Forum » Loža » Ročni mlinček za kavo
Aston_11 ::
erkgheoruugh je izjavil:
Mislim, da ga iam tudi Cafe čokl v LJ. A po netu pa ne bi naročal?Prepozno. Todaj is D-day. Grem pa kamorkoli, samo da ga imajo.
Aston_11 ::
Pa si preveril tam, kjer sem ti napisal?Ne, do Ljubljane sem sicer prišel, nato pa sem ga našel pred nosom, torej v trgovini v Postojni.
alkor ::
zivijo,
v cem je fora rocnega mlincka za kavo? oz prednost pred motornim? toplota?
našel sem tole, kar me pa ne prepriča:
Why Grind By Hand?
So if hand grinders are a little trickier to use and don’t create the most even grind out there then why even bother using them at all? Personally, I believe they do have their place in the world of coffee grinders for several reasons.
Hand grinders are perfect for travelers. If you have to bounce around from hotel to hotel for work you know how hard it can be to enjoy some of the little things in life. Hand grinders are small and easy to carry with you so you can enjoy your favorite specialty coffee no matter where you are.
Hand grinders are more affordable. While we may all want to spend however much money we want on our coffee habits, the fact is we can’t do that. Just because you have to operate on a budget, doesn’t mean you shouldn’t be able to enjoy a cup of coffee. Hand grinders are far more affordable making them the perfect grinders for people who are shopping on a tight budget.
Hand grinders show your dedication to quality coffee. Using a hand grinder to grind your own coffee is probably the best way to demonstrate your devotion to the perfect cup of joe.
thx,
Why Grind By Hand?
thx,
LP,
a
erkgheoruugh ::
Razlika je v načinu mletja. Taki poceni mlinčki imajo rezilo, ki razbija zrnja in daje nekonsistentno mletje, kar je pri kavi, kjer je zaželjeno nekoliko bolj grobo mletje, pomembno.
Pač pri nas je kultura pitja turške kave, zato to niti ni toliko pomembno. V lokalih pa imaš itak ta prave grinderje.
Realist ::
Živjo,
kateri ročni kavni mlinček priporočate pa da je cenovno ugoden?
Verjetno je fajn da se da štelat grobost mletja?
Prvič kupujem mlinček, pa ne bi elektro zadeve zaradi cene in tudi ne rabim tako pogosto.
mujek ::
Živjo,
Vzami takega z jeklenimi rezili.
Pred časom sem uporabljal Hario s keramičnimi, pa ni bila ravno enakomerno mleta kava.
Sedaj pa kakšne 2-3 leta, uporabljam Timemore Chesnut mlin z jeklenimi rezili. Kava je precej bolj enakomerno mleta.
Na kakšen način pa misliš pripravljati kavo?
Takšni ročni mlini so primerni za prelito/filter kavo. Za espresso pa ti ne morem svetovati.
Poglej si James Hoffmannove posnetke o teh temah.
HotBurek ::
Jaz imam takega, za poper. Top zadeva.
Vir: https://www.bolha.com/ostale-umetnine-s...
Tule je pa postopek obnove, če ti to leži.
root@debian:/# iptraf-ng
Please resize your window
- spremenilo: HotBurek ()
Matwic ::
Živjo,
Timemore C5 PRO, direktno iz AliExpressa (cca 62 EUR z DDV in poštnino, namesto 115 EUR iz EU štacune):
https://www.aliexpress.com/w/wholesale-...
Edino opozorim, da za Turško kavo (nekako 2,8 - 3,2 nastavitev mletja) se boš kar namlel za polno kapaciteto (cca 30g). Nekako 8 minut vrtenja. No ja še vedno imaš opcijo, da uporabiš bormašino, pa glede na to kako zelo so tej ročni mlinčki popularni grem stavit, da bodo v roku enega leta na voljo baterijski adapterji za vrtenje.
- spremenil: Matwic ()
| » | Kateri kavni apart? (strani: 1 2 3 4 5 6 7 8 )Oddelek: Loža | 93051 (15765) | Horas |
| » | Kvalitetna kava (strani: 1 2 3 4 … 9 10 11 12 )Oddelek: Loža | 169357 (36253) | hotig |
| » | Kava (strani: 1 2 3 4 5 6 7 )Oddelek: Loža | 116972 (20401) | kuglvinkl |
| » | Mletje kaveOddelek: Loža | 7250 (6027) | TheBlueOne |
| » | Kavni aparat Gorenje?Oddelek: Loža | 9987 (8844) | Badwolff |
