Forum » Operacijski sistemi » Debian Gnu/Linux kot workstation
CCfly ::
--limit-rate=amount
Limit the download speed to amount bytes per second. Amount may be expressed in bytes,
kilobytes with the k suffix, or megabytes with the m suffix. For example,
--limit-rate=20k will limit the retrieval rate to 20KB/s. This kind of thing is useful
when, for whatever reason, you don't want Wget to consume the entire available bandwidth.
Note that Wget implements the limiting by sleeping the appropriate amount of time after a
network read that took less time than specified by the rate. Eventually this strategy
causes the TCP transfer to slow down to approximately the specified rate. However, it may
take some time for this balance to be achieved, so don't be surprised if limiting the rate
doesn't work well with very small files.
"My goodness, we forgot generics!" -- Danny Kalev
CCfly ::
Mislim da apt-get uporablja wget, kar pomeni da vpiši limit v .wgetrc datoteko.
blue ::
@CCfly hvala za nasvet, ampak ne dela (čeprav za wget deluje)
Zgleda, da bo treba mp3je poslušat namest net radio
blue ::
@CCfly thanx!!!
Sm ugotovil, da bi mogu v svoji google poizvedbi uporabiti ~
- spremenilo: blue ()
Screamboy ::
ok man proftpd pa gftp pa apche pa me zanima kako bi lahko dal neko datoteko gor na apache preko ftp povezal bi se na ftp pa šel/var/www/ pa dodal datoteko samo ko to hočem nimam dostopa da bi dodal datoteko
kaj je tu narobe
kaj je tu narobe
Nerdor ::
A se je komu zgodilo, da Knoppix 3.3 in 3.4 "zašteka" na nForce 2 mama ploščah!? In da se noče dhcp client povezat s SMC Barricade routerjem !? Windows seveda dela super, samo bi rad mel linux. S freebsd-jem se še nisem pohecal (na ta "novi" mašini) ... Mislim, nisem si predstvaljal, da bom imel s (relativno) novim hardware-jem take problme s linuxom. Kako ste vi te zadeve usposobili pod nForce 2 based sistemih!?
... for lifetime!
- spremenil: Nerdor ()
Nerdor ::
Hruške: Evo pišem pod Knoppixom 3.8 CeBit Ed., deluje perfekt (kernel 2.6.11). Na začetku me je pozdravil v nemščini, vendar nič hudega, navajen sem na knoppix kratice (lang=sl screen=1028x1024) in pazi to delujejo "čžš" in nekaj opozoril v slovenščini. OO je 1.1.4, ni še 2.0 nažalost. S dhcp se je sporazumel s routerjem in internet promet je tako stekel.. Kratko malo sem navdušen, samo me moti, da je za zvočno (nforce2) izbral oss driver in ne alsa. Niti s soundconfig ga nisem mogel prepričati. Ampak ok, sej je live cd anyway.. Lep zaključek nedeljskega vikenda zame..
Dobil sem ga prek torrenta, ker ga officialy še ni na ftp in http..
PS: celo scroll za miško dela, odlično.. Ubutu Preview Hoardy 5.0x so smeti! Mrežno in router mi Hoardy lepo locknal in samo reboot obeh naprav je bila rešitev. Nobenih blemov s Knoppixom in s (pravim) Debianom!
... for lifetime!
hruske ::
Če rečeš apt-get install apache, dobiš 1.3, če rečeš apache2, dobiš dvojko. Če pa nič ne rečeš, imaš pa morda kak paketek, ki si želi še apača ob strani.
pikachu004 ::
supr..
no se nekaj programov bi rabil pa ce mi nekdo pove kako se imenujejo.. rabil nekaj podobnega kot je za win:
-corel draw
-photoshop
-nero
-easy cd-da creator
-msn messenger..trillian...
-net limiter
-kaksen resizer slik
-bs player
-kaksen ftp client
-dreamweaver-frontpage
-corel draw
-photoshop
-nero
-easy cd-da creator
-net limiter
-bs player
-kaksen ftp client
- spremenil: pikachu004 ()
Gandalfar ::
-corel draw - inkscape
-photoshop - gimp
-nero - k3b
-easy cd-da creator - k3b
-msn messenger..trillian... - gaim
-net limiter - trickle
-kaksen resizer slik - imagemagick
-bs player - mplayer/xine
-kaksen ftp client - gftp, nautilus, (k)bear
-dreamweaver-frontpage - nvu
-photoshop - gimp
-nero - k3b
pikachu004 ::
kako se nastima da npr. z mapo /aaa/bbb lahko delajo vsi uporabniki vse, in kako se nardi da z to mapo dela lahko samo en Uporabnik vse?
CCfly ::
Vse osnovne pravice se določa z ukazoma chmod in chown, če želiš več pa moraš uporabiti ACL.
grim_ ::
daš nazaj tako kot je bilo ;P
lahko pa tudi tako spremeniš pravice:
chmod 666 file
po tem bodo file lahko spreminjali vsi uporabniki
chmod 666 file
- spremenil: grim_ ()
pikachu004 ::
grim_ vem da das nazaj tako kot je bilo :) ampak kako se to nardi? da noben ne more vec nic delat z mapo.
aja.. pri gnome ko nekaj minimiziram kr zgine nekam. kam?
grim_ ::
chown root:root file, pa bo lahko s file-om delu samo root
Screamboy ::
mi lahko kdo pomaga pri modulih za ipv6
kernel je pa 2.4.27
sem poskusiol z apt-get install ipv6 pa ni tega paketa
ima kdo kak predlog
kernel je pa 2.4.27
ima kdo kak predlog
r5r ::
Kako onemogočiti panel pri xfce4
, ter dodati ikono na namizje.
Ter kako nastaviti samodejni zagon firefox, če je le-ta zaprt.
And it makes me wonder.
- spremenil: r5r ()
blue ::
Kup vprašanj:
1.Zakaj mi xf86cfg ali xf86config ne shrani nastavitve ???
V obeh primerih vnesem vse podatke.. Me vpraša če hočem shranit in še vedno nič.
2. Disk dela zelo zelo počaš hdparm -t pokaže prenose okol 3MB/s (poznam ljudi, ki majo hitrejšo povezavo v internet). Mam geforce1
3. Noče mi mountat cdroma. Imam ga na /dev/hdc. Sm naredil simbolični link. (NEC 3500 dvd pekač.)
V fstab mam tole:
/dev/cdrom /cdrom auto ro,noauto,user,exec 0 0
Hvala za poomč!
V fstab mam tole:
Hvala za poomč!
hruske ::
1. poskusi raje z "dpkg-reconfigure xserver-xfree86"
to ti shrani nastavitve, dokler ne spremeniš originalne datoteke na roko.
2. poskusi hdparm -d1 -c1 /dev/hdX kjer je X prava crka tvojga diska
3. a rocno ga kot root lahko mountas?
- spremenilo: hruske ()
Daedalus ::
1. Hja, za štelat X server morš v debianu nastavit paketek - dpkg-reconfigure xserver-xfree86 (nekaj na to temo, nisem 100%, trenutno delam v winsih, tak da ne morem preverit). Vsaj jaz vedno delam tak in do zdaj je še vedno shranil nastavitve...
2. Če znaš s hdparm zagnat disk benchmark, boš znal tudi vpisat man hdparm in si pohitrit disk z ukazom - hdaparm -opcija1, opcija2,...opcija3 /dev/hda - samo previdno, ker lahko z siljenjem višjih nastavitev, kot jih disk prenese, poškoduješ disk. z hdparm -i /dev/hda boš ugotovil, kaj disk prenese, z hdparm -v /dev/hda pa kaj je vklopljeno, kaj pa ne. Na koncu nastavitve zrihtaš v /etc/hdparm.conf datoteki, da se ob vsakem zagonu aktivirajo.
3. za CD-ROM ti fali filesystem opcija, uredi takole (mam isto na router mašini)
/dev/cdrom /cdrom iso9660 ro,noauto,user,exec 0 0
Takole na pamet bi tole moglo lavfat...
[J.P.Sartre]
[J.P.Sartre]
- spremenilo: Daedalus ()
Screamboy ::
alo nekaj me zanima glede psy bnc man debian z kernelom 2.4.27 pa man psybnc gorik pa men da ident xy namesto xx
pa sem dodal /adduser xx :scream pa potem enmu kolegu dal bnc pa dodal tudi pravilno pa njemi dal tudi ident xy pa sedaj imava oba enak ident to pa ni vredu.
Kaj bi lahko blo narobe
blue ::
Daedalus in hruske hvala za odgovor!!
Vse deluje!
Velikokrat ko "sshjam" se mi dogaja da zgubim povezavo (dial up
) ali pa gre pc v stand by.....
Kako lahko dobim nazaj tisto okolje v katerem sem delal ??
Vse deluje!
Screamboy ::
živjo vsem
mene zanima če obstaja še kako namizje polek gnome pa kde ki deluje na debian?
pa kak link do tega če lahko dobim
moj_nick ::
setxkbmap sl
Najbolje pa, če ročno popraviš xorg.conf/XF86Config
110111001001010001010000
Screamboy ::
mi lahko kdo že urejen config za apache + php ker mi trenutno nedeluje pa nevem zakaj
php4 imam nameščen
php4 imam nameščen
Daedalus ::
Jaz sem delal po teh navodilih.
[J.P.Sartre]
[J.P.Sartre]
Screamboy ::
a mi lahko kjdo pove kje najdem icone od katere koli theme od namizja gnome?
ker bi si jih rad ven zamenjal z nekimi drugimi iconami tnx vnaprej
christooss ::
Ce si zlodal ikone z neta potem gres pod upravljalnik tem. Cemas slovensko namizje se imenuje preprosto TEMA. Potem pa izberes install Theme. Pa izberes paketek z ikonami. Ko installiras gres pa pod Theme Details/icons
Drugac pa naredis kot ti je rekel gandalfar
Zakaj je nebo modro? Da imamo lahko sladoled Modro Nebo
| ! | [(K)Ubuntu] Vprašanja in težave (strani: 1 2 3 4 … 23 24 25 26 )Oddelek: Operacijski sistemi | 410544 (10104) | bosmla |
| » | Python - pošlji aplikacijo na serverOddelek: Programiranje | 1972 (1207) | HotBurek |
| » | Debian in iptablesOddelek: Operacijski sistemi | 2025 (1747) | karafeka |
| » | X window na Debianu mi ne delaOddelek: Operacijski sistemi | 1831 (1750) | roscha |
| » | Bi Linux? Bi Debian? Ubuntu! (strani: 1 2 3 4 … 8 9 10 11 )Oddelek: Operacijski sistemi | 39676 (27217) | Trubadur |
