Forum » Pomoč in nasveti » branje filma na dvd playerju
sokrates9999 ::
Pozdravljeni !
Imam eno težavo, in sicer imam film avi, ki mi na računalniko normalno deluje, ko pa želim film pogledati na JVC-jevem dvdju pa imam problem. Prosim za ustrezno rešitev
StratOS ::
Ni važno kakšno končnico ima, važno kako je avdio in video v tem kodiran.
Preglej kakšne filme lahko tvoj player predvaja ( kodeki ) avdio in video.
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
sokrates9999 ::
oznaka dvd playerja JVC, na njem je zapisano, da podpira dvix, mpeg multi chanel, dts..., če je to to??
StratOS ::
Da, to so standardi, vendar pa je nastavitev za vsako vrsto istega/podobnega kodeka v skupini, ki podpira ta standard velika.
Če še razmišljaš, da obstajajo in video in audio kodeki za kodiranje, ti more dekoder (čip) v DVD-ju takšen zapis uspeti razluščiti kateri je ter z ustreznim ( kompatibilnim, če ne gre drugače ) dekoderjem preleviti v avdio oz. video.
Če ne veš kaj tvoj DVD podpira natančno, lahko sam sprobaš, na netu je ogromno Cd-jev, ki se ukvarjajo ravno z to tematiko : Testiranje predvajalnika - Test CD
What’s in the test CD ?
To test your player, parts of trailers have been encoded in a maximum of video and audio formats. You will also find files to test the most common types of pictures and subtitles. Last but not least, we have provided a check-list of functionalities and accessories often integrated or wished by end-users in order to estimate the level of your player’s equipment.
Here is a list of the tests categories :
A_ Medias and Disc type
B_ Options / general Specifications
C_ GUI : Menus options
D_ GUI : Audio and image files options
E_Connections
F_Compatibility : Supported image types
G_Compatibility : Supported audio types
H_Compatibility : Supported video codecs
I_Compatibility : Video containers and “bivx” tests
J_Compatibility : separated subtitle files tests (for *.avi containers)
K_Others unreferenced (optional tests)
A detailed manual is available on the CD itself.
E_Connections
sokrates9999 ::
Hvala za tale test, pogledal na spletni strani. Imam player XV-N422 jvc; http://www.divxtest.com/form/divxtest2_.... Sedaj me zanima, kateri program rabim, da ta movie file pretvorim v kodeke, ki bodo mojemu playerju razumljivi. Celotna oznaka fila je sledeča DVDSCR.XVID-FICO.... . Moj model pa tega pri karakteristiki A ne podpira.
Hvala vnaprej
Hvala vnaprej
| » | [Divxvid] Quadro predvajalniki (strani: 1 2 3 4 5 6 7 8 )Oddelek: Zvok in slika | 57441 (12266) | Spajky |
| » | HD codec (strani: 1 2 3 )Oddelek: Zvok in slika | 18995 (11880) | GrimReaper |
| » | DVD predvajalnik .sub .txtOddelek: Zvok in slika | 1346 (1265) | Zorro |
| » | [divxvid] Eltax predvajalnikiOddelek: Zvok in slika | 3139 (2327) | Oldi |
| » | AVI 2 VCDOddelek: Zvok in slika | 2588 (2379) | marS |
