Forum » Loža » WTC_What Was In Building 7 in kaj se je dejansko dogajalo 9/11 -
CoolBits ::
But when you need to bring down a massive structure, say a 20-story skyscraper, you have to haul out the big guns. Explosive demolition is the preferred method for safely and efficiently demolishing larger structures. When a building is surrounded by other buildings, it may be necessary to "implode" the building, that is, make it collapse down into its footprint.
The basic idea of explosive demolition is quite simple: If you remove the support structure of a building at a certain point, the section of the building above that point will fall down on the part of the building below that point. If this upper section is heavy enough, it will collide with the lower part with sufficient force to cause significant damage. The explosives are just the trigger for the demolition. It's gravity that brings the building down.
Demolition blasters load explosives on several different levels of the building so that the building structure falls down on itself at multiple points. When everything is planned and executed correctly, the total damage of the explosives and falling building material is sufficient to collapse the structure entirely, so cleanup crews are left with only a pile of rubble.
Več tukaj:
http://science.howstuffworks.com/engine...
Super Sonic ::
"Za zgradbo št. 7 se že ve, da je dokazano padala po kriterijih načrtnega rušenja" SS
"Ni res." Hamax
"Torej, boš vedel povedat, zakaj se gospod (od 6,59 glej naprej) laže? " SS
Video spodaj link - Vir AE.
"Ne, rekel bom samo, da gospodje na koncu ocitno se niso slisali nacrtnega demoliranja stavbe. Poisci kak video pa bos slisal veliko razliko v glasnosti. Jaz na nobenem od teh posnetkov ne slisim eksplozij.
Btw, kako hitro pa naj bi padala stavba, ki ni nacrno zrusena? " Hamax.
SS poda link:
Hamax obsedi v tišini.
Kdo laže? Da ne bom zahteval opravičilo.
"Ni res." Hamax
SS poda link:
hamax ::
A sem kje rekel da ni padla priblizno tako hitro kot prosti pad? Nisem.
Je to edini kriterij za nacrtno rusenje? Ni.
Torej? Ti kar zahtevaj opravicilo.
Arto ::
Point je, pri načrtovanem rušenju se zruši cela stavba naenkrat, ne pa da se vrh stavbe zruši na ostala nadstropja in jih podre. Prav tako se naj ne bi zrušil takole postrani, ker je potrebno zminimizirati škodo na okoliških stavbah.
Super Sonic ::
"Je to edini kriterij za nacrtno rusenje? Ni."
Ni čist edini, več kot očitno pa strokovnjakom veliko pomeni. ;)
Ma ne rabim opravičila, še najmanj. Iščem samo resnico in tisto, kar bi bilo najbolj verjetno. Ampak nimam v naprej zabetoniranega mnenja o tem, ker stvari so se spremenile.
Hvala za izjemno pomoč pri tem, ker tvoji odgovori to so. Izjemni.
Banč of politics here, guys (+ obtožbe, da so nasprotniki razni Danny Šmiti in Jelke Strojan). Čist mim.
CoolBits ::
Lahko če ga najdeš, ni problema.
Če ga pa slučajno ne najdeš pa to ne pomeni, da ni možno
ampak samo, da ne najdeš.
Ziga Dolhar ::
Če ga pa slučajno ne najdeš pa to ne pomeni, da ni možnoampak samo, da ne najdeš.
Zaželjena je argumentirana debata. Pravila & Burden of proof - Wikipedia, the free encyclopedia. Opozorilo.
https://dolhar.si/
CoolBits ::
Sem večkrat podal povezavo kot argument... a po novem je posnetek obvezen del argumenta?
rndm2008 ::
Kot sem že rekel, razen forumskega gobcanja se še ni našel STROKOVNJAK, ki bi v peer-reviewed študiji ovrgel Harrita in ekipo. Ga še ni bilo, v približno dveh letih od objave študije.
Ni dokaza, da je nanotermit iz WTCjev?
, ja, od kje se je pa potem vzel? So ga podtaknili trutherji? Kako je pa nastal?
Bi bil kar soliden začetek, ja, če kdo od slotek intelektualne elite pokaže, kako se nanodelci aluminijevega oksida lahko tako natančno, v plasteh, zmešajo z železovim po naravni poti. To bi pa bilo nekaj. Mogoče bi Jest10, al kaj je že, vešč mikroskopiranja, vpregel svoje sile.
Namesto tegale praznega natepavanja prestrašenih debunkerjev.
V VSEH vzorcih (tudi NIST-ovih oz. FEMA) so najdene kroglice železa, ki so stranski produkt termitske reakcije. Ampak po slotek interpretaciji so le-te menda od švasanja tistih par ostalih stebrov med cleanupom,
. Ok, zamižimo na eno oko, pa gremo dalje. Torej, od kje je pa nanotermit, če ni iz WTCjev?
AE911TRUTH
All Hail Thermal Expansion!
bluefish ::
Nehaj že s tem nanotermitom in beri:
Nano-thermite has been talked about but its uses fall far short of cutting these massive columns. It's in its research stage. They include possible uses for welding molecular devices and possible use as a heat signature flare decoy. Then there is a patent of a device which has been brought up but as of yet, there is no evidence the idea went any further. Does it even work? Even if it did, they are "Ganged" together to make the cut. You would still need these boxes all over the columns. Once again the answer to this from the "scholars" is "rationalized technology". They need this technology to exist so it exists. There is some secret super thermite which can be placed in a canister which can survive 1,100 degree C so the primary charge doesn't go off. "Gee debunking, you're so dumb."
bluefish ::
Sem večkrat podal povezavo kot argument... a po novem je posnetek obvezen del argumenta?Tisti tvoj link iz HSW kaže ravno eksploziv pri dnu in nato še pri vrhu. Prav tako sliko kažejo rušenje, ki se prične na dnu. Kak dokaz je to torej v prid teoriji kontroliranega rušenja, ki se prične na vrhu?![]()
CoolBits ::
Rušenje se lahko prične, kamor paše minercem in po dogovoru... lahko tudi pri anteni na vrhu.
Da je bilo minirano tudi v kleti in nižje je pa dosti pričevanj.
bluefish ::
Te "čistilke" so pa bile po eni strani res domiselne (nameščanje eksploziva po jaških), po drugi strani pa za en drek (eksploziv v kleti, ki na koncu nima efekta, črne skrinjice). Ah, ta genialnost.
Zanimivo je, da v eni sapi trdiš, da so stolpnice predimenzionirane in lahko zdržijo dodatno težo padajočih nadstropij, kljub vsemu pa je pri miniranju vseeno, če se začne pri anteni in ima enake posledice.
- spremenil: bluefish ()
CoolBits ::
Čistilke niso pojma imele v bistvu :)
Škoda ko se nekateri nalasc neumne delate.
Bistvo miniranja je oslabit konstrukcijo tolko da ne zdrzi svoje teze in pol rabis se triger reakcije nekje, lahko spodaj al pa zgoraj.
PaX_MaN ::
Peer rijuvd? Če glavna urednica odstopi, ker so tole "raziskavo" objavili kar mimo nje - v žurnalu, ki nima niti malega veze s temo raziskave - in če eden izmed avtorjev izjavi, da 'pozna dva rivjujerja, ampak ju ne izda, ker sta v principu anonimna', potem se lahko vprašamo o krediilnosti objave.
Kot sem že rekel, razen forumskega gobcanja se še ni našel STROKOVNJAK,[...] Ga še ni bilo, v približno dveh letih od objave študije.
O, saj je:
Abstract: A recent paper claiming "active thermitic material" in dust collected in the vicinity of the Twin Towers after their collapse is found to have shortcomings in its methodology.
The paper also fails to explore adequately alternative, non-thermitic explanations for its findings.
Specifically, the paper's use of methyl-ethyl-ketone (MEK) to demonstrate the presence of elemental aluminum is known to yield inconsistent results because MEK could react with aluminum;
alleged elemental aluminum nanoparticles are claimed to remain unreacted after 55 hours of MEK bath, but also contradictorily to react violently already at 430°C;
photographic and spectral comparisons between commercial thermite and spheroidal particles in Ground Zero dust omit any other comparison with possible alternative sources of such findings;
DSC analysis was conducted in air, but should have been conducted in an inert gas environment in order to obtain reliable results for thermite, which does not require an external oxidizer.
The paper also does not consider the chemical composition of the corrosion-proofing paints and of the vermiculite used as thermal insulation and soundproofing at the World Trade Center and extensively documented by NIST.
These products contain exactly the same elements and exhibit the same structural characteristics as the allegedly thermitic material found by the paper's researchers in their samples.
The researchers therefore appear to have been somewhat hasty in reaching their conclusions.
XsenO ::
Hmm ne morem verjeti eno leto je že spet mimo in ljubitelji USofA spet poskušajo braniti svojo ljubo, nezmotljivo in mogočno deželo deželo z pravljicami o super naprednih materialih/ekslozivih, zigzag raketami, droni itd... Na žalost pa vidim, da gre le za pogrevanje 1-3 let stare juhe.
Spet je govora o slišanih POSAMEZNIH eksplozijah, ki po njihovih trditvah prihajajo od eksploziva namenjenemu demoliciji (kateri kolikor vem iz neštetih pogledanih posnetkov rušenj vedno pridejo v rafalu). Zraven pa povsem zavračajo možnost, da lahko so te "eksplozije" povzročene s strani naprav/materialov pod pritiskom kot so razne pipsne, gasilni aparati, boilerji...(za primer eksplozije slednjih dveh so pri mythbusterjih naredili nekaj lepih poskusov :) )
Spet je onemnjen pentagon le, da ga tokrat namesto enega tomahowka so to bogo stavbo zadeli ne manj kot trije. Seveda so te 3 rakete spet zig zag podirale luči.
Lanska nova zvezda debate, je bila raziskava Harrita in bande. Če me spomin ne vara sem že lani po prebrani študij omeni, da niso nikjer preverili za morebitne druge vire delcev, možnosti kontaminacije vzorcev in vprašljivosti pristonsti same publikacije glede nato, da je Bentham Open že znan po tem, da so pripravljeni objavite vse kot "peered review" za pravi denar. Glede na to kar je zgoraj napisal PaX_MaN sem že takrat popolnoma zadel.
No danes pa je med "dokazi" se pojavila nova zvezda in sicer .gif rahlo boljše kvalitete od tistega s pentagona, kjer se naj bi vidlo "bruhanje" termita. No glede tistega .gif bi imel nekaj vprašanj preden dodam končno mnenje.
- Se, da kje dobiti posnetek iz katerega je gif nastal?
- Zakaj levi del gif-a izginja z vsakim frajmom? -
- Se, da kje dobiti podaljšan gif, kjer se vidi tudi vsaj 3-5 framov po končanem "bruhanju"
- Zakaj med in po bruhanju ni nobenih opaznih sprememb na steni stavbe v območju kjer se je "bruhanje" dogajalo?
Ajde mejte se
Ajde mejte se
1 + 1 = 1
- spremenil: XsenO ()
V-i-p ::
Nisem ne na levi in ne na desni strani. Kar se je zgodilo, briga me :). Ne bom zagovarjal nobene strani, ker se na te reči ne spoznam. Sem pa "otrok tehnologije" in edino kar bom do smrti trdil okoli 9/11 je tole: tisti objavljen posnetek kamere izpred Pentagon-a je ena velika buča. Zakaj? Zato, ker sem že sam takrat imel Logitech web kamero, za katero sem navdušenec odštel čez 30 tisoč tolarjev in sem videl več, veliko več. Pa je bila velika in grda in da ima najbolj varovana stavba na svetu tako krš robo, ne tega pa ne bom verjel :).
- spremenil: V-i-p ()
rndm2008 ::
Če bi bral manj površno, Kseno, bi videl, da je zraven gifa tudi link na cel video, kjer se cedi tekoče železo. Črni rob se pojavi zaradi stabilizacije slike, kar vzame tudi nekaj ostrine. Ampak trutherji zihr kej potvarjajo, kaj?
Kseno:
Slabo veš. Bajte med postopkom demoliranja postopno mehčajo, lahko tudi po več tednov, odvisno od več dejavnikov. Najprej porežejo samo določene točke, preverijo, če je vse v redu, itd. In bajta lahko kljub resnim poškodbam stoji še v nedogled. Lahko jo dejansko poruši le "zadnji" charge. Kar pozanimaj se malo bolj.
Se bil ti tisti, ki si zagovarjal, da tisti policaji pri telefonski govorilnici pravzaprav slišijo le "kakšno eksplozijo gasilnega aparata"? Ali si to na JREFu pobral? :)
Ja, napadi na Bentham Open so se začeli takoj po objavi nanotermita, ena od umazanij pa je bilo podtikanje člankov s strani "debunkerjev", ki se niso znali lotiti vsebine, so se pa lotili kurirja. Znano, bedno.
Enako tukaj. In o kakšni kontaminaciji nanotermita sanjate? V vsakem primeru ostaja vprašanje, od kod se je snov vzela. Geniji... Geez.
Kdo ga je ustvaril, no? Trutherji? Nek magičen naravni proces med kolapsom? Med požarom? Da so nastali takšni koščki fino zmešanega materiala?
Navsezadnje, če je študija res tako majava, bi jo že zdavnaj debunkali, ne pa skušali očrniti ugled revije, ki jo je objavila, kar je bil maksimum, ki so ga skupaj spravili debunkerji. Skratka, enako paglavski odnos, kot ga izkazujejo debunkerji skozi ves čas. Ko ne zmoreš sesuti vsebine, napadaj kurirja.
Da zanemarjanja kršenja fizikalnih zakonov niti ne omenjamo. To je itak osnova. NISTovo priznanje prostega pada pri sedmici in tragikomično ignoriranje tega dejstva, češ, da v končni fazi to slike kolapsa ne spremeni, bodo za končni "conviction" dovolj. Samo, ko bo dovolj politične volje (pritiska množic), da se prave kriminalce zgrabi za vrat.
Do naslednjega zbira "nejasnih zmazkov", have a nice time
Kseno:
AE911TRUTH
BigWhale ::
Ajde, bodi junak in svojo web kamero uporabi za snemanje vhoda v hiso. Resno.
Web kamera in nadzorna kamera sta nekaj povsem drugega.
imagodei ::
Še enkrat bi prosil razne modre može, ki nam pojasnjujejo, da je bil v Dvojčkih eksploziv, naj pojasnijo sledeče:
Kako so spravili ustrezno količino eksploziva v stavbe, ne da bi to opazilo tisoče zaposlenih? Kdaj v predhodnih tednih, mesecih, so zvozili tone (nano)termita v zgradbo? Kdaj v predhodnih tednih, mesecih, so po dvojčkih vrtali in pripravljali vse za miniranje?
Ideja je zanimiva, všečna, pogojno celo verjetna. Problemček je le, ker se na S-T zahteva argumentirana debata. Če ne zmorete pojasnit, kako so tone eksploziva prišle v zgradbo, lahko na tem mestu zaključimo. Mission impossible in Oceanovih nevemkoliko so ZF; v Dvojčkih je umrlo precej ljudi, tudi varnostnikov, ki so bili zagotovo obveščeni o vseh delih na zgradbi in če bi nekdo "švercal" na tone eksploziva ter vrtal luknje v jedro zgradbe, bi se zgodilo sledeče:
- ali bi zadeva prišla v javnost pred 9/11
- ali bi imeli kar nekaj mrtvih varnostnikov, ker bi bilo treba zavarovat tajnost operacije; spet bi to prišlo v javnost pred 9/11
- če so bili pa varnostniki podkupljeni, jih pa na 9/11 v zgradbi ne bi bilo.
Jaz se povsem strinjam z vami, da uradna verzija gotovo ni najbolj verjetna. Problem glav, ki imajo preveč časa, da premišljujejo bedarije je pa v tem, da mislite, da je možno zaroto takšnih razsežnosti obdržati v tajnosti, če zanjo ve več tisoč ljudi! Ni možno! Že ena afera Patrija pride na plano; ali pa Watergate, če hočete... Ali pa streljanje na civiliste v Iraku (?) iz Apacheja. Halo? Tisoče ljudi ve za te operacije, pa nihče nima slabe vesti, nihče ponoči ne spi? Nihče ni potožil svojemu psihoterapevtu? Nobenemu se še ni utrgalo in še ni končal v psihiatrični ustanovi, kjer bi cele noči kričal, da so ZDA zminirale Dvojčka? Nihče iz tega kroga tisočih sodelujočih še ni bil označen za security risk in se še niso začele dogajati čudne nesreče?
To cut the long story short: spet imate izpade in spet se vas je lep čas toleriralo. Zdej je pa čas, da pustite blodnje za sabo in pokažete argumente. Kako in kdaj je (nano)termit prišel v Dvojčka?
- Hoc est qui sumus -
Arto ::
Zakaj mora biti pa tista svetleča stvar ravno staljeno železo? Ne more biti staljena plastika, naprimer? Ali pa mogoče aluminij?
CoolBits ::
Glede vnosa eksploziva ni problema... to je bil "material" za obnovo dvigal.
Inglede na to da je imel wtc mechanical floors
World Trade Center @ Wikipedia
Tam zato ni bil problem postavitve eksplozivov.
In glede da se je izvajala "obnova" dvigal... pa tudi hrup pri vrtanju ni nič posebnega ali nenavadnega.
Of the 110 stories, eight were set aside for technical services in mechanical floors Level B5/B6 (floors 7/8, 41/42, 75/76, and 108/109), which are four two-floor areas evenly spaced up the building. All the remaining floors were free for open-plan offices.
Super Sonic ::
Pravo vprašanje pravzaprav je, kaj "nanotermit" sploh dela tam, ne pa kako so ga vozil notri. Najprej je potrebno odgovoriti na to vprašnje, potem pa se vprašati kako je prišel tja.
Odgovorov na to je več - tisti z bujno domišljijo vam bodo povedal da so nanotermit notr vozil s karjolo ali pa, da ga je avijon imel pripetega na trup. Dejstvo pa je, da nobena stvar ni ravno verjetna, ampak po drugi strani pa, nanotermit je bil najden v prahu. Jaz sem prepričan, skladno s stroko, da če tega termita ne bi bilo, dvojčka ne bi padla.
Jaz res ne vem, ali je tako težko postavit neko maketo v meri 20:1 in poslat frčoplan notri, ter vsaj okvirno razrešit stvari. Za varnost države gre, madona.
p.s
Človek kar težko verjame, da lahko pena podre Shuttle, ampak če je interes se zadevo jasno in javno testira in potem je mir.
p.s
imagodei ::
@CoolBits,
seveda se hecaš? Ker na "Mechanical floors" res niso imeli nobene kamere, vsakdo se je tam lahko prosto sprehajal, ni bilo nobenega varnostnika tam?
Ta nadstropja so ključna za celokupno delovanje visokih zgradb. Če odleti vodna pumpa, zgornja nadstropja nimajo vode - niti za gašenje začetnih požarov.
CoolBits ::
Aha pol sigurno kje obstajajo posnetki teh kamer, ne? Kdo pa jih je pregledoval, nekdo od njihovih mogoče al nemogoče?
Par mesecev pred napadom je WTC dobil novega lastnika :)
- spremenil: CoolBits ()
imagodei ::
Jah, modri mož... Ti trdiš, da bi bilo na posnetkih kaj videt, ne jaz. Jaz trdim, da na posnetkih ne bi bilo videt nič posebnega. Kaj se zdaj sprenevedaš in odvračaš pozornost? Zakaj bi posnetke kdo gledal PO 9/11? Uradna razlaga itak ne govori, da bi (nano)termit kdo tam polagal.
Zadevo bi odkrili oz. morali odkriti, ko bi nastavljali eksploziv. Kdo? Ja, varnostniki, zaposleni tam. Mal si naiven, če misliš, da za varnost v 100-nadstropnih stolpnicah, kjer imajo sedeže mnoga pomembna podjetja, skrbijo taki "varnostniki", kot jih najdeš pri nas v Globalu. Jaz sem prepričan, da pri vsakih posegih v jedro takšnih stavb sodelujejo tudi gradbeni inženirji in da protokol narekuje, da brez petih štemplov nihče nima kaj vrtat v nosilne stebre. In brez nadaljnega sem prepričan, da so bili varnostniki toliko usposobljeni, da bi takoj odstranili vsakega, ki bi brez ustreznih papirjev delal kakršne koli posege.
Še enkrat, niso to varnostniki, kot jih najdeš pri nas v Globalu in katerih edina naloga je ustrahovat obiskovalce.
In, ko smo že pri tem, kdo naj bi pregledoval posnetke - spet, a še dodatne ljudi so imeli zarotniki? Zdej jih še 5 več ve za zaroto, pa nihče nič ne pove?
Tale tema in predvsem zmožnost argumentiranja glavnih akterjev, ni vredna počenega groša.
CoolBits ::
Jah pač ima uradna razlaga polno lukenj, zato pa se jih polni na tak način... ma kaj lukenj, celih kraterjev...
imagodei ::
Nikakor niso manjši teli vaši kraterji. Ogromni so. Mnogo večji, kot pri uradni razlagi. Da pojasnete eno luknjo, si izmislite nek scenarij, kjer potem dobite 10 novih lukenj za poflikat.
Kje je ugrabljeno letalo, ki se po vašem NI zaletelo v Pentagon? Kje so potniki? A so jih zapeljali na dno oceana? Lost, much?
Nebo nad ZDA nadzoruje v vsakem trenutku vsaj nekaj 100 kontrolorjev leta - a so vsem zagrozili, da jim bodo pobili familije, če bodo povedali, da je tist avion v resnici odletel direkt v Bermudski trikotnik, kjer se je za njim izgubila vsaka sled? In v skoraj 10-letih se še vedno ni nihče upal oglasit, pa povedat, kje se nahaja to letalo? Kaj pa tisto, ki je treščilo v tla in ga baje tudi ni bilo? Po vaše spet podobna zgodba? Charles Widmore?
In zdej tale termit - ja, fajn bi ga blo imet v WTC-ju, samo kako je prišel tja? Odgovora se seveda izogibaš.
In ko zmanjka argumentov, daš komentar, da ima uradna razlaga polno lukenj. Super, ker ima polno lukenj, bomo nekaj neargumentirano nakladali. Posluš, pa saj ne veš, zakaj ima polno lukenj - mogoče samo nimaš dovolj visokih pooblastil, da bi prišel do posnetkov varnostnih kamer na Pentagonu. Mogoče so bili posamezniki v ameriški vladi res vmešani v to godljo. Mogoče. Ne morete pa blebetat o najverjetneje tisočih sodelujočih, od katerih še nihče v desetletju dolgem obdobju ni dobil napada slabe vesti in priznal vpletenost. Ne morete sanjat o nemogočih podvigih, pa če še tako krasno izgledajo.
CoolBits ::
Kako je prišel termit tja, mislim da bi morali vi povedat... našli so ga in to je dejstvo.
Tukaj pa lahko pišemo svoje teorije... nekateri z izginulimi letali pretiravajo ampak vseeno.
Kar sem jaz povedal ni nič nemogočega in vse lepo izvedljivo in logično.
dzinks63 ::
Vprašanje kdaj so termit našli? A so ruševine po podrtju zavarovali in povzorčili vse skupaj. Ali pa so termit našli po tem, ko so delavci podrli in porezali ostanke od železnih konstrukcij?
hamax ::
A zdej se strinjamo, da rusenje wtc-jev ni izgledalo kot nacrtno rusenje? Vsaj ne tako kot vsa posneta ali slikana rusenja?
Ter kje je kontrola. Morda je nano termit(ki je btw neuporaben za rusenje) pogost pojav na tistem mestu. Morda ni.
Ne strinjam se.
hamax ::
Ne strinjam se.
A lahko pol vidmo kaksno kontrolirano rusanje, ki izgleda vsaj podobno kot rusenje wtc-ja?
Pyr0Beast ::
Sem že bral enkrat, ko je bil sam eksploziv skrit v konstrukcijo štadiona (zabetoniran), kjer so potem lepo šiclni predsednika, brez da bi se ta zaveda nevarnosti :)
CoolBits ::
Bom kar prilepil en star post.
No, če povzamem nekaj vaših bluzov:
- eksplozije so bile od vsemogočega, samo od eksplozivov ne (zdaj se je pojavila celo potapljaška jeklenka, haha). Kit, samo toliko, za informacijo, v teh stolpnicah si kofetkov ne kuhajo na plinskih bombah, toliko, da veš. No, naštej še kaj, kar bi po tvoje povzročalo eksplozije.
- Dalje, priče, ki opisujejo staljeno jeklo in eksplozije, so le slave lačni luzerji, ki lažejo, da lahko po TVju pozdravijo svoje mame.
- Termit, ki so ga našli, je prišel od bogvekje, le iz WTCjev ne.
- Napačna navedba o številu in imenih teroristov v uradnem poročilu je nepomembna, tudi če je namerno napačna.
- Da NORAD ni poslal niti enega letala, je le naključje ali nesposobnost.
- Da končno poročilo sploh ne omenja WTC 7, ni nič čudnega, ker je itak samo kolateralna škoda. Termalna ekspanzija jekla je (prvič v zgodovini) simetrično podrla stolpnico, čeprav smo prikazali slike kar nekaj stoplnic, ki gorijo kot bakle, pa niso niti približno padle, in to po precej daljšem gorenju. Ampak tale je bila po mnenju slotekovcev pač slabo grajena, (skoraj kot šentviški predor, se je nekomu zareklo) čeprav je bil v njej sedež CIA, županov bunker in tako dalje.
- In čeprav Pentagon pokriva desetine kamer, nimamo posnetka letala, imamo pa dejstvo, da so FBIjevci zaplenili trakove okoliških bajt. Ampak kritičnim slotekovcem to ni sumljivo.
- Čeprav črne skrinjice v dvojčkih niso bile najdene (vsaj uradno ne), so drugi dan že našli potni list ugrabitelja. To seveda slotekovcem ni čudno. Je pač naključje, je pač možno, da je ravno ta preživel ognjeno kroglo. Enkrat je nekdo napisal: "Ja, možno pa je!" Occam, pa to.
- Slotekovcem prav tako ni sumljivo, da komisija ni zaslišala desetin prič, neprijetna pričanja pa izločila iz končnega poročila.
In ta seznam bluzov in izmikanj je dolg, dolg, dolg. Kamorkoli se obrneš, naletiš na smešne izgovore, kako je ta in ta stvar takšno in takšno naključje, kako je to in to dejstvo v resnici to in to. Eno samo izmikanje, ko pa zmanjka prostora za izmikanje, se poslužite pa smešenja in omalovaževanja. Žalost.
PaX_MaN ::
Dejstvo je le to, da so "našli" ... nekaj, ampak še sami pojma nimajo, kaj naj bi to bilo.
- spremenilo: PaX_MaN ()
BigWhale ::
Za uvod: vceraj je bil pozar v eni izmed sezigalnic plastike pri nas v Sloveniji. Po radiu so danes sporocili, da so explozije in glasno pokanje, ki se je slisalo med pozarom nastali zaradi tega ker so se je vnelo nekaj praznih doz od pur-pene. Zarota?
Torej, pokanje in explozije, ki so se bojda slisale v WTCju niso mogle biti od nicesar drugega ampak samo od explozij razstreliva s katerim so podrli bajto? Ok.
Explozije cesa so se slisale? Termit NE explodira. Pri konstrukciji oziroma pri rezanju s termitom termit NE explodira, ne verjamete? Poglejte kronski dokaz. YouTube video!
Ce imas jekleni steber, ki je se debelejsi in vecji, traja rezanje se precej dalj casa.
Torej, ce so se slisale explozije, kaj se je slisalo? Demolition charges? So uporabljali navaden exploziv? Ja? Zakaj so pa potem 'nasli termit'? Aja oboje so uporabljali. Ok. Termita niso nasli, nasli so nekaj kar lahko ostane po uporabi termita.
Ali je mozno, da so na podzemni popravljali tracnice in polagali novo progo, pa so varili s termitom in je tisti prah usel v ozracje? Nemogoce? Popolnoma nemogoce?
Glej zgoraj, pozar v sloveniji in kako so porocali o eksplozijah. Ce meni ne verjames poklici na Radio Center in jih povprasaj. Linka zal nimam.
Kako so pa price prepoznale staljeno jeklo? Ja, precej je takih, ki so slave lacni luzerji. Eni verjamejo v podiranje dvojckov, drugi verjamejo v to, da jih bo Jezus ozdravil. Torej, ljudi je polno! Taksnih in drugacnih. In takrat je bilo polno ljudi, ki so nekaj videli in nekaj slisali. Vse zivo so lahko videli in slisali. Ne pomeni vedno, da so laznivci, lahko pomeni samo to, da ne vedo tocno kaj so videli in da so zmedeni. Spet vprasanje, je to popolnoma nemogoce?
Termita NISO nasli. Nasli so ostanke, ki bi lahko bile termit vcasih. Nujno pa ni. Ne vedo od kje so prisli ti ostanki v prah in ne vedo a so bili ti ostanki ze prej prisotni. Spet, je popolnoma nemogoce, da bi ta prah prisel od drugje? Ali pa se vec, bil ze v samem WTCju? Kako so pa gradili WTC? So morda jeklene stebre varili tudi s termitom? Ce so, potem sem preprican, da niso prej celotne zgradbe sterilizirali in pobrisali vse prah. :)
No, to za samo fiziko podiranja stavbe nima prav nobenega pomena in je v term primeru res irrelevantno. Se ne strinjate? Ima pa to vezo z drugimi porocili o dogodkih, ki pa v bistvu niso stvar te debate.
Poslal kam? Ugrabljenega letala nad USA ni bilo ze skoraj 30 let do 9/11. Poleg tega nihce ni vedel, da so letala ugrabljena, kaj sele, da so namenjena za zaletavanje v neboticnike. In kaj bi naredili? Sestrelili letala? Hihi, to bi bilo super, ze kar vidim naslov v casopisih. "Amerisko letalstvo sestrelilo potniski avion, ker bi se lahko zaletel v Pentagon."
A sosednjo posto, ki je bila tudi prakticno porusena porocilo omenja? Omenja se kako drugo sosednjo bajto? Ce jih ne, potem jest ne vidim problemov. Preiskava je bila namenjena za tocno doloceno zadevo. Iskanje crnih skrinjic v rusevinah WTC7 pa nima pomena.
- Termalna ekspanzija jekla je (prvič v zgodovini) simetrično podrla stolpnico, čeprav smo prikazali slike kar nekaj stoplnic, ki gorijo kot bakle, pa niso niti približno padle, in to po precej daljšem gorenju. Ampak tale je bila po mnenju slotekovcev pač slabo grajena, (skoraj kot šentviški predor, se je nekomu zareklo) čeprav je bil v njej sedež CIA, županov bunker in tako dalje.
Ja, prvic v zgodovini zato, ker je bil to edinstven dogodek. Ognji so pa lahko razlicni, lahko gori znotraj stavbe in se ga na zunaj sploh ne opazi kaj dosti vendar segreje celo stavbo, lahko pa gori bolj zunaj, ker se vname izolacija in tisto gori na povrsini zgradbe. Stvar zgleda precej bolj spektakularna ampak se stavba sproti hladi zaradi prepiha.
Sumljivo je ravno toliko, kot to, da pri ropu banke zaplenijo vse posnetke s kamer, ki bi utegnile posneti roparja.
Ce je prezivel samo en potni list, potem je stvar cudna, ce je pa prezivel se kakrsen koli drugi dokument, list papirja, karkoli kar je priblizno tako gorljivo, potem pa stvar ni vec tako zelo cudna. Ce je bil ugrabitelj v pilotski kabini in je imel potni list pri sebi ga je v trenutku trka zabrisalo naprej v kokpitu, se preden je karkoli explodiralo. Sprednji del kabine se je deformiral in obstaja verjetnost, da ga je pri tem vrglo iz kabine. Popolnoma nemogoce?
Odvisno kaj so pricali. Ce so nakladali o visoko energetskih skrivnih orozjih potem bi jih tudi jaz ven pometal. Prav tako, ce bi se izkazali za psihicno nestabilne, jih ne bi uposteval. Zaslisali pa verjetno niso na stotine pric. Tam je bilo ljudi na tisoce. :)
Torej, ce se vam vse te stvari zdijo popolnoma nemogoce in se vam zdi, da je EDINA mozna razlaga za vase 'anomalije' to, da so zgradbo porusili namenoma, potem bomo tezko razpravljali naprej.
imagodei ::
BigWhale, poudarek moj> "Torej, ce so se slisale explozije, kaj se je slisalo? Demolition charges? So uporabljali navaden exploziv? Ja? Zakaj so pa potem 'nasli termit'? Aja oboje so uporabljali. Ok. Termita niso nasli, nasli so nekaj kar lahko ostane po uporabi termita."
Ključno tukaj je, da so našli nekaj, kar LAHKO (ne pa nujno) ostane po uporabi termita. Lahko je pa iz vsaj 10 drugih virov, tako iz okolice, kot iz samih ruševin... WTC je imel preko milijona ton materiala!
PaX_MaN ::
Jajaja, rja in aluminij.
Nikoli videno v naravi, pardon, mestu kjer se konstantno nekaj gradi iz železa in aluminija, res.
hamax ::
Si bo treba kej prebrat kako zgleda in kako deluje...
Ti si kar preberi.
No povej kaksna je molekula termita, ki jo je tako tezko najti v naravi? In kaj natancno je vezano v termitu.
dprjones o termitu in o peer reviewed studiji omenjeni tu.
CoolBits ::
Sem nehal gledat pri "thermite was never used for demolition"
Nano-thermite @ Wikipedia
V bistvu bi morali govoriti o nanotermitu najdenem v WTC.
MICs or Super-thermites are generally developed for military use, propellants, explosives, and pyrotechnics. Because of their highly increased reaction rate, nanosized thermitic materials are being researched by the U.S. military with the aim of developing new types of bombs that are several times more powerful than conventional explosives.[3] Nanoenergetic materials can store higher amounts of energy than conventional energetic materials and can be used in innovative ways to tailor the release of this energy. Thermobaric weapons are considered to be a promising application of nanoenergetic materials. Research into military applications of nano-sized materials began in the early 1990s.
bluefish ::
Pa sploh razumeš citiran del, ki si ga prilepil? Sploh del o trenutno raziskovalni uporabi in o tem, da se gre pravzaprav za moderator.
hamax ::
In kaj v tvojem citatu negira to trditev? Dej poboldi tocno trditev.
| ⊘ | Kdo vodi svet in podobne zarote (strani: 1 2 3 4 … 7 8 9 10 )Oddelek: Loža | 37925 (8814) | T-h-o-r |
| » | Resnična zgodovina - kdo zares vlada na zemlji (strani: 1 2 3 4 … 11 12 13 14 )Oddelek: Problemi človeštva | 49218 (36126) | Matev |
| ⊘ | Irak ll. Mogoče se bo pa komu posvetilo :) (strani: 1 2 3 4 5 6 7 8 9 )Oddelek: Problemi človeštva | 28623 (24509) | jype |
| ⊘ | 11 september in teorija zarote!? (strani: 1 2 3 )Oddelek: Loža | 15676 (11299) | jype |
