Forum » Loža » Umetna inteligenca
Umetna inteligenca
Povej mu, da so se vsaj 10 let tudi assembler maherji zgražali nad compilano kodo, pa to kmalu ni več nikogar brigalo. Ker se je malo izboljšala in ker je to toliko pohitrilo stvari da je postalo nepomembno, če je malo "slabša".
Kayzon ::
"AI does the coding, and the human in the loop is the orchestrator"
This is the sentiment being hyped up around the industry currently: traditional coding is all but dead, and Spec Driven Development (SDD) is the future. You generate a plan, and disconnect from writing any code. The agents know better, and handle all the implementation. You are there as the expert, to provide "good taste", review the outputs, and constantly steer the agent(s) to execute the plan that you meticulously put together.
The workflow takes many shapes at this point, but in general, it is a process where someone defines the project's requirements (simultaneously at a micro and macro level), generates a plan, and then pulls the slot machine lever over and over, iterating and reiterating with often multiple agent instances until it's done. All the while, putting a growing distance between the "orchestrator" and the code that is being generated and committed.
Coding Agents are helpful, and powerful, but there's already some quantifiable trade-offs that need to be discussed:
An increase in the complexity of the surrounding systems to mitigate the increased ambiguity of AI's non-determinism.
Atrophying skills for a wide swath of the population.
Vendor lock-in for individuals and entire teams (Claude Code outages have already had entire teams at a stand-still).
Fluctuating and increasing costs to access the tools. An employee's cost is fixed; tokens are a constantly moving target.
Being successful with this approach to coding agents hinges on a rather crucial element: only a skilled developer who's thinking critically, and comfortable operating at the architectural level, can spot issues in the thousands of lines of generated code, before they become a problem.
Yet, in an ironic twist of fate, it's the individual's critical thinking skills and cognitive clarity that AI tooling has now been proven to impact negatively.
https://larsfaye.com/articles/agentic-c...
joez7 ::
Če bo tole šlo v produkcijo https://www.msn.com/en-xl/news/other/ch... bo počil balon.
BigWhale ::
Assembler maherji so se zgrazali nad prevajano kodo vse dokler prevajalniki niso postali dovolj dobri, da so proizvajali kodo, ki je bila boljsa od tiste, ki so jo pisali assembler maherji. Enako bo z LLMi. Kako pomembno je da je koda "malo slabsa" je odvisno predvsem od namena kode in v cem je malo slabsa. Posplosevanje je mati vseh zajebov.
OP sestavek sem jaz razumel drugace, bolj v stilu, da Fable sedaj melje neko stvar pol ure, Opus jo je pa v pol ure trikrat iteriral in prisel do enakega ali pa boljsega zakljucka. Tudi moja opazanja so podobna, mene Fable zaenkrat se ni preprical in tezko recem, da je nek blazno viden napredek. To je bila prva stvar, kot druga je pa to, da so ljudje sedaj bolj odklopljeni od kode, in posledicno cutijo manj odgovornosti do tega kar so sproducirali.
Jaz sem ze veckrat imel primere, ko sem ljudi spraseval zakaj so kodo popravili tako kot so jo, pa tega niso znali razloziti, ker je kodo pisal LLM. A je to dobro ali slabo lahko vsak sam presodi.
To da ti zarad ene male spremembe vse obrne na glavo je sicer zoprno, ampak če je tak refactoring zastonj, why not. Seveda je problem to potem stalno na novo testirat, ampak a ni bolje da je narejeno prav in optimalno (recimo da je) kot pa da čim bolj podobno kot prej.
BigWhale ::
Tud ce imas vse pokrito s testi (pa v praksi nikoli nimas), te vsak refaktor nekaj stane. Nekdo mora narest code review. Proper code review zahteva svoj cas, ce ti LLM zgenerira 500 vrstic nove kode to ni vec trivialen review, sploh ce je konkreten refaktor. Ce ti v testu kaj pade, mora spet nekdo to popravljat. Ce delas code review z LLMom se tud na ta review ne mores zanasat, lahko ga vzames kot guideline. Meni je ze velikokrat nasel stvari, ki niso bile relevantne ali pa niso imele smisla.
In navsezadnje, tisi, ki dela review mora vedeti kaj gleda. Na koncu dneva, ce ne ves kaj je hashmap potem ne mores LLMju rect naj ga uporabi namesto linked liste. In ce ne ves, da ni dobro OpenAI API kljuca shranit kar na githubu, tud ne mores vedet, da ga je LLM tja shranil.
Način dela se bo moral spremenit. Firma, ki bo vsakih 500 vrstic kode, ki je pljune AI, analizirala do zadnje pike, bo pač zaostala za tisto, ki ne bo. Pogleda se od daleč kako dela, stestira se funkcionalnost, ki naj bi bila, popravi kar je potrebno, in gremo naprej. Meni v enem šihtu komot pljune 2000 vrstic. Sam jih ne bi napisal, in sure as hell ne preverim vsake vrstice v nulo. Niti nihče drug za mano. Če bi, potem bi bilo res vseeno, če bi sam naredil vse na roke. Pogledam od daleč, poskusim razumet kako dela, če me kaj ni prav razumel, potem se pa pač preizkuša rezultate.
Ja, itak, eno je kvaliteta, drugo pa v kolkem času lahko nekaj dostaviš. Ponavadi je treba najt nek kompromis, ker narjeno bi itak moralo bit že včeraj.
- spremenil: Utk ()
SambaShare ::
2000 vrstic dnevno? Potem si najbolj produktiven programer na svetu. Razen če jih 90% ne dela nič koristnega, ali non stop refaktoriraš stare stvari.
Katera branža programiranja presnese tak način dela?
Ne vsak dan, je pa kak dan ko je tako. Če imaš recimo kako poročilo, malo sql, malo html, javascripta, itd, se tega nabere. Jaz naredim sql, ki vrne neke podatke, on pa zgenerira html, ki to prikaže na razne načine, z interaktivnimi grafi itd. Vrstic je ogromno, lahko je kar komplicirano, in sigurno ne preverjam vrstico po vrstico kode, preverim pa rezultate.
Ali pa mu dam nek xml kot primer, ki ga vrne nek webservis, skupaj s shemo in mu rečem da mi naj naredi nek človeški prikaz, povežemo to še z opisi polj iz drugih virov, dodamo neke povzetke samo določenih stvari, itd.
To je delo za codemonkeya, ne rečem, ampak codemonkey mi ne naredi tega cel mesec kar dobim od AI v uri ali dveh (ko skupaj dodelamo stvari).
- spremenil: Utk ()
codeMonkey ::
codemonkey lahko samo se ploscice polaga danes. Pa se to vprasanje, ce je sposoben. :)
- spremenilo: codeMonkey ()
codeMonkey ::
Jaz zdaj vmes med nogometom lepo opencode poganjam, da mi potestira kar sem danes implementiral. Agent ve kaj je relevantno za feature, ze ce samo primerja branch z master, zna iti tudi skozi coverage report, in tako ima vse kar rabi, da pokritost pride na 100%. Mi je nekaj malenkosti nasel, nismo pa se na 100%. Jutri bom malo pregledal teste in predal kolegu v review. Verjetno vseeno bolje, kot pa da sam svojo kodo testiram. Po vsem tem itak se pride fuzz testing, pa bo ze moralo biti za silo OK. Za implementacijo pa ga jaz ne uporabljam na tak nacin. Tu imam rad nadzor in mentalno sliko produkta, pa se stik s kodiranjem ohranjam, dokler je to kaj vredno.
Dobro ajde, če delaš reporte res ni nič kritičnega. Drugo bi bilo, če bi mu dal za narediti kakšno obdelavo podatkov (beri insert in update) na produkciji.
Dobro to je drugo. To menda boš dobro preveril. Pa tega ni toliko, glede na vse drugo.
Menda si boš pomagal z njim tam kjer si lahko čim bolj. Ne pa tam kjer ti ne prihrani nič.
- spremenil: Utk ()
PluribusUnum ::
Ja novi nazivi slo tech bi dodali podaljšek potencialni realnosti.
Rescimo; persona futura
- spremenilo: PluribusUnum ()
SambaShare ::
Pa spet vprašam, komu je tak produkt zadosten? A je pod reportom tudi vključen disclamer, da ga je zgeneriral LLM in so notri lahko napake?
Productivity gaini, ki jih nekateri baje dosegajo so pa tudi fenomen zase. Zavijem vsake toliko v r/futurology, r/accelerate, ipd in se čudim. Bereš same zgodbe o uspehu, vsi x10 gain, ...
Po 5 letih tega je rezultat kaj točno? Očiten padec kvalitete in kup klonov aplikacij, brez dodane vrednosti.
- spremenilo: SambaShare ()
DamijanD ::
Ne morete vsega enačiti. Seveda tudi reporti morajo biti pravilni - ampak škoda oz. odpravljanje napake na reportu (sploh, če gre samo za UI/typo probleme) je povsem druga stvar kot pa zajeb, če so v bazo letele napačne stvari, ki so potem posledično vplivale, da so se odvisne stvari napačno generirale in imaš cel zaj. to pofixat, če je sploh možno...
BigWhale ::
Do zadnje pike nihce ne pogleda nicesar. Ampak, ko delas z osebnimi podatki, ko delas z varnostno obcutljivimi podatki, stvari enostavno moras pogledati. Ko lovis mili in mikro sekunde pri dostavi rezultatov je pomembna marsikatera malenkost, ki se zdi trivialna. Ena dodatna milisekunda se ne slisi veliko, sam, ce mas pa nekaj milijonov uporabnikov, se pa nabere. Marsikaj ti ujamejo performace testi, ne pa vsega. Plus, ce ti testi trajajo predolgo, ti testiranje postane bottleneck. Je kar frustrirajoce, ko cakas 20 ljudi, da se merge queue zvrti do konca, samo zato, da na koncu ugotovis, da je tvoja koda prepocasna in mors se enkrat cez vse.
Tudi UI in UX testi trajajo nekaj casa in ce mors Clauda tepst, da ti en gumb premakne tri piksle v desno in za to porabis tri iteracije, se stvari pocasi nabirajo.
141741 ::
Tole zaenkrat bolj spada sem kot pa boxoffice temo ali med filme za razmišljanje, je kar zanimivo? :D
Domain FilmEs A.I
Description
Welcome to Domain Films A.I – where artificial intelligence meets cinematic storytelling!
We create complete original films using the most advanced A.I tools, bringing epic, emotional and visually stunning stories directly to you.
🎬 What you'll find here:
Post-apocalyptic science fiction films
Engaging narratives with complex characters
Cinematic visual production generated by A.I
Expansive universes with multiple chapters
Original atmospheric soundtracks
🔥 Series in production:
"THE FALLEN" - A post-apocalyptic saga about humanity's survival against giants that fell from the skies after dimensional portals opened.
Each video is carefully scripted, produced and edited to offer a complete cinematic experience. These aren't just clips - they are real films, created entirely with A.I.
📺 Subscribe and hit the bell to not miss any release!
Domain Films A.I - The future of cinema has already begun.
Domain FilmEs A.I
Description
- spremenilo: 141741 ()
dronyx ::
Bi mi znal kdo narest ali vsaj svetovat, kako se naredi AI agenta, ki bi spremljal Trumpov Truth Social in investiral glede na njegove objave? Po moje bi se tu dalo služit lepe denarje, samo bi moral ujet pravi ritem.
dronyx ::
Trenutno stanje na področju AI biznisa: There is an infinite demand for $20 notes at a $10 price, but this is not a sustainable business model.
BigWhale ::
Ce kdo slucajno uporablja Grok Build CLI, Elon se vam zahvaljuje. :>
https://www.reddit.com/r/LocalLLaMA/com...
tldr verzija je, da bo grok pobral vse kar imate v repozitoriju in to poslal v xAI cloud, tud ce se nardi opt-out. :D
joez7 ::
Ja, pa če ma gdo namesko zloben, slab, zavajajoč - bo znal filtrirat, ali pa bo to vključil za sveto - tu je razlika med mesom in peskom.
141741 ::
Ja, če se zavedaš, se da marsikaj - tudi agente poganjati iz kontejnerja in ne iz matičnega os in 'občutljivosti' namensko ne šerati s tem 'ujetim' agentom. Mene bi mogoče bolj zanimalo, pri kom opt-out sicer 100% deluje in bo od tod do večnosti, da ni potrebno namensko omejevati.
V času prihajajočega UTD tudi denar ne bo več pomemben, menda končno kmalu tudi v Sloveniji, kjer se to čaka od 'vekomaj'.
Že veste, kaj boste delali takrat? Upam, da se ne boste kratkočasili z dejanji inu debatami iz kakšne od sosednjih tem? :D
141741 ::
Ker bomo predolgo čakali ali se pobili iz dolgega časa, ker dvomim, da bi UTD omogočal nek freedom, ki se ga tako naivno slika v Sloveniji?
Lahko bi tudi poleteli k Xenomorphom v naročje :D
Boš prepočasen, Trump uvaja plačljivo spremljanje Truth Social v realnem času, preden objave vidijo laiki.
IgorCardanof ::
Pri nas se tudi vecino kode napise z AIjem, vsaj v sirsem oddelku, kjer delam. Smo omejeni samo na Gemini modele, ki so zaenkrat kar konkretno zadaj za top coding modeli, pa se vseeno da z dovolj skilli in agenti, da kar dosti stvari naredit.
Si mislim, da ko bodo Gemini modeli na visjem levelu enkrat, da bo kar naenkrat ogromna razlika v outputu.
Podrocje se res spreminja in v nekaj letih je vprasanje, kako bo zgledal SWE poklic.
Ne odgovarjam na DM.
- spremenilo: IgorCardanof ()
Po moje bodo specializirani modeli vedno v prednosti. In čedalje več bo te specializacije in drobljenja.
V nekaj letih vprašanje, če ne bo človek ura spet cenejša.
- spremenil: delavec44 ()
141741 ::
Pošteno - čeprav izgleda, da je anthropic postal bolj radodaren kot je bil in deli bonbončke obstoječim naročnikom - da ne odidejo v 2H26, ker se je aktivnost podmnožice naročnikov zmanjšala (ne povečala!) - ali pa je pravičniški val iz OpenAI upadel - glede na zgornji video:
Umetna inteligenca, ki je ob izidu leta 2022 obljubljala drastično znižanje stroškov in nadomeščanje človeške delovne sile, se danes spreminja v izjemno drago korporativno breme. Podjetja so sprva množično uvajala AI in odpuščala zaposlene, hkrati pa so začela meriti uspešnost inženirjev glede na porabo žetonov (t.i. "token maxing"), kar je privedlo do njihove nesmotrne in pretirane porabe za povsem nepomembna opravila. Posledično so stroški žetonov poskočili; povprečna cena za milijon žetonov se je od konca leta 2025 do maja 2026 več kot podvojila in dosegla 2,12 $. Velikani, kot sta AT&T s porabo 8 milijard žetonov dnevno in Meta s 60 bilijoni žetonov mesečno (kar nanese približno 900 milijonov dolarjev), se soočajo z astronomskimi računi, zaradi česar je celo Microsoft svojim zaposlenim prepovedal uporabo orodja *Claude Code*.
Zaradi teh ekstremnih podražitev so številna podjetja že v nekaj tednih izčrpala svoje letne proračune za AI. Ker sta ponudnika, kot sta Anthropic in OpenAI, še vedno neprofitna in delujeta z izgubo, bosta ob načrtovanem odhodu na borzo prisiljena še dodatno dvigniti cene žetonov, kar bo stroške za podjetja eksponentno pomnožilo. Analize kažejo, da je poganjanje avtonomnih AI agentov ponekod jé zdaj dražje od najema ljudi; medtem ko je AI pri programiranju res cenejši, je razlika pri vnosu podatkov minimalna, v klicnih centrih pa je človeško delo celo cenejše. Ob upoštevanju, da je bilo skoraj 50 % načrtovanih gradenj podatkovnih centrov v ZDA za leto 2026 odpovedanih ali odloženih, se podjetja upravičeno sprašujejo o dejanski donosnosti teh investicij in ugotavljajo, da je človeška sila dolgoročno finančno bolj smiselna.
141741 ::
No, seveda, ampak če ostanemo v 'mirni dobi', mene to najbolj preseneča, kako so se firme nahakljale, mi, naročniški skromneži, smo bili prisiljeni precej optimizirati svoj 'ai workflow', od različnih semantičnih indeksov, namenskih skillov in agentov z delegiranjem na poceni modele (tudi zunanje) - začela meriti uspešnost inženirjev glede na porabo žetonov - FFS, porabo? A ni bila neka tema, kjer je en slo-techar na poročilu porabe dokazal (ali poskušal dokazati, saj ne vem), da lahko porabi 5M tokenov do malice za zelo malo efekta? Vsak.Ljubi.Dan.
IgorCardanof ::
AI disproval nekaj novega:
https://x.com/__alpoge__/status/2079028...
Čakam, da začne tudi še s kakšnimi dobrimi dokazi, kot samo s kontra primeri.
JanBrezov ::
ChatGPT na lastno pest vdrl v drugo podjetje s področja umetne inteligence
Glavni izvršni direktor podjetja OpenAI Sam Altman je v torek sporočil, da je njihov model umetne inteligence ChatGPT samoiniciativno in povsem samostojno vdrl v drugo podjetje s področja umetne inteligence.
Good news: https://apnews.com/article/ai-anthropic...
Zdaj pa upam da jih tožijo še vsi ostali :)
A ko greš v knjižnico in prebereš knjigo, tistega, kar si se pri tem naučil, ne smeš kar brezplačno uporabljati?
SambaShare ::
Za sposojo knjige v knjižnici plačaš članarino, knjižnice pa tudi kupijo knjige ter plačajo na nek način avtorske pravice.
141741 ::
Haha, kaj, kako? Se je ozavestil ali kaj, FFS? To je nek jeben bullshit!
Nobenega drugega akterja ni bilo, niti posrednega, niti šeduliranega?
Torej AI že kuri Veliki raženj, pardon, plete Veliki filter?
Ja nič, lepo je bilo. Recimo... :D
PS: Še temu je veliko lažje verjameti, čeprav...
asinhronc ::
Koliko strokovnih knjig si prebral? Če bi kakšno, bi vedel da na začetku lepo piše: (vzel eno iz moje arhive) To delo je objavljeno po licenci.... Uporabnikom je dovoljeno ..... da navedejo avtorja in da ne gre za komercialno uporabo ..... Vsa gradiva tretjih oseb .... Če gradivo ni pod licenco, boste morali pridobiti dovoljenje neposredno od imetnika avtorskih pravic...
Podrobnost je vedno na prvih straneh knjige. Torej? Avtor ti daje vsa dovoljenja da se lahko naučiš, saj je zato tudi izdal knjigo in dobil cekine, knjige pa ne dovoljuje brez njegovega dovoljenja neposredno uporabljati za komercialno rabo. Ampak ja, svet je že davno šel v MP3, morale ni več, kraja je že davno legalna.
| » | Anthropic opozarja, da se bo umetna inteligenca kmalu sama izboljševala (strani: 1 2 )Oddelek: Novice / Znanost in tehnologija | 13908 (9184) | c3p0 |
| » | GPT-5.2 je tu (strani: 1 2 )Oddelek: Novice / Znanost in tehnologija | 13778 (6152) | kriptobog |
| » | O tveganjih in stranskih učinkih se posvetujte s ChatGPT HealthomOddelek: Novice / Znanost in tehnologija | 7135 (4713) | ToniT |
| » | Strokovnjaki za umetno inteligenco postali zvezdnikiOddelek: Novice / Znanost in tehnologija | 14051 (11178) | Legon |
| » | Jaz pa mislim, da bo ChatGpt izpodrinil programerje (strani: 1 2 3 4 5 6 )Oddelek: Loža | 84948 (44327) | SambaShare |
