Ubuntu 12.04 Precise Pangolin
12 / 24
lopov ::
Lastniki ThinkPad morda raje namestijo "thinkpad-acpi".
Na mojem T500 imam z "laptop-mode-tools" temperature nad 50 stopinj, s "thinkpad-acpi" pa večinoma ne zleze nad 40. Imam sicer hibridno grafiko (ATI3650/MHD4500), a je ATI preko svitcheroo izključen in delam striktno z integrirano (imam dual-boot z Win7 kjer potrebujem ATI, zato ni izključeno v BIOS).
  • spremenil: lopov ()
Kiborg ::
Hm, ravnokar sem ugotovil, da nimam Swap particije, a sem prepričan da sem jo nastavil ko sem postavil sistem? Je možno da je prišlo do napake zaradi dual boota? Kako ustvarim Swap particijo?
Icematxyz ::
cat /etc/fstab
Kiborg ::
Kako vstavim podatke sem? S-T misli da je HTML koda in ne dovoli vnosa.
Icematxyz ::
Pripni med značke Vstavi kodo (sedmi gumb).
Vstavi kodo
Kiborg ::
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
proc            /proc           proc    nodev,noexec,nosuid 0       0
# / was on /dev/sda5 during installation
UUID=17eb254e-124d-4755-904a-3c8be28b7fae /               ext4    errors=remount-ro 0       1
# swap was on /dev/sda6 during installation
#UUID=65bb7560-7eab-47ff-a198-615a9e205016 none            swap    sw              0       0
/dev/fd0        /media/floppy0  auto    rw,user,noauto,exec,utf8 0       0
/dev/mapper/cryptswap1 none swap sw 0 0
Takole, pa sem. Narobe sem uporabljal vstavi kodo gumb...
  • spremenilo: Kiborg ()
Icematxyz ::
Kaj vrne sledeč ukaz:
sudo blkid
Kiborg ::
/dev/sda1: LABEL="PoM-DM-^Masn" UUID="0880413980412E8E" TYPE="ntfs"
/dev/sdb1: LABEL="Veliki" UUID="E25C2E1D5C2DECCB" TYPE="ntfs"
/dev/sdc1: LABEL="Rezerviran sistem" UUID="4236B72136B7153F" TYPE="ntfs"
/dev/sdc2: UUID="2A94D21A94D1E879" TYPE="ntfs"
/dev/sdc5: UUID="17eb254e-124d-4755-904a-3c8be28b7fae" TYPE="ext4"
/dev/sdc6: LABEL="Disk" UUID="3ACEC1E1CEC19593" TYPE="ntfs"
technolog ::
Ne, res nimaš swap particije.
Če imaš spodobno rama, to ni tako velik problem.
Icematxyz ::
Kaj vrnejo sledeči ukazi:
cat /proc/swaps
cat /etc/crypttab
top -n 1 | grep Swap
Kiborg ::
cat /proc/swaps
Filename				Type		Size	Used	Priority
cat /etc/crypttab
# <target name>	<source device>		<key file>	<options>
cryptswap1 /dev/sda6 /dev/urandom swap,cipher=aes-cbc-essiv:sha256
Swap:        0k total,        0k used,        0k free,   303188k cached
Drugače pa imam 4 GB DDR3 rama.
Daedalus ::
Lahko narediš file ustrezne velikosti z dd, ga formatiraš kot swap in vključiš swap z ukazom swapon. Nekaj takega:
:~$ dd if=/dev/zero of=swap.img bs=10M count=100
:~$ mkswap swap.img
Setting up swapspace version 1, size = 1023996 KiB
no label, UUID=044b24f3-432b-415c-bcc7-37cba1d9882c
:~$ sudo swapon swap.img
Pol pa z ukazom free -m preveriš, če je swap tam.
[J.P.Sartre]
Icematxyz ::
sudo cryptsetup status cryptoswap
Kiborg ::
Ali lahko tako po pomoti izbrišem kakšne podatke z diska? Imam dual boot in res nebi želel česa po pomoti izbrisati.
Icematxyz ::
Kaj vrne ta ukaz in ne z njim ne boš nič izbrisal:
Kiborg ::
/dev/mapper/cryptoswap is inactive.
Ne mislil sem, če bom moral ustvariti nov swap. Se lahko zgodi da po pomoti kaj zbrišem?
Icematxyz ::
Verjetno si pred kratkim spreminjal strukturo razdelkov, oziroma najverjetneje kakšnega z "neznanim" datotečnim sistemom tudi izbrisal?
Preveri sledeče:
sudo apt-get instal gparted
Preveri v GParted, če se na podatkovnem nosilcu, kjer se je nahajal /swap razdelek še nahaja "prazen prostor" velikosti /swap razdelka.
Icematxyz ::
Oziroma prilepi še izpis:
sudo fdisk -l
Kiborg ::
Poizkus namestitve gparted preko konzole je bil neuspešen. Napaka: E: dpkg je bil prekinjen. Za popravilo napake morate ročno pognati 'sudo dpkg --configure -a'.
Potem sem ga namestil preko programskega središča, kjer ni bilo težav.
Icematxyz ::
Da nič ni narobe, če poženeš:
Drugače pa to me sedaj zanima:
sudo fdisk -l
Kiborg ::
Disk /dev/sda: 320.1 GB, 320072933376 bytes
255 heads, 63 sectors/track, 38913 cylinders, total 625142448 sectors
Units = sektorji of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disk identifier: 0x3ec1595d
  Naprava Zagon    Začetek       Konec     Bloki    Id  Sistem
/dev/sda1              63   625137344   312568641    7  HPFS/NTFS/exFAT
Disk /dev/sdb: 500.1 GB, 500107862016 bytes
255 heads, 63 sectors/track, 60801 cylinders, total 976773168 sectors
Disk identifier: 0xd7fe5084
/dev/sdb1            2048   976769023   488383488    7  HPFS/NTFS/exFAT
Disk /dev/sdc: 251.0 GB, 250999111168 bytes
255 heads, 63 sectors/track, 30515 cylinders, total 490232639 sectors
Disk identifier: 0x00005822
/dev/sdc1   *        2048      206847      102400    7  HPFS/NTFS/exFAT
/dev/sdc2          206848   102402047    51097600    7  HPFS/NTFS/exFAT
/dev/sdc3       102404094   490231807   193913857    5  Razširjen
/dev/sdc5       102404096   142001752    19798828+  83  Linux
/dev/sdc6       142002176   481835007   169916416    7  HPFS/NTFS/exFAT
/dev/sdc7       481849344   490231807     4191232   82  Linux izmenjalni / Solaris
Icematxyz ::
sudo swapon /dev/mapper/cryptswap1
swapon -s
Kiborg ::
swapon: /dev/mapper/cryptswap1: stat failed: No such file or directory
swapon -s
Icematxyz ::
Zadeva je povezana s šifriranjem /swap razdelka in tudi /swap razdelek še imaš na voljo tako da ne rabiš na tem področju zaenkrat početi nič. Sedaj najlažje bi verjetno bilo "usposobiti" obstoječ /swap razdelek da deluje, kot običajen /swap razdelek, ampak predvidevam, da želiš tudi šifriranje. Sedaj bolj ugibam kje je težava, preizkusi to:
gksudo gedit /etc/crypttab
Spremeni vrstico in shrani:
V to:
cryptswap1 /dev/sdc7 /dev/urandom swap,cipher=aes-cbc-essiv:sha256
Potem preizkusi še sledeč ukaz in poročaj:
Kiborg ::
Icematxyz ::
Po tej spremembi poženi še sledeč ukaz in znova zaženi računalnik:
sudo update-initramfs -u -k all
Če ne bo nič drugače boš usposobil obstoječ /swap razdelek brez šifriranja.
Torej ta sprememba + ukaz v tem odgovoru + ponovni zagon računalnika in poročaj kakšno je stanje!
Kiborg ::
swapon: /dev/mapper/cryptswap1: swapon failed: Device or resource busy
Icematxyz ::
cat /proc/swaps
cat /etc/crypttab
Kiborg ::
cat /proc/swaps
/dev/dm-0                               partition	4191228	0	-1
cat /etc/crypttab
Swap:  4191228k total,        0k used,  4191228k free,  1040188k cached
Ja in ravnokar sem opazil v nadzorniku sistema da imam 4 gb izmenjevalnega razdelka. Prej je tam pisalo da izmenjevalnega razdelka ni.
Icematxyz ::
Jah nič to je sedaj to, kaj pa si še drugega pričakoval. ;)
Morda kvečjemu kaj takšnega:
Fancy Terminal
iLove
Ne vem. Zdaj pa gremo spat!
  • zavaroval slike: Icematxyz ()
Kiborg ::
Fancy! No super! Hvala! Je 4 gb swap dovolj?
Lahko noč.
Icematxyz ::
You're Welcome
0k used,
Lahko noč.
Enako in prijetne sanje.
Icematxyz ::
Darktable 1.0.4
Home & iLove
Gabe Newell
Rumour Or Fact: Yes
Pol Poti
Arm Gun
Mango - (Production update – halfway!)
Icematxyz ::
Na voljo je Arronax.
Arronax
Arronax je Nautilus dodatek (GUI orodje), ki služi izdelavi in spreminjanju obstoječih zaganjalnikov.
Home & Vibes
Grive
Grive je odprto kodni odjemalec za sinhronizacijo s Google Drive. Trenutno ne nudi GUI orodja in sinhronizacija se zaenkrat vrši le ročno.
WebUpd8
Lastnikom AMD grafičnih kartic pred Radeon HD 5000 series se kot kaže vendarle še obeta podpora za Xorg 1.12 strežnik v "legacy" lastniškem gonilniku.
What I've been told is that where the legacy driver was forked in the fglrx 8.97 stream, there is xorg-server 1.12 support. So when AMD ends up pushing out their first Linux legacy driver update for the HD 2000/3000/4000 ASICs, there should be this 1.12 support still included. AMD won't be back-porting new kernel / xorg-server support in future legacy releases, but at least we should see support for this X.Org Server that was released in early March.
Phoronix
Fedora 17 GMA500 Poulsbo
Lastniki GMA500 strojne opreme se v Fedora 17 več ne rabijo ukvarjati s delovanjem grafične kartice, saj je podpora na voljo out-of-the-box. Ker ni na voljo 3D pospeševanja za podporo GnomeShell skrbi CPU (llvmpipe) pristop, ki bo ga morda izbral v bodoče tudi Ubuntu (namesto Unity 2D lupine).
Fedora 17 GMA500 (Poulsbo)
Samba 4 prinaša v mešana IT okolja Active Directory podporo:
The Samba development team has released the first beta of Samba 4 which, after over six years of development, will introduce the first open source implementation of Microsoft's Active Directory technology.
Samba 4 beta 1 brings Active Directory support
Lara Croft
Lara Croft pa nam bo kot kaže v novem Tomb Raiderju pokazala tudi bolj ranljivo stran!
Torej razno razne "šminke" & Stuff, ki pač sodi zraven:
mjolnir ::
Pozna kdo kakšen dober ter enostaven DLNA program za filme ter glasbo? Na windowsih uporabljam twonky. Zanima me, če obstaja kakšna podobna zadeva za ubuntu.
trnvpeti ::
mjolnir je izjavil:
minidlna
Mavrik ::
mjolnir je izjavil:
Če si z njim zadovoljen, Twonky obstaja tudi za Linux.
mjolnir ::
Ja, twonky je vredu. To pa nisem vedel, will try. Hvala obema.
mjolnir ::
Zanima me še, kako se twonky namesti. Zloudal se nek .sh file, sedaj pa nevem kako ga zaženem.
panteist ::
chmod +x imefajla.sh
sh imefajla.sh
To ti požene inštaller. Jaz najraje instaliram v folderju /usr/local, kjer je včasih potrebno ustvarit še folder za ta program. Pri drugem ukazu je v folderju /usr/local najverjetneje imeti še administratorske pravice.
Če sem kaj narobe napisal...me popravite.
Torej, jaz napravim nekaj v stilu:
cd /Downloads
sudo mkdir /usr/local/imeprograma
cd /usr/local/imeprograma
sudo sh ~/Downloads/imeprograma.sh
  • spremenilo: panteist ()
šernk ::
končno, in hvala za veselo novico :D
mjolnir ::
Kaj lažjega načina kot to ni?
panteist ::
Lažji način? Ne razumem kaj misliš s tem :)
- narediš fajl executable
- ustvariš novo mapo
- se premakneš v to mapo
- poženeš shell-script v terminalu - oz. installer
EDIT:
z mal prakse takole inštaliraš dosti hitreje kot v Win s klikanjem
5er--> ::
Oz. desni klik na datoteko -> lastnosti -> permissions -> allow executing file as program
Slikica
Nato pa dvakrat klikneš na datoteko in izbereš, da bi jo rad zagnal.
Icematxyz ::
Corporate News
Samsung se pridružuje The Linux Foundation kot Platinum Partner.
World’s largest device maker places strategic, long-term investment in the Linux platform
Samsung Electronics Joins Linux Foundation at Platinum Level
Microsoft pozdravlja prihod priljubljenih Linux distribucij in razvijalskih orodij na Azure.
We will also add support for new operating systems, release new language libraries for .NET, Java, PHP, and Node.js, and will make Windows Azure available in new geographies.
Announcing New Windows Azure Services to Deliver “Hybrid Cloud”
Chris Mason zapušča Oracle, pridružil se bo podjetju Fusion-io, kjer bosta skupaj s Steve Wozniakom še naprej razvijala visoko zmogljive rešitve na področju hrambe podatkov.
Hello everyone,
Oracle has been a fantastic place to work, and I really appreciate their
support for my projects. But, I've decided to take a new position at
Fusion-io. I will start the new job on Monday, June 11.
From a Btrfs point of view, very little will change. I'll still
maintain Btrfs and will continue all of my Btrfs development in the
open. Oracle will still use Btrfs in their Oracle Linux products, and
I'll work with all of the distros using Btrfs in production.
Fusion-io really believes in open source, and I'm excited to help
them shape the future of high performance storage.
Leaving Oracle
Video Support
Mozilla popušča in B2G dobiva H.264/AAC/MP3 HTML 5 podporo.
The work allows for VA-API to communicate with the reference Weston compositor and to exchange buffers based upon the Wayland-DRM protocol. "Now the patches work well to send XRGB buffer to weston. the interface alsosupports YUV buffer between vaapi and weston."
Intel pa ne popušča in Wayland/Weston dobiva podporo strojnem pospeševanju videa (VA-API).
3D Performance
Zadnje posodobitve (Unity 3D v Ubuntu 12.04) prinašajo izboljšave, ki naslavljajo zaznan upad prikaza števila sličic pri nekaterih 3D aplikacijah v kombinaciji s določeno strojno opremo.
Po položenem kvalitetnem temelju, racionalizaciji se kot kaže začenja naskok na zmogljivost. Jedro 3.5 prinaša občuten dvig zmogljivosti za novejše AMD grafične kartice (HD 5000/6000 series) pri uporabi odprto kodnega gonilnika za grafiko:
Performance Boost
Linux 3.5 Can Massively Boost AMD Radeon Graphics Performance
panteist ::
Sem pa ravno prejle gledal na phoronixu te benchmarke s kernelom 3.5. Precej obetavni rezultati - vsaj za ATI na linuxu kar dobro kaže. Čeprav, tisto umikanje podpore starejšim grafičnim v prihajajočih zaprtokodnih gonilnikih mi ni tako všeč :)
Icematxyz ::
Sedaj imajo dobro priložnost, da s zdravim temeljem, stabilnostjo in dodajanjem ustrezne podore vsem zmogljivostim, ki jih njihova strojna oprema nudi in to v okvirjih odprto kodnega gonilnika distancirajo podjetje od slabe podobe na področju gonilnikov. To občasno navijanje zmogljivosti pa tako ima potencial, da jih popelje tudi na sam vrh. Da vidimo.
panteist ::
Hja, res da performance odprtokodnih gonilnikov dosega dost slabše rezultati, mi je zanimivo njihovo delo, ki opazno napreduje. Mi pa te hibridne grafične niso preveč všeč :)
šernk ::
Osebno bom po pravici povedano prav kmalu zapustu ubuntu iz istih razlogov kot sem zapustil windows.
več kot očitno je da besedi enostavnost in delovanje nimata nič skupnega z uspehom.
kaj me je najbolj motilo pri windowsih:
1. Restart skoraj ob vsakem updejtu
2. Klikanje na next next next (vsaj tega tu zaenkrat še ni)
3. Vsak drugi updejt nekaj sesuje
včeraj so mi updejti totalno sesuli network manager (ista težava, tako da nisem edini http://askubuntu.com/questions/146076/n... )
za povrhu vsega mi pa še stari NM noče vzpostavit povezave...po updejtu se sploh ni prikazal zgoraj desno da je zagnan, sedaj je zagnan ko sem spet starega inštaliral ampak prikladno piše: device not managed...spravit h delovanju zadeve pa nikakor ne morem. Pišem pa iz tega računalnika kjer NM ne dela...povezava je vzpostavljena z ukazom pppoeconf, pa modem deluje v router načinu in on vzpostavi povezavo z netom ne pa računalnik. Skratka točno zaradi takšnih idiotskih izpadov sem preklopil iz windowsa na ubuntu pred 4 leti in očitno bom zaradi istih idiotskih stvari zapustil ubuntu, dobesedno ne morem verjet kaj se mi pred očmi dogaja.
trnvpeti ::
Sernk, a gres nazaj na winse?
12 / 24
[(K)Ubuntu] Vprašanja in težave (strani: 1 2 3 4 … 23 24 25 26 )
Oddelek: Operacijski sistemi
1262411498 (11058) bosmla
Ubuntu 12.10 Quantal Quetzal (strani: 1 2 3 4 )
18960008 (50632) MrStein
[Ubuntu 10.04] Problem z zvočno kartico (mikrofon)
92648 (2549) Icematxyz
Izšel Ubuntu 12.04 LTS (strani: 1 2 3 )
13447751 (40894) panteist
Ubuntu Oneiric Ocelot 11.10 (strani: 1 2 3 4 … 14 15 16 17 )
813225913 (191852) Icematxyz
