SETI@home ?
SETI@home ?
Mitja 34 ::
Web Page Missing
The page you selected isn't on our server, or currently unavailable due to hardware/software maintenance.
If this is a broken link, please report it to us via the bug report form on our help page - make sure you categorize your report as a "Website or CGI Problem."
If you ended up here while trying to access personal/team stats, or read the newsletters, or submit a bug report form, then CGIs have been turned off. You needn't bother to send us e-mail, as we are quite aware of the problem. Sorry for the inconvenience - we turn CGIs off occasionally when working on the user/science databases.
  • spremenilo: Mitja 34 ()
Tomi ::
Ja, saj ti vse piše, kaj je lahko narobe. In verjetno res popravljajo server, kar se dogaja pogosto..
Ni panike:D
metrodusa.blogspot.com
DOLF ::
Pa dajte si ljudje ki ste v SETI projektu malce poštimat stvari, da ne boste vedno odvisni od njihovega strežnika, ki ima kar pogosto težave. Pbstaja več programov, s katerimi si na zalogo dolpobereš WU-je pa jih potem nemoteno obdeluješ. Jst uporabljam SetiGate. Čist kul zadevca, pa vedno imam 100 WU-jev na zalogi! Pa lahko deluje kot interni server za seti@home na katerga se linka 7 mašin in potem vse skupaj 16 ur na dan računa in računa (in kuri elektriko:\)
....I have seen things you people wouldn't belive.....
gkovac ::
Pa vi modeli resno verjamete v to, da boste lahko preko tega nasli ET inteligenco???
vsekakor pa velik srece
lp,SuLc
lp,
____________________________________________
"Left to themselves, things tend to go from bad to worse."
Doom III (strani: 1 2 3 4 … 22 23 24 25 )
Oddelek: Igre
1210104145 (16649) opeter
Kako dobro znate angleščino? (strani: 1 2 )
6610399 (8304) Tezaab
Izšel Ubuntu 11.04 (strani: 1 2 3 4 5 )
20664309 (54171) Icematxyz
Outlook 2007
Oddelek: Programska oprema
71715 (1534) jype
Logitech MouseWare bug (?)
272600 (2196) Swiwer
