Zakaj imajo avti 4x4 pogon če nimajo 16 koles? Torej so 2x2 =)
Ve kdo zakaj se reče 4x4 in ne 2x2 kar bi bilo bolj logično iz vseh smeri?
krneki0001 ::
4x4 pomeni 4 kolesa in ot teh štirih koles 4 pogonska kolesa. 4X2 pomeni 4 kolesa in od tega 2 pogonski kolesi, 2x2 pa bi pomenilo 2 kolesi in pogon na 2 kolesi - pa tudi to obstaja in lansko leto se je par takih motorjev udeležilo tekme pariz dakar.
krneki0001 ::
4 x 4 (4WD) - Describes a vehicle with four-wheel drive. The first figure is the number of wheels. The second is the number of powered wheels.
4 x 2 (2WD) - Refers to a two-wheel drive vehicle with four wheels. The first figure is the number of wheels. The second is the number of powered wheels. With a 4x2, engine power is transmitted to only two wheels, usually the rear.
Part-Time 4WD - Refers to a four-wheel drive system that operates on-demand and drives all four wheels by locking front and rear axles together via a shift lever. It usually includes two speed ranges (Hi and Lo). Part-time 4WD systems must be operated in 2WD mode on dry pavement, as they're designed to be used only in specific situations when extra traction is required.
Full-Time 4WD - Describes a four-wheel-drive system that can be operated continuously on all surfaces. A full-time four-wheel-drive system may include the option of part-time operation (allowing you to shift into 2WD on dry pavement for example), and may or may not have Hi and Lo speed ranges.
Automatic Four-Wheel Drive (A4WD) - This type of drive system automatically engages 4WD as needed. When internal monitors sense differences in individual wheel speeds, indicating that a tire is slipping, then 4WD is automatically engaged.
Shift on the Fly - This type of system allows manual shifting from 2WD to 4WD Hi without coming to a stop. Most systems have a speed limit at which you can engage the system; typically it's under 60 mph.
All-Wheel Drive (AWD) - A full-time single-speed system designed to supply drive power to all four wheels. The percentage of front/rear power delivery varies from system to system.
shm ::
Čudno da nisi vprašal zakaj se patrii reče 8x8 če pa nimajo 64 koles 8-O
Ja kul, sam še vedno bi bila bolj logično ime 2x2. Zakaj? Ker 2x po 2 kolesi vlečeta in še 2x2=4.
KandazaR ::
Narobe razumeš tist x umes. To ni mišljeno kot znak za množenje. Kako bi pa povedal za npr mopede po tvoje? Mogoče 1x0?
  • spremenil: KandazaR ()
Pr nobenem mopedu še nism vidu da bi moralo pisat kje je pogon npr 2x1 torej po vaše.
perci ::
Dejansko je bistveno bolj smiselna oznaka 4WD, 8WD ali AWD.
bremzzi ::
4x4 pomeni, da ima 4 kolesa in pogon na 4 kolesa, prva številka je št. koles, druga pa število "pogonov"
Te oznake se veliko uporabljajo pri tovornjakih, recimo 4x2, 4x4, 6x2, 6x4, 8x4
  • spremenil: bremzzi ()
DimmniBurek ::
Zakaj more vsak še 5. napisat isto. Saj smo v 1. postu zaštekali da je prvo št. koles, drugo pa št. pogonskih koles
There Is No Stronger Drug Than Reality
BigWhale ::
Sej ni tko tezko razumet no! 4x4 pomeni, da ima avto stiri kolesa in da je pogon na vsa stiri kolesa, lahko bi imel na primer tudi 4x2. Pogon samo na dve kolesi.
perci ::
BW: :)
DimmniBurek ::
Hahaha, pa ti, BW, tebi še najbolj verjamem. Drugi so tko sumljivo napisal, in nevem če jim je za verjet.:D
PANDA 4×4 Extreme:D
imagodei ::
Oznaka 2x2 je ravno tako nesmiselna, kot 4x4. Če "x" med številkam razumeš kot znak za množenje, je 2x2 seveda 4 in ni potrebe, da bi pisal 2x2.
Kot je že perci rekel malo višje - najbolj smiselno je 4WD.
- Hoc est qui sumus -
krneki0001 ::
Evo kje se 4x4 pogon orenk pozna
drgac sm že vozu avto ki je za carpat trophy pa je to boljše od seksa =)
St@jler ::
moj avto je 5x2 :)
BigWhale ::
PANDA 4×4 Extreme[:D]
No, pande imajo vse 4x4 pogon, tko k njihovi drugi bliznji sorodniki medvedi. Lahko tud preklapljajo med prenosom. Komot laufajo po zadnjih dveh tacah. Po sprednjih mal tezji ampak cirkuski medvedi tud to znajo. Tko da se da! Z mal volje in vztrajnosti.
krneki0001 ::
Jst se s takim vsak dan vozim, pa ni boljše od seksa.
Loki ::
x ni znak za mnozenje, razen za vektorsko. si potem, ko si mnozil 2x2 uposteval tudi kot.
4x4 je cisto smiselna oznaka, saj ti 2x2 ne pove nic oz. manj kot 4x4 (2x2 so motorji s sprednjim pogonom).
4wd, awd me pa nebi cudilo, ce nista kako patentirana.
I left my wallet in El Segundo
imagodei ::
x seveda je znak za množenje. Poglej na kalkulator.
T-h-o-r ::
x je tudi za vektorski produkt :P
krneki0001 ::
x je tudi črka v abecedi (ne naši) in ni samo znak za množenje ali za vektorski produkt. In v primeru napisa 4X4 na avtomobilih ta x ne pomeni znaka za množenje, ampak samo znak za povezavo med številom koles na vozilu in številom pogonskih koles na vozilu.
username ::
Ko gre za avtomobile, je 4x4 uveljavljena oznaka - taka se je pač prijela in vsak ve (če ga vsaj malo zanimajo avti), kaj pomeni.
Ne se delat mone no.
I've got a solution for the rainforest: napalm the lot. (Jeremy Clarkson)
Izi ::
Ne pozabimo na Piaggiova vozilca z pogonom 3x2, ki jih še danes precej vidimo po Italijanskih mestih.
Video
Raje bi namesto iksa uporabili kakšno drugo ločilo, npr. poševnico 4/4 (podobno kot v tiskarni). A ne bi bilo dosti bolj logično?
Prva številka bi označeval kolesa, druga pa pogon.
Vice ::
opeter glede na to da nekaterim x poruši IQ si ne predstavljam koliko časa bi nekdo porabil da mu kapne smisel oznake 4/4, ne da bi pomislil zakaj ima njegov avto pogon samo na eno kolo, ali pa je smisel znaka za deljenje, da označuje 4 kolesa na en motor s štirimi osmi...
DimmniBurek ::
Čaki malo, a ni 4/4=1? Kolk koles pa ma moj avto, a sam 1??? O fak!
LeXani ::
Da ne boste odkril tople vode...
Čas prve prijave 04.11.2005
PrimozR ::
AWD ima verjetno patentiran Subaru, saj povsod uporabljajo AWD oznako, drugi proizvajalci pa sploh ne.
nebivedu upam da veš, da je vožnja podobna tvojim filmčkom v Sloveniji rpepovedana. Ti ki si tak ljubitelj zakonov in enforcanja le-teh.
krneki0001 ::
Sej zato se pa vozim po hrvaški in bosni, tam to še dovolijo. Pač zapravljam denar na hrvaškem in v bosni, namesto, da bi pri nas določili kak predel, kjer bi se lahko vozili v zameno za plačilo. Meni je vseeno, če bi bil samo en predel v vsaki pokrajini v sloveniji za take stvari, povsod drugje pa strogo prepovedano. Ni mi pa všeč, da je povsod prepovedano.
nebivedu, počakaj do 2010, ko bodo v Petišovcih dokončali motodrom...
krneki0001 ::
Sej sedaj se na veliko dela, da bi na vranskem bil tudi offroad poligon z inštruktorji. Tisto bo tudi zanimivo. Če jih pa še ene par postavijo po drugih regijah, pa zaradi mene lahko prepovedo povsod drugod kakršnokoli vožnjo izven urejenih cest.
Kilovati in Konjske moči (strani: 1 2 )
Oddelek: Na cesti
7017969 (15873) konspirator
Torsen diferencijal
Oddelek: Na cesti
266505 (5400) lovro535v2
Avtomobili s trpežnim podvozjem (strani: 1 2 3 4 5 6 )
Oddelek: Na cesti
27595742 (88191) krneki0001
Vožnja v snežnih razmerah (strani: 1 2 3 4 )
Oddelek: Na cesti
16043500 (40517) PrimozR
BMW serija 5 zadnji pogon in sneg?! (strani: 1 2 )
9147984 (44582) chucki
