Forum » Loža » Cena nafte
Cena nafte
SambaShare je izjavil:
Kaj ti pomaga tržni delež, skozi nižjo ceno, če imaš na koncu isto denarja. Konkurenca pa tudi če propade, ponovni zagon proizvodnje ne stane veliko in na dvig cene čez n let, ko si sam na trgu ne moreš računati.
V bistvu je ponovni zagon proizvodnje nafte iz konvencionalnih virov kar zelo drag. Na novo moraš postaviti skoraj vse vrtine, ker se ti stare ob prenehanju proizvodnje izredno hitro zamašijo. Hidravlično lomljenje ima tu odločno prednost, saj tam ponoven zagon res ne stane veliko. Zanimivo in zelo pomenljivo za prihodnost - če cene nafte skočijo v nebo bo hitro skočila tudi proizvodnja iz skrilavcev. Srednjeročno zato nafta čez 70 dolarjev za sod skoraj ne more iti, pričakovati je cene do kakih 40 dolarjev na sod.
Tisti, ki mislite, da je vse zaradi Rusije, tukaj imate tarčo. Pod 15$/sod.
http://rbth.com/business/2016/01/19/at-...
Analysts at Bank of America Merrill Lynch think that Russian companies are resistant to the fall in oil prices, as they are aided by the exchange rate, which falls with the oil price, and flexible tax rates.
But if prices reach $15, budget revenues will drop significantly: at this price and lower, the mineral extraction tax (MET) and export duties are automatically reset to zero.
In the case of zero rates of MET and export duties, general budget revenues in rubles will drop by half and even more in hard currency. This would put a great burden on the state, therefore at a price of $15 per barrel the tax burden on companies will be increased in one way or another. This will lead to an increase in the break-even number for oil companies.
Zdaj pa hitro nafto shortat, milijoni čakajo.
Kdo je kaj trdil?
Vanich ::
Cena nafte in devalvacija glavnih svetovnih valut. = one nice big clusterfuck. Mogoče bo pa to dobro za EURO?
Vanich ::
Zakaj pa clusterfuck? Nimas rad vec denarja v svojem zepu?!?
Meni se pozna en drek. Glavnino pobere država. Dolar pa tudi ni devalviral, ravno nasprotno.
Pridobis, ce drzava pobere vec - drugace bi pobrala nekje drugje.
Pridobis tudi indirektno, ker se evroobmocju izboljsa trgovinska bilanca.
Da evro ni pridobil proti dolarju tudi ne pomeni nic, morda bi v primeru visje cene nafte bil evro sedaj se sibkejsi.
- spremenil: kow ()
Brez nje si pa lahko lačen ...
Polento se ponavadi brez nafte papca.
To je sicer res, toda rabiš nafto da požanješ...
barakus ::
A mislite da bodo sle cene se kaj dol? Ne vem ali naj se malo pocakam z nakupom kurilnega olja :/
Tilen ::
Kurilno olje se zna podražiti že samo zaradi liberalizacije trga naftnih derivatov, ki začne veljati predvidoma 9. februarja.
- spremenil: Tilen ()
Vanich ::
Jaz bi pridobil, če bi $ dolar šel nazaj na 50 centov, ali še manj, in bi potem poceni kupoval blago iz USA. To bi bilo tudi izjemno blagohotno za USA, za njihov izvoz in gospodarstvo.
Nafta raste. The horror, Rusija še ne bo propadla ali kateri koli drugi.
Ubogi smrekar1.
Ubogi smrekar1.
Najnižje je bil dolar okoli leta 2007, ko smo za 1 dolar plačali cca 63 centov. Drugo imaš sicer prav, to bi bilo za gospodarstvo ZDA blagohotno, a kaj, ko zoprni ameri nočejo sodelovati in vodijo kredibilno fiskalno politiko, tudi če to škodi nekaterim sektorjem njihovega gospodarstva. Zoprno, res.
Nafta raste. The horror, Rusija še ne bo propadla ali kateri koli drugi.![]()
Podražiti se mora še za 150% (za faktor 2,5), da je Rusija ta hip vzdržna. Čez nekaj let bo ta cena še precej višja, saj imajo povsem nevzdržen pokojninski sistem, nenaftno gospodarstvo je v prostem padu, proizvodnja nafte pa bo v naslednjih nekaj letih trpela zaradi pomanjkanja investicij.
Rusija je na dobri poti, da postane propadla država (failed state). Vse skupaj je bolj kot ne vprašanje časa, malo dražja ali malo cenejša nafta lahko to samo nekoliko pohitri ali upočasni, to je to.
- spremenil: Smrekar1 ()
Podražiti se mora še za 50% (za faktor 1,5), da je Rusija ta hip vzdržna.
Popravljeno.
P.S.
Koliko časa moramo še čakati? Pišeš, da bo zdaj zdaj.
Smrekar1,
ZDA pa provinca Kitajske, saj tako vse kitajske.
Popravljeno.
Nak, je bilo kar prav. Za vzdržnost ta hip rabijo nafto pri vsaj 84 dolarjih za sod. Zdaj je cena 35 dolarjev za sod, 84/35 = 2,4, kar je dovolj blizu 2,5 (oz. povečanju za 150%) da lahko rečemo, da znam tele številke na uč kar fenomenalno dobro zadeti.
Nadalje, v naslednjih 5 letih bodo dobili še vsaj 2 milijona dodatnih upokojencev, ki jih plačujejo predvsem iz prihodkov iz nafte. Dolgoročno Rusija zato rabi še občutno višje cene nafte.
Smrekar1,
Mhm, sigurno.
Popravljeno.
Smrekar1,
Mhm, sigurno.![]()
Jp , bil je ölanek kako kupiti v ameriki zadeve ki so v lasti "amrikancev" in ne kitajcev...
Popravljeno.
Smrekar1,
Mhm, sigurno.![]()
Nope. 50$ je kar pravilno, kar bo več je že "pozitivna ničla"
Se je kaj podražilo?
Na www.petrol.si nimajo več cen (na prvi strani).
kuglvinkl ::
OPEC meeting ends without deal on oil production freeze, http://www.aljazeera.com/news/2016/04/o...
Kar pomeni, da bo do 2017 sod nafte (o)stal okrog 40$.
- spremenil: kuglvinkl ()
razerznak ::
Kar so arabci iskali to so dobli ko so hotli ruse zajebat, zaj bodo pa sami nasrkali
vesoljec nacist fojb
#trump2016
ups https://www.rt.com/usa/339768-us-marines-aircraft-aging/
#trump2016
Karaya 52 ::
Primarna tarča je bila tehnologija fracking s katero so ZDA v parih letih postale top proizvajalke nafte. Tisti, ki smo že dlje časa na forumu pa se spomnimo Thomasa, ki je že pred 10timi leti točno to napovedal, medtem ko je 95% populacije onaniralo na "oil peak" teorije. Respect.
Tilen ::
Se je. Samo ne zaradi uredbe, ker je bila sprejeta šele v začetku aprila. Sedaj bodo trgovci pridni, da se sprosti še cena bencina (95) in dizla.
Sej to je problem večine ljudi, ne zavedajo se niti malo kako zadeve funkcionirajo v naravi. Mislijo, da je vsa nafta v mehurčkih tik pod površjem in, ko jo bo zmanjkalo, bo konec. Nefte je pa v bistvu ogromno, le cena črpanja se veča, težje kot jo je dosežt. Tiste nefte, ki bi jo moralo že počasi zmanjkat napovedano v prejšnjem stoletju, je cena črpanja pod 10$ na sod. Pri 80$ se splača že fraking, kar je dobesedno stiskanje nafte iz podpovršja. Prav tako imaš še kup drugih metod in pri ceni 100-150$ imamo toliko nafte, da jo še sto let ne bomo niti priimbližno porabili.
Karaya 52 ::
Niti "učenim glavam" s slovenskih fakultet niso bile zadeve jasne in so v Odmevih ob rekordnih cenah razlagali, da tako poceni kot je nafta danes, jutri več ne bo. Čez leto dni so cene strmoglavile.
Opec ima zdaj problem, če zmanjša produkcijo bodo njegove deleže na trgu zavzeli drugi igralci. Tudi njihovi zlati časi so se končali. Kdo ve, mogoče bodo začeli zdaj dejansko kaj proizvajati...
razerznak ::
zdaj bo ali bo arabija plačala kako vojno v iranu ali pa res invazija arabije in turčije na sirijo
#trump2016
#trump2016
kuglvinkl ::
Enormno vlagajo v solarno tehnologijo.
BTW, v času poletja kurijo 1.5 mil sodčkov na dan samo za hlajenje.
Imajo nafto in imajo sonce. Idealni pogoji za oboje. A vseeno je to tako kot da bi nekdo sredi gozda, kuril na elektriko. Bo res bolj eko, a dražje. Na koncu zaslužili ne bodo na ta račun. Je pa prav, da so tam začeli malo bolj intezivno s solarno tehnologijo. Tam lahko vsaj doseže eno normalno ceno tako proizvedena elektrika, ne pa klepci v Nemčiji(ali pri nas npr. Gorenjskem), kjer je bolj malo sončnih dni.
kuglvinkl ::
IIRC razvijajo najprej zase tehnologijo, da bi lahko nafte čim več izvozili. 1.5 mil sodčkov na dan za klime? :)
Ti ne pomaga ravno veliko v ekonomskem smislu, če denar ki ga dobiš od 1.5mil sodčkov zapraviš za investicijo in vzdrževanje sončnih elektrarn.
Najboljši način je ta:
Concentrated solar power @ Wikipedia
Ne potrebuješ silicija, hkrati je tudi zbiralnik energije.
@kuglvinkl
Mas prav. Samo moras vedeti, da je nafte ze sedaj dovolj. V Severni Ameriji in Evropi poraba stagnira. Nafta je 40 dolarjev trenutno, ceprav se Iran sele vraca na trzisce. Ko se v Libiji nehajo klofati je na trgu ekstra 1 milijon sodckov. Kaj sele, ce bi se investiralo v povecanje proizvodnje. Teksacani zmanjsuje proizvodne stroske. 1 milijon sodckov vec za izvoz je 10, 15 odstotkov povecanja dohodkov. Poti nazaj do blagostanja prejsnjih let enostavno ni.
Ja, praktično vsi ukrepi za varčevanje energije niso v plus črpalcem nafte ...
Meni nekaj ni jasno. Kako lahko "strokovnjaki" izjavljajo tako debilne stvari, kot da je Kitajska pomembnejsi trg za porabo Nafte, kot EU.
http://www.bloomberg.com/news/articles/...
http://peakoilbarrel.com/a-surprising-l...
Dejstvo je, da je ravno obratno. Cetudi se je na sreco nasa odvisnost od nafte znizala, jo zaradi visjega standarda se vedno porabimo vec.
Res bi rad videl, da bi folk preden gre govort na TV, vsaj preveril osnovna fucking dejstva.
Seveda trendi porabe vplivajo na ceno:)
stara mama ::
Kdo pravi da nimajo prav?
In kdo sploh so ti "strokovnjaki", o katerih dostikrat slišim po TV, pa nikoli ne izvem kdo so to in kakšne reference sploh imajo?
@tikitoki
Imajo kar prav. Pomembnejsi je zaradi nagle rasti porabe, medtem ko EU poraba stagnira. Velika vecina svetovne rasti porabe v zadnjem desetletju je zaradi vzhodne Azije.
Massacra ::
| » | Iran vs Savdska arabija (strani: 1 2 )Oddelek: Problemi človeštva | 20150 (11540) | Pac-Man |
| » | Zakaj je dizel (še vedno) cenejši od bencina?Oddelek: Na cesti | 9462 (7810) | LeQuack |
| » | Cena nafte (strani: 1 2 3 )Oddelek: Loža | 22150 (15745) | krneki0001 |
| » | Peak oil? (strani: 1 2 3 4 … 9 10 11 12 )Oddelek: Problemi človeštva | 49732 (30373) | guest #44 |
