Forum » Kaj kupiti » GIGABYTE, AMD, AM2+, 790X (GA-MA790X-DS4 1.0)
kiros ::
kaj menite o tej plošči:
http://www.nakupi.net/izdelek_OP-GIGABY...
Rad bi kupil novo ploščo s podnožjem am2. Ali priporočate kaj drugega do 100€?
kiros
DJ MartiNi ::
Sem imel to plato, pa mi je po kakih treh mesecih crknila. Drugače pa je kar solidna plata. Edino kar me moti pri njej je to, da je opremljena z južnim mostom SB600, ki pa ni ne vem kako dober. Sem pa na njej mel navitega Phenoma X3 8450 na 2900MHz in je delalo brez problema. Sam bi ti priporočal katero drugo plato, recimo ASUS M3A-H/HDMI za slabih 79€. Kateri procesor pa imaš in če boš kaj navijal.
Ryzen 7 7800X3D/MSI B850 Edge Ti Wifi/2x16GB G.Skill Ripjaws S5 6000/RX 7900 XT
Ryzen 7 5700X/ASRock B550 PG Velocita/2x16GB G.Skill Ripjaws V 3600/RX 5700 XT
AMD FX-8350/ASRock 970 Extreme4/2x4GB Kingston HyperX Beast 2400/R9 270X
kiros ::
imam AMD X2 4200+ a bi ga rad navil na 3 GHz ker sem slišal da se ga da normalno navit na 3Ghz a rabim boljšo ploščo
kiros
- spremenilo: kiros ()
Gamez0r ::
The major downsides of SB600 according to user consensus are:
a) RAID errors and erratic functioning in RAID 0/1, specifically on Vista 64-bit.
b) AHCI not working properly so SATA drives nearly always are running in IDE UDMA 6 mode.
c) HDD and ODD SATA/IDE combinations on many motherboards may not function correctly or not function at all due to SB600 problems which are not remedied in the BIOS releases although could be.
d) Lower USB and HDD performances in general.
e) A clock generator bug which means it will induce erratic overclocking behaviour every 9/10 attempts and limit the processor overclock somewhat substantially with the known "poor overclockers". The cause is very likely on-die PLL's falling out of the required phase synchronization window parameters.
f) For the same reasons, poor and/or limited HT overclocking.
The latter two are critical problems for overclockers in that, you can fall 200 - 500 MHz short of the actual overclocking silicon frequency limit due to synchronization errors within the allocated time.
Vzeto iz http://forums.amd.com
Torej je Asus M3A-H/HDMI prava zate.
WTF!
x45 ::
tale gigabyte ima SB 700 v reviziji 2,0 in 5 fazno napajanje ( max 140w TDP cpu ) in še kako izboljšavo. pa crossfire seveda.
R1.x z SB 600 pomoje več ni v prodaji. Preveri...
po moje dober nakup.
sem pogledal zdaj ampak revizije so izginile in SB je še vedno SB 600. Čudno res. stare so mele 4 fazno napajanje tale pa ima 5 faz sam ne vem kje je SB 700.
http://www.gigabyte.com.tw/Products/Mot...
- spremenilo: x45 ()
jest10 ::
2.7 Ghz na ASUS M2N-E
Za 300MHz navitje je brez veze zapravljati denar za novo matično. Na koncu bi se pa še mogoče izkazalo, da te v resnici omejuje slabši primerek procesorja...
Če si že tako zagret za menjavo, potem vsaj pri kom stestiraj svoj procesor, če je v resnici kriva plata za po tvoje slabo navitje.
kiros ::
sm kupil M3A-H/HDMI, ne morem pa navijat procesorja, saj je blokirana frekvenca na 200mhz. A se da to kje spremenit?
...jest10: ploščo sm kupil ker se mi je prejšnja pokvarila ;)
kiros
DJ MartiNi ::
Mislim da moraš AI Overclocking nastavit na Manual.
kiros ::
aha..hvala
to je blo
sem pa presenečen da rezultati so malenkost boljši kot na stari plošči m2n-e
zgleda da je slaba verzija procesorja
to je blo
kiros
| » | AMD Phenom II Uporabne informacije, izkušnje, testi, navijanje, plošče ..... (strani: 1 2 3 4 … 99 100 101 102 )Oddelek: Strojna oprema | 301728 (134390) | x45 |
| » | AMD Phenom- uporabne informacije: CPUji, plošče, BIOSi, izkušnje- držite se teme, pro (strani: 1 2 3 4 … 19 20 21 22 )Oddelek: Strojna oprema | 67234 (30744) | Meizu |
| » | Matična plošča Gigabyte GA-MA790X-UD4Oddelek: Kaj kupiti | 2204 (1916) | TOP |
| » | AMD phenom 2 x3 720BE (strani: 1 2 )Oddelek: Kaj kupiti | 6700 (5367) | DJ MartiNi |
| » | AMD SB750 na Foxconn A79A-SOddelek: Novice / Procesorji | 4646 (2515) | PrimozR |
