Bi Linux? Bi Debian? Ubuntu!
10 / 11
64202 ::
deb http://si.archive.ubuntu.com/ubuntu/ hoary universe main restricted multiverse
deb http://security.ubuntu.com/ubuntu/ hoary-security universe main restricted multiverse
deb http://si.archive.ubuntu.com/ubuntu/ hoary-updates main restricted universe multiverse
deb http://ubuntu-backports.mirrormax.net/ hoary-extras main universe multiverse restricted
deb http://ubuntu-backports.mirrormax.net/ hoary-backports main universe multiverse restricted
I am NaN, I am a free man!
BaRtMaN ::
Hvala!
christooss ::
Izšel je Ubuntu breezy prewiev release
Mislm da je to že verzija ki jo lahko sprobajo tudi množice.
DL na http://se.releases.ubuntu.com/5.10/
Cdje pa lahko naročite na http://shipit.ubuntu.com/
About Ubuntu 5.10 Preview
To see it all, you'll need to try the CD, but the highlights
include:
On the Desktop
* GNOME 2.12 -- Very fresh... Released yesterday!!
* OpenOffice.org 2.0 beta 2
* X.org 6.8.2 with wider hardware support
* An enhanced tool for easily installing new applications
(see "Add/Remove Programs" in the System Administration menu)
* A new tool which makes it easy to install support for
multiple languages (Language Selector)
* Editable GNOME menus
* Applications are now linked into the Launchpad infrastructure
(new entries on the Help menus for translation and support)
* Support for writing audio CDs (Serpentine)
* Graphical boot process with progress bar (USplash)
On the Server
* PHP5
* Support for installing directly onto LVM volumes
* Built-in thin client functionality produced in cooperation
with the LTSP project (http://wiki.ubuntu.com/ThinClientHowto)
* Simple NFS root setup with automatic hardware detection
through initramfs-tools
* Support for up to 4 gigabytes of RAM by default on 32-bit
architectures
* Kernel support for cluster filesystems (OCFS2 and GFS)
Hardware Support Improvements
* Linux 2.6.12.5 with many updated drivers from third parties
* Further enhancements to laptop support (hot keys,
and working suspend/resume on more models)
* HP all-in-one printer/scanner devices are supported out of
the box
* Bluetooth input devices (such as keyboards and mice) are
supported out of the box
* Multiple audio devices are handled more gracefully (and one
can easily select the default device)
* 64-bit PowerPC kernel available
Installation
* A new OEM mode to simplify the process of preinstalling
Ubuntu on computers for resale or redistribution
* Automatically makes existing hard drive partitions available
to the desktop
* Simple "dual boot" configuration with automatic resizing of
an existing installed OS
* The second stage of the installation now has a progress bar
"Under the hood"
* GCC 4.0.1
* glibc 2.3.5
* New early userspace infrastructure based on initramfs-tools
* More modular X.org packaging
As always, Ubuntu includes the very best of the 100% FREE / LIBRE
application software world, and each new release incorporates
countless new features and bugfixes from the global development
community.
Zakaj je nebo modro? Da imamo lahko sladoled Modro Nebo
christooss ::
Brez izida sesterske distribucije seveda tudi ne gre Kubuntu prewiev relese 5.10
http://se.releases.ubuntu.com/kubuntu/5...
New in this release is:
- The latest KDE 3.4.2
- OpenOffice 2 beta 2
- X.org 6.8.2
Other new features include:
- Krita - state of the art bitmap image editor
- Katapult - an advanced application and item launcher
- System Settings - a user friendly replacement for KControl
- A simplified Konqueror profile
pobcc ::
Morm rečt da sm z Ubuntu-jem kar zadovoljen, sedaj sm zapustil windowse in se spustil v svet linux-a ... ok-ej dovol o tem ...
Nekak mi je ratal vse nastavit v tem Ubuntu, tko da deluje vse kot sm si zaželel... sam nekaj pa neznam nastavit.. in sicer ta ubuntu mam posnet na prenosniku in v windowsih sm znal naredit, da če prenosnik zaprem, da se ubistvu nč ne naredi, to v Ubuntu mi pa to ni uspel, če ga zaprem gre v eno stanje in sploh ne vem v kakšno v glavnem ko ga odprem je zaslon črn in nič ne morm nobena tipka nč ne naredi ...
Ma kdo kkšno rešitev, nasvet, karkoli ....
christooss ::
Mislm da je to hiberncija
64202 ::
Verjetno ti linux kernel na podpira dobro power management od prenosnika, ker default ko zapres zadevo je blank screen ali nekaj podobnega. Sicer jaz sem si nastavil hibernate na zapiranje, popravis filet /etc/acpi/events/lidbtn tkole:
action=/etc/acpi/hibernate.sh
Potem pa se:
/etc/init.d/acpid restart
(ali pa mogoce za zihr rebut)
pobcc ::
64202... kaj mi bo to zdj nardil, ko zaprem prenosnik?
64202 ::
Hibernate: RAM + stanje hardvera se spravi na disk, potem se pa 100% ugasne. Nato spet pozenes laptop in vse se bo postavlo v tako obliko, kot je bilo ravno pred hibernacijo, traja pa zdaj "boot" samo okol 10 sek. Ce imas nesreco (da imas ATI-jev fglrx driver ali pa slabse podprt laptop s strani kernela), potem se stvar ne bo dvignila in bos moral resetirat.
pobcc ::
Em.. kako bi pa naredil tko, da se ne bi nč zgodilo, če zaprem pokrov. Ker jst nočem da mi gre v hibernet, ko zaprem... jst hočem da pač ostane tko kot je, da potem spet odprem in deluje normanlno naprej !
64202 ::
Nastavi action=
pobcc ::
Zdj pa potrebujem še en dobr program za peko CD/DVD -jev.. poskusu sm NERO .... sam to je res 100000 svetlobnih za fukncijami ki so pri NERO-tu možne v windowsu...
christooss ::
sudo apt-get install graveman
64202 ::
Najbolj powerful je k3b
christooss ::
Začelo se je izbiranje imena za Ubuntu 6.04
http://lists.ubuntu.com/archives/ubuntu...
pobcc ::
Imam en problemcek pri mauntaju NTFS diska, nikjer nism zasledu kako nj ga mauntam da bo imel pravice read/write vedno pise le za read...
christooss ::
TO je zato ker zaenkrat driverji za ntfs pisanje niso še na taki stopnji da bi bili varni za uporabo
christooss ::
V enem izmed prejšnih postov sm napisal da se je začelo izbiranje imena za novo distribcijo. Bil sem v zmoti ker nism prebral do konca annoucmenta.
Naslednja verzija Ubuntuja se imenuje
The Dapper Drake - Podgana Drake :)
Kaj je dapper?
pobcc ::
Imam eno zelo cudno tezavo... in sicer vse besedilo, ki ga kopiram tko recimo CTRL + C (ali X) in če grem potem v konzolo se mi ko pritisnem tipko o namesto o izpise tist kar sm prej kopirov (CTRL + c)...ve kdo v čem je težava?
christooss ::
Ja v konzoli pastaš s schift + ctrl + v kopiraš pa z schift+ ctrl + c
pobcc ::
Ne ne.. ni me to zanimal... pravm da katerkol text kopiram predno grem v konzolo, mi v konzoli tipka o sploh ne dela.. ampak mi namesto tipke o izpise tist text, katerega sm prej kopirov
christooss ::
Ja sori sm narobe prebral
christooss ::
Dej poglej v Terminalu pod Pogled - Tipkovnične bližnjice.
Sigurno si ponevedoma zamenjal kombinacijo tipk Shift ctrl v za črko O
pobcc ::
Zdj pa tko čist eno splošno vprašanje... gledel zaščite... me tko zanima.. a je treba tukej tut men kkšn antivirusen program, pa kkšn spyware programčke... (kot. npr. v windowsu, ki jih maš lahko 10 in vsak vedno kj druzga najde)
Kami ::
Ne, razen kakšen root kit hunter je pripročljiv, če laufaš SSH server pa firewall je dobro met :)
pobcc ::
no in sedaj hocm naredit mrezo med ubuntu in windows XP.....
enostavno bi samo dal eno mapo na share...
sam se mi pri temle ukazu mal zatakne: sudo /etc/init.d/samba restart
* Stopping Samba daemons... [ ok ]
* Starting Samba daemons.. [fail]
Bi spet prosu za pomoc!
christooss ::
A sambo si inštaliral?
pobcc ::
Seveda...
sudo apt-get install samba
sudo apt-get install smbfs
In če to zdj izvedem.. za oba pise, da sta namesčena..
pobcc ::
Če bo to kej pomagal.. :
Ko dam: # sudo testparm
Load smb config files from /etc/samba/smb.conf
Processing section "[homes]"
Processing section "[printers]"
Processing section "[print$]"
params.c:Section() - Badly formed line in configuration file: ]
params.c:pm_process() - Failed. Error returned from params.c:parse().
Error loading services.
christooss ::
pobcc ::
No sm že odkril... bla je ena napak v smb.conf
Tko da hvala vseen
smihael ::
Jst mam pa kubuntu 5.10:) poberte si ga na Kubuntujevi spletni strani
Ta ma za razliko od ubuntuja KDE.8-O
"I hate GNOME!"
christooss ::
Ne a res? Vuav :P
CaqKa ::
kaj pa če ne maramo zmajčkov?
pobcc ::
No zdj pa mam problem ... ob zagonu ubunta...
Failed to start X server ( your graphical interface) It is likely that is not set up corectly...
Sploh ne vem kaj nj nardim. Sm tut že backup-ov xorg.conf ... pa nč ne pomaga...
Prosm za pomoc
Daedalus ::
xorg na novo nastavi...oziroma pravilno.
[J.P.Sartre]
pobcc ::
Sj sm ga neki nastavlu pa mi ni uspelo.. nikakor mi ne uspe !
christooss ::
Spremeni driverje svoje kartice na vesa
pobcc ::
SM spremenu driverje ... pa je bla le ena popacena slika... in potem spet isto.. SE pravi ni rešil mojih tezav!!!;(
babylon9 ::
probi Knoppix dela marsikje cudeze.
zoneh ::
Uporabljam Kubuntu 5.10 preview in je supr.
AMD64 3000+ , 2x 512mb Muskin DDR400, GF7600GT
Windows XP, C# and XNA programmer
Kami ::
Kaj pa če bi mogoče sem prilepim xorg.conf in povedal kakšni monitor maš in kakšno grafično + kire gonilnike, bo mogoče ti kdo pomagal, ko se mu bo dalo
smihael ::
vsen bolš k stopinja
Daedalus ::
Katera verzija Ubunta se trenutno priporoča za uporabo? 5.10 je že primerna, al je boljš vzeti 5.04?
[J.P.Sartre]
christooss ::
Preview release inštalirej gor pa pol takoj upgrejdaš. Lahko uporabš tud breezy colony 5. Al pa počakaš v četrtek izide RC čez deset dni pa official. Cko da jest priporočam kr vzem Preview pa je. Bum flokneš gor. Bum dodaš multiverse repozitorije. In bum potegneš nek iz neta w32codecs. In tada popolnoma stabilen sistem. Mogoče samo izgled še ni čisto isti kot bo. Vem pa da se je od Prewie releasa rahlo sprmenil položaj ikon v menujih. Pa walpaper se je spremenil.
Ker če daš zdej hoaryja gor potem lahko pride do nekih nev slow downov pa nekih kurcarij brezveznih.
Daedalus ::
Ok, pol 5.10... Pa še eno vprašanje - kako se ubuntu obnese kot server OS?
[J.P.Sartre]
christooss ::
Hm baje da dobr. Sej to je itak debian.
http://www.howtoforge.com/perfect_setup...
Samo na tem linku je še za Hoary napisan ampak sej je isto za Breezyja :)
Daedalus ::
Huh, dober vodič. Vedno bolj mi je všeč Ubuntu podpora:))
[J.P.Sartre]
christooss ::
Za vse k še ne veste izšel je Ubuntu 5.10 RC1
13. pa Uradna verzija
BaRtMaN ::
Mene pa zanima, če kdo ve, kateri direktorij je Trash za roota?
10 / 11
Omrežna kartica nezdružljiva z Ubuntujem
Oddelek: Operacijski sistemi
151932 (1627) Zvezdica27
WiFi ne dela na Lenovo R500 z Ubuntu 10.04 LTS (64 bit)
181954 (1759) Icematxyz
Ubuntu compiz
162319 (1996) Loaded
Izbira Linuxa
472870 (1727) Border
Ubuntu 5.04 (strani: 1 2 )
5511156 (9491) Tarzan
