Javier Milei prisegel kot novi argentinski predsednik!
TezkoDihanje ::
https://twitter.com/nexta_tv/status/174...
Argentine President Javier Miley speaks at the World Economic Forum in Davos
- The Western world is in danger. It is in danger because those who should defend the values of the West are consumed by a vision of the world that leads inexorably to socialism and poverty. Collectivist experiments are not the solution.
- Free enterprise capitalism is not only the only possible system that can end world poverty, it is the only morally acceptable system to achieve that goal.
- Social justice is unjust because it is based on tax collection. Collectivism constrains entrepreneurs willing to offer the best goods at the best prices.
- We live in the richest and most prosperous times, but this is true for free countries. We must not forget that socialism has failed in every country where it was installed and ruined millions of people. There are no examples of "market error".
- Argentines have been through all of this and we are here to warn you, it doesn't matter how rich you are or how educated the population is, if you attack capitalism and private property, you will impoverish yourself. The state is not the solution, the state is the problem.
Možakar se vidi, da je zelo brihten sploh to, da je proti totalitarnim režimom.
Dementni, a ti je Miley všeč, al še vedno prcaš na sibirske pijance ki delajo za 20 jurjev rubljev, da te bodo rešili vseh muk?
Vsi ekstremi so slabi. Zlati časi US kapitalizma so bili ko je bilo malo monopolov in veliko davkov na podjetja.
Glede na ekonomsko sranje ki ga imajo v Argentini, je ekstremni kapitalizem ki se ga hoče it Javier sicer velika izboljšava. V splošnem pa ni dobro dolgoročno iti v tak ekstram.
Sicer tak ekstremni kapitalizem bi vsaj prinesel neko čistko državnih parazitov, tak da morda ga rabimo tudi pri nas, vsa začasno da se malo spuca. Je pa res da začasno lahko postane stalno :)
PovemVfaco ::
Tovariš Xi z veseljem čaka, da pajac odpre vse skup, da lahko čajna preko prostega trga pokupi pol Argentine. Hamburgerje na kontinentu najbolj zanimajo kolumbijske droge.
kuglvinkl ::
Lonsarg je izjavil:
Res je. "Edini" problem je v tem, da z letnim bonusom nisi mogel kupiti zadnjega Gulfstreama al pa srednje velikega otoka. No, smo popravl to.
nekikr ::
Tole. Država je problem pri praktično vsem. Samo novice preletiš pa vidiš kako ta mafija dela kar hoče, z bistveno večjim denarjem kot katerokoli podjetje.
TezkoDihanje ::
PovemVfaco je izjavil:
Čajna je nehala kupovat in investirat zunaj. Bi moralo bit počasi že vsem jasno zakaj.
Kresnik ::
TezkoDihanje je izjavil:
Morda, ampak a ni en kup problemov, ki danes pestijo Zahodni svet ravno v tem, da vsak gleda na lastno rin v naslednjih 15 minutah, noben pa nima nekega dolgorocnega plana ali resnih vrednot? Pa ne da je nek kolektivizem boljsi ampak... 90% eksplicitnih tezav je zaradi individualizma.
Maš prav, povej to egoističnemu individualistu ki hoče kupit svoj flat... naj pogleda na druge da bi meli flete tudi ne pa on prasec individualistični
nekikr ::
Ljudje smo pač taki. Če misliš, da ti pa nisi, potem samo nisi imel primerne prilike. Poglej kaj nam je za zgled. Holob je pa prvi seji, ko je prevzel oblast, nastavil svoje ljudi na firmo, ki daje denar njegovi firmi. Pa tako je opeval svobodo in drugačne čase. In ko Janez to vidi se potem upravičeno vpraša: "a jaz naj imam pa dolgorocne plane in bom poln etike in morale"? Cel svet je tak in na žalost je bedak tisti, ki plava proti toku.
Kresnik ::
Mato989 je izjavil:
Snemi aluminijasto kapico in si raje poglej internetne rante boomerskih sefov, kako milenijci nimajo vec nobenega spostovanja ali zvestobe do podjetja. Jebiga, free market kapitalizem, cry me a river.
Poglej si redne rante konzervativcev, o propadu druzine in tradicionalnih vrednot. Jebiga, to je ta individualizem, ko te skrbi le za lastno rit in nic vec. Kje je moja mikro violina?
V nebrzdanem kapitalizmmu si ne bos nikoli kupil flat-a, ker bo Korporacija kupila vso zemljo in ti po oderuskih cenah oddajala flat, gradit pa ne bos mogel, ker nobene zemlje ne bo naprodaj.
Kresnik je izjavil:
in točno ti ki jih omenjaš da jamrajo, so največ profitirali od kolektivizma, sedaj pa se nikakor ne želijo odreči udobju in prikrito podpirajo individualizem...
Kresnik ::
gruntfürmich je izjavil:
Kresnik je izjavil:
Okej, objasni?
hendriks ::
Mileiev video govor v Davosu, preveden s Heygen. Impresivno, tako govor kot prevod: https://x.com/aphysicist/status/1747868...
Kresnik ::
hendriks je izjavil:
Eh, še en cenen populistični oportunist, ali pa naivčina, ki mu bodo pred očmi pokradli državo, ljudstvo pa v borderline državljansko vojno nekaj let kasneje.
Kresnik je izjavil:
Mah vsi tipi njegovega kova imajo nek plan stegniti tako ali drugače, če zagusti. ...kar je v bistvu pošteno - bolj vas lahko skrbijo politiki, ki ga nimajo. Ampak kot rečeno, je še prezgodaj za neke zaključke.
Kresnik je izjavil:
torej ti izhajaš iz tega, da je argentina cvetoča socialistična dežela, ki ji grozi hudobni kapitalizem.
user123456 ::
Javier s svojim stališčem popolnoma zadane bistvo..največja grožnja za pomankanje in revščino je komunizem.
Komunizem temelji na sladkih lažeh in leporečju katero potem vodi v pomanjkanje, revščino in družbeni konflikt.
Ni naključje da ga komunistični mediji z njihovo propagando skušajo označit kot skrajnega desničarja.
Pomembno pa je vedeti da je komunizem nemogoče izkoreniniti dokler ekonomija temelji na komunistični valuti (centralno planirani). Rešitev je prehod na pošten politično nevtralen monetarni sistem.
Imamo rešitev? DA
Bitcoin.
PS vsi večji vojaški konflikti kjer umira miljone ljudi so direktna posledica komunističnih režimov in uporabe komunistične valute ki vladajoči skupini ljudi omogoča neomejeno financiranje konflikta (in utrjevanje svoje oblasti), plačajo pa ljudje z inflacijo in življenji.
jest10 ::
Kresnik je izjavil:
Izhaja iz tega, da bo za povprečnega argentinca po tem populističnem preblisku slabše, kot je bilo.
In za kaj takega sploh ni majhna verjetnost
hendriks ::
jest10 je izjavil:
A res? Tole ti kar tako čez palec? Argentina bo čez nekaj let cvetela. Zapomni si to! Če pa misliš da se motim, poglej kje je Venezuela sedaj. Vas levakov res ne smemo nikoli spustil zraven oblasti. Ker vse zjebete...
Saj je, poglej samo rast inflacije po volitvah.
Poleg tega je zdajšnji predsednik pravi levičar, za prosti trg, Friedmanov učenec, itn... Bodo razprodali celo Argentino Amerom...
jest10 ::
jest10 je izjavil:
Bo ja. Zihr
jest10 je izjavil:
30 let zavožena država 1 teden po volitvah ne bo postala uspešna ekonomija, pa če pripeljejo vse najboljše politike iz tega sveta.
potrebna so leta sprememb. argentina bo še naprej tonila, edino vprašanje je, kdaj se bo krivulja obrnila.
kdor meni da bo takoj bolje je v 99,9% debil in levuharski populist.
jest10 ::
jest10 je izjavil:
Ja, so potrebne spremembe.
Ampak ne full retard ekstremno desna razprodaja države.
Se da to speljati dosti bolj nežno z manj populizma ter škode za prebivalce.
No sej se bo videlo, kaj bo dejansko sploh naredil. Verjetno bo samo veliko govorjenja in malo učinka
  • spremenilo: jest10 ()
Najboljše je da država nima kontrole nad notranjim trgom... Država mora samo poskrbeti da jastrebi od zunaj ne pokupijo industrije itd... razen v kakih izjemah.
In naredit mora dober regulatorni okvir kaj se sme in kaj ne sme in to enforcat... Ni pa treba da je država lastnik česarkoli razen
1. električnega omrežja
2. vodovoda
3. kanalizacije
4. internetnega omrežja
5. pogojno 1 ITK podjetja za zagotavljanje interneta in telefonija (pa še to je tako, ne 100% nujno)
Vse ostalo naj gre v privat roke pod regulacijskimi zakoni ki določajo minimume in maksimume.
user123456 ::
Mato989 je izjavil:
2. vodovoda
3. kanalizacije
država ne rabi imet monopola nad ničemer ...ravno monopol (naj bo to država ali kdorkoli drug) je izvor vsega slabega...in problem je v tem da država z prekomerno birokracijo omejuje konkurenco. Nič ni narobe s tem da tujec kupi neko podjetje če mu lahko vsak državljan konkurira..ampak zaradi birokratskih ovir (komunizem) mu ne more.
Bo šlo, dokler ne zmanjka državnega premoženja za prodat.
Tudi nad uporabo (pri)sile? Kako si to predstavljaš, da ima vsak ki si lahko privošči svojo policijo? Svojo vojsko? Pa se potem ti povežejo, da imajo lahko skupno in določijo svoja pravila, kaj se sme in kaj ne? Pa še določijo nekaj svojih predstavnikov, da imajo skupnega arbitra?
Da te konkurent ovira je komunizem? Al je komunizem to, da država konkurenci ne dovoli da te 'prepriča', da jim ne konkuriraš?
user123456 ::
kapitalizem...grenka resnica ki vodi v prosperiteto in lepšo prihodnost
komunizem.....sladka laž (droga) ki pelje od navdušenja do propada civilizacije
user123456 je izjavil:
Mato989 je izjavil:
2. vodovoda
3. kanalizacije
Torej hočeš rečt da bi lahko vsak državljan zgradil paralelene vodovod do vsake bajte in paraleleno omrežje do vsake bajte?
Aja, kaj pa monopol nad represijo? in sodiščem? Ali lahko torej ustanovi vsak državljan sodišče in represivni organ in privede na zaslišanje kapitaliste?
user123456 ::
Mato989 je izjavil:
da, če mu je to ceneje kot mu monopolist (država ali kdorkoli drug) ponuja ..drugače seveda zakaj bi to naredil ampak point je v tem s tem ko ima vsak pravico gradit svoje omrežje in vode monopolist nima več interesa držat ljudi za jajca ampak je edini njegov interes delat dobro za njih, bistvo je da je dovoljena konkurenca
Mato989 je izjavil:
glede policije in sodišč ni panike če ima geografsko območje kot je slovenija enotno organizacijo dokler so ta pravila relativno enostavna in človeška se velika večina prebivalstva s tem strinja in ni težav. Težava ki se začne pojavljat je ko se začne prekomerna birokratizacija nerazumljivi zakoni ki si jih vsak tolmači po svoje in pravila napisana tako da vsak ki ima dobrega odvetnika (poznavalta te prekomerne birokracije) lahko doseže svoje. Npr slovenija ima 10x več zakonov kot jih je imela par let po osamosvojitvi.
Na koncu hočem povedat da se ta prekomerna birokratizacija države (komunizem) sesede sam vase ko je ljudem dovolj in imaš anarhijo. Sepravi neka enostavna pravila o katerih se strinja večina pa seveda morejo bit. In ves zahodni svet drvi v prekomerno birokratizacijo (komunizem) kar Javier lepo pove
priporočam branje tega članka:
https://www.zurnal24.si/slovenija/kako-...
user123456 ::
TESKAn je izjavil:
razprodaja državnega premoženja je nujna...vsa korupcija in gospodarski kriminal o katerem so neskončne debate po medijih izvira državnega premoženja. Državna podjetja so bankomat za politične stranke. V državnih podjetjih se slabo dela in krade (tako je bilo , je in bo) ni rešitev drugačna politična opcija na oblasti ampak da se država umakne iz teh podjetij
TESKAn je izjavil:
TESKAn je izjavil:
glej komentar ki sem ga komentiral matotu
te besedne igre ne razumem najbolje, jaz samo hočem povedat da je omejevanje konkurence bistveni problem ki se izvaja preko prekomerne birokratizacije
Zakaj pa se torej strinjaš da je lahko represivni organ in sodišče monopol? Ne bi bilo bolej če bi vsak imel svoj represivni organ in sodišče in zakone? Ker to je potem tisti korak naprej pri konkurenci ne? =) Ljudje pa bi se svobodno odločali h kateremu represivnemu organu in sodišču bomo šli >:D
user123456 ::
vsak človek ima neke svoje interese.
kapitalizem je sistemska rešitev kjer ljudje iz lastnih interesov sodelujejo med sabo in gradijo civilizacijo (win-win)
sepravi kapitalizem je sistem kjer posameznika preko osebnih interesov motiviraš da dela dobro za drugega in tako se gradijo civilizacije.
Mato989 je izjavil:
To je bil standard v Evropi še v Renesansi. >Recimo v italijanskih deželah je bilo kar pomembno, ali si bil v kakih Firencah, Veroni ipd. tudi zaradi "sodnega sistema" (ki je bil recimo presenetljivo napreden in niti ne tako "srednjeveški", kot si mi marsikdaj predstavljamo.. samo KAKOR KJE!) Isto je veljalo za finance, varnost ... te svoboščine so takrat že vse imeli in folk dejansko je prehajal iz ene mestne države v drugo tudi zaradi takih .. podrobnosti.
user123456 ::
Mato989 je izjavil:
si prebral članek ki sem ga linkal?
dokler so pravila človeška in enostavna se večina z tem strinja in nikomur ne pade na pamet da bi ustanavljal lastno sodišče in represivni organ. Bolj ko gremo v prekomerno birokratizacijo manj ljudi se strinja z tem in manj ljudi to upošteva ...na koncu prideš do slabšega stanja kot pri enostavnih pravilih.--in enostavna pravila so konsenz večine in popolnoma ustrezajo ti free marketu
ja drži imamo izvoljeno vlado itd ..nikoli nisem trdil da imamo v slovenijo 100% komunizem , hočem rečt da je smer napačna ker gremo spet čedalje bolj v komunizem namesto obratno oz da vsaj ostanemo tukaj pri delnem komunizmu (poslušaj govor Javierja)
no comment ::
Zakaj je kadmij v korenju dober za mene? Sicer razumem zakaj je kadmij v zemlji bil dober za nekoga drugega. Nekako ne vidim win-win, ampak zagotovo imajo utopični kapitalisti razlago zakaj je dobro, da pojem še nekaj kadmija, potem ko imam že dovolj svinca v krvi...
Mato989 je izjavil:
Jaz se z logiko povsem strinjam... Ampak imamo eno težavo, da vemo s čemer se strinja vsak ali večina ljudi moramo potem za vsak zakon dat referendum brez marketinga samo z obrazložitvijo... in ker je večina neumna ne bo prišla volit, kar pomeni da moramo zahtevat volilno udeležbo s katero se večina ne strinja ker jih ni :))
user123456 ::
no comment je izjavil:
kdo pa pravi da je? ..tudi če pravi v kapitalizmu se lahko sam odločaš drugače nihče te na silo ne hoče prepričat v svojo resnico..komunizem v nasprotju je vsiljevanje resnice s strani centrov moči.
lahko e ješ korenja če se ti ne zdi ok, lahko gojiš svojega...
Mato989 je izjavil:
komunistična logika: ljudje so neumni mi (komunistična partija) smo pametni in vemo bolje kaj je dobro za njih.
PS: elektronski referendum je zelo enostavno in poceni izvedljiv če bi obstajal interes BTW Golob je pred volitvami na široko obljubljal elektronske referendume sedaj pa je vs tiho.
če nekdo ne glasuje je to njegova pravica in tudi preko neglasovanja vpliva na rezlutat
Narobe... če bi to držalo, bi bilo v parlamentu toliko praznih stolčkov kolikor procentov ljudi ni glasovalo pa oba veva da to ne drži kajne...
Dejansko tisti ki ne pride glasovat na parlamentarne volitve da moč glasu drugim glasovalcem... In dokler se moč v parlamentu deli glede na vstopni prag, namesto glede na celoto glasovanja je odsotnost od glasovanja samo udarec na gobec.
Drugo je na referendumu kjer z neglasovanjem dejansko si proti ker referendum ne uspe! (kar je imo tudi neumno, ker če ne prideš bi moralo biti predpostavljeno da ti je vseeno in naj zmaga kdo motivira več prihoda)
no comment ::
Kapitalist pravi, da je čisto ok, če je v mojo zemljo dodal kadmij.
Aja, sej imam prosto možnost kupiti zemljo, ki še nima kadmija...
user123456 ::
Mato989 je izjavil:
saj si sam lepo povedal citiram Dejansko tisti ki ne pride glasovat na parlamentarne volitve da moč glasu drugim glasovalcem. ...in če se nekdo tako odloči je to njegova odločitev
kdo je v tvojo zemljo dodal kadmij?
Kapitalist, ki ga država ni omejevala z 'birokracijo'.
user123456 ::
TESKAn je izjavil:
konkretno imenuj ter pokaži rezultate meritev prej in potem
...in če je vse to res lahko potem ta kapitalist za ta svoja dejanja (posegov v tvojo posest brez privoljenja) odgovarja na sodišču
..strinjam pa se da je to težka misija ker imamo komunistično prekomerno birokratizirano sodstvo in bo ta kapitalist lahko z dobrim odvetnikom (ki pozna to prekomerno komunistično birokracijo) zmagal na sodišču
če pa bi imeli enostavna človeška pravila pa bi ti seveda lahko jasno dokazal svojo resnico
LightBit ::
Vedno bo imel nekdo monopol, če ne država pa podjetje ali mafija. Načeloma je bolje če je to demokratična država.
user123456 ::
LightBit je izjavil:
komunistična država=mafija
seveda demokratična v pravem pomenu besede..in po definiciji če je demokratična je obenem tudi kapitalistična ...kapitalizem je najvišja oblika demokracije.
LightBit ::
Lahko je tudi "kapitalistična" mafijska država, ampak res je "komunizem" bolj pogost v tej kombinaciji.
no comment ::
Kakšna so enostavna človeška pravila?
LightBit ::
Pravilo močnejšega. ;((
Verjeti v anarho-kapitalizm je enako utopično kot verjeti v "pravi komunizem".
no comment ::
Ja, samo da "pravi komunizem" je obljuba o pravljici za lahko noč, "pravi kapitalizem" pa obljuba o nočni mori.
LightBit ::
Odvisno iz čigave perspektive. Za bogatejše je obratno. Je pa oboje pravljica.
no comment ::
Iz perspektive povprečnega Argentinca. Ali pa Slovenca.
Da pa največji kapitalisti živijo celo bistveno boljšo pravljico kot pa jim jo obljublja "pravi kapitalizem" pa mislim, da ni neka novica.
Havana Collapse: Ameriški Prevzem Kube 2026 (strani: 1 2 3 4 )
Oddelek: Problemi človeštva
16511754 (1436) enavlaka
Komunizem (strani: 1 2 3 4 5 6 )
26339486 (33191) nergac
Umrl je Fidel Castro (strani: 1 2 3 4 5 )
22178525 (73637) stara mama
Novopečeni diktator Venezuele Maduro (strani: 1 2 3 4 … 7 8 9 10 )
470144106 (138362) NavadniNimda
