WD TV.. kdo ima?
WD TV.. kdo ima?
27 / 32
Wd TV Live ima nov chipset : Sigma 865X. primerjava: http://www.iboum.com/artkill/chipsets.p...
... zelo dobro:)
The Sigma 864x and the 865x are related and similar chips. The 864x has Blu-Ray capability and is the more powerful. It contains a 667mhz CPU and a 333mhz IPU (image processing unit), 2* HD video decoding, and three 333mhz Audio DSPs. The 865x lacks Blu-Ray support and uses a 500mhz CPU / 333mhz IPU, 1.25x HD video decoding, and one Audio DSP.
... tole mi ni čisto jasno; če ni blu-ray podpore, pomeni to zgolj, da ne morem priklopiti blu-ray predvajalnika na napravo, ali tudi da ne morem predvajati blu-ray vsebine na trdem disku (sicer tudi pod razno še nimam takih potreb, zgolj malo "teoriziram":D)
  • spremenil: Gregor P ()
OK.d ::
ima pa samo 1 leto garancije dočim ima wd1 2 leti
LPOK.d
To je tudi zanimiva informacija za potencialne kupce. Sam recimo, ko kupujem trde diske, ko smo že ravno pri WD, ponavadi kupim tudi tistega, ki ima daljšo garancijo, ker menim da proizvajalec že ve, zakaj ima pri določenem produktu krajšo, pri drugem pa spet daljšo garancijo.:|
RuN ::
Novi neuradni FW: 1.03.01
Prerelease 1.03.01 (includes all previously released updates)
Resolved Issues:
* Resolved the language displayed as OFF when English was selected
* Resolved the "Contains" button displayed as "ContainsWWW" in the search function
* Resolved MKV audio which was out of sync with the video
* Resolved slow rendering of Greek subtitles in Greek character encoding mode
* Resolved disappearance of Korean subtitle during video playback
* Resolved missing characters from the Greek subtitle font
* Resolved playback issues with VC-1 codec in an MKV container
* Resolved gain being applied to audio output that resulted in signal clipping
* Resolved playlists playing audio tracks in alphabetical order by playing them in track order
* Resolved the appearance of tracks in alphabetical order by displaying them in track order
* Resolved the spacing issue seen in Korean subtitles during video playback
  • spremenilo: RuN ()
zmaki ::
Grafično predelani firmware v1.03.01 (by "Lilibabe", simple)
z vgrajenimi večjimi podnapisi (by "Rezmus", do 80 pixlov)
http://wdtv.free.fr/osdmod/dl/simple_v2...
OK.d ::
kakšen screen?
LPOK.d
zmaki ::
White666 ::
mogoče kdo ve kako predvajat pondapise pri DVD formatu filma (Video_TS)? Menu se mi zažene, vendar ne morem izbrat ničesar. Film sicer deluje b.p. Pod opcije/subtitles -napiše no subtitles (pa vendar so noter). V naprej hvala.
Zurbum ::
To se je pri meni pojavljalo pri slabo narejenih DVD ripih. Jaz sem do sedaj uspešno reševal zadevo tako, da sem DVD(na disku) dal skozi DvDShrink. Na tak način sem reševal tudi tiste DVDje, ki mi jih sploh ni hotel predvajati oz. mi je predvajal le par sekund.
matki ::
Pozdravljeni
Naložil sem FW od "Lilibabe" vendar nikjer ne najdem možnost povečanja
podnapisov ( 80 ). Še vedno je v meniju največja možnost 40 kot je na
WD -jevem FW-ju.
Prav tako me zanima kako spraviš v mape ( thumnail) naslovnice filmov
kot jih kaže forum .Namreč pri večini download -ow teh slik ni zraven.
boko34 ::
Naloži si njegov zadni firmware (Update 2009.10.22 : updated to fw 1.03.01) kjer je dodan "rezmus patch" za večje fonte. Če želiš videti slike filmov pa si moraš pravtako pobrati sliko filma. Poimenovati jo moraš isto kot film.
npr.
Up.mkv
Up.srt
Slike so lahko tudi večje in sicer: 180x240
Če iščeš sklike za filme je ta stran odlična: http://www.movieposterdb.com/
Firmware: http://wdtv.free.fr/osdmod/dl/simple_v2...
  • spremenil: boko34 ()
matki ::
Boko pa ti si car !
WD imam sedaj "nafriziran" v nulo in zadeva je skoraj že super .
Edino kar ostaja je zatikanje filmov 1080p z bit rate večjim od 9600kpbs.
Bomo pač počakali na WD TV Live (2) , če bodo še to zadevo poštimali .
Še enktrat Hvala
Slehernik ::
WD TVja ne morem fleshat?
Noben firmware ne zagrabi s sveže formatiranega ključka. Help?!
firbec ::
+ verzija, katero nalagaš, mora biti višja od te, katero imaš naloženo zdaj.
Slehernik ::
Pod "Settings" ni nobene "ikone" Firmware upgrade.
Spremenil z notepadom, verzijo v višjo (1.02.08); ne zazna ničesar.
Uporabil dva različna ključka, 1GB in 4GB (LaCie); sveže formatirana. Nič. Nobene avto detekcije, nobene ikone za upgrade v Settings.
Kako sploh preveriš kateri firmware je na mlinčku?
Ker tale šumnikov ne pozna. Pod Subtitle Language sicer ima Central European.
BTW, tale WD TV mini kupljen v E.Leclercu za 61 EUR.
Tody ::
Mogoče maš pa fake WD ? :)
TOP ::
Pa kjluč si formatiral v FAT
Slehernik ::
Kolikor sem zasledil na netu in na WD support strani, WD TV mini še nima nobene uradne nadgradnje firmware-a.
 WD TV mini
WD TV mini
Če na ključe dam film, mi jih bere normalno. Firmwarejev NE. Predvidevam, da zato, ker je to MINI. Se pravi, da ima drugačne zahteve, čeprav je zunanja razlika v pomanjkanju HDMI in nepopolna podpora za HD.
LunKi ::
Boko pa ti si car !
Še enktrat Hvala
Mislm da en bodo tega poštimal ker je pač hardware tko omejen. Imo je to tudi edini minus poleg LAN-a. Zato razmišljam o playon ali egreat 34a. Cilj je 1080p hd streaming.
... in ker ima WD TV Live novejši in zmogljivejši procesor (Sigma Design SMP8655, kot je že povedal White666) ter LAN (Realtek RTL8201EL 10/100), je verjetno tudi eden izmed kandidatov.
 Sigmin procesor
Sigmin procesor
 Realtek
Realtek
simnov ::
cool večji podnapisi kakšno velikost podnapisov imajo na pop tvju.
presing ::
A je že kdo naložil prerelease verzijo 1.03.01 in ali dela??? Naložen imam firmware 1.02.07, dela BP, zanima me, če je zaradi omenjenih dodanih sprememb/izboljšav vredno naložit 1.03.01???
dani8 ::
seveda se splača
b-rad 5.8.1
  • spremenil: dani8 ()
subert99 ::
Prihaja novi model WD TV HD - bistvena navost DTS downmix!!!
OK.d ::
vir?
LPOK.d
genesiss ::
ja saj to je wd tv live ?!?
NazgulRR ::
A se tudi vam USB ključek ful segreva, tudi ko je WD TV izklopljen? (vklopljen je edino v el. vtičnico).
  • spremenil: NazgulRR ()
Tody ::
ja
Zurbum ::
Meni se že sam WD segreva, ko je ugasnjen, tudi disk-a ne zna izklopit, domnevam, da ima to kakšno povezavo tudi s segrevanjem tvojega USBja.
subert99 ::
Ni live! Nova zadeva cena bo 109,99
Javim ko bo na prodajni polici.
  • spremenil: subert99 ()
OK.d ::
če je res pol upam da se bo tudi starega dalo shekat za downmix>:D
LPOK.d
NazgulRR ::
Mhm, meni tudi. Zelo slabo narejeno IMO.
OK.d ::
ko bi vi vedli kako je pri xtreamerju šele vroče-pasivno hlajenje(hladilno rebro)
LPOK.d
Scorpia ::
Sam imam tudi wd, se nikoli ne greje (tudi poleti) oz. je mlačen ko je izklopljen, zdej pa pozimi je še komaj kaj topel. Edino ko gledam hd filme, je že topel, ampak ne pretirano. Imam wd disk in ko ugasneš, se tudi disk ugasne, edino modri lučki gorita ampak to me niti ne moti. Vsaj ponoči kej vidim. Ali pa so izjema druge firme externih diskov da vam ne izklopi? Se sliši disk da še dela? Če ne, torej ga izklopi.
Če se zadeva segreva pri kablu kjer je usb priključek je normalno, saj zadeva vleče tok in se more gret.
Zurbum ::
Jaz moram disk fizično izklopit, drugače ne morem spat.
subert99 ::
Omenjeni WD Tv se že da kupiti v Big Bangu!
Iz koga se ti sedaj hecaš? Ni ta stari navadni WD TV, ni malo novejši a zastarel WD TV Mini in kot praviš ni niti ta najnovejši WD TV Live (pregled naprav); katera fantomska naprava pa je sedaj to, razen če ne delaš reklamo oz. se poslužuješ prikritega oglaševanja za določeno podjetje?:|
zmaki ::
To je WD TV HD gen.2 (interna WD oznaka WDBABF0000NBK).
http://www.wdc.com/en/products/Products...
Ta samo z malo spremembo hardwera (sumim da samo zaradi potem namerne nekompatibilnosti firmwera s prvotnim WD TV HD gen.1) omogoča DTS downmix v stereo, ter DVD menuje.
Aha razumem, torej starega WD TV je zamenjal novi model WD TV z boljšo strojno opremo, ta starega pa so umaknili iz proizvodnje; o tem je govora. Torej gre za staro-novo napravo in moramo biti kupci zelo pozorni na te oznake (WDBABG0000NBK) ob nakupu "klasičnega" WD TV-ja.
AVS: WD HD media player with model number WDBABG0000NBK-EESN has DTS 2.0 downmix
Najlepša hvala za obrazložitev:)
bosko1982 ::
? zbegan... in kateri je boljši? WD TV live ali pa WD TV gen.2 ?
škoda da ne dajo GIGA LAN namesto 100mega
**moja napaka, slabo sem gledal***
WD TV gen2 nima niti LAN =//
katastrofa od človeštva...
  • spremenilo: bosko1982 ()
kmetek ::
in COMSHOPu !
pedalo ::
Kupil sem WD TV druge generacije in zaenkrat sem zadovoljen, za dvakrat pa bomo še videli :) Dela DTS preverjeno
kmetek ::
Zgleda res:
Torej imamo na voljo:
WD TV stari klasični - ta bo verjetno v kakih akcijah & razprodajah po 75-80EUR
WD TV nove generacije z novo oznako, ki omogoča DTS !!! 100EUR
"WD HD media player with model number WDBABG0000NBK-EESN has DTS 2.0 downmix"
http://www.comshop.si/Article.asp?artic...
WD TV live DTS + LAN. 130EUR-150EUR
  • spremenil: kmetek ()
badabim ::
danijel8:
Ima wd tv druge generacije možnost zoom 1.1x podobno kot wd tv live ?
NazgulRR ::
A je WD TV druge generacije WD TV1 z DTS downmixom, ali je to WD TV Live brez LAN-a?
pedalo ::
WD TV 2. gen. ima DTS downmix. Od predhodnika pa naj bi se razlikoval po procesorju. Po tujih forumih sem zasledil, da ima hitrejši Sigma čip (enak kot pri WD TV live). Na podlagi tega bi lahko trdil, da je to WD TV live brez LANA. Zato bi ga priporočil vsem, ki ne potrebujejo LANA.
babadim: WD TV 2 ima možnost zumiranja 1.1x in 1.2x
agerg ::
Pozdravljeni
Imam vprašanje. Mam WD tv media player mini(WDBAAM0000NBK) in sem si iz računalnika na zunaji trdi disk naložil nekaj filmov skupaj z podnapisi. Na televiziji mi potem ti filmi res delujejo, ampak BREZ podnapisov.
Si moram še kakšen program naložit ali se to nastavi kje v nastavitvah. Najlepša hvala za morebitne odgovore!
NazgulRR ::
Ime filme in ime podnapisa morata biti enaka, npr: xyz.avi in xyz.srt. Meni delujejo samo .srt podnapisi. Pa poglej, da so med filmom vključeni podnapisi.
agerg ::
Ja, ko se film začne moraš na daljincu prtisnit tipko "option" ter nato dodaš podnapise. Tako enostavno, pa nisem vedel :)
NazgulRR ali kateri drugi, mogoče veste če se da podnapise kako povečati in črke š in ž mi ne pokaže, kakšna rešitev? Hvala
bastadu ::
V nastavitvah lahko tudi vključiš, da se podnapisi ob predvajanju avtomatsko vključijo. Kje točno je to v nastavitvah pa sami malce prebrskajte, ker ne vem sedajle z glave ...
27 / 32
Wd TV Live (strani: 1 2 3 4 … 21 22 23 24 )
Oddelek: Zvok in slika
1173230202 (73665) scipascapa
h.264/DVD/DivX player (strani: 1 2 3 4 … 44 45 46 47 )
2330273432 (87524) dope1337
WD TV Live HUB (strani: 1 2 )
7825667 (19105) kamuee
Nakup WD HD TV Player
115603 (3776) Robert1
DVD Pomoč!
162345 (2187) boogie_xlr
