Crysis
Crysis
36 / 53
mesoreznica ::
Jaz ves čas laufam najnovejše Beta driverje, pa je vse ok. Ne vem zakaj bi čakal. :D
Gigabyte UD3P, E8500 @ 4.5 GHz , HD4870-X2, 4GB ram (Xtreeme Dark),
WD Velociraptor, LC Legion-X
Engineer_SLO ::
Dr.M - kje pa si dobil te driverje? na nvidiini strani so samo 169.xx (beta)
ASUS ROG Maximus X Hero, I9 9900K, NZXT Kraken X62
32GB DDR4 3200 CL16, 512MB + 1024GB GB NVME SSD+ 2x2TB 7200rpm
EVGA GeForce RTX 3090 FTW3 ULTRA, ALIENWARE 38 - AW3821DW
PINki ::
Kje ga lahko dobim?:8)
EDIT: Že dobu:D
  • spremenil: PINki ()
m.i.h.a. ::
Forceware 171.16 beta - WinXP
Forceware 171.16 beta - Vista
*gre za 32bit verzije
Edit: pa še test na vr-zone.com
  • spremenil: m.i.h.a. ()
PINki ::
A mi lahko nekdo prosim nekam uploada CVAR mapo z cfgji, ker sem zjebal zadevo z editanjem teh cfgjov. Prosim:'(
Tilen ::
tilinho20 ::
Jaz bi vprašu vse lastnike kartice 8800 GTS G92 koliko imajo FPS-jev v Crysis-u ter nastavitve naštimane na very high.
tilinho20: sej lahko bi ti tudi naredil ksn gpu test in prilepil sem. :)
ahac ::
  • zavaroval slike: Alpheus ()
Engineer_SLO ::
Win XP -high-privzeto brez cfg- grafična gf8800gts512 navita na 716/1800/1050 - cpu test 1
TimeDemo Play Started , (Total Frames: 1500, Recorded Time: 44.62s)
!TimeDemo Run 0 Finished.
Play Time: 37.37s, Average FPS: 40.14
Min FPS: 26.31 at frame 1091, Max FPS: 61.78 at frame 162
Average Tri/Sec: 41109416, Tri/Frame: 1024093
Recorded/Played Tris ratio: 0.70
!TimeDemo Run 1 Finished.
Play Time: 33.52s, Average FPS: 44.75
Average Tri/Sec: 45757156, Tri/Frame: 1022392
!TimeDemo Run 2 Finished.
Play Time: 33.45s, Average FPS: 44.85
Min FPS: 26.31 at frame 1091, Max FPS: 62.49 at frame 190
Average Tri/Sec: 45746280, Tri/Frame: 1020040
Recorded/Played Tris ratio: 0.71
!TimeDemo Run 3 Finished.
Play Time: 33.24s, Average FPS: 45.13
Average Tri/Sec: 46111752, Tri/Frame: 1021814
TimeDemo Play Ended, (4 Runs Performed)
Win XP -high-privzeto brez cfg- grafična gf8800gts512 navita na 716/1800/1050 -gpu test 1
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
Play Time: 44.73s, Average FPS: 44.71
Min FPS: 29.26 at frame 167, Max FPS: 54.98 at frame 994
Average Tri/Sec: 45242208, Tri/Frame: 1011847
Recorded/Played Tris ratio: 0.91
Play Time: 40.85s, Average FPS: 48.96
Min FPS: 29.26 at frame 167, Max FPS: 59.29 at frame 1006
Average Tri/Sec: 49994736, Tri/Frame: 1021086
Recorded/Played Tris ratio: 0.90
Play Time: 40.83s, Average FPS: 48.98
Average Tri/Sec: 50083348, Tri/Frame: 1022497
Play Time: 40.79s, Average FPS: 49.03
Min FPS: 29.26 at frame 167, Max FPS: 59.48 at frame 1002
Average Tri/Sec: 50103104, Tri/Frame: 1021825
Win XP -high-privzeto brez cfg- grafična gf8800gts512 nenavita cpu test 1
Play Time: 39.61s, Average FPS: 37.87
Min FPS: 23.36 at frame 1100, Max FPS: 55.92 at frame 155
Average Tri/Sec: 38716224, Tri/Frame: 1022282
Play Time: 36.83s, Average FPS: 40.72
Min FPS: 23.17 at frame 1098, Max FPS: 56.58 at frame 177
Average Tri/Sec: 41640580, Tri/Frame: 1022530
Play Time: 36.67s, Average FPS: 40.91
Average Tri/Sec: 41933844, Tri/Frame: 1025003
Play Time: 36.38s, Average FPS: 41.23
Min FPS: 23.17 at frame 1098, Max FPS: 57.29 at frame 217
Average Tri/Sec: 42135140, Tri/Frame: 1021915
Win XP -high-privzeto brez cfg- grafična gf8800gts512 nenavita gpu test 1
Play Time: 48.17s, Average FPS: 41.52
Min FPS: 23.00 at frame 157, Max FPS: 51.12 at frame 1014
Average Tri/Sec: 41974572, Tri/Frame: 1011056
Play Time: 44.81s, Average FPS: 44.63
Min FPS: 23.00 at frame 157, Max FPS: 52.69 at frame 988
Average Tri/Sec: 45596852, Tri/Frame: 1021666
Play Time: 44.82s, Average FPS: 44.63
Min FPS: 23.00 at frame 157, Max FPS: 53.21 at frame 1021
Average Tri/Sec: 45621324, Tri/Frame: 1022273
Play Time: 44.80s, Average FPS: 44.64
Min FPS: 23.00 at frame 157, Max FPS: 54.17 at frame 1000
Average Tri/Sec: 45626032, Tri/Frame: 1022129
uporabljeni so gonilniki ForceWare Release 169 WHQL Version: 169.21 in patch za crysis 1.1 vse privzeto na high brez uporabljene cfg datoteke z katero bi sigurno pridobil še kak fps..
zanimivo je da ni nobenih tako nizkih min fps kot pri Dr_M
me prav zanima kaj bodo zmogli novi gonilniki in patch 1.2
še nakaj a ima kdo kakšen dober cfg za very high nastavitve v win xp oziroma tudi cvar file-kako ga preurediti za boljši preformanse
tilinho20 ::
Dr_M@ hehe jaz imam trenutno tak računalnik, da igranje Crysis-a na njem so le pobožne želje.;)
Engineer_SLO: jest mam E2140 @ 3120MHz, kar je precej mn kot pri tebi,pa se 8800GT mam. :)
Na kateri locljivosti si testiral? AA in AF si mel na 0?
CFG za veryhigh tudi mam,ampak je frame drop zelo velik (HIGH cca 48fps povprecno, Very HIGH 33fps), tako da vec kot za slinit se ni :) :\
Engineer_SLO ::
resolucija je 1280x1024
aa=0
af=default (se mi zdi 16x na high)
procesor pa je ob testiranju bil na 3200 MHz,ker tudi če ga imam na 3600 ni nobene razlike 8-O zato sem multi spustil na 8...
sigurno pa grafična lahko zaradi dodatnih shader cevevodov manj pade pri min fps...
a lahko nekam nalepiš cfg za very high
,ker jaz sem poizkusil z ccc 1.2 pa zadeva sploh ne zoptimira stvari,temveč kar upočasni zadevo...;(
Jest sem uporabil tole.
Zanimivo, da se frekvenca procesorja ne pozna nic. Men se je med opteronom 170 @2800 in E2140 @ 3120 poznal kr ene 30-40%, oz vec kot 10fps.
edit: lahko probas tudi s tem modom.
  • spremenil: Dr_M ()
Hister ::
Pozdravljeni!
Nekaj sem se matral z Crysis tweakingom (http://www.tweakguides.com/Crysis_8.htm... sam mi za mojo specifikacijo PC-ja (glej spodaj) ne rata narediti dobrega kompromisa med FPS in kvaliteto slike. Ima mogoče kdo kakšen predlog kako naj si uredim parametre v CFG datoteki, da dosežem željene učinke?
Motherboard Asus M2N32-SLI Deluxe/Wireless Edition, AM2
AMD Athlon 64 5600+ X2 Dual-Core, AM2
Gigabyte GeForce 8800 GTS, 320MB, PCI-e
Monitor Samsung SyncMaster 931c 19"
Patriot DDR2 2 x 1GB 800MHz DL PC2-6400
Harddisk Seagate 320GB, 7200rpm, 16MB, NCQ, SATAII
iLichu ::
djte mi povedat kako bi delal crysis na mojem računalniku
Intel E6550 2.4GHz
ATI HD 3850
2x1GB RAM
dzinks63 ::
:)) Z primernimi nastavitvami dokaj lepo in igralno.
Engineer_SLO ::
win XP - Very High Settings in DX9 - gf8800gts 512 - default - c2d6850@3.2ghz
Play Time: 64.21s, Average FPS: 23.36
Min FPS: 15.60 at frame 1088, Max FPS: 34.59 at frame 164
Average Tri/Sec: -31138646, Tri/Frame: -1333009
Recorded/Played Tris ratio: -0.54
Play Time: 55.82s, Average FPS: 26.87
Min FPS: 15.60 at frame 1088, Max FPS: 34.67 at frame 205
Average Tri/Sec: -35750956, Tri/Frame: -1330315
Play Time: 55.83s, Average FPS: 26.87
Min FPS: 15.60 at frame 1088, Max FPS: 34.71 at frame 205
Average Tri/Sec: -35749820, Tri/Frame: -1330630
Play Time: 56.18s, Average FPS: 26.70
Average Tri/Sec: -35551084, Tri/Frame: -1331467
win XP - Very High Settings in DX9 - gf8800gts 512 - 738/1836/1062 - c2d6850@3.64ghz
Play Time: 56.38s, Average FPS: 26.61
Min FPS: 19.43 at frame 1094, Max FPS: 39.20 at frame 188
Average Tri/Sec: -35677936, Tri/Frame: -1341018
Play Time: 50.27s, Average FPS: 29.84
Min FPS: 19.43 at frame 1094, Max FPS: 39.26 at frame 188
Average Tri/Sec: -39604568, Tri/Frame: -1327169
Play Time: 50.24s, Average FPS: 29.86
Min FPS: 19.43 at frame 1094, Max FPS: 39.27 at frame 194
Average Tri/Sec: -39770736, Tri/Frame: -1332090
Play Time: 50.33s, Average FPS: 29.81
Average Tri/Sec: -39727124, Tri/Frame: -1332892
igralno,samo malo preveč zahtevno - za igranje mi je high dovolj....:D
janwoolf ::
Ne vem kaj naj naredim!
hvala :D
moja grafa 7900gto lepo dela na medium in high
C2D E8400, Crucial Ballistix Tracer 2x1gb PC-8500,
P5K-E, XFX 8800GTS (G92) 512MB,Antec nine hundred
cooling 4x120mm and 1x200mm, Enermax Infiniti 650W
Klemzz ::
am, laufi čez most...
C4rtm4n ::
Meni se je pa zataknilo tukaj: :D
Baje moram neko orožje pobrat, vendar ga ne najdem. :8)
Respect my Authority!
Klemzz ::
Hm, TAC gun bi moral imeti, nevem če lahko brez njega prideš do zadnjega bossa...
Engineer_SLO ::
ne moreš,tako da ga sigurno imaš samo ga uporabiš šele ko ti to naročijo iz ladje....
seveda moraš najprej sesuti vse topove na vesoljski ladji....
janwoolf ::
laufat čez most???
janwoolf ::
nič ne razumem, kaj moram naredit
C4rtm4n ::
Hmm... Saj mi govori, da naj vzamem TAC gun, vendar ga ne najdem nikjer. :D
janwoolf @
Moraš skočit na drugo stran mostu.
janwoolf ::
skočim pa sm mrtev....
janwoolf ::
rad bi igral! čakam odg. :D
Mirč ::
ma moraš orozje pobrat v letalonosilki preden prideš iz nje
iLichu ::
pomagas si lahko s gamefaq.com
janwoolf ::
probat v letalonosilki kje je to?
Mislm, da mors it ene 2 savegamea nazaj it. Tac gun dobis tm nekje, ko unga kapitana ubijejo. Ne spomnim se cist tocno, ampak mislm, da mal pred tem zavijes v en hodnik in prides nazaj v laboratorij, kjer so te prej na en racunalnik priklopil. Ce si ze zunaj, ne mores nazaj v ladijo.
C4rtm4n ::
Aha
Bo treba poskusit.
Tnx
janwoolf ::
a tu?
mislim da ne?
a grem še nazaj?
prosim naj slika crysis, da bom vedel :D
hyphh ::
Če ste se naveličal SP kampanije..
Crysis Singleplayer Custom maps:
- Giggenheim
- Physis
- MakinAtoll
- Jungle Map
- Country Path
Te so mi bile kul in sem jih preigral.
Tukaj pa se nahajajo še ostale mape oz modi:
- Crymod Downloads
Meizu ::
Ej una mapa MakinAToll - faak, sam usta sm odprl - zakon!! Sm se prou obliznu, ko sm gledal to grafiko in mapo nasploh - me pritegnejo tile ozki prehodi, ozke poti med gostim šavjem :D Sam škoda da je moj komp v sestavi še in nimam primernega računala trenutno za poganjat to špilo. Zakon mapa res, svaka mu čast :D
aodius ::
Kaj do igra prek neta?
http://www.gregorsalobir.si/
Tilen ::
Lahko nekdo, ki ima te fajle že dol jih uploada na kakšno hitrejšo povezavo? S crymod.com lahko downloadam samo 1 file istočasno, pa še to z 10kB/s.
edit: prve večje fajle mam dol, tako da za vse ostale, ki se jim ne da čakat 20min :
http://www.boomy.org/Giggenheim1.1.rar
http://www.boomy.org/physisIII.rar
http://www.boomy.org/khenaz___island_aka_jungl_.rar
http://www.boomy.org/MakingAtoll.rar
http://www.boomy.org/Country_Path.rar
  • spremenil: Tilen ()
hyphh ::
En mod, katerega bi se splačalo probat.
Natural Mod For Crysis
Shegevara ::
je to že blo?
barrel explosions
Meizu ::
blo blo:D
Galaxy ::
Meni igra zamrzne ob checkpointu, ko disablam GPS Jammerja. imam patch 1.1, vendar nikakor mi ne uspe usposobit Crysisa.. :'(
janwoolf ::
rad bi noclip. kateri mod rabim?
kako dobit 3000 barrel explosions
  • spremenil: janwoolf ()
Hister ::
Še enkrat pripenjam vprašanje...
Pozdravljeni!
pozitron ::
Daj vse na medium oz. vsaj shader-je in sence 1280 x 1024 2xAA pa uživaj in se ne obremenjuj za tiste extra bombončke. Na high na tvoji nativni resoluciji, boš bolj težko igral.
Engineer_SLO ::
poizkusi z temle,najprej pa nastavi v igri vse na high nato zapusti igro in skopiraj tole v autoexec file....
con_restricted = 0
r_displayinfo = 1
r_driver = "Dx9"
g_useProfile = 1
e_particles_thread = 1
sys_budget_videomem = 1024
sys_budget_sysmem = 1536
sys_physics_CPU = 1
r_GeomInstancing = 1
r_MultiGPU = 1
r_ShadersAsyncCompiling = 1
e_vegetation_static_instancing = 1
e_hw_occlusion_culling_objects = 1
e_hw_occlusion_culling_water = 1
e_terrain_occlusion_culling = 1
r_TexturesStreaming = 0
e_screenshot_width = 5120
e_screenshot_height = 2880
e_screenshot_quality = 100
e_screenshot_file_format = jpg
r_HDRlevel = 0.7
r_HDRBrightOffset = 3
r_HDRBrightThreshold = 2
r_HDRRendering = 1
r_EyeAdaptionClamp = 2.5
e_obj_quality = 2
e_proc_vegetation = 1
ca_useDecals = 1
e_decals_allow_game_decals = 1
e_decals_life_time_scale = 0.5
e_lod_ratio = 4
e_lod_min = 2
e_view_dist_ratio_detail = 20
e_view_dist_ratio_vegetation = 25
e_vegetation_min_size = 1.0
i_rejecteffects = 1
e_vegetation_bending = 0
sys_flash_curve_tess_error = 6
e_view_dist_ratio = 50
e_max_view_dst_spec_lerp = 0.5
e_vegetation_sprites_distance_custom_ratio_min = 0.5
e_vegetation_sprites_distance_ratio = 1
e_detail_materials_view_dist_z = 128
es_DebrisLifetimeScale = 0.3
e_cbuffer_resolution = 128
e_dissolve = 1
ca_DrawFaceAttachments = 1
ca_AttachmentCullingRation = 100
e_terrain_occlusion_culling_max_dist = 100
i_lighteffects = 0
g_ragdollMinTime = 5.0
g_ragdollUnseenTime = 1
g_ragdollDistance = 15.0
g_battleDust_enable = 0
e_particles_quality = 2
e_particles_lod = 1
e_particles_max_emitter_draw_screen = 16
r_UseSoftParticles = 0
e_water_ocean_soft_particles = 0
e_particles_object_collisions = 0
e_cull_veg_activation = 40
g_joint_breaking = 1
g_tree_cut_reuse_dist = 0.35
p_max_MC_iters = 4000
e_phys_foliage = 2
es_MaxPhysDist = 60
es_MaxPhysDistInvisible = 10
e_phys_ocean_cell = 1
e_foliage_wind_activation_dist = 10
g_breakage_particles_limit = 130
v_vehicle_quality = 2
p_max_substeps_large_group = 3
p_num_bodies_large_group = 30
r_PostProcessEffects = 1
r_MotionBlur = 0
r_Flares = 1
r_Coronas = 1
r_UseEdgeAA = 2
r_sunshafts = 1
r_colorgrading = 0
r_GlowScreenMultiplier = 0.2
r_WaterGodRays = 1
q_ShaderGeneral = 3
q_ShaderMetal = 2
q_ShaderGlass = 0
q_ShaderVegetation = 1
q_ShaderIce = 0
q_ShaderTerrain = 1
q_ShaderShadow = 1
q_ShaderFX = 0
q_ShaderPostProcess = 2
q_ShaderHDR = 1
q_ShaderSky = 1
q_Renderer = 2
r_LightsSinglePass = 1
e_sky_type = 1
e_sky_update_rate = 0.12
r_DetailTextures = 1
r_DetailNumLayers = 2
r_DetailDistance = 4
r_HDRRendering = 1
r_SSAO = 0
r_SSAO_quality = 2
r_SSAO_blur = 2
r_SSAO_radius = 2
r_SSAO_darkening = 0.3
e_ram_maps = 1
sys_flash_edgeaa = 1
e_vegetation_use_terrain_color = 1
e_terrain_ao = 0
e_terrain_normal_map = 0
e_max_entity_lights = 8
r_UsePom = 0
r_EnvTexUpdateInterval = 0.01
r_TexturesFilteringQuality = 2
r_HairSortingQuality = 0
r_FillLights = 7
e_particles_lights = 1
e_shadows = 1
r_ShadowJittering = 0.1
e_shadows_max_texture_size = 512
r_ShadowBlur = 3
e_gsm_lods_num = 4
e_gsm_range = 3
e_shadows_cast_view_dist_ratio = 0.4
r_ShadowsMaskResolution = 2
e_shadows_on_alpha_blended = 0
e_shadows_from_terrain_in_all_lods = 0
e_gsm_cache = 0
s_FormatSampleRate = 48000
s_CacheSize = 80
s_MPEGDecoders = 64
s_Obstruction = 1
s_ObstructionAccuracy = 1
s_ObstructionUpdate = 0.1
s_SoundMoodsDSP = 1
s_VariationLimiter = 1.0
s_ReverbType = 2
sys_LowSpecPak = 1
r_TexSkyResolution = 2
r_ImposterRatio = 1.7
r_EnvCMResolution = 1
r_EnvTexResolution = 2
r_DynTexMaxSize = 50
r_TexAtlasSize = 512
r_DynTexAtlasCloudsMaxSize = 24
r_DynTexAtlasSpritesMaxSize = 16
r_Beams = 3
r_BeamsDistFactor = 0.05
r_BeamsMaxSlices = 64
e_Clouds = 1
r_CloudsUpdateAlways = 0
r_WaterRefractions = 1
r_WaterReflections = 1
r_WaterUpdateFactor = 0.001
e_water_tesselation_amount = 10
e_water_tesselation_swath_width = 10
r_WaterUpdateDistance = 0.2
r_WaterCaustics = 1
r_WaterReflectionsQuality = 1
e_water_ocean_fft = 1
q_ShaderWater = 3
r_WaterReflectionsMinVisiblePixelsUpdate = 0.05
r_DepthOfField = 0
e_terrain_texture_lod_ratio = 1.5
e_terrain_lod_ratio = 1.5
e_detail_materials_view_dist_xy = 4096
upam da ti bo delovalo dovolj v redu...
Hister ::
Oj!
Hvala za pomoč! S tvojimi nastavitvami imam average 40 FPS. HDD sem spremenil, ker je bil zelo nerealističen. Sence bi bilo treba izboljšati, dodal pa bi tudi učinek vetra - premikanja rastlinstva. Kje to naredim?
Engineer_SLO ::
tukaj nastavljaš za sence,malo se poigraj
e_shadows = 1
r_ShadowJittering = 0.1 - povečuj po 0.1
e_shadows_max_texture_size = 512 - probaj na 1024
r_ShadowBlur = 3
e_gsm_lods_num = 4
e_gsm_range = 3
e_shadows_cast_view_dist_ratio = 0.4 - povečuj po 0.1
e_gsm_cache = 0
r_UseEdgeAA = 2 - poizkusi zmanjšati na 1 ali 0 ,to je kao mehčanje textur ki doda obilnejše rastje vendar zgubiš nekaj na hitrosti
za učinke vetr in podobno pa se moraš poigrati z naslednjimi nastavitvami:
ca_useDecals = 1
e_lod_ratio = 4
e_lod_min = 2
i_rejecteffects = 1
e_dissolve = 1
spreminjaj po svojih potrebah in željah,je pa res da moraš skleniti marsikateri kompromis na račun strojne opreme
m.i.h.a. ::
za premikanje rastlinja spremeniš vrednost v vrstici: e_vegetation_bending iz 0 na 2
(0 = OFF, 1 = slabša kvaliteta, 2 = boljša kvaliteta)
za lepše sence pa spremeniš: q_ShaderShadow iz 1 na 3
(0 = OFF, 1 = low, 2 = med, 3 = high)
+ e_shadows_max_texture_size....kot je opisal Engineer v postu zgoraj
Hister ::
Najlepša hvala za navodila!
36 / 53
Crysis 3 (strani: 1 2 3 4 5 )
Oddelek: Igre
23851392 (34538) kajetan
Far cry 2 (strani: 1 2 3 4 … 9 10 11 12 )
Oddelek: Igre
564132912 (86724) Assass1n
Radeon 4870 in Crysis
482676 (2003) SebaR
Februarja že GeForce 9? (strani: 1 2 3 )
10010915 (10911) Senitel
DX 9 vs. DX 10 (strani: 1 2 )
Oddelek: Igre
928148 (7186) kobilica
