Forum » Zvok in slika » mede8er MED500X2
mede8er MED500X2
gregor ::
Nov predvajalnik:
http://www.mpcclub.com/forum/showthread...
http://www.mede8ershop.eu/products.php?...
http://www.mede8er.eu/products/new-med5...
The Greatest Show on Earth
The MED500X2 is the very latest Multimedia Player developed by Mede8er for today’s demanding media enthusiast. The X2 has been designed for good solid media playback from a hard drive, USB device, SD Card, Internet or Local Network source. The X2 is equipped with advanced features like Fast Gigabit Port and Super Fast USB 3.0 Slave port and is upgrade ready for the fast PCIe WiFi kit that will be available as an optional aftermarket upgrade kit. The Mede8er fully supports the very latest video codec's such as MKV-H264, BDMV, BDISO, M2TS for seamless playback of all supported media files. You can now pass full HD Audio streams via HDMI to your amplifier for a full 7.1 surround sound experience.
The Mede8er fully supports the very latest MKV/H264 codec that achieves an incredible compression ratio whilst still maintaining a reasonable file size. The Mede8er supports most SD & HD Camcorder formats - so now you can easily store all your family videos on the Mede8er and play them back in crystal clear quality on your large screen TV. Now you can really enjoy your Movies, Pictures, Camcorder Videos, Music and Internet Radio at home or when you are on the go. Just connect the Mede8er to your TV and start enjoying all your digital media on your big screen. The Mede8er incorporates a HD JPEG engine that renders still digital images with superb clarity on your large screen TV. Now you can enjoy slide shows with background music with your family and friends. For easy convenience you can even insert your Camera's SD card directly into the Mede8er and view your pictures directly from the memory card.
Designed with people in mind. The Mede8er remote is real easy to use as all buttons are clearly laid out and easy to get to. When watching video content the navigation buttons can be used to control key functions like Fast Forward, Rewind, Play, Pause and Volume. So now you can easily control your Media Player in the darkness of your TV Room. Leading edge features also include in folder preview facility that enables users to easily view cover art and content info.
It has never been easier to stream digital media content from your network PC or NAS storage device via Ethernet or optional fast speed USB 802.11n WiFi dongle.
Play just about everything... on your TV
Specifications
Processor: Realtek RTD1185- 256MB SPI Flash - 256MB DDR2 SDRAM
Video Formats Supported: AVI / BDMV Light / BDISO Light / MKV / TS / TP / TRP / M2TS / MPG / MP4 / MOV / M4V / VOB / ISO / IFO /
DAT / WMV / ASF / RM / RMVB / FLV resolution up to 720p / 1080i / 1080p
Video Codecs Supported: MPEG-1 / MPEG-2 / MPEG-4 SP /ASP /AVC (H.264) / XviD / DivX / WMV9 (VC-1) / RealVideo 8/9/10 (up to 720P)
Audio Codec Supported: Mp3 / Mp2 / OGG Vorbis / APE - APE Cue /PCM / LPCM / AAC / RA / Dolby True HD - DTS MA Passthrough on HDMI
Dolby AC3 Downmix & Passthrough / DTS Downmix & Passthrough / FLAC up to 24bit 192Khz (HDMI & Co-Ax Digital only) Flac Cue / WAV, WMA Standard (DRM, & Advanced Profile not supported)
Photo format Supported: JPEG, BMP, PNG
File System Supported: FAT32 (up to 2TB), NTFS (up to 3TB), MAC HFS+
Video output resolution: NTSC, PAL, 480p, 576p, 720p, 1080i, 1080p, 1080p. 24hz
Input / Output
• HDMI 1.3, Component Video, Composite Video
• Stereo RCA audio for analogue audio connection
• SD / Sony Pro Duo Card Slot
• SPDIF Optical - Co-Ax Digital Audio Outputs
• USB - 2.0 HOST port x 2
• USB - 3.0 SLAVE port
• RJ45 - Network Connector
General
• 3.5" SATA Internal Hard Drive Bay up to 3TB compatible SATA2 (SATA3 not compatible with current firmware)
• Built in 40mm cooling fan - TPE mounts for low noise
• Media Library Video Wall with Metadata *
• Favourites Manager *
• Alpha Jump in Media Library
• BD Menu - Non Java support
• 12 Bit Deep Video Colour support
• Internet Browser (Flash / Video playback not supported)
• Parental Control
• Playlist creation from remote
• Screensaver – Selectable in GUI setup
• In folder JPEG preview feature
• Easy navigation button use
• Resume playback feature
• Photo slide show with background music
• Network - Ethernet 10/100/1000* Mbps
• Optional Wi-Fi (802.11b/g/n up to 300Mbps) - MED10WFB
• Samba server - NAS storage
• UPnP Media Server, DLNA (DMR) complaint
• Internet Radio (SHOUTcast) / .pls Playlist support
• File Copying - Card, USB, HDD and Network
• Subtitle: SRT, SSA, SUB, SMI format
• Size: 225 X 160 X 60 mm
* Subject to Firmware update -- In development
* 1) Typical wire network transfer speeds Samba NAS -- From PC to MED500X2 (8.5MB/sec) -- From MED500X to PC 12MB/sec to MED500X2 internal HDD
* 2) Typical Video Streaming on Gigabit Network -- Full BDMV / BDISO non 3D (max 8.5MB/sec)
Contents: MED500X2, RC, 2 x AAA Batteries, AC Adapter, HDMI - Component - AV - USB 3.0 - Cables, User Instructions.
Izgleda zanimivo!
Specifications
Input / Output
General
• Parental Control
Izgleda zanimivo!
- zavaroval slike: bluefish ()
Tomson ::
140€ pri XenonForte. Kar ugodna cena napram konkurenčnim izdelkom ...
Runnagain ::
Svojega PCH-ja A-110 sem zamenjal z omenjeno zadevščino...zaenkrat imajo še kar nekaj bugov, prihaja do rebootov, zmrzovanja...pri običajni uporabi sicer nisem opazil večjih napak, vendar če ga "orenk" uporabljaš, spoznaš, da bo zadevca potrebovala še kar nekaj obratov FW-ja.
Lp, Runnagain!!
Lp, Runnagain!!
- spremenil: Runnagain ()
ge ::
Lp, Runnagain!!
Mi zaupaš kak ti dela povezava (LAN) PC - Med500X2, tukaj je predvsem mišljena hitrost prenosa ?
Meni namreč ne rata dobiti več kot ~ 1.2 Mb prenosa.
Ge
| » | Xtreamer prodigy 4KOddelek: Kaj kupiti | 4496 (2175) | fender2206 |
| » | Xtreamer ali kaj drugega?Oddelek: Zvok in slika | 22381 (21540) | Han |
| » | Medijski predvajalnikiOddelek: Zvok in slika | 2501 (2082) | baltso |
| » | Predvajanje datotek .mkvOddelek: Programska oprema | 5238 (4518) | Zvezdica27 |
| » | Mede8er MED500X Full HD Network Media Player (strani: 1 2 )Oddelek: Zvok in slika | 14681 (12279) | upgrade |
