Degiro online broker (in alternative) - ima kdo izkušnje?
8 / 12
CoreySteel ::
Kdaj si odprl račun?
Twitter: @CoreySteel_
Stokarino ::
2018, no zdaj sem zagotovo jixal
CoreySteel ::
Pomoje se za 2018 ni bati. Upam :)
Ascendor ::
ubermensch je izjavil:
kok je izjavil:
Degiro v Sloveniji očitno za nove uporabnike ni opcija - katero alternativo priporočate?
Sam se nagibam k Trading212
En velik minus, ki ga vidim pri njih je, da ne moreš prenesti pozicij. Razen če se motim. :)
Pahuljone ::
Vprašanje glede davkov.
Na nekem brokerju kupim ETFje, katere po določenem času prodam. Ta denar ostane na brokerju z katerim kupim druge ETFje.
Ali morem pri prvi prodaji plačati davek na dobiček? Ali se ta plača samo, kadar pride z brokerja na moj TRR?
CoreySteel ::
Plačaš pri prodaji.
BuDi79 ::
Ascendor je izjavil:
Ker pozicije niso povsem tvoje. Zato tudi lahko kupiš samo en delček - broker kupi celoto in razdeli virtualno med kupce, ki kupijo samo delčke.
  • spremenilo: BuDi79 ()
Ascendor ::
BuDi79 je izjavil:
Če kupiš celotno delnico temu ni tako? Npr. tudi pri Revolutu prenos ni mogoč, ne glede na to ali imaš delček ali celo.
  • spremenilo: Ascendor ()
BuDi79 ::
BuDi79 je izjavil:
Povsem enako je če kupiš delček ali celoto, in isti sistem ima Revolut.
CoreySteel ::
We would like to update you about an important change regarding your DEGIRO account.
As an investment firm, DEGIRO is unable to hold clients' money. Therefore, we currently make use of Money Market Funds (MMFs) as a solution for you to invest your unused money and as a way to make sure it is sufficiently safeguarded.
We are happy to inform you that we will soon replace the MMFs with a bank account solution from flatex Bank. This change means that we can then answer the frequent question "Does my unused money at DEGIRO fall under the €100,000 Deposit Guarantee Scheme?", with a ''yes''.
In a few weeks, we will begin to migrate clients to this new solution. We will inform you in due time to make sure you are aware of all conditions, changes and actions that are required. However, with this e-mail we would already like to communicate in short what you can expect and update you on related changes in the Client Agreement.
Your money will be kept with a bank
Although DEGIRO is not a bank, this does not mean we can't team up with one. In flatex Bank, a regulated German bank, we have found the perfect partner. flatex Bank has €14 billion in assets under administration.
Your money will be held in a segregated personal Cash Account with your own new IBAN, guaranteed up to €100,000. Your new IBAN will be directly connected to your existing DEGIRO account. All you need to do is complete the online form that will be made available in the platform when you log in. It will not take more than a few minutes of your time. After you have completed this, you will receive your unique IBAN and additional instructions as to how deposits will work in the future.
Please note that our compensation policy for negative returns remains unchanged. The flatex Bank accounts will not give positive returns.
Očitno dobimo IBAN, ki ga bo treba javit FURS-u.
buttcrack ::
danes so mi javili, da moram ponovno naložit dokument...
se bojim, da me bodo kmalu odslovili :(
CoreySteel ::
Uh... Ti si tudi marec 2019 kot te, ki so jim zaprli? GL.
buttcrack ::
mhm
sam sem imel najprej napačen račun odprt in so mi preko supporta naknadno odprli custody račun.
močno upam, da sem se zaradi tega zajeba izognil, da mi zaprejo. Sicer pa vsak mesec nekaj kupim za 400/500€
pirx ::
Mene zaenkrat še ne gnjavijo. Odprl v letu 2018.
buttcrack ::
da datum je še OK, marec 2019 je baje presečni in za tem datumom slo račune brišejo
pirx ::
Dobro vedet, hvala.
natand ::
Vprašanje... račun na degiro.ie odprt januarja 2018, prejšnji teden sprememba iz moje strani- bančni račun-primary: N26 account, ker starega bančnega računa (sparkasse) nimam več (zaprt). Sprememba primary/sekundary bank account je bila uspešna.
Zanima pa me ali moram narediti še kaj drugega na degiru (N26 je prijavljen na Furs) in kaj pomeni za moje delnice, če se slučajno degiro odloči zapret račun, ker sem pač iz Slovenije?
Hvala za morebitne odgovore.
Gep75 ::
Pri prijavi davka na dividende prejete od podjetij iz tujine je potrebno vnesti znesek v evrih. Pri dividendah v drugi valuti me zanima kateri datum je merodajen za preračun vrednosti dividende v evre? Ali je za preračun vrednosti dividende v evre merodajen datum ko sem znesek dividende prejel na trgovalni račun s strani brokerja, ali je merodajni datum tisti na kateri je podjetje izplačalo dividendo?
metalc ::
Pred časom sem točno to vprašal na FURS in priložil še vzorec izpiska. Od nekoga, ki je bil podpisan kot "finančni kontrolor svetovalec specialist" sem prejel odgovor, da se kot datum prejema (in s tem tudi ref. tečaja ECB) upošteva "value date", ki je hkrati tudi datum, ko jih izplačevalec izplača.
Gep75 ::
metalc je izjavil:
Se pravi je dejansko pravi datum pri obračunu valute za dividende datum na kateri podjetje izplačuje dividendo - Payment date in ne datum ko ti je dividenda vplačana na račun?
Johan_skala ::
Natand, podobno je bilo tudi pri meni, ko sem lani zamenjal banko. Redno trgujem na degiro prek N26 in ni težav.
Johan_skala ::
CoreySteel je izjavil:
Danes sem dobil obvestilo, naj posodobim svoj račun in odprem Cash Account. Ali ste ostali to že naredili?
CoreySteel ::
Nope, pri meni še nič.
buttcrack ::
Tudi pri meni še ni nic, ne v appu, ne na webu.
Upam da ko bodo tole uvedli za vse, da me ne skinejo :)
Oz. ko mi uvedejo, da me lahko počasi neha skrbet :)
lejko0 ::
Dobil notification v appu in naredil (vzame ti 2 minuti). Časa so mi dali do 12/9, da si uredim. Počasi mi gre degiro malo na živce - stalno novi pogoji, spremembe ipd. Nič od tega običajno v korist uporabnika. Še vedno pa so provizije vsaj 10x nižje kot naprimer pri BKS broker. To je druga skrajnost, ki nima nobene povezave z logiko in je zrela za kakšno skupinsko tožbo.
pirx ::
So pred tednom ali dvema napovedali to spremembo. Jaz sicer še nisem nič dobil.
otago ::
Sie haben kürzlich durch das Ausfüllen des W-8BEN/-E Formulars (Ersatz) die Anwendung des US-Doppelbesteuerungsabkommens bei uns beantragt, um von einem reduzierten Steuersatz auf US-Einkünfte wie z.B. Dividenden und Kupons zu profitieren. Beachten Sie bitte folgendes, um den reduzierten Steuersatz zu behalten:
Für persönlichen Depotkonten müssen Informationen wie der Wohnsitz, Steuerwohnsitz und der Ort des Bankkontos im gleichen Land sein.
Degiro odprl z nemskim naslovom in nemsko banko (N26). Zdaj spremenil naslov na slovenskega. Komplicirajo kaj, ce drzava prebivalisca, drzave banke oz. davcno rezidentstvo ni enaka?
  • spremenilo: otago ()
buttcrack ::
otago ::
2018/2019
buttcrack ::
2018 naj bi bil še varn, od marca 2019 pa ne več. So precej folka zaprli račun ker so iz Slovenije...
Sicer je pa tole dons prišlo na mail:
Dear Mr. X,
The Dutch Regulatory Authorities have recently approved the acquisition of DEGIRO by the flatex group. We are proud to become part of the flatex group as of August 1st 2020. In this e-mail, we are pleased to inform you what this new step will mean for you as our client.
A strong partnership
Both companies complement each other well, resulting in many synergies. flatex brings a lot of experience in the brokerage industry and operates under a German banking license. This offers further stability and an increased capacity for sustainable growth and development as an organisation.
What will change for you as a client of DEGIRO?
We would like to reassure you that you can continue using our familiar award-winning trading platform and the same level of service from our Service Desk.
This partnership may lead to an even wider range of product offerings for you as a client. On top of that, we are investigating the possibility of extending trading hours.
As the first step in our partnership during the second half of 2020 we will make flatex bank accounts available for our clients to hold their uninvested money. Your money will then fall under the German €100,000 Deposit Guarantee Scheme. This will replace the current Money Market Fund setup. We will send you a personal invitation to complete the opening of your personal flatex bank account. This account will then be connected to your trading account at DEGIRO. Opening an account will only take a few minutes.
About flatex
Founded in 2005, flatex Bank is a full-service bank based in Germany. It is thus subject to supervision by the BaFin (Federal Financial Supervisory Authority) and is allocated to the Compensation Scheme of German Banks (Entschädigungseinrichtung deutscher Banken). With one of the most efficient securities settlement systems in Europe, flatex Bank is one of the leading providers of financial technology and executed 13,1 million transactions for its customers in the first half of 2020.
DEGIRO has always strived to provide added value by developing affordable, custom-made financial services for all investors. This new chapter with flatex will allow us to continue doing so and improve our services to you.
Regards,
DEGIRO
CoreySteel ::
lejko0 je izjavil:
Tokrat pač spremembe zato, ker so bili kupljeni od banke. Katere druge spremembe v škodo uporabnikov pa so bile do zdaj? Jaz se ne spomnim nobene, pa sem že leta gor.
Johan_skala ::
Ali ima kdo izkušnje z nakupom surovin prek Degira. Zanima me zlato, srebro, baker kot Futures prek COMEX. Kako to deluje, kako je z davki, na kaj je potrebno paziti?
Hvala za odgovore.
fiction ::
Je kdo od vas ze dobil flatex IBAN? Me malo skrbi, zakaj ga jaz se nisem :) Nimam nobenega sporocila niti v formularja, ki bi ga moral izpolnit. Samo obvestilo, da kmalu ne bo vec delal deposit direktno na racun od Stichtung Degiro.
CoreySteel ::
Nope, tudi jaz še nisem.
koli99 ::
Jaz sem dobil. Včeraj nakazal, danes na računu.
buttcrack ::
meni so cca 14 dni nazaj ustvarili račun, nakazal bom pa prihodnji teden, ko se mi nekaj sredstev sprosti.
natand ::
Vprašanje: Degiro mi občasno (npr. feb, avg, sept letos) zaračuna pod account statements Exchange Connection Fee 2020 za borzo na kateri se ni nič kupilo že dve leti (zdaj kupujem izključno na EAM)... zneski so različni od 0,05 do 0,55€... ni veliko ampak vseeno ne vem točno zakaj. Lahko kdo mogoče pojasni?
Johan_skala ::
fiction je izjavil:
Da, meni že deluje. Sem nakazal na ta novi IBAN, denar je bil prek N26 hitreje gor, kot prej ko je šlo na degiro račun.
pirx ::
Zanima me, če moramo te nove osebne račune, ki nam jih je odprl Degiro, prijaviti na FURS? Revolut račune je potrebno (v nasprotnem primeru lahko sledi kazen od €200 do €1.200).
Grho ::
Ne, ne rabiš prijavljati brokerja :) prijaviti je potrebno samo bančne račune
pirx ::
Sedaj je Degiro odprl prav bančne račune za svoje stranke. Prej so denar hranili v Money Market Funds, vendar tega več ne bo. Ves neporabljen denar bo na osebnem bančnem računu, ki je odprt v Nemčiji. Zadnje nakazilo sem naredil sebi, torej ime in priimek ter moj nemški IBAN. Zato me zanima.
  • spremenil: pirx ()
Ascendor ::
pirx je izjavil:
če ima IBAN potem mislim da veš kakšen je odgovor...
pirx ::
No, potem to moramo sedaj vsi narediti, ki smo še pri Degiroju. Spomnil sem se, ker isto velja za uporabnike spletnih bank, kot so Revolut, N24,...
BuDi79 ::
Ali lahko na ta račun prejemaš plačo?
buttcrack ::
na tem računu denarja ne moreš hraniti, to je samo vmesnik za nakazila pomoje. Če kaj nakažeš nanj, gre direktno na degiro. Oz. če se ne motim, lahko na ta TRR nakažeš samo z računa v tvojmem imenu. Torej plača ne gre gor.
GizmoX ::
Tako je, če na ta flatex-TRR pride priliv iz kjerkoli drugje, kot iz nastavljenega TRR-ja, zavrnejo/vrnejo.
Na FURS je treba ta flatex prijavit. Sicer bi lahko tam skrival denar.
Je pa sedaj to dokaj enostavno. eDavki - Ostale vloge - DR-Racun (Prijava tujih računov). Pa screenshot iz degira kot dokazilo.
udirač => uni. dipl. inž. rač.
pirx ::
OK, hvala! Danes uredim.
buttcrack ::
Kaj pa ko bo CSD zahteval stanje s tega računa? AFAIK na temu računu ne moreš sploh hraniti sredstev, je samo kot vmesni korak za nakazilo.
pirx ::
Ja, res ni za hranjenje denarja. V bistvu svetujejo, da se ves "odvečen" denar prenakaže nazaj na primarni bančni račun.
GizmoX ::
Takrat bo CSD dobil podatek o stanju po uradni poti. Kaj mene briga, saj imajo podatke, ki so jih želeli od mene (TRR, lastnika, ...).
Na tistem računu ti lahko dlje časa sedi tudi tisoče evrov, saj lahko npr. čakaš pravi trenutek za nakup. Ampak takrat je to denar. Potem pa kupiš delnice in PUF, ni denarja.:)
8 / 12
Izbira on-line brokerja (strani: 1 2 3 4 … 14 15 16 17 )
818277922 (8311) Compare
Trading212 (strani: 1 2 3 4 5 6 )
26486754 (6379) 133780
DURS dividende davek
417754 (5910) FireSnake
