CuBox Pc
CuBox Pc
BlackMaX ::
Danes sem naletel na kar dobro alternativo Raspberry Pi modelom, katera ponuja nekaj več. Seveda, razlika je v ceni ampak je dokaj zanimiva stvarca.
Je slučajno kdo naletel na kaj podobnega? Na ebayju je cena Cuboxa-a cca. 150 dolarjev
Designed as an open source development platform, use CuBox to create your own media center, thin client, XBMC console, network attached storage device, or anything else you want. Boasting 1080p full HD output, HDMI out, and a full gigabyte of RAM, it's incredible what you can create with this tiny device.
Applications
The CuBox Pro developer platform is highly energy efficient and based on Marvell Armada 510 SoC. The uses for the device are endless, yours might be used as a thin client, network attached storage, digital signage solution, set top box, Android TV, home security device or as a well-rounded media player. Take advantage of the following key features:
Linux based distributions like Ubuntu, Debian and others
Android
800 MHz dual issue ARM PJ4 processor, VFPv3, wmmx SIMD and 512KB L2 cache.
1080p Video Decode Engine
OpenGL|ES 2.0 graphic engine
HDMI 1080p Output (with CEC function)
2GByte DDR3 at 800MHz
Gigabit Ethernet, SPDIF (optical audio), eSata 3Gbps, 2xUSB 2.0, micro-SD, micro-USB (console)
Standard Infra-red receiver for 38KHz based IR controllers.
No JTAG required. Unbrickable for Developers!**
Supported Standards
Video Output Up to Full-HD at 1080p60
Video Codec HD - H.264 HP@L4.1, VC-1 AP@L3, WMV 9 MP@HL, MPEG-2 MP@HL, MPEG-4 ASP, DivX, Xvid
Video Container MKV, M2TS, AVI, MPG etc...
Technical Specifications
Main Processor ARMv7 running up to 800MHz
DRAM 2GByte, 32 bit, 800MHz Data Rate DDR3.
Network One 10/100/1000 Ethernet Port
USB Host 2 High Speed Ports
USB Device 1 device used for development purposes.
HDMI 1 HDMI Output Port (with CEC support)
Audio 1 Optical SPDIF Output Port
Storage – MicroSD One MicroSD - System ships with 4GB for system files. Can be upgraded to 64GB or more by the user.
Storage – eSATA One eSATA Port Supporting both Gen-1 and Gen-2
Infrared Infrared Receiver with LIRC software support
Input power 5mm/2.1mm DC Jack. Requires a 5V/2A power supply (included). Actual current consumption is much less if no USB devices are connected to the system.
Power Consumption Streaming from fast Ethernet and playing Full HD less than 3 W. Certain tasks and configurations might produce higher power consumption.
Dimensions Approximately: 55mm x 55mm x 42mm.
Software Architecture
OS Android 2.2, Linux
Media Player XBMC Media Player with all supported plugins. Example: YouTube plugin – supports 1080p playback
Browser Chrome browser with flash 10.1
Video Gstreamer based video acceleration architecture
USB Subsystem Mass storage device support and USB wifi (11 b/g/n based).
eSata External storage bricks addition via eSata
mirancar ::
teh TV predvajalnikov imaš veliko ...
USB 3.0 dvakrat hitrejši (strani: 1 2 )
6926684 (22303) Lonsarg
Katero in kje kupiti osnovno ploŠčo z vodilom 1155 in sata3 priključkom
353903 (3471) easyrider3
Zotac ZBOX in 1080p?
Oddelek: Zvok in slika
82381 (2086) chiuaua2
mede8er MED500X2
83128 (2622) ge
HTPC sestava in programska oprema (strani: 1 2 3 4 5 6 7 8 9 )
41764689 (26755) umexteacher
