Forum » Na cesti » Torsen diferencijal
Torsen diferencijal
Martin Krpan ::
Se še uporablja v 4x4 avtomobilih ali ga je že povsem zamenjala elektronika ?
V 90 je bil višek tehnike , uporabljale so ga rally specijalke kot so Audi Quattro in Lancia Delta S4 in tudi njihove "civilne" verzije , danes pa se o njem nič več ne sliši.
lovro535v2 ::
Uporabljav ga je audi do quattrota iv generacije sedaj pa uporabljajo planetne zobnike.Na tej strani lahko izveš kaj več o tem http://www.awdwiki.com/en/audi/
Raspberry Pi 512MB 32GB Raspbian/Asus P7P55D Intel core i5 2,66ghz
LGA 1156 8GB Kingston DDR3 WD Black 1TB Gigabyte GT430 W7/
Nexus 7 2013 32GB/Oneplus one 64GB Sandstone black.
krneki0001 ::
Nehal so ga dajat v poceni serijske avtomobile, ker je predrag in ker so vse rešili z elektroniko.
Pa subaru impreza wrx sti ima tudi sredinski in zadnji dif torsenov. Od leta 2007 naprej.
The Torsen T-3 is currently employed as the centre differential in all non-Haldex Traction Audi models with a ZF-sourced automatic transmission quattro four-wheel drive, such as: Audi A6/A7, and Audi Q7. Note Audi uses a mechanical "Crown Wheel" centre differential for all longitudinal implementations using dual-clutch transmissions, such as the 2013/14 S4/RS4. Alfa Romeo used a Torsen C twin differential in the Alfa Romeo 156 Crosswagon Q4 and also in the 159, Brera and Spider Q4 models. Also, Toyota uses a Torsen T-3 in the center differential of the 4Runner Limited, FJ Cruiser 6-speed manual, Land Cruiser and Lexus GX470, with manual locking feature, and GM used a Torsen T-3 center differential in the transfer case of the Chevrolet TrailBlazer SS and Saab 9-7X (Aero model only).
- spremenilo: krneki0001 ()
krneki0001 ::
GrimReaper ::
Kar je novih FWD avtomobilov, Torsen imata Peugeot 208 GTi by Peugeot Sport (novi 208HP) in 308 GTi, Opel Corsa OPC + OPC Performance Pack pa ima Drexler.
lovro535v2 ::
krneki0001 je izjavil:
A6 ga še ima, A4 ima haldex.
Tanovi ne več, imajo vsi haldexa, tudi A8, ker je cenejša izvedba.
Kolikor vem imajo A3,Q3 in TT haldex, ker je prečno nameščen motor A4,A6,A8 planetne zobnike Q5,Q7 pa naj bi še, kar uporabljala torsen R8 pa ima visko sklopko katero krmili računalnik nisem pa prepričan za te trditve tako, da me popravite če se motim.
krneki0001 ::
Imeli so torsna A4,6 in 8 do prejšnje generacije. Zadnja generacija je cela na haldexu.
Martin Krpan ::
lovro535v2 je izjavil:
Ja , problem je ker pri Audi-ju kar vse povprek označujejo z Quattro kar je bil včasih sinonim za torsen , danes pa še VW-jev syncro prodajajo kot quattro.
lovro535v2 ::
Aha se pravi da sedaj šparajo še pri pogonu.
korenje3 ::
kaj ima pa škoda superb 4x4?
lovro535v2 ::
Haldex, ker imajo prečno nameščen motor ter ker je tudi cenejši.
- spremenil: lovro535v2 ()
krneki0001 ::
lovro535v2 ::
Kako pa deluje DCCD pri imprezi wrx sti v povezavi s torsen diferncialom sem misliv da imajo vsi subaruji visko sklopko razen justya.
krneki0001 ::
Večina subarujev ima sredinski diferencial skupaj z viskom (kot zaporo), da zaklepa sredinski diferencial.
wrx in legacy spec B imata pa od 2007 naprej:
Vir: http://www.rallispec.com/dif_gls_rst190...
Tukaj so pa razloženi skoraj vsi pogoni subarujev:
http://www.awdwiki.com/en/subaru/
Subaru uses a Torsen(R) T-2 type LSD in the rear of the Impreza STI starting in 2007 as well as the rear of the Legacy Spec B (6MT version). The front helical LSD's used in both 5MT and 6MT models are, as far we can tell, GKN models.
lovro535v2 ::
Kolikor gledam to vidim pa, da avtomatiki nimajo visko sklopke ali je to res ali se potem obnaša kaj drugače na terenu kot z ročnim menjalnikom gre boljše slabše.
korenje3 ::
če koga zanima :)
krneki0001 ::
avtomatiki se obnaša kot haldex, ker imajo stalno 90:10 razmerje pogona. Torej 90% moči na prednja kolesa, 10% na zadnja. Ob zdrsu prednjih koles in nad 3000 obrati pa preklopi na 50:50. Seveda so tudi že pogruntal fantje, da rabiš par uporov in stikalo, pa lahko to potem ročno vklapljaš, da imaš stalni 50:50 pogon.
noraguta ::
Zaporo nucaš tud na torsnu. Če gre za off road. No tam se obnese tud preprosta sklopka. Na cesti je pa druga reč. Ampak večinoma je nepotrebna komplikacija. Žr ožje gume peljejo scat torsen in visko na snegu al pa spuščene na pesku.
Največji joke u lajfu je bil ko je kolega z kadetom trobil pajerotom nej se skidajo iz zasnežene ceste.
- spremenilo: noraguta ()
lovro535v2 ::
a se da potem z drugačnim upornostmi tudi regulirti razmerje npr. 60:40 70:30 ali 40:60 30:70lovro535v2 je izjavil:
lovro535v2 ::
Zato pa lahko imaš samo sprednji pogon če daš FWD varovalko notri ker se mi je zdelo čudno ker drugače se ne bi dalo če bi imel visko sklopko.
cvalsr ::
Noraguta, malo se pouči o torsen diferencialu. Je samozaporen in niti slučajno ne rabi neke dodatne zapore. Zobniki v njem so nekaj vmesnega med čelnimi in polžastimi, zato so obremenitve zelo velike, diferencial je robusten in težak , tako da zaradi njega steče kak dodaten lit'rček skozi motor.
krneki0001 ::
Jap. Čeprav tudi visko imajo sedaj z elektromagnetno zaporo.
lovro535v2 ::
Aha
| » | Avtomobili s trpežnim podvozjem (strani: 1 2 3 4 5 6 )Oddelek: Na cesti | 95740 (88189) | krneki0001 |
| » | Nakup Passat-a l. 2006Oddelek: Na cesti | 6505 (5629) | -valvoline- |
| » | Poceni terenc (strani: 1 2 )Oddelek: Na cesti | 26905 (23479) | krneki0001 |
| » | Vožnja v snežnih razmerah (strani: 1 2 3 4 )Oddelek: Na cesti | 43499 (40516) | PrimozR |
| » | BMW serija 5 zadnji pogon in sneg?! (strani: 1 2 )Oddelek: Loža | 47982 (44580) | chucki |
