LG 3D SMART TV in nedelujoči podnapisi
2
vančika ::
Aja, da pa še jaz doprinesem neko novost v post, še tole povem, kar mi je ravnokar moderator bloga na Patriotovi strani odgovoril glede mojega problema, bom kar prilepila, ko vidim, da tudi ti obvladaš angleško:
Beware I know that one of the firmware (Can't remember which one) when using the reset to default sets the brightness so low that you can not even see the screen anymore. Pretty hard to see the screen when it's all dark to try to increase the brightness back up. I do not recommend to do the restore setting to factory default if that is what you mean.
Takole. :D
  • spremenilo: vančika ()
T_F_7 ::
kako se je potem končalo? sta se poročila vi2? :))
ttommy ::
Ha ha ha...
Gamer
Wd TV Live (strani: 1 2 3 4 … 21 22 23 24 )
Oddelek: Zvok in slika
1173231107 (74570) scipascapa
3D SBS podnapisi - kako jih vstavit v MKV
2513271 (7724) kitl76
3D (SBS) in podnapisi
113067 (2554) j3rn3jk
Patriot box office (strani: 1 2 )
567016 (5285) polde66
Uporabnost USB na LCD TV-jih (strani: 1 2 3 )
12164911 (56802) Lupin
