Forum » Igre » Rise of the Tomb Raider (Tomb Raider 2)
Rise of the Tomb Raider PC patch adds new graphics options, fixes critical issues
Startup issues (Steam Only):
Fixed C++ runtime error showing up on startup preventing some users from running the game.
Provided work-around for issue where the VC++ redist would not properly get installed, stopping the game from starting at all.
Solved problem where the game would crash on startup when tools like Bins Taskbar organizer or Spacedesk are installed.
Updated options screen with among other things
Independent mouse sensitivity control for aim and regular navigation.
Mouse and Gamepad X axis inversion
Option to disable keyboard button prompts.
Option to disable mouse smoothing (very light mouse smoothing is present otherwise)
Other fixes
A variety of fixes and improvements to UI including map, basecamps, and Remnant Resistance mode.
New graphics option 'Specular Reflection Quality' to enhance resolution and reduce aliasing of specular reflections, at some performance cost.
New graphics option to disable film-grain independently from 'Screen Effects'.
Improved HBAO+ quality, including better occlusion for distant objects.
Improved NVIDIA SLI performance. (Steam only)
Fixed SLI glitches during water/snow effects. (Steam only)
Resolution Modifier option that allows you to use a lower rendering resolution independent from window size when running in windowed mode.
Performance optimization for situations where Razer Chroma features are enabled. (Steam Only)
Improvements to Razer Chroma effects. (Steam Only)
Fixed an issue that could rarely lead to an error on machines with 16 hardware threads or more.
Fixed mouse cursor not always being hidden when using gamepad.
Fixed major stuttering in Endurance mode.
Fixes for Endurance leaderboards.
Fixed Remnant Resistance missions occasionally not starting.
Fixed rendering glitches on some objects on NVIDIA 6×0 and 7×0 hardware. Some issue do still happen and we are working with NVIDIA to resolve those in future patches or drivers.
Warning messages for users turning textures to Very High or enabling SSAA to indicate high-end hardware is required.
A variety of other smaller optimizations, bug-fixes, and tweaks.
Other fixes
Evo končal kaj naj rečem igra mi je bila všeč se je splačalo počakati
Končal sem na 84% in za to porabil 21 ur.
Sama igralnost se mi je zdela enaka kot v prvem edino lokacije so mi pa bile v tem drugem delu res fenomenalne sploh ta sibirija in sneg :)
Zgodba pa je nastavljena za nadaljevanje torej čez 3-4 leta nov Tomb Raider ?
Najljubše orožje pa definitivno lok in strupene puščice, ki so bile najbolj učinkovite proti vsakem sovražniku sem nabiral gobe kot nor
e-marko ::
Ok, razmišljam o nakupu. Kje dobiti najceneje?
In ali bo zadeva dovolj igralna na i5 2500K 3.30 GHz in R9 270X?
Hvala.
Hvala.
...somebody, somewhere...
Hvala.
Koliko imaš pa Ram-a?
Drugače pa minimum zahteve so:
OS: Windows 7 64bit
Processor: Intel Core i3-2100 or AMD equivalent
Memory: 6 GB RAM
Graphics: NVIDIA GTX 650 2GB or AMD HD7770 2GB
DirectX: Version 11
Storage: 25 GB available space
Jaz mislim, da bi moralo delati brez problema.
e-marko ::
8 GB RAM. Sem malo pogledal po yt in poganjajo s tole kartico, ja.
Na cdkeys je za 30 eur. To je trenutno verjetno minimum?
He-Man ::
OS: Windows 7 64bit
Memory: 6 GB RAM
DirectX: Version 11
Od nekoga prenosnik izpolnjuje vse zgornje zahteve, razen GPU ima švoh: AMD Radeon HD 6650M.
Bo Rise Of The Tomb Raider sploh delal na taki mašini, tudi če bo vse na "low"? Ali bo štekal, kaj mislite?
Jst ::
>3.5Gb je itak preveč.
Kaj si sploh pogledal video? V videu tip nastavi teksture iz High na Very High in mu na 2x 970 šteka ko pra**ca. Zakaj limaš videe, ki jih očitno sploh ne pogledaš, potem pa še izjavljaš samo-kontradiktornosti???
Alien123 ::
so nVidia butthurti pravli da je 3.5 Vrama preko dovolj.. omg lal :D
Saj ga je dovolj.
Jaz sem celo igro preigral na GTX 970 na very high nastavitvah brez vsakega problema.
100 ludi 100 čudi.. naprimer tebi štekanje ni problem, meni pa je..
100 ludi 100 čudi še enkrat preberi kaj sem jaz napisal.
AapocalypseE ::
Še bom enkrat prilimal video, da boste videli kako trokira na MAX. nastavitvah 970.
Za info. samo, poglejte 1:03 kako 970 suvereno gre mimo listja s 50fps, 390 pa padejo fpsji na 36 in slika kar zastane. Stuttering party na 390...
Zanimivo bi bilo tudi vedeti clocke obeh kartic.
PredatorX ::
"Can the GTX 970 and R9 390 handle Rise of the Tomb Raider maxed at 1080p60? The answer's no - this game is demanding, trashing our budget PC on console equivalent settings. You'll need a quad-core processor and a GTX 960 to beat the Xbox One experience, and GTX 970 to hit 1080p60."
Različne mape = drugačen VRAm usage. In če se prav spomnim so kle uporabili high texture.
- spremenilo: PredatorX ()
AapocalypseE ::
Če piše maxed, potem je maxed in nič manj in ne se ne delaj norega trollek...
Rise of the Tomb Raider running unlocked on max settings on the R9 390 and its Nvidia counterpart, the GTX 970. It's a demanding game that monsters our budget PC, and requires deft settings management for the best experience - but we still managed to get good 1080p30 and 1080p60 gameplay experiences.
The pursuit of 1080p60 at these same settings takes a little more grunt of course, something we can achieve using a GTX 970. Even with tessellation enabled it sits at a solid 60fps, with only The Village level causing frame-drops below. This is a one-off problem area, and the simple solution is to switch this option off - though alternatively, the issue can be mitigated to a degree via overclocking.
Ni problema z vramom trolleki amd-jaški
AapocalypseE je izjavil:
Jaz sem igral 21 ur brez problemov edino, ko sem prvič prišel v tisto Rusko vas mi je 1 minuto štekalo potem pa nič več. 1 minuta od 21 ur na very high nastavitvah lahko samo rečem ODLILČNO. Kartica GTX 970 me do zdaj ni še nikoli razočarala
- spremenil: oo7 ()
AapocalypseE ::
Največji pa si ti, ker bluziš nekaj v tri dni tukaj na forumu...
Idi malo na zrak ven. Danes je fajn pihalo, bi ti lahko malo razpihalo to tvojo pamet.
PredatorX ::
Zase govori.
In pri eurogamerju so uporabili high texture. In prav tako je M-Powerju Gforce experience naštimal high texture, neglede kakšne nastavitve je sam on naštimal.
PredatorX ::
"Those with 4GB GPUs are recommended to use High as VRAM stuttering can be observed on Very High, especially when swapping between gameplay, cutscenes and cinematics, and between gameplay zone transitions.
For a smooth experience with those max-quality, 4K x 4K textures, a 6GB GPU is instead recommended. And to crank things up to 4K (3840x2160), with Very High textures and max settings, we'd recommended GeForce GTX TITAN X GPUs with 12GB of VRAM, as usage can near 10GB over prolonged sessions.
Performance: As you'd expect, adjusting Texture Quality has a minimal impact on performance, with only two frames per second separating Very High and Low."
ker sem največji troll dodajam še potrdilo od NVIDIAje, da 4Gb kartice nemorejo laufat teh textur. In M-Power je ubistvu igral z "high texturami".
http://www.geforce.com/whats-new/guides...
https://www.reddit.com/r/pcgaming/comme...
https://steamcommunity.com/app/391220/d...
ZbitaGrinta ::
sem malo igral na xbox pa mi igra ni bila všeč starejše verzije so mi boljše.
kar se pa tiče grafičnih kartic pa se je brez veze kregat sploh zato, ker AMD bo čez par let propadel Nvidia ima vsako leto višji tržni delež zdaj ga ima že več kot 80% in Amd je z zadnjo serijo grafičnih kartic pridobil samo 0,8% v tržnem deležu kar je vse skup nič.
Alien123 ::
ZbitaGrinta je izjavil:
saj pol lahko rečemo za Sony tudi da bo če par let propadel, saj ga samo ps4 gor drži..
Saj mogoče bi res bilo boljše da bi AMD propadel, da bi plačevali za medium grafe preko jurja.. Pa da bi vsak driver bil plačljiv.. Za vas nVidia plebe bi še vam to kul blo..
PredatorX ::
@Alien123
Eh, ja sej tud NVIDIA ni ravno na trdih tleh, prav tako INTEL. Intel lahko izgubi google.
GenZNPC ::
@Alien123
Sej ves Commodore, Amiga, motorola so bili tudi superiorni, pa jih ze dolgo ni. Pa vseeno dobis HEVC capable pentiuma, z DDR4 plato za 110EUR. OMG.
Kdaj si kupu nazadnje IBM PC, vodoo karto, zvocno ? ?
Glede Sony pa:
Im vergangenen Jahr habe Sony fünf Mal so viele PlayStation 4 wie Microsoft Xbox One in Deutschland verkauft. Zuvor lag das Verhältnis bei gut 4:1.
in upostevaj se kolko oni zasluzijo na azijskem trgu (miljarde ljudi) z azijskimi ekskluzivami.
Nvidia je ravnokar zmagala na sodiscu, proti samsungu. AMDjasi se se spomnimo, kak ste bli pametni?
Glede Sony pa:
skibidi
- spremenil: GenZNPC ()
Jst ::
Kakšna grda slika.
PredatorX ::
Zakaj se mi zdi, da ima AMD dosti lepšo sliko?
- predlagal izbris: Thuban ()
Jst ::
To so neke čudne nastavitve. Še FXAA ne bi izgledal tako. Potem njeni lasje. In to laufa na dveh GPUjih. Me zanima, kaj je avtor te slike hotel sporočiti.
AapocalypseE ::
Kaj noben ne vidi kako lepo se ji ritka sveti?
Raje grafiko gledate omg
- spremenil: AapocalypseE ()
ahac ::
Kam gre ta forum ajej...![]()
Fanboyi se kregajo... in ne vidjo, da fanboyisem škoduje gamingu...
PredatorX ::
Kr si cuden in fanboy
Aja... zakaj si užaljen trollek? Nebi bilo prvič...
Kje je zdej streetracer, da bo začel nabijat kako GTX 970 laufa 4k texture z 3.5Gb VRAMA.
AapocalypseE ::
Čudi me, da še ni dobil ta trollasti predatorček kakšnega naziva in opomina.
Res že meji to na obsedenost
Thuban ::
kako se lahko prepirate o takih neumnostih namesto da bi nekdo pohvalil delo dizajnerja ki je tako lepo oblikoval ritko Lare Croft?
Dajte debatirat o igri. Če se hočete borit za dolžino penisa imate na razpolago privat pogovore.
I'm sorry, Dave. I'm afraid I can't do that.
- spremenil: Thuban ()
Thuban ::
je bilo lepše ko smo na VoDoo 3 2000 in kasneje na Geforce 4 mx440 igrali začetne verzije Tomb Raiderja, kjer smo namesto mlekarn na zaslonu gledali orjaške piramide.
Se ni nihče pizdil glede takšnih neumnosti.
jao kakšno veselje je bilo ko je iz tega
ratalo to
much 3d, so smooth, waw O_o
ratalo to
Kaj je tukaj suvereno?
AapocalypseE ::
Sem napisal 970 50fps vs. 36 in zastanek slike na 390.
Še napišem v katerem drugem jeziku?
| » | Tomb Raider 2 - Film (strani: 1 2 3 4 )Oddelek: Sedem umetnosti | 31998 (3584) | oo7 |
| » | Tomb Raider (strani: 1 2 3 4 5 6 7 8 )Oddelek: Igre | 82060 (32941) | oo7 |
| » | Shadow of The Tomb Raider (Tomb Raider 3) (strani: 1 2 3 4 5 )Oddelek: Igre | 43306 (17648) | oo7 |
| ⊘ | Tomb Raider (2017) (strani: 1 2 3 4 5 6 7 8 9 )Oddelek: Sedem umetnosti | 90351 (70269) | ahac |
| » | AMD pokazal svojo najhitrejšo grafično kartico Radeon R9 Fury X2 (strani: 1 2 3 4 5 )Oddelek: Novice / Grafične kartice | 78600 (71779) | Napajalc |
