Forum » Pomoč in nasveti » pomoč DVD
pomoč DVD
sloeagle ::
Živjo!
Mam en velik problem s DVD predvajalnikom.Nalagam novo posodobitev in jaz majster medtem ugasnem DVD (ponesreč staknil kabel ven - električen)
. Ponovno zaženem DVD predvajalnik in CD noče več ven.
Kaj naj naredim? Ali je varijanta samo servis?
Blaž
Blaž
huek111 ::
Notice (Read Prior to Beginning the Firmware Update Process)
The following events may cause the writing of the firmware update to the player to be halted and the player to no longer operate properly.
exclamation !
1. DO NOT unplug the power cord during the firmware update process.
2. Avoid loss or interruption of power during the firmware update process.
3. DO NOT press the power button on the unit during the firmware update process.
4. Check the firmware update disc for dirt or scratches before beginning the firmware update process.
Mislim da te reši samo servis!
exclamation !
damjan11 ::
ok hvala. bo pa treba mal do servisa:D
Jure
Dej še malo forum preberi.... meni se zdi, da so to fantje za pivičko naredili
| » | LG 3D SMART TV in nedelujoči podnapisi (strani: 1 2 )Oddelek: Pomoč in nasveti | 10956 (9750) | ttommy |
| » | [DivXviD] Pioneer predvajalniki (strani: 1 2 3 4 … 8 9 10 11 )Oddelek: Zvok in slika | 77423 (22185) | LexLuthor |
| » | Router in zunanji diskOddelek: Pomoč in nasveti | 1124 (946) | SasoS |
| » | [DivXviD] Silva Schneider predvajalniki (strani: 1 2 )Oddelek: Zvok in slika | 13910 (6030) | primozzzz |
| » | Nov članek: "All your firmware are belong to us" (strani: 1 2 3 )Oddelek: Novice / Nova vsebina | 20335 (17175) | arrigo |
