Crysis
Crysis
50 / 53
darius ::
Dobro da ti ni dodatek, ampak povsem nova igra. 8-) Dobro jutro žakelj perem!
- P5KC - E6750 - HD4870 - 4GB ram - Samsung T220 -
ROVER POWER ;)
iLichu ::
[quote] Crysis: Warhead gets a 9.4 from IGN [/quote]
http://uk.pc.ign.com/articles/909/90958...
AnWar ::
Hm glede na ta link: sm zastopil da bo to delalo na c2,9800,na vse very high dx10, vse lepo?
Popravite me ce se motim...
[PC AMD7800X3D 5.2GHZ ,7900XT,32GB G.SKILL CL30 6400MHZ,ASROCK X670E]
tilinho20 ::
Na kateri grafi to? Veliko graf je z imenom 9800.
DOOM_er ::
radeon ?
_GiZmO_ ::
9800 GT !!
destroyer2k ::
Pa da dodam še tole, potrjeno je da ta igra in crysis originalen bo na voljo pri steam. Cena crysis warhead bo na steam 29$.
AnWar ::
Zal tok bo:
* CPU: Intel Core Duo e7300 (@2.66GHz)
* Video card: Nvidia 9800GT
* RAM: 2GB
"When we started working on Warhead, we decided performance was a big issue," he explained. "We said, 'Guys, we're going to build a PC which has a maximum price of six or seven hundred dollars, and it has to run Warhead in high spec at an average framerate of 30'...All the milestone presentations we did for EA, for the [founding brothers] Yerlies, for the team, all the new prototypes, we showed on that machine."
Na high/30Fps-jev
aodius ::
http://www.gregorsalobir.si/
simnov ::
glede tega , da mi bo na 9800gx2 delalo na max gladko sploh ne verjamem.
AapocalypseE ::
Zanimivo, da se bo dalo v Warhead naret na Very High v XP brez kakega vsiljevanja.
destroyer2k ::
StreetRacer
Ne brez vsiljevanja bo sedaj se dalo na xp. Ker warhead sploh dx10 nima več samo dx9.
DOOM_er ::
warhead ne bo dx10?
destroyer2k ::
DOOM_er
Nope pure dx9.
AapocalypseE ::
Pomoje bo DX10. Čudno bi blo, da nebi bil. Se bo pa dalo v XPjih naštelat na Very High, kar se pri navadnem Crysisu ni dalo.
DOOM_er ::
svašta :O
AapocalypseE ::
Sem malo pogooglal :D
Torej v Crysisu se je lahko samo v Visti dalo naštelat na Very High in je blo kao DX10, ampak daleč od tega. Na XPjih se je dalo vsilit to in je zgledlo enako kot v Visti, tako da je čisti DX9. Warhead bo torej tudi DX9 igra, ampak se bo tudi v XPjih dalo naret na Very High oz. po novem Enthusiast.
Še kopiram kar je en napisal:
DX10 effects will not work on DX9. The very high settings weren't DX10 effects. It was probably microsofts influence in trying to promote Vista and DX10. It is possible that a developer called it a DX10 effect when really it wasn't. However there is no way to call it a DX10 effect when it can be done as well in DX9.
destroyer2k ::
StreetRacer
Ja crysis je bil nekaj sponzoriran zraven še od MS in so zato dobili dx10 futures. Sedaj v warhead pa ne podpirajo več to in bo čisti dx9 in boš lahko imel tudi v xp-ju very high.
AapocalypseE ::
Še majn razlogov, da grem na Visto. True DX10 iger še tak zgleda ni in jih še kar nekaj časa ne bo. Pol pa že pride DX11 in se mi zdi vseskupaj kot eno veliko napizdovanje folka.
very high =! DX10
To smo ze dolgo nazaj ugotovil. Very high na XPjih je delec od DX10 na visti.
Rippy ::
Hmm nemorete reč,i da Crysis nima DX10 podpore, tudi na visti je razlika med dx9 in 10 (sicer bolj kot ne samo v FPS :D )
AapocalypseE ::
Dr_M, pol pa mi pokaži razliko Very High na Visti in Very High na XPju.
Nevem kako podporo ima za DX10. Kot je že en napisal: However there is no way to call it a DX10 effect when it can be done as well in DX9.
Senitel ::
Jah isto stvar lahko narediš v DX9 in DX10 na več različnih načinov. Zdej v Crysisu je pač situacija taka, da se iz high na very high spremenijo samo shaderji in pač tisti najdaljši so umetno zaklenjeni na DX9 poti, čeprav (očitno) pašejo v DX9 okvire, ki so, kakor koli obrneš, dovolj široki, da bodo še prihajajoče grafe v naslednjih letih brez problema spravili pol 30fps. Po drugi strani bo pa špil že na low detajlih v DX10 uporabljal featurje, ki so samo v DX10 na razpolago! To je čisto logična posledica tega, da je DX10 podrl vse vezi za nazaj, DX10 hardware ponuja vse DX10 featurje, zakaj jih torej ne bi uporabili.
Večina efektov pride "avtomatsko" zaradi hitrejšega hardware-a in to je pač neodvisno od tega ali je DX9 ali DX10. To je nekako tako kot "kateri efekti v programih so SSE2, kateri pa SSE3?"
destroyer2k ::
Dr_M
Dobro preberi o kateri igri smo se menili WARHEAD in za to igro je potrjeno da bo samo dx9 imela in da boš lahko dal very high tudi na xp-ju.
Eh...
Grem na pivo...bo vec koristi. :\
AapocalypseE ::
Še enkrat!
Dej ne bod tak froc. Vse je blo ze v tej temi. Zdej pa nehi jokat.
In ne, nimam viste, tko da si kr sam poisc.
AapocalypseE ::
Vem kaj je blo v tej temi in to je, da razlike neke ni, razen večji fps droop na Visti. Idi raje na eno pivičko, ti bo dobro delo ;)
darius ::
Če Crytek reče da je DX10, potem že je. in niti Streetracer, niti bog ne more rečti drugače, pa če se postavita 20x na trepalnice. Razlika med visto pa XP na very high pa je vidna na 100metrov z eno pokrito oko. Roko na srce, takih efektov v igri na dx9 ni nikdar blo pa nikdar ne bo.
ROVER POWER ;)
Jst ::
En primer: Sence! V XPjih so sence takšne na High, kot v Visti dx10 na medium.
Najlepše se pa to vidi v sceni, ko prideš v Vas, kjer ti pa Psycho prideta v sobo, kjer je ena argeologinja.
  • spremenil: Jst ()
R-H-O ::
Rabim vedet:
Zakaj se kitajcev ne da metat skozi zidove netrdnih zgradb?
(to sem videl v trailerju)
No, pravzaprav ti prides v vas, ampak ko prides do sobe za zasliševanje se psyho spawna za tabo, vklopi cloak, pride v tvoje vidno polje in izklopi cloak.
  • spremenil: R-H-O ()
Jst ::
Ja, in ko oba skupaj vdreta v sobo, se na steni vidi senca tiste arheologinje. V dx9.high je senca nazobčana, a manj, kot dx10.medium. Že tu se lepo vidi, da se uporablja drugačna koda tako za dx9 kot za dx10. Zato tudi dx10 dela tako počasneje. Sicer to ni izgovor, ampak bolj obrazložitev.
janwoolf ::
Pozdravljen! Imam problem. Ko igre nastavim vse na high pritisnem apply. Potem sem pogledal nazaj na nastavitev, so spremenili v custom. kaj je narobe??
C2D E8400, Crucial Ballistix Tracer 2x1gb PC-8500,
P5K-E, XFX 8800GTS (G92) 512MB,Antec nine hundred
cooling 4x120mm and 1x200mm, Enermax Infiniti 650W
  • spremenil: janwoolf ()
Rippy ::
Janwoolf, "Object Quality" nemoreš spreminjat če si med igranjem igre. Če to ni na high takrat, kot ostalo daš na high bo ostalo na medium, in celotna nastavitev nebo označena kot High zaradi tega.
Je pa tudi priporočeno pri tej igro, da takrat ko najdeš dobro nastavitev ponovno zaženeš.
Jst ::
Ali pa če imaš v autoexec.cfg kaj nastavljeno, potem se tudi zadevem, ki se tičejo v autoexec.cfg, v sami igri spremenijo v "Custom."
R-H-O ::
Ti samo poglej vsako opcijo posebej.
Nastavitve pa raje spreminjaj na začetku, če ne ti lahko tudi zašteka.
Glede štekanja pa: ali boš pustil da pol ure melje novo kvaliteto objektov ali počakal da se računalnik znova zažene od preobremenjenosti sistema.
Povejte če se motim, ampak tisti set all options to: "kvaliteta"
je odvisen tudi od drugih natavitev.
XBOX 360 in en švoh comp.
Rabš kej vč!?
Jst ::
Ne motiš se, niti motiš se: sploh te ne razumemo, kaj si hotel povedati...
R-H-O ::
Tisto je bilo vprašanje.
Rabš kej vč!?
bigbug ::
Ali je model FunTech Intel E8500 Platinum 4850 2Gb dovolj mocan za nemoteno poganjanje novega crysis-a?
Povezava
Hvala
Urc ::
Da. :)
  • spremenil: Urc ()
ivanuscha ::
Če boš poganjal Visto in vse na very high, pol rajš razmisl vsaj o hd4870.
AapocalypseE ::
Odvisno na kateri resoluciji igraš. Very High in 1680x1050 bi rabo 4870x2.
M-XXXX ::
Postavil sem server za Crysis wars, tako da če bi kdo bil zainteresiran špilat kar pm me:D
svetetko ::
Hej!
Inštaliral sem si crysis na visto ultimate 64bit.ne deluje. a morm crack kopirat v bin64, bin32? ali moram dobiti drug crack?
Rotaidal ::
Rabiš samo original igro.
svetetko ::
hočem sprobat špil, pa če mi bo kul, kupm original. a to pomen da na 64 bitni visti ne deluje piratska verzija?
DOOM_er ::
ne nimaš šans. Na visti 64 zaradi nekih for ne deluje, brezveze se matraš
svetetko ::
jao sranje. kaj pa crysis warhead? ista fora najbrž?
Rotaidal ::
Sprobaj demo, pa boš videl, če bo dobra. Gusarjev se ne podpira.
svetetko ::
vidm, da ni lih draga, tko da jo bom pomoje naroču. na 64 bitni visti naj bi original delal brez problema? je to sigurno?
50 / 53
Crysis 3 (strani: 1 2 3 4 5 )
Oddelek: Igre
23851379 (34525) kajetan
Far cry 2 (strani: 1 2 3 4 … 9 10 11 12 )
Oddelek: Igre
564132902 (86714) Assass1n
Radeon 4870 in Crysis
482676 (2003) SebaR
Februarja že GeForce 9? (strani: 1 2 3 )
10010909 (10905) Senitel
DX 9 vs. DX 10 (strani: 1 2 )
Oddelek: Igre
928148 (7186) kobilica
