Forum » Igre » Doom III
Doom III
suntrace1 ::
Z artefaktom, ki si ga pobral na začetku igre upočasniš čas, tako da boš lahko mirno pretekel tistih par metrov, polniš pa ga z dušami trupel.
Torej vzemi stvar v roke, fire in teci.
Sami ::
Kako čez ta vrat vsakič ko hočem preko me ubije se zataknem na vratih in me zdrobi, je kaka finta tu.
Control time to defeat the enemy and evade deadly traps
mich ::
Mali Problem, ko sem dodal se eno 7800GT v SLI mi doom3 ne dela.
Vse ostalo mi deluje, imam nove gonilnike in popravek za doom3.
napise mi;
X..GL_EXT_shared_texture_palette not found
X..GL_EXT_texture3D not found
X..GL_EXT_stencil_wrap not found
X..GL_NV_register_combiners not found
X..GL_EXT_stencil_two_side not found
X..GL_ATI_separate_stencil not found
X..GL_ATI_fragment_shader not found
X..GL_ATI_text_fragment_shader not found
X..GL_ARB_vertex_buffer_object not found
X..GL_ARB_vertex_program not found
X..GL_ARB_fragment_program not found
ERROR: The current video card / driver combination does not support the necessary features.
Error during initialization
Shutting down OpenGL subsystem
...wglMakeCurrent( NULL, NULL ): success
...deleting GL context: success
...releasing DC: success
...destroying window
...resetting display
...shutting down QGL
...unloading OpenGL DLL
POMOČ
napise mi;
POMOČ
mich
Orchestra ::
Jow, evo moje konfiguracije:
Radeon 9600PRO 128MB
2x256DDR
Sempron 2200+ nenavit(1,5Ghz)
Asrock k7Upgrade 880
20GB ATA(200GB sata otišo rakom žvižgat)
Okol 7000 pa še mal pik v 3dmark2001SE(patched)
Evo problema:
Doom III skor da mi ne dela, par fps mam, use na ultra low. En tip ma 4200ti pa ma 30fps...no comment
2x256DDR
Evo problema:
stock ::
Mogoce mas kj z driverji... Jst sm meu takrt se fx5200 pa 256RAMa, Pa se prou spomnem da sm igrou na 800x600 Low/Medium. Tud 3dmark01 sm meu 6k..
ripmork ::
ja vzrokov je dosti:
od slabih drajverjev, količine rama in procesorja, zdravstveno stanje računalnika(antivirus,register cleaner,spyware...)
sam imam 9500 PRO pa isto 2x256 rama in Athlona 2400+(nenavit), pa mi je Doom 3 čist spodobno delal na resoluciji 800x600 pa na med detajli...sem pa to nazadnje špilal že ohoho nazaj,sam kolikor se spomnim ni bilo kakih problemov,jasno pa nimam konfiguracije da bi dal vse na high pa resolucijo nabil take scene...
Orchestra ::
3dmark 2001 SE(patched), registrirana verzija, default test + 4 testi dodani(image quality)
SLIKA
2x256DDR
20GB ATA
SLIKA
2x256DDR
20GB ATA
- spremenil: Orchestra ()
R33D3M33R ::
Mah.
Tudi meni Doom 3 ne dela več tako kot je včasih. Sem poskušal preizkusiti Resurrection of Evil razširitev pa mi je bilo že od začetka sumljivo zakaj tako počasno deluje - štekalo je kot ne vem kaj. Potem sem pa poskušal z raznoraznimi tweaki, ki so mi že enkrat pomagali pri pridobitvi FPS. Rezultat: porazen. Na najslabši kvaliteti in resoluciji 640x480 mi timedemo demo1 (usecache vklopljen) ne pride čez 40 fps. Grrrr! Včasih mi je delovalo čisto OK na 800x600 in medium.
Sploh ne vem zakaj mi ne deluje več na primernih FPS. Mogoče je bil kriv patch? V glavnem za znoreti
Preizkusil sem pa Catalyst 5.10 in 6.3.
Imam pa R9500Pro 128 MB, AXP 1800+, 768 MB RAM - mekaj takega kot ti Orchestra. Mogoče bo tebi pomagal kak ta tweak.
Nekdo je usposobil DooM 3 alfa (E3 demo) verzijo iz leta 2002:
| » | Half-Life II (strani: 1 2 3 4 … 31 32 33 34 )Oddelek: Igre | 133328 (12804) | oo7 |
| » | Doom 4 (strani: 1 2 3 4 … 11 12 13 14 )Oddelek: Igre | 141245 (56532) | SoundBlaster |
| » | 6800 gt sparkle (strani: 1 2 )Oddelek: Strojna oprema | 7408 (6402) | jest10 |
| » | Quake IV or 4Oddelek: Igre | 2754 (1596) | Tilen |
| » | NV35 ali GeF FX 5900 Ultra (strani: 1 2 )Oddelek: Strojna oprema | 6210 (5500) | Ahiles |
