Forum » Operacijski sistemi » Debian Gnu/Linux kot workstation
r5r ::
Upam, da bo tole delovalo...
apt-get install apache php4 mysql-server php4-mysql
Unstable je z najnovejšimi paketi, vendar ni v bistveni prednosti od testing. Popravi datoteko /etc/apt/sources.list, tako da spremeniš besedo stable na unstable. Po postopku poženeš apt-get update, da se baza paketov nadgradi
And it makes me wonder.
Gandalfar ::
NE UPORABLJAJ unstable na server masini.
Sarge bo sedaj postal stable (cez par dni), ima ze security in bodo skrbeli zate. Z unstable sicer nisi kakor svicarski sir, ampak nikoli ne ves.
bam88 ::
hvala jaka... em unstable sm mel prbl pol leta.. zj mam pa sarge.. testing..
btw se to me zanima.. zakaj hudica se mi psybnc ne pozene v backround?
Hohohoahao
christooss ::
apt-get xmms-wma
prej pa pejd pod Izbire(preferneces) pa na seznamu poglej če maš wma plugin inštaliran. Mogoče ga maš izklopljenga.
Zakaj je nebo modro? Da imamo lahko sladoled Modro Nebo
Screamboy ::
mi lahko kateri pomaga kako se imenuje paket za compajlanje naprimer c++
ker rabim en program skompajlat pa mi noče ker niamm nameščeno
Screamboy ::
checking for X... no
checking for glib-config... no
checking for GLIB - version >= 1.2.10... no
*** The glib-config script installed by GLIB could not be found
*** If GLIB was installed in PREFIX, make sure PREFIX/bin is in
*** your path, or set the GLIB_CONFIG environment variable to the
*** full path to glib-config.
configure: error: *** GLIB >= 1.2.10 not installed - please install first ***
hm še vedno nedeluje
CCfly ::
Kaj pa vem mogoče: apt-get install glib ?
"My goodness, we forgot generics!" -- Danny Kalev
CCfly ::
@Scream: daj si aptitude ali pa Synaptic dol.
bam88 ::
net/ax25/ax25_in.c: In function `ax25_rcv':
net/ax25/ax25_in.c:449: internal compiler error: Segmentation fault
Please submit a full bug report,
with preprocessed source if appropriate.
See URL:http://gcc.gnu.org/bugs.html for instructions.
For Debian GNU/Linux specific bug reporting instructions, see
URL:file:///usr/share/doc/gcc-3.3/README.Bugs.
any ideas? to se mi pa v debianu res se ni naredl.. v slacku ze .. tuki pa se ne..razn odkar mam testing pa sarge
Hohohoahao
bam88 ::
nene vse je vredu.. js sm butast :P spremenu sm verzio kernela :P zj dela ql... btw neki me matra k bom ob ziuce
kernel panic dobim da nism pravilno appendov root= ... mam grub .. pol sm tud installov lilo.. isti shiet
moj konfig:
title Debian GNU/Linux, kernel 2.6.11-darkstar
root (hd0,0)
kernel /boot/vmlinuz-2.6.11-darkstar root=/dev/hda1 ro
#initrd /boot/initrd.img-2.4.26-1-386
savedefault
boot
kaj mi je za naredit? kernel sm nickolikorat ze rekompajlov!
moj konfig:
root (hd0,0)
savedefault
boot
Hohohoahao
hruske ::
moras bit zihr, da imas vkompajlano vse, kar potrebujes za dostop do diska. Ce imas ide, potem je to podpora ide diskom, tvoji maticni plosci itd ... ce imas sata, je to podpora sata, pri prehodu iz 2.4 na 2.6 pa se hde spremeni v sda in podobno in je potrebno še to pazit. :)
kihc ::
Tega men nikakor ni ratal pogruntat.
Nakonc sem naredu tako, da sem vzel default config od woodija, pa popravu kar sem rabil. Če ugotoviš kaj TOČNO rabiš da dela, bi bil zelo hvaležen če napišeš sem.
x
hruske ::
Kihc, to je odvisn od mamaplate, tako da tisto, kar imam js, skor zihr ni isto kot zate.
Lahko pa poveš kaj imaš not, pa bomo zgruntal.
- spremenilo: hruske ()
hruske ::
Za 2.6:
Device Drivers -> ATA/ATAPI ..-> Generic PCI bus-master DMA support
spodaj se AMD and nVidia IDE support
Device Drivers -> I2C support -> I2C hardware bus support -> Nvidia nforce 2
Če česa nimaš, moraš mogoče prej še kej v tisti kategoriji omogočit.
bam88 ::
to mam za server en star intel 200 mmx ...
drgac pa bom probov tvoja navodila..zj kompajlam kernel zadnjic... ce mi nau delal mi bo dopizdil pa obm nazaj fbsd nalozu
Hohohoahao
christooss ::
Kako pa jih dodaš pri bs playerju?
hruske ::
ok, jz uporabljam mplayer brez gui-ja, podnapis pa "dodam" tako, da ga poimenujem enako kot film, le končnica ostane od podnapisa.
christooss ::
desni klik na na oknček kjer je film
open - load subtitle
64202 ::
scream:
mplayer - drag'n'drop subtitle v glavno okno (al pa z desno tipko pa 'subtitles' iirc)
kaffeine - desna tipka v playlistu na filmu pa 'add subtitle'
I am NaN, I am a free man!
theD3viL- ::
Js mam pa problem pr firefoxu.. in sicer mi ne predvaja wmv filmčkov, oz. kkšne php strani ne prkaže dobr...installeru sm mplayer-firefox al obratno .. pa ne dela 0 .. =/ ..
Kaj nej?
Kaj nej?
christooss ::
v /etc/mplayerplug-in.conf mora bit enable-wm=1 pa odstrani # Pol pa dela
theD3viL- ::
Hm.. še zmeri nedela ampak se bom poigrov iz confom.. drgač pa za navadn mplayer mi pa napiše ko ga hočm zagnt:
MPlayer 1.0pre7-3.3.5 © 2000-2005 MPlayer Team
CPU: Advanced Micro Devices Athlon MP/XP/XP-M Barton (Family: 6, Stepping: 0)
Detected cache-line size is 64 bytes
CPUflags: MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 0
Compiled for Debian.
Usage: mplayer [options] [url|path/]filename
so on........
in noče se prkazat u grafičnem načinu.. =/
so on........
christooss ::
Hm sej men isto napiše. Mam pa Ubuntu
Ej dj probj tole copy paste moj /etc/mplayerplug-in.conf
#debug=0
#logfile=$HOME/mpp.log
vo=xv
ao=esd
download=1
dload-dir=$HOME/tmp
#keep-download=0
noembed=1
#cachesize=256
#use-mimetypes=0
enable-real=1
enable-wm=1
enable-qt=1
enable-mpeg=1
enable-ogg=1
qt-speed=med
#rtsp-use-tcp=0
#nomediacache=0
BTW filmček ti bo odprl v svojem okencu.
Men default mplayer ni delal ko sem pa spremenil parametre - zdj nevem več katere - mi pa dela bp
Seveda prej naredi kopijo svojega prejšnjega.
#debug=0
vo=xv
ao=esd
download=1
dload-dir=$HOME/tmp
#keep-download=0
noembed=1
#cachesize=256
#use-mimetypes=0
enable-real=1
enable-wm=1
enable-qt=1
enable-mpeg=1
enable-ogg=1
qt-speed=med
#rtsp-use-tcp=0
#nomediacache=0
theD3viL- ::
Ne nedela...neki cajta neki dela... pol pa črn zaslon.... =/
Btw.. ve kdo mogoče zakaj mi šumniki ne delajo sploh? Tipkovnica dela.. tud irc, msn, ... ampak k hočem npr. nardit novo mapo .. mi prikaže šumnike, tkoj k stisnem enter pa mi nardi za vsak šumnik en "?".
Plz help.
Plz help.
Gandalfar ::
klikn help v menuconfigu:
──────────────────────────────────────────────────────────────────── I2C support ─────────────────────────────────────────────────────────────────────┐
│ CONFIG_I2C: │
│ I2C (pronounce: I-square-C) is a slow serial bus protocol used in │
│ many micro controller applications and developed by Philips. SMBus, │
│ or System Management Bus is a subset of the I2C protocol. More │
│ information is contained in the directory file:Documentation/i2c/, │
│ especially in the file called "summary" there. │
│ Both I2C and SMBus are supported here. You will need this for │
│ hardware sensors support, and also for Video For Linux support. │
│ If you want I2C support, you should say Y here and also to the │
│ specific driver for your bus adapter(s) below. │
│ This I2C support can also be built as a module. If so, the module │
│ will be called i2c-core. │
│ CONFIG_I2C: │
bam88 ::
hruske ti si car hvala ti za kernel.. dela zj ql...
gandalf.. a v sources list pustim testing al morm ksn drug source dat not?
Hohohoahao
64202 ::
Mislim, sam so pa res carji
, pejdz je se vedno do pike isti, razen teh detajlov:
1. ni vec zaobljenih vogalov na okvirjih (!!)
2. 3.0 -> 3.1
3. 8k paketov -> 15k paketov
4. latest release: June 6th 2005 namesto nekineki 2002
ROFLMAO
2. 3.0 -> 3.1
ROFLMAO
Nerdor ::
A to ste že opazili: Debian GNU/Linux 3.1 r0 released! 14CDjev ali pa 2DVD-ja.
... for lifetime!
Gandalfar ::
Iz slashdota:
Now, when can we expect Etch?
These are some of the things that happened between Debian releases:
a) The Olympic games returned to Greece.
b) The Pope died.
c) A German Pope got elected in a conclave.
d) Apple switched to Intel.
e) Watergate's Deep Throat identity was revealed.
f) The French rejected the European Constitution
g) Boston won the World Series.
So just sit, be patient and wait for the signals my son.
in se ena: For a full set of CDs (that only an anal collector would actually want) for all 11 archs, and the source, you'll need 164 CDs
b) The Pope died.
Daedalus ::
Pa smo le dočakali
He he, Gandalfar - tiste točke so direkt za v funny links
Aha, še eno vprašanje - zdaj lahko v sources repozitorije spremenim v stable?
/zdaj pa sistem upgrejdat
[J.P.Sartre]
[J.P.Sartre]
- spremenilo: Daedalus ()
| ! | [(K)Ubuntu] Vprašanja in težave (strani: 1 2 3 4 … 23 24 25 26 )Oddelek: Operacijski sistemi | 410464 (10024) | bosmla |
| » | Python - pošlji aplikacijo na serverOddelek: Programiranje | 1970 (1205) | HotBurek |
| » | Debian in iptablesOddelek: Operacijski sistemi | 2024 (1746) | karafeka |
| » | X window na Debianu mi ne delaOddelek: Operacijski sistemi | 1831 (1750) | roscha |
| » | Bi Linux? Bi Debian? Ubuntu! (strani: 1 2 3 4 … 8 9 10 11 )Oddelek: Operacijski sistemi | 39673 (27214) | Trubadur |
