 6 )Oddelek: Loža | 51578 (45353) | 111111111111 |
| » | IPCC: Ukrepati je treba takoj (strani: 1 2 3 4 … 9 10 11 12 )Oddelek: Novice / Znanost in tehnologija | 131146 (119885) | Daniel |
| » | Moralni in ekološki vidiki prehranjevanja (strani: 1 2 3 4 … 17 18 19 20 )Oddelek: Loža | 192377 (159330) | razerznak |
| » | Kitajska študija, Avtor: Colin Campbell (strani: 1 2 3 4 5 6 7 8 )Oddelek: Problemi človeštva | 128134 (114934) | Smrekar1 |
