Forum » Na cesti » Formula 1 2020
Formula 1 2020
springfield je izjavil:
@Gambino zanimivo, da se ti zdi vredno prilepit samo stvari, ki govorijo proti Ferrariju. Ocitno izrazas svoje mnenje s tem. Se bolj zanimivo pa je, da porabis vec casa s Ferrarijem kot Mercedesom, za katerega baje navijas.
Pa daj ti prilepi prispevke medijev, ki govorijo v prid FII.
Tle se sploh ne gre za to, ali si za ali proti Ferrariju. Če so goljuali sploh ni pomembno. Pomembno je le obnašanje FIE, ki pa je nadvse sporno.
Cr00k ::
Ne da se mi na dolgo pisat... je pa na redditu en lepo napisal in si preberite. Nihče nima dokazov proti Ferrariju. Se je pa FIA uspela dogovorit za hud monitoring (zato NDA) in nadzor. Ferrari ni želel, da to pride v javnost ravno zaradi Gambinotov, kateri takoj pritisnejo petelina in strelajo vsepovprek z obtožbami, čeprav so (dokler ne dokažejo) nedolžni.
Kar se mene tiče kapo dol FII, da so se za tak deal uspeli pogoditi. Ferrari bi jih lahko poslal v tri krasne brez dokazov.
Why the FIA-Ferrari Deal is the only right solution for the FIA
First of all: This is NOT meant as a defence for the FIA or Ferrari. This is purely an explanation to why this deal happened the way it happened.
The FIA came to an agreement with Ferrari over the engine issue last year, which was followed by a public outrage from the other F1 teams and the majority of F1 fans. I will try to explain why the deal benefits the FIA the most.
1.) The FIA was not able to prove that Ferrari was cheating. They assumed it, but they can't prove it. Without proof, you can't punish a team, otherwise you will most definitely lose if it goes to court. So the only option was bringing Ferrari to the table and negotiate a deal, otherwise it would have been a farce after all the talking last year.
2.) The FIA will most probably gain a lot of insight from Ferrari. Not only explanations about how the PU trick works, but schoolings of the whole concept. Plus they will most probably gain informations on other parts of an F1 car too, like how the flexible wings actually work, etc. FIA will be able to use new methods of monitoring overall, which is always very healthy for the sport.
3.) Ferrari will still get hurt through the deal, they have sort of confessed of cheating. Their public reputation got hurt and they aren't just a racing team, but a public company. And a public company always depend on their public reputation. This could result them in losing millions in stocks.
4.) This is probably the most important aspect for the FIA. If they did go to court and lost, that would mean that the FIA, the most important institute for motorsport and cars in general, has implemented rules which they are not able to monitor. This would question the importance of the whole governing body. After all, companies spent billions for the power unit. If they are not able to monitor them, then what are they there for after all?
Why they did not publish the content of the deal can be explained to: Because Ferrari wanted it that way, otherwise they would not get a deal.
springfield ::
Zdaj ne vem, ce si polpismen al res ne ves, da kljub prepricanju nekaterih Ferrari ni FIA. In zgoraj mas lepo obrazlozitev. Nobenih dokazov ni proti Ferrariju, ce bi jih imeli, bi se vlagali tudi uradni protesti na dirkah, ne pa neko po ovinkih sprasevanje pri FII. FIA je naredila vse znotraj pravil. Mimogrede, ce se ne motim, je bilo pravilo za NDA dodano ravno, ko je Mercedes imel tisti skrivni test s Pirellijem. Ampak se lepo vidi, kako si "nevtralen".
- spremenilo: springfield ()
Gambino ::
Točno tako. Samo nekateri tega ne razumejo in nikoli ne bodo.
springfield ::
Te pa dajta prosim vidva "genijalci", ki edina razumeta (ocitno niti FIA ne razume), nam butlom razlozit, kaj bi morala naredit FIA v tem primeru? Razkrit vsem ekipam kako deluje Ferrarijev motor, ceprav ga nimajo za ilegalnega? Vztrajat pri tem, da je Ferrari ilegalen in izgubit tozbo na sportnem sodiscu, ker nimajo dokaza proti njim razen slutnje Totaja in Helmuta, ker imajo boljsi motor od njih?
Če FIA Ferrarijevega motorja nima za ilegalnega, naj jasno napiše, da je legalen, ne pa da nekaj serje z NDA :)
- spremenil: Sheteentz ()
springfield ::
Vsak motor se smatra za legalnega, dokler se ne razglasi za ilegalnega. Al ti more FIA priporoceno domov poslat, da je Ferrarijev motor legalen?
Da.
springfield ::
Zal si popolnoma irelevanten za FIO, tak da se ti to zal ne bo zgodilo. Zdaj pa se hitro malo pojokcaj, kak je FIA ne fer, ker niso razkrili vseh Ferrarijevih skrivnosti.
MaterVola ::
The Australian Grand Prix has been called off, two senior Formula 1 sources have told BBC Sport.
https://www.bbc.com/sport/formula1/5184...
masevc ::
Kolikor jaz spremljam se ni nic odpovedano.
Dirkaci ne zelijo nastopiti, organizator pritiska za zacetek (denar..).
pirlo ::
Ne razumem zakaj se tako borijo proti dirki. Že tista Hamiltonova izjava je bla čudna, pol pride en bolan Anglež, čeprav so se vsi bali Italjanov. McLaren odstopi zaradi enega okuženega v ekipi. Res mi ni jasno v čem je fora.
PrimozR ::
Case in point.
broken/link ::
na twitterju 15min nazaj
https://twitter.com/F1/status/123824042...
"Formula 1 and the FIA, with the full support of the Australian Grand Prix Corporation (AGPC), have taken the decision that all Formula 1 activity for the Australian Grand Prix is cancelled"
billy ::
Pa ravno zdaj, ko bi moral šport "cvetet", ker je večina folka paničnega in v "karanteni", ergo so več pred TV :) Tistih nekaj gledalcev ob stezi imo ne prinesejo muchos dineros...
pirlo ::
To je vse del tega plana, sejanja panike. Če bi šport potekal normalno dalje, ne bi bilo takega efekta. Samo ne vem komu to koristi. Neke čudne zadeve se tu dogajajo.
masevc ::
Pirlo, se ti ne zdi, da si ti malo cuden v tej zadevi?
Ko jebe F1 ob vsej nastali situaciji.
Get a life
Get a life
pirlo ::
Jaz sem čuden, ker nisem v vsesplošni histeriji? Verjetno res ja. Jaz mam life, večina ga trenutno nima.
Scorpy84 ::
Ne gre se za histerijo, ampak za odgovorno ravnanje. Sicer pa je to predmet ene druge teme, naslov te je Formula 1 2020.
Torej, Avstralija je splavala po vodi, najbrž bo odpovedan tudi Bahrain prihodnji teden. Kaj menite?
Osebno mislim, da je pod vprašajem vse vsaj do Azerbajđana.
springfield ::
RB, AT in RP so baje hoteli dirkat v Avstraliji.
Mercedes, Ferrari in Renault so ze napovedali, da ne bodo sli v Bahrajn. Tudi motorjev ne bodo dobavili ekipam. Govori se, da bi naj zdaj uvedli obvezno mirovanje ekip in bi namesto poletnega premora izpeljali dirke, ce bo situacija seveda dopuscala.
Me drugim pa Mercedes zapusca upornike proti FII in Ferrariju https://f1-insider.com/en/news-en/formu...
pirlo ::
Mercedes je tudi hotel, do klica iz Stuttgarta. Ferrari ve da še ima kup problemov in je to izkoristil. Zakaj so pri Mercedesu spremenili mišljenje pa je vprašanje, bo treba še malo počakat. Možno da je kakšna povezava s tem zadnjim dogovorom. RB, ki je letos zelo dobro pripravljen od štarta bo tu potegnil najkrajšo.
springfield ::
Uradna verzija je trenutno, da bi radi zaceli konec maja, torej v Monaku. Monako je menda edina dirka, ki se je ne da premaknit zaradi logisticnih tezav samega mesta. Sam ne bi imel nic proti, ce Monako izpustijo in zacnejo junija.
Čestitam za navedbo enega najbolj neverodostojnih virov, kar jih obstaja.
springfield ::
Potem pa prosim navedi vire, ki so po tvojem strokovnem mnjenju verodostojni in jih lahko uporabim.
TOP ::
Sevada bi Lojzek rad dirkal,ker vejo da imajo avto veliko hitrejši od konkurence.Razmišljajo celo,da naj bi spremembo pravil,prestavili na leto 2022,evo pa bo Lojze lahk osvojil še dva naslova.
Lewis pokazal, da ima možganske kapacitete retardirane amebe. Res, ful šokantno ob vsem tem worldwide dogajanju :D
PrimozR ::
Ne, samo TOP-ov komentar je prebral, mojega linka pa iz nekega razloga ni pogledal.
Ironično to glede možganskih kapacitet...
Res je, sam sem na nivoju retardirane amebe. Več moram hodit na luft, glede na to, da mi že osnove bralnega razumevanja delajo probleme.
Še dobro, da je FIA zakuhala to s Ferrarijem, da boste imeli kost za glodanje do junija ali julija, ko bodo (če bodo) spet začele dirke.
EnStot ::
No, tudi kronan virus ima dobre strani. Odpovedana je Evrovizija, sedaj pa še kakšne pol sezone največjega dolgočasja na TV, Formule 1. Kadarkoli sem hotel aktivirati zdravilni nedeljski popoldanski spanec, sem se samo vsedel pred telečjo vizijo in preklopil na F1.
Bravo kronski virus, tako se dela!
Vazelin ::
torej ma sedaj hamilton dejansko šanse, da po naslovih prehiti schumacherja
| » | Formula 1 2019 (strani: 1 2 3 4 … 30 31 32 33 )Oddelek: Na cesti | 251273 (185833) | |
| » | Formula 1 2017 (strani: 1 2 3 4 … 23 24 25 26 )Oddelek: Na cesti | 216910 (148469) | broken/link |
| » | Formula 1 2016 (strani: 1 2 3 4 … 37 38 39 40 )Oddelek: Na cesti | 311664 (225591) | kosta |
| » | Formula 1 2015 (strani: 1 2 3 4 … 66 67 68 69 )Oddelek: Na cesti | 462832 (318427) | BT52 |
