Debian Gnu/Linux kot workstation
14 / 40
Gandalfar ::
lordkocka: kako pa izberes te nastavitve? Poskrbi, da jih bos imel napisane v /etc/modules mrezno pa v /etc/network/interfaces
r4r: kao, da si lahko na testing sam tist ni varno. Kakor tudi unstable ni varno za serverje. Lahko si pa na stable z backporti.
hruske ::
kojk so backporti varni?
Gandalfar ::
kolikor zaupas tistemu, ki dela backporte (ponavadi sebi..)
zdej r4r pomojem hoce narest neki cudnega ampak.. bo to moral sam povedat.
backporte uporabljas takrat kadar hoces nadgraditi samo en delcek drugace 'stable' sistema..
r5r ::
Gandalf: Da bom bolj jasen :\, bom zdej povedu. Postavu sem Debian unstable, kernel-image-2.4.25-1-686, kde 3.2.1, zdej pa mi tole vse skupi ne dela, navaden uporabnik se ne more prijavit v KDE oz. pri 85%(predzadnja slikca) se vse skupi ustav. Mogoce je ta napaka samo v unstable. Zdej bom vse ponovil samo, da bom bil v testing.
Evo dmesg:
Linux version 2.4.25-1-686 (herbert@gondolin) (gcc version 3.3.2 (Debian)) #1 Tue Feb 24 10:55:59 EST 2004
0MB HIGHMEM available.
128MB LOWMEM available.
ACPI: have wakeup address 0xc0001000
On node 0 totalpages: 32768
zone(0): 4096 pages.
zone(1): 28672 pages.
zone(2): 0 pages.
ACPI disabled because your bios is from 99 and too old
You can enable it with acpi=force
Kernel command line: auto BOOT_IMAGE=Linux ro root=301
Local APIC disabled by BIOS -- reenabling.
Found and enabled local APIC!
Initializing CPU#0
Detected 400.921 MHz processor.
Console: colour dummy device 80x25
Calibrating delay loop... 799.53 BogoMIPS
Memory: 123116k/131072k available (1221k kernel code, 7568k reserved, 457k data, 116k init, 0k highmem)
Dentry cache hash table entries: 16384 (order: 5, 131072 bytes)
Inode cache hash table entries: 8192 (order: 4, 65536 bytes)
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer cache hash table entries: 8192 (order: 3, 32768 bytes)
Page-cache hash table entries: 32768 (order: 5, 131072 bytes)
CPU: L1 I cache: 16K, L1 D cache: 16K
CPU: L2 cache: 512K
Intel machine check architecture supported.
Intel machine check reporting enabled on CPU#0.
CPU: Intel Pentium II (Deschutes) stepping 03
Enabling fast FPU save and restore... done.
Checking 'hlt' instruction... OK.
POSIX conformance testing by UNIFIX
enabled ExtINT on CPU#0
ESR value before enabling vector: 00000000
ESR value after enabling vector: 00000000
Using local APIC timer interrupts.
calibrating APIC timer ...
..... CPU clock speed is 400.9157 MHz.
..... host bus clock speed is 100.2288 MHz.
cpu: 0, clocks: 1002288, slice: 501144
mtrr: v1.40 (20010327) Richard Gooch (rgooch@atnf.csiro.au)
mtrr: detected mtrr type: Intel
ACPI: Subsystem revision 20040116
ACPI: Interpreter disabled.
PCI: PCI BIOS revision 2.10 entry at 0xfb470, last bus=1
PCI: Using configuration type 1
PCI: Probing PCI hardware
PCI: ACPI tables contain no PCI IRQ routing entries
PCI: Probing PCI hardware (bus 00)
PCI: Using IRQ router VIA [1106/0686] at 00:07.0
PCI: Disabling Via external APIC routing
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
VFS: Disk quotas vdquot_6.5.1
devfs: v1.12c (20020818) Richard Gooch
devfs: boot_options: 0x0
pty: 256 Unix98 ptys configured
Serial driver version 5.05c (2001-07-08) with HUB-6 MANY_PORTS MULTIPORT SHARE_IRQ SERIAL_PCI enabled
COMX: driver version 0.85 © 1995-1999 ITConsult-Pro Co.
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
Initializing Cryptographic API
NET4: Linux TCP/IP 1.0 for NET4.0
IP: routing cache hash table of 1024 buckets, 8Kbytes
TCP: Hash tables configured (established 8192 bind 16384)
Linux IP multicast router 0.06 plus PIM-SM
RAMDISK: cramfs filesystem found at block 0
RAMDISK: Loading 3932 blocks [1 disk] into ram disk... done.
Freeing initrd memory: 3932k freed
VFS: Mounted root (cramfs filesystem).
Freeing unused kernel memory: 116k freed
vesafb: framebuffer at 0xe4000000, mapped to 0xc881d000, size 1875k
vesafb: mode is 800x600x16, linelength=1600, pages=7
vesafb: protected mode interface info at c000:47bb
vesafb: scrolling: redraw
vesafb: directcolor: size=0:5:5:5, shift=0:10:5:0
Console: switching to colour frame buffer device 100x37
fb0: VESA VGA frame buffer device
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
Uniform Multi-Platform E-IDE driver Revision: 7.00beta4-2.4
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
ide: late registration of driver.
VP_IDE: IDE controller at PCI slot 00:07.1
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt82c686a (rev 14) IDE UDMA66 controller on pci00:07.1
ide0: BM-DMA at 0xe000-0xe007, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0xe008-0xe00f, BIOS settings: hdc:DMA, hdd:pio
hda: FUJITSU MPD3064AT, ATA DISK drive
blk: queue c8a10940, I/O limit 4095Mb (mask 0xffffffff)
hdc: CRD-8400C(MAS), ATAPI CD/DVD-ROM drive
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
ide1 at 0x170-0x177,0x376 on irq 15
hda: attached ide-disk driver.
hda: 12672450 sectors (6488 MB) w/512KiB Cache, CHS=13410/15/63
Partition check:
/dev/ide/host0/bus0/target0/lun0: [PTBL] [788/255/63] p1 p2
Journalled Block Device driver loaded
EXT3-fs: INFO: recovery required on readonly filesystem.
EXT3-fs: write access will be enabled during recovery.
kjournald starting. Commit interval 5 seconds
EXT3-fs: recovery complete.
EXT3-fs: mounted filesystem with ordered data mode.
Adding Swap: 417680k swap-space (priority -1)
EXT3 FS 2.4-0.9.19, 19 August 2002 on ide0(3,1), internal journal
Real Time Clock Driver v1.10f
ip_tables: © 2000-2002 Netfilter core team
parport_pc: Via 686A parallel port disabled in BIOS
8139too Fast Ethernet driver 0.9.26
PCI: Found IRQ 10 for device 00:10.0
eth0: RealTek RTL8139 at 0xc8a64000, IRQ 10
eth0: Identified 8139 chip type 'RTL-8139C'
eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
ip_conntrack version 2.1 (1024 buckets, 8192 max) - 292 bytes per conntrack
eth0: link down
Server mi brez tezav laufa na unstable :D
And it makes me wonder.
Skrat ::
r5r: a si slucajno ze postavljal firewall (iptables) in zaprl loop na localhostu??
Free software is a matter of liberty, not price.
Phoebus ::
pa za vsak slučaj napiši še "ifconfig lo 127.0.0.1" pa probaj potem zbudit KDE :D
dodajam: odgovor je 100% resen!!!
  • spremenil: Phoebus ()
Piston ::
hm...zanima me kako bi usposobu debian linux kot router (je že bilo neki govora o tem samo nič konkretnega)...probal sem že vse sorte pa še vedno mi ne dela
pač imam linux debian comp z dvema mrežnima karticama eth0 (v adsl) in eth1 (lokalna mreža)
v /etc/network/interfaces je :
auto lo eth0 eth1
iface lo inet loopback
iface eth1 inet static
address 192.168.0.1
netmask 255.255.255.0
network 192.168.0.0
broadcast 192.168.0.255
imam tudi nastavljeno ip forward v /etc/network/option in
v /proc/sys/net/ipv4/ip_forward
na winxp mašini imam naštiman ip 192.168.0.2 subnet mask : 255.255.255.0 in gateway 192.168.0.1 ter še vpisana oba dns siol strežnika...pingat se da iz obeh drug računalnik
zdej me pa zanima, kaj moram še narest, da bi to delal...aja pa iptables je izključen
r5r ::
evo firewall:
IPTB="/sbin/iptables"
IP="/sbin/ip"
# name of our Internet and intranet interfaces
INTERNET="eth0"
# what is our static IP - if we have one
GW_IP="zzz.yyy.xxx.qqq" - ip compa
# what TCP ports/services we allow (and FORWARD) from Internet
TCP_PORTS="22"
# first we flush the tables and policy
$IPTB -F
$IPTB -F INPUT
$IPTB -F FORWARD
$IPTB -F OUTPUT
# INPUT TABLE
$IPTB -P INPUT DROP
# statefull firewall
$IPTB -A INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
$IPTB -A INPUT -p tcp -m multiport --dport $TCP_PORTS -j ACCEPT
$IPTB -A INPUT -i $INTERNET --fragment -p icmp -j ACCEPT
$IPTB -A INPUT -p icmp --icmp-type 8 -m limit --limit 3/second -j ACCEPT
$IPTB -A INPUT -m state --state NEW -j DROP
mogoce pa res manjka lo ? kako dodam ?
  • spremenil: r5r ()
Skrat ::
Pred #INPUT TABLE dodas:
$IPTB -A INPUT -p all -s localhost -d localhost -j ACCEPT
wind ::
jaz za firewall na debianu priporocam Arno's IPTABLES firewall script
http://rocky.molphys.leidenuniv.nl/
kihc ::
@Piston, jaz sem našel tole.
Jaz imam pa še 2 vprašanji;
1. Zdaj ko sem uštimal sheranje povezave, mi nekaj stvari ne deluje tako kot bi moralo -- na irc se mi sploh ne connecta iz winsev (napiše too many connections, ceprav nimam se nobene), ter emula ima zavezane oči (low id). Najbrz je tukaj kaksna fora z porti, samo jaz jih nisem nic zapiral ali instalirav kaksenga firewalla.
Kaksna ideja?
2. Tale by-linux-powerd-pc bi rad upravljal iz druge kište -- se pravi telnet, vendar mi ob ukazu 'telnet 192.168.0.1', javi napako, da je bila povezava skozi port 23 zavrnjena. Zdaj nevem ali bi moral v linuxu še kaj posebenga inštalirat oz. enablat?
hvala za odgovore...
x
MasterMind ::
Posnami SSH server. Pol se pa gor poveži preko Putty. (googli :D). Telnet je itak zastarel...
kihc ::
Thnx :)
x
Piston ::
@kihc : muchos gracias...dela :)
kihc ::
Ej, kako je tebi uspelo te nastavitve shranit, da se ob rebootu ne ponastavijo? Men se resetira vse mrezna in ip_tables, tisto kar je v clanku napisano (service iptables save), pa tudi ne prime.
x
Skrat ::
Ce mas driver za mrezno skompajlan kot modul, ga moras dodat v /etc/modules
Nastavitve mreze pa nastavis v /etc/network/interfaces
Piston ::
@kihc : poglej si kako imam napisan v /etc/network/interfaces zgoraj v postu, za iptables sem pa uporabil skripto, do katere link je dal wind, super zadevca(podpira tudi ip masquerading), samo par parametrov naštimaš in odpreš katerekoli porte za nat in preverjeno deluje
  • spremenil: Piston ()
Gandalfar ::
Iscem mojstra, ki bi mi znal razloziti kako deluje KDE meni v Debianu in kako Gnome in bi se mu sanjalo kako to samodejno na kaksn eleganten nacin generirat
Phoebus ::
Za gnome: odpreš nautilus in kot naslov napišeš "Applications:///"
hruske ::
Em... Gandalfar se mi zdi da je imel v mislih bolj kako stvar deluje pod pokrovko...
Gandalfar ::
sem pogruntu pol .. ce mene vprasas je tko nekak na nivoju voodoo magica kako so si tele menije zamislili ...
se kernel je lazje hekat ;-)
kockish ::
Sem ugotovil, da po restartu deluje samo intelova mrezna, tista na maticne pa ne, tako kot ne deluje zvocna. Ocitno torej nforce2 zadeve po restartu izginejo... Kak namig?
MasterMind ::
modprobe nvnet?... (za mrežno)
kockish ::
ne dela... error v stilu da se ni slisal za nvnet...
v /etc/modules je samo
ide-cdrom
ide-detect
  • spremenil: kockish ()
Phoebus ::
gandalf: v bistvu se pa zdi meni pristop s temi meniji zelo dober, edino manjka ena dobra aplikacija za njih urejanje.
Včasih je bla cela serija fajlov ki si jo popravljal, ali pa totalno čudne zadeve ki je blo sploh kr neki, zdaj imaš pa lepo XML in te tri ali 4 fajle.
Gandalfar ::
Phoebus: ubistvu imas kompleksne XML-je, ki so razsuti po polovici sistema :>
Phoebus ::
sploh ni res da so razmetani po celem sistemu;
/etc/gnome-vfs-2.0 in v ~/.gnome2/vfolders
Pač v linuxu imaš vedno system-wide in user nastavitve.
Gandalfar ::
zdej si pa poglej kako ma to se KDE to izveden :)
r5r ::
Kako zablokirati Ctrl+Alt+Del, da ne bi prislo do reboota ? :\
Phoebus ::
poglej v /etc/inittab pod točko "what to do when CTRL-ALT-DEL is pressed".
Gapi ::
Od kar sem instaliral kernel 2.4.25 in se nek drobiz se mi pri zaganjanju linuxa pokaze tele nesrecni eror Partition check:
/dev/ide/host0/bus0/target0/lun0: [PTBL] [2495/255/63] p1 p2 p3 p4
VFS: Can't find ext3 filesystem on dev ide0(3,2).
mount: wrong fs type, bad option, bad superblock on /dev2/root2,
or too many mounted file systems
VFS: Can't find ext2 filesystem on dev ide0(3,2).
FAT: bogus logical sector size 0
VFS: Can't find a valid FAT filesystem on dev 03:02.
Unable to identify CD-ROM format.
reiserfs: found format "3.6" with standard journal
reiserfs: checking transaction log (device ide0(3,2)) ...
Ki mi je nadlezn. System deluje kolikor toliko normalno. V fstabu mam vnos za lokalne diske z pravilnimi opcijami.
/dev/hda2 / reiserfs defaults 0 0
/dev/hda4 none swap sw 0 0
proc /proc proc defaults 0 0
/dev/fd0 /floppy auto user,noauto 0 0
/dev/cdrom /cdrom iso9660 ro,user,noauto 0 0
/dev/hda1 /boot ext2 defaults 0 2
/dev/hda3 /data ext2 defaults 0 2
Kje jest delam napako? Kernel je original od debiana
No person is rich enough,to buy back his past.
Gapi ::
Ok a res noben ne ve ?
Gandalfar ::
pokazi /etc/fstab oz. ali pa imas kaksn cudn automount, ker ti neka stvar hoce
/dev2/root2
mountat .. preveri svoje .rc skripte pa mal grepaj po /etc
Gapi ::
fstab je že c&p spodaj
Sej dokler system deluje kolikor toliko je čist uredu sem se sprijaznu z tem
Aja ta suse v podpisu naj ne moti. Gre za Debiana unstasble
Jest sem debiana namestil tako da sem takoj na začetku dal pri zagonu opcijo verbose ker te le tako vpraša ker system naloži, maš na izbiro stable unstable in testing tako da mi ni treba po instalaciji ponovno vlečt dol še nekaj paketkov. Res da tvoj način deluje a men je ta hitrejši . Ker to ni mašina za v produkcijo je le za testiranje raznih distribucij.
  • spremenil: Gapi ()
Phoebus ::
poglej da nimaš v lilo.conf kakšnega appenda da je hdX=ide-scsi pa je v resnici hdd.
kihc ::
Amm, mene pa zanima neki v zvezi z ipv6.
Tukaj je pač tutorial kako na linuxu uštimat ircanje na netu preko ipv6. Zdej problem je, da kot kaže moj install nima naloženih ipv6 modulov (sem probal z modprobe ipv6 pa napiše da jih ne more locirat). Zdaj me pa zanima kako bi jaz tole stvar uštimal da bi delal? Od nekje imam info da če debiana inštaliraš iz cdja (full install ane), pride tole že gor.
Zdaj v kratkem bom jaz cel sistem formatiral in še enkrat naložu vse gor, pa sem se tak fajn navadu na net instal itd... me zanima a se da kako tole med/pred inštalacijo vključit v sistem?
Oz. če se ne kaj lahko naredim drugega razen da uporabim full install z cdja?
Aja, tist link par strani nazaj sem videl, samo mi ne pomaga 0
Hvala za odgovore...
x
hruske ::
kihc, zakaj bi bili paketi na cdjih drugačni kot na cdjih?
pomoje se ti skor bolj splača skompajlat kernel.
kihc ::
sem se bal da boš to rekel... :|
A bi lahko nekako zelo na hitro povedal, recimo da imam čisto frišen install, kaj kje kako moram to nardit? Ali pa morda kakšen hint? Sej neki sem bral kako se to dela samo amm, ubistvu mi ni nič jasno. :D
x
hruske ::
najprej
# apt-get install build-essential make-kpkg kernel-source-2.4.26 (ali pa 2.6.5)
build-essential je paketek, ki ti namesti vse kar rabis za buildat.
in naprej
# cd /usr/src
/usr/src # tar -jxvf kernel-source-2.4.25.tar.bz2
in imas novo mapo
/usr/src/kernel-source-2.4.26
potem se
/usr/src # ln -s kernel-source-2.4.26 linux
/usr/src # cd linux
/usr/src/linux # make menuconfig
potem pa
# make-kpkg
in cakas kake pol ure, da zmelje ter nato se
# dpkg -i kernel-image-2.4.25-nekibla.deb
  • spremenilo: hruske ()
nimam_uporabniskega_imena ::
No najprej lp vsi .. zdaj pa k mojem problemu, pri katerih pri drugih distrotih nism mel tezav =)
1. Kako se installirajo driveri za GeForca MX 440 (Uporabljam kernel 2.4.18 bf2.4)
2. Kako nastaviti sumnike
3. Printer --> HP deskjet 3350
za odg. se vam ze v naprej zahvaljujem =)
A pa se to debian s totim apt raztura !! :D
Can u boy give me your root =)
hruske ::
zivjo gospod brez uporabniškega imena. :D
1. preden bos nameščcal gonilnike, si posodobi jedro.
# apt-get install kernel-image-2.4.26-1-686
oziroma
$ apt-cache search kernel-image
glede gonilnikov za nvidio obstaja nvidia-glx paketek, kaj vec o njem poglej z
$ apt-cache show nvidia-glx
2. šumnike... v konzoli ali kje? v konzoli mas slovensko tipkovnico z
# dpkg-reconfigure console-common
3. printer: OpenPrinting - OpenPrinting
No zdaj pa me zanima pri tocki 1. , ce posodobim kernel a bo mi to naredlo tak kotsem kernel upgrajto iz 2.2.0 (se mi zdi nism nit gledo =) ) v 2.4.18bf2.4?
moj_nick ::
[offtopic]
Zanimivo, nekdo se je registriral tocno eno leto za mano in se enako beden nick ima kot jst :D
edit: 7 minut manj kot eno leto 8-O
[/offtopic]
110111001001010001010000
  • spremenil: moj_nick ()
[offtopic]
He he tega sploh nism vidu =)
[/offtopic]
HerrBaron ::
Mene pa zanima, če je mogoče za vsakega uporabnika posebej blokirati dostope do določenih portov na 127.0.0.1, npr.:
uporabnik abc lahko dostopa do portov 2346 - 2349, do portov 2350 - 2353 pa ne,
uporabnik bca pa do portov 2346 - 2349 ne more dostopati do portov 2350 - 2353 pa lahko
(ali pa še bolje, skupina, ne le uporabnik)
Porti ni nujno, da so zgoraj navedeni, morajo pa biti nad 1024.
Rad bi namreč naredil sledeče: uporabnik a forwarda port 5900 na server na port npr. 2346, nato pa lahko od doma "pobere" te port k sebi in ima VNC dostop do svoje delovne postaje v službi. Ker pa je takih uporabnikov več, bi rad drugim uporabnikom preprečil dostop do teh portov.
Evo problemi so reseni ...
1. skompajlo nov kernel
2. drivers --> mal so me zezali ampak je slo ! =)
Brane2 ::
HerrBaron:
Tu seveda nisem referenca, a ker ti se nihce ni odgovoril, se oglasam jaz.
Kot mi je znano, omogocajo iptables ob potrebnih modulih v kernelu filtritranje tudi glede na user id in group id izvornega procesa.
Tega ne uporabljam, le ostalo mi je v spominu. Sicer pa se mi zdi tako zaklepanje tvegana zadeva.
Ce rabite take stvari, odpri varni tunel pod SSH, IPSEC ali kako drugace...
Podrabnosti ne poznam, zagotovo pa je denimo na www.tldp.org kak Howto tudi za to.
  • spremenil: Brane2 ()
HerrBaron ::
Ker imamo v potjetju več zunanjih ip naslovov, sam na enega obesil server, na katerem teče samo ssh server, nanj pa pač odprem konekcijo s svojega računalnika na določen (vedno isti) port. Ta server pa sem dal v zunanji segment zaradi še večje varnosti.
Za ssh server pa uporabljam rsa ključe z gesli.
Na svojem pcju v službi preko putty-ja forwardam 5900 port na ssh server (npr port 5910), nato pa se doma povežem spet na ta server, kjer te port 5910 poberem k sebi na port 5900 in zaženev VNC viever na localhost.
Tako mi VNC deluje preko ssh povezave, edini problem tukaj pa je da nočem da drug user dostopa do porta 5910 na serverju.
dr. Jst ::
Imam tudi Jst problem. Včeraj sem nadgradil na Gnome 2.6 in vsakič ob zagonu dobim sledeč error.
Stvar je taka, da imam neko eksotiko od tipkovnice in ni podprta v xserverju, tako da sem jo sam konfiguriral in je v Gnome2.4 delalo super, zdaj pa ne. Kje bi lahko to porihtal.
Hvala
hruske ::
isto sm jz naredu in imam isto napako...
pocak ksn dan.
14 / 40
[(K)Ubuntu] Vprašanja in težave (strani: 1 2 3 4 … 23 24 25 26 )
Oddelek: Operacijski sistemi
1262409434 (8994) bosmla
Python - pošlji aplikacijo na server
Oddelek: Programiranje
201963 (1198) HotBurek
Debian in iptables
172015 (1737) karafeka
X window na Debianu mi ne dela
91820 (1739) roscha
Bi Linux? Bi Debian? Ubuntu! (strani: 1 2 3 4 … 8 9 10 11 )
53039599 (27140) Trubadur
