Crysis 3
Crysis 3
2
3 4 5
miraldi ::
Dua'L je izjavil:
Kdor želi naj gre po tem postopku
1. go to http://www.fileplay.net [fileplay.net]
and register for a free account and verify that account.
2. go to http://www.fileplay.net/keys/55/crysis3... [fileplay.net]
and request for a new key and your key will be displayed on the screen so copy and have it.
3. Download origin or if you have origin , login with your email and password.
if you dont have account in origin , create one.
4. go to redeem product code and paste that product code which you got from fileplay.net and
click redeem.
5. the game will appear in your origin account and the hover over the game and click pre load.
No more keys :8)
i7 12700k
RTX 4070ti
32Gb
miraldi ::
Looks nice:
i7 12700k
RTX 4070ti
32Gb
Bolf3nk ::
fail
tole zgleda kot crysis 2 dlc
galu ::
Jutri pride Crysis 3 (open) Beta ven, 19. 2. pa full release.:D
Zdej pa na lov najnižjih cen za preorder... Trenutno je moja najdba tole - http://www.cdkeyhouse.com/origin-keys/3... (stran je sicer trenutno down zaradi prenove). Hunter Edition preorder (digital) za cca 37€. Je našel kdo ceneje?
Tako to gre.
galu ::
Tako to gre.
Skyman ::
http://www.zavvi.com/games/platforms/pc... 36.25€ škatlasta verzija!
miraldi ::
Iz kje se da jutri downloadat demo najbolj zihr?
i7 12700k
RTX 4070ti
32Gb
galu ::
Skyman je izjavil:
+ 10% popusta.. Hudo.8-O
Tako to gre.
ahac ::
Sba ::
Če bo kdo kupoval, se priporočam za group buy. Zadnji čas, da si kako kartico zrihtam. :))
Those that claim that they're not showing off are drowning in denial!
Tr0n ::
Kr cool tale multiplayer. Na high se dela kolko tolko pa FXAA. :)
6151 ::
Izjemno optimiziran spil =)
Z FXAA Na 1920x1200 dobim 70-80 fps
7900X3D | 32GB | 6800 | 4 TB
  • spremenil: 6151 ()
galu ::
TBH, vegetacija zgleda ko drek..;((
Tako to gre.
Tr0n ::
Pa Very High settingi. :)
miraldi ::
Sem tudi jaz malo sprobal Crysis 3. Ja nekih vauuu sprememb kar se grafike tiče nisem opazil. Zgleda pa multiplayer kar zanimiv. Treba premislit o nakupu..
Igram na Very high 4x MSSA 1920x1080 pa imam stalno vsaj 50fpsjev. Dobro optimatizirana igra.
i7 12700k
RTX 4070ti
32Gb
Bolf3nk ::
Itak da špil laufa, če je konzolni špil enako kot drugi del.
Tr0n ::
Tudi res.
Jst ::
i3770k@4.5 & 670 & very high FPSji preveč skačejo za normalno igranje... (Bo pa nvidia sigurno v kratkem izdala driverje, kjer se bo to vsaj do neke mere rešilo - še vedno je, prav tako AMD.)
Oktan ::
nvidia je že izdala driverje za tole beto
to so za 560ti
http://www.nvidia.com/object/win8-win7-...
Berserker ::
Dobra grafika, slaba igralnost, UI je preveč poln. Kako si tisti aimpoint dol vzameš iz puške.
Siddh ::
grafika je super, samo barve se mi zdijo nekak nerealne, tako kot je rekel berseker igralnost je res slaba, odzivnost miške je vsaj pri meni zelo počasna, se bom malo moral še igrat z nastavitvami in UI je res nagačen vsega sranja, vse zgleda kar zmetano na en kup pa v malo fancy obliko postavljeno
upam, da bo dejanska igra konkretno drugačna od te bete, ampak vem, da to nebo res
Berserker ::
Se vidi da tole ne dela nemški Crytek.
Nope. Zato pa grem igrati Far Cry 1 :D
Blue3D ::
Meni je ta demo všeč.
Tested on Quakers
I5 14600K 4080SUPER
Pro_moted ::
Mah, jaz osebno sem se sedaj nekak navadil na BF3 in mi je večina ostalih FPS iger prav smešna za igrat. Je pa dobra grafika ja, pa še novi driverji bodo malo pošlihtali nizke FPS z vključenim MSAA.
AMD FX8120;GB 990FXA-UD3
6151 ::
Sem sprobal in je super.Men vse dela na medium na gtx 470 brez problema grafika odlična.Multiplayer super ampak jaz se bolj veselim sigleplayerja imam pa igro prednaročeno že 1 leto:)že zato,ker imam vse prejšne dele komaj čakam:)
Xserces ::
tut men leti tale demo na medium. še malo driverje spedenajo pa bo to to! :) mi je pa zanimiv špil!
dottor ::
Bo treba grafične zamenjat, ker ne podpira DX10 ;((
M-XXXX ::
dottor je izjavil:
4870 PODPIRA DX10!
Siddh ::
verjetno je mislil da igra podpira dx11 only
galu ::
Sej tudi je DX11 only.
Tako to gre.
dottor ::
Siddh je izjavil:
Točno to.
fireX88 ::
in nič drugače!
Bolf3nk ::
Špil bi moral biti to kar je bil prvi farcry in prvi Crysis. Da so top mašine pokleknile ob izidu. Da je bila grafika res top. Sedaj pa imamo bedne konzolne porte in enako grafiko že nekaj let.
  • spremenil: Bolf3nk ()
dottor ::
Bolf3nk je izjavil:
Se popolnoma strinjam. Ob izidu prvega Crysisa je otročad jokala, ker igra ni delala, in so se sistemi gradili okoli sistemskih zahtev (tudi sam sem sestavil 2 sistema ki sta temeljila na igranju crysisa), dan danes, pa konzole diktirajo zmogljivost, čeprav crysis še dan danes marsi kateremu sistemu povzroča težavice :))
Pro_moted ::
Bolf3nk je izjavil:
Ja , najboljše. Pa da vsako leto daš 500 evrov za novo high end grafo.
Bolf3nk ::
eh... najbolje, da bi igre ostale na nivoju pacmana, pa nebi bilo treba nič zapravit
miraldi ::
i7 12700k
RTX 4070ti
32Gb
Bolf3nk je izjavil:
Pacman je kult.
Blue3D ::
Zakaj lahko eni imajo boljša orožja v Crashside meni se sploh ne odklenejo.
V igri mi piše maximum rank reached.
HD7850 moram imeti vse na low, da ne pade FPS pod 50 ko je full gužva.
Tested on Quakers
I5 14600K 4080SUPER
Men je pa cool, ker imam 5let star procesor in ati 4800 pa mi še vedno vse dela tekoče.
Ps razen crashside, kjer sem na min resolucijo in detajle gledal diapozitive.
  • spremenil: Magic1 ()
6151 ::
Blue3D je izjavil:
Suit si že rebootau?
Blue3D ::
Nisem vedel,da to obstaja.
Ok zdaj pa imam Hunterbow.
Tested on Quakers
I5 14600K 4080SUPER
  • spremenil: Blue3D ()
Halfdead987 ::
AMD je izdal nove gonilnike 13.2 beta,ki naj bi po XFX-ovih informacijah dodal 40% boost v Crysis 3 (in 10% v Farcry 3)
Blue3D ::
13.2 BETA 4 :)
Tested on Quakers
I5 14600K 4080SUPER
Xserces ::
Blue3D je izjavil:
13.2 BETA 4 :)
13.2 b5 :)
FEATURE HIGHLIGHTS OF THE AMD CATALYST 13.2 BETA 5 DRIVER
Crysis 3 multi-player Beta: Improves CrossFire scaling by up to 40%
Far Cry 3: Improves performance up to 10% at 2560x1600 with 8xAA
New 3D Mark release: Adds CrossFire profile support for the new 3D Mark release under Windows 8
  • spremenil: Xserces ()
6151 ::
Blue3D je izjavil:
Ko dosežeš max rank, daj še enkrat, boš še več imel unlockano
Je kdo našel ceneje kot 30€ C3?
Blue3D ::
Jaz sem tukaj, ko je še bila 34€ brez poštnine ki je 0
Čudno, da je sold out.
Pa ne piše če je škatla.
Tested on Quakers
I5 14600K 4080SUPER
dottor ::
Magic1 je izjavil:
Pa Crysis 3 ne dela gor :))
2
3 4 5
Crysis 2 (strani: 1 2 3 4 … 14 15 16 17 )
Oddelek: Igre
841175747 (57083) Horas
Grafična kartica HD6850 - Pomoč (strani: 1 2 )
7916517 (16216) dzinks63
Crysis 1 še vedno grafično zelo zahtevna igra?!
Oddelek: Igre
244147 (2915) Halfdead987
Grafična kartica nekje okoli 200€ za igre...
204881 (4272) Doc123
Bo Crysis 2 omejen le na DirectX 9? (strani: 1 2 )
Oddelek: Novice / Igre
7131717 (29774) korenje3
