Ubuntu 21.04 AMD Radeon RX 6000 artifacti
Rad21 ::
V Ubuntu 21.04 imam artifacte na zaslonu z AMD Radeon RX 6000. Za Ubuntu 21.04 nisem našel AMD gonilnikov razen za Ubuntu 20.04 in starejše. Z NVIDIA GPU nikoli nisem imel teh problemov.
V Windows 10/11 nimam tega problema razen v Linux-u.
Kakšna rešitev?
https://www.reddit.com/r/linux4noobs/co...
  • spremenilo: Rad21 ()
Rad21 ::
Gonilniki so problem v Ubuntu 21.04. V Ubuntu 20.04 brez gonilnikov nimam artifactov.
Kako zamenjam gonilnike?
Na spletu sem bral, da je treba zamenjati kernel.
Rad21 ::
Gonilniki za graficno kartico so bili problem. Sedaj nimam vec artifactov.
https://linuxconfig.org/amd-radeon-ubun...
PPA third-party repository
If you absolutely insist to have the latest AMD Radeon driver version you may use the PPA third-party repository which might be always ahead of the stable default opensource driver coming with your Ubuntu 20.04 system as default. To install the PPA third-party repository drivers execute the following commands:
$ sudo add-apt-repository ppa:oibaf/graphics-drivers
The above will add the PPA AMD Radeon driver repository to your system. The following command will upgrade your current AMD Radeon driver to the latest version:
$ sudo apt update && sudo apt -y upgrade
Bizkit45 ::
glad you made it
[(K)Ubuntu] Vprašanja in težave (strani: 1 2 3 4 … 23 24 25 26 )
Oddelek: Operacijski sistemi
1262411616 (11176) bosmla
Ubuntu, Xubuntu 21.04 bootable USB problem
61607 (1442) Sindrom
Ubuntu vprašanja (strani: 1 2 3 4 … 19 20 21 22 )
1061249546 (118385) poweroff
Ubuntu Oneiric Ocelot 11.10 (strani: 1 2 3 4 … 14 15 16 17 )
813225957 (191896) Icematxyz
Ubuntu 10.04 LTS - Change is coming (strani: 1 2 3 4 … 17 18 19 20 )
999172843 (135729) Icematxyz
