Forum » Problemi človeštva » Piramide v Gizi
Piramide v Gizi
Baje so nekaj slikali z radarjem (SAR) in odkrili cel kup podzmenih struktur.
https://nypost.com/2025/03/23/world-new...
Je to res, al spet nek fake news?
- poskusilo klonirati: bm1973 ()
Blinder ::
Kost za glodat za vernike v teorije zarot
errhec ::
TUKAJ si poglej.
Raziskava je bila objavljena že 2022, niti približno ni, kar hočejo nekateri prikazati.
dd
chort ::
Moj problem s to novico je, da synthetic aperture radar načeloma res težko prodre globlje kot nekaj m v tla. Za to se uporabla ground penetrating radar, še raje pa kar seizmika.
Kayzon ::
Cist mozno d se gre za prave dvorane.
Consider ancient Greek legends about a hidden above-and-below ground complex known as ‘The Labyrinth,’ at the Hawara pyramid, some 60 miles from Giza. As described by 5th century BCE Greek historian Herodotus:
“There I saw twelve palaces regularly disposed, which had communication with each other, interspersed with terraces and arranged around twelve halls. It is hard to believe they are the work of man. The walls are covered with carved figures, and each court is exquisitely built of white marble and surrounded by a colonnade. Near the corner where the labyrinth ends, there is a pyramid, two hundred and forty feet in height, with great carved figures of animals on it and an underground passage by which it can be entered. I was told very credibly that underground chambers and passages connected this pyramid with the pyramids at Memphis.”
SAR tega ni posnel, ker preprosto ne more prodreti pod zemljo. En trezen video na temo in to od človeka, ki ima rad UFOs, pardon UAPs:
Daniel ::
Bujna domišlija skupaj z dostopom do "novinarjev" ustvari marsikaj. Žal so časi, ko si še lahko verjel temu kar si slišal ali prebral že davno nepreklicno minili.
Strel455 ::
https://x.com/BrianRoemmele/status/1903...
Does The Recent China Observation Of Plasma Over The Great Pyramid Form A Sort Of "Earth Battery"?
It is very early days however now that China has disclosed they have discovered Plasma Bubbles over the Great Pyramid and Midway Island, we can begin to form a hypothesis of why this Plasma, a product of solar activity is concentrated in these areas?
A Hypothesis:
The Plasma concentrations has a potential of millions of volts. Collector in theory could drive this into the Earth as a "storage" "capacitor" or even a "battery".
This effect could be tied to billions of gallons of water held below the Giza Plateau that at one time had a very high flow rate.
The differential between the Plasma bubble above and the flow of water below would represent the ability to capture a sort of "static" electricity in the millions of volts per hour.
This is as far as I will hypothesize at the moment. But there is much more to this.
Others from Nikola Tesla to Joseph P. Farrell have suggested this as well as writings as far back as 8,000 years. But these new findings are substantially moving this into empirical science.
A Hypothesis:
Blinder ::
Vidim zdej v sosednji temi, da je bm1973 podpornik rusije. No, taki ljudje so tudi tisti, ki tipično verujejo v razne nesmiselnosti kot v tej temi neke strukture pod piramidami.
link_up ::
butasto vprasanje, ampak ali je ze kdo skopal kaksnih 10m jamo pred piramidami in pogledal, ce so kamni tudi tam?
In and Out
No končno. Zdaj bo tudi uradno dokazano, da so piramide zgradili Rusi.
Srbi so jih pa stražili.
- spremenil: Utk ()
Bosanci pa itak imajo svoje, imaginarne. Bošnjaški Indiana Džouns lepo služi s tem kačjim oljem.
Scaramouche3 ::
Ne ampak Slovenci!
Piramida, Maribor @ Wikipedia
Bingo. Take putler najlažje nateguje s svojo 'pravico do vojne'.
tetriandoch ::
Eni debili pa res ne morete brez politike v vsaki temi. Če Rusi zginejo, se obesite drugi dan,ker ne bi imeli več smisla življenja, ker bi vam izginil glavni sovražnik.
Tole iskanje so delali Italijani. Dotični youtuber metatron je Italijan. Živi pa v ZDA. Po izobrazbi je zgodovinar.
En Italijan je celo pogledal 4h konference.
- odbrisalo: CookieCutter ()
HotBurek ::
Kua kurba pa ti veš?
Putin je itak po očetovi strani en četrt slovenc po koreninah. Dol iz kozjanjskega je.
Kar se pa piramid tiče. Itak, da je to vse fejk. To snemajo, pol pa sonce in topel zrak vse okrog obrne. Turiste in nepoznavalce potem nategujejo.
A ne nas, poznavalcev. Ne ne. Mi vemo za Sudan.
root@debian:/# iptraf-ng
Please resize your window
tetriandoch je izjavil:
Kaj hoces povedati?
| ⊘ | Kan. 15-letnik odkril, da so majevske piramide postavljene enako kot nek zvezdni sistOddelek: Problemi človeštva | 6608 (6050) | zee |
| » | V bosni piramide (strani: 1 2 3 4 … 7 8 9 10 )Oddelek: Loža | 125451 (102915) | GizmoX |
| ⊘ | Ancient Aliens (strani: 1 2 3 4 5 6 )Oddelek: Loža | 88762 (84352) | hamax |
| » | skrivnost gradnje piramide (strani: 1 2 3 4 )Oddelek: Loža | 58906 (49260) | Bellatrix |
| ⊘ | Žitni krogi, ki so postali tema o Piramidah (strani: 1 2 3 4 5 6 7 8 )Oddelek: Loža | 35067 (29651) | Stepni Volk |
