Forum » Problemi človeštva » Biti vegan
Biti vegan
NikolormousB ::
Ne kvasi debilizmov. Rezultati kažejo drugače in zahteva se mešan korektno sestavljen obrok glede na urnik treniranja če si kaj resen športnik.
Kateri rezultati?
Unknown_001 ::
NikolormousB je izjavil:
Kateri rezultati?
Rezultati športnikov. Si kdaj slišal za atletska tekmovanja ipd. ?
Begabt
xxxul ::
mene vegani ne motijo, problem je da je vecina veganov ki jih jst poznam, ko so postal vegiji/ egani, so doživel katarzo in zacel drugim najedat kak je fajn in oh in sploh, dejte se vi, etc... poznam 4 in ironicno 2 nista vec...
tako da OP, postani vegi ce ti je to kul, ne pa prepricevat drugih in bos mel mir (ce te bo kdo prcu ga pac ignoriri)
Unknown_001 ::
Sem mislil, da imaš v mislih takšne stvari:
Od kdaj je napihovanje sinonim za uspeh? A to ti je wet dream? Imaš rad napihnjene moške?
Begabt
NikolormousB ::
outflierje se vedno najde. zdej pa pejt po sportih gledat kolk % vrhunskih aktivnih sportnikov je vegijev/veganov
Bistveno večjo procent kot je procent veganov v splošni populaciji.
Samo take, ki takole za šalo nesejo 555kg.
chucki ::
NikolormousB ::
-valvoline- ::
We chew side to side. Similar to other herbivores like cows, and unlike omnivores who cannot break down their food this way.
Bad Cholesterol only comes from eating animal-based products.
Human's tongues don't have fat or meat receptors. This means that we cannot taste much of anything when we eat raw meat. We do taste salt and plant seasonings, but neither of those are animal products.
Herbivores:
Many doctors believe that humans are herbivores. DR. William C Roberts believes that eating animal products actually hurts our health and clogs our arteries. Since heart disease is the number 1 killer in the US it is important to take care of our arteries.
In a study when other herbivores were made to eat animal products they started to get clogged arteries. This won't happen to your dog.
Herbivores have an ideal weight. They are the only category of human to be within the recommended "healthy" BMI averages.
Psychologically, humans are herbivores because blood, guts, and gore gross the majority of us out. Omnivores and carnivores are not disgusted when they see these things.
When the gut bacteria in vegans was studied researchers discovered that it contained the healthiest types of bacteria. Once the vegans started to eat meat they quickly developed harmful types of bacteria.
Herbivore and human intestines are 10-12 times their body lengths and omnivores intestines are only 4-6 times their body length.
Many people argue that if humans were supposed to be herbivores, then the B12 vitamin wouldn't only come from meat. The truth is that B12 actually comes from bacteria in the soil, which is how many herbivores get it. You can also get it from unpurified drinking water. Many vegans choose to just take a supplement.
The Okinawan people of Japan are one of the most herbivorous cultures on the planet and they are also said to be the healthiest and live the longest. There is no way that this is a coincidence.
Our teeth aren't shaped like other meat eaters, especially when it comes to our canines. They simply aren't designed to pierce skin and eat flesh.
Omnivores:
Omnivores have sharp molars that hang over their lower jaw. These molars are designed to chomp and break bones. Our molars are located on top of each other.
Omnivores have large opening mouths and throats designed to swallow meat whole. Humans have much smaller mouth opening, and small throats just like other herbivores.
Similar to other herbivores humans have a stomach PH between 4 and 5. Omnivores, on the other hand, have an extremely acidic PH of 1, which is used to digest meat. For instance, a wolf can devour 20 pounds of meat in a single meal. Humans would have to eat over 100 burgers in one sitting in order to compare.
The stomachs of omnivores are 2/3rds the size of their digestive systems, whereas humans and other herbivores have stomachs that are 1/4th the size of our digestive tracts.
xxxul ::
ta je zmagovalna...
GenZNPC ::
PacificBlue je izjavil:
@m0LN4r
Za dve kravi je en travnik dovolj? A cez poletje, kaj pa pozimi zivijo od lufta? Da jim priskrbis krmo moras vsteti se stroske za gorivo za stroje, razen ce delas vse rocno, zato pa rabis cas.Pri vseh zivalih ni samo slikovitih prispodob kako se lepo pasejo na cvetocih travnikih, ampak je veliko odrekanja in dela. Za 10 krav skrbet rabis vsaj 4 ure dela dnevno v hlevu, kje je sele kosnja in vse ostalo. Ni to easy job, sploh ne.
Prva kosnja druga kosnja, seno a ves. Vem o cem govorim.
Samo moderni folk brez krmil vec nic ne ve dandanes.
A ves kok sena spravis na en kolovoz?
frudi ::
Vi na momente delujete bolj moteno kot tisti, ki imajo kartoteko na Polju. Neka vrsta narsicisticne motnje.
Ze to, da morate zaradi vase prehrane zacenjat teme in trditi kako ste pametnejsi od celega sveta bi vam morala biti dovolj dobra opozorilna lucka, da je z vami nekaj hudo narobe.
Mesojedci so tisti, ki so pripravljeni mučiti in ubijati druga čuteča in inteligentna bitja samo zato, ker mislijo, da so boljšega okusa od rastlinske hrane... ampak zate so vegani tisti, ki so narcisisti? Zanimiva projekcija.
OP je začel temo o tem, ali se mu splača vztrajati pri veganstvu v 99% mesojedi družbi. Ni pametoval, ni se delal žrtve, zgolj zanima ga, ali se splača vztrajati kljub konkretnemu družbenemu pritisku, ki vsekakor pride s tem, ko počneš nekaj drugače, kot skoraj vsi ostali ljudje okrog tebe, znaten delež katerih pa proti tebi celo nastopa agresivno. Če se ti zdi provokacija in izzivanje, da nekdo vpraša za malo podpore, potem si zelo verjetno ti del problema, zaradi katerega OP sploh išče podporo.
Potem cela tema bullshit video posnetkov o tem, da imamo telo herbivora cesar ti ne bo potrdil noben ugleden znanstvenik...ma da vas ni sram.
Smo vsejedci, glede tega se strinjam. Lahko preživimo tako z izključno rastlinsko kot izključno z živalsko hrano. Ampak to sploh ni relevantno, ker argumenti za veganstvo niso v tem, kaj je 'naravno', ker naravno ni sinonim za boljše (karkoli že smatraš pod pojmom boljše).
Pa kup nesmislov o tem kaj je tezje pridelati med tem, ko nihce od vas zgleda v lajfu ni solate pridelal. Ste kdaj videli koliko prostora rabi scinja, ki je bla gor omenjena? Ce ignoriramo predpise, ki zivljenski prostor povecujejo zaradi 'humanega ravnanja' in ne dejanske potrebe za vzrejo mesa?
To da 'humano ravnanje' daješ v narekovaje in bi živalim že tako nizke standarde ravnanja z njimi očitno najraje še dodatno znižal, mi pove, da te za dobrobit živali prav nič ne skrbi.
Me pa zanima, ali tako nehumano gledaš samo na živali za zakol, ali tudi na vse ostale? A pse, mačke, slone, opice, orle... te bi tudi stlačil v male kletke, ker itak ne rabijo nič več?
Ste kdaj videli kako hitro v trenutnem. vremenu propade zelenjava ce je ne zalijes?
Niste. Nakladate pa kot, da lastnorocno dobavljate vso zelenjavo, ki jo proda Agrokor.
Kaj se pa zgodi z rastlinami, ki jih pridelujemo za krmo živalim, če jih ne zalijemo?
Globalno se večina pridelanih rastlin porabi za prehrano živali, ne direktno za prehrano ljudi. Če bi vsi živeli zgolj od rastlinske hrane, bi rabili bistveno manj kmetijskih površin in bistveno manj pridelanih rastlin, kot sedaj, ko gre večina te hrane še skozi dodatni korak predelave v živalsko hrano.
m0LN4r morda vzredi svojih par krav s pašo na travniku in s spravilom sena, ampak moti se, kdor misli, da lahko s takšno vzrejo pridelamo dovolj mesa za celoten svet. Niti približno. In moti se, kdor misli, da tisto meso, ki ga kupi v Mercatorju ali Sparu, pride od tako vzrejenih krav. V resnici velika večina mesa, mleka in jajc, ki so naprodaj v trgovinah, pride iz industrijskih farm (procenta za Slovenijo ne poznam, ampak za druge države sem videl številke, ki gredo krepko nad 90%).
Nafutrali bi polovico ljudi vec. In kaj boste s tem dosegli? Povecano neravnovesje. Al. bo potem sledila obvezna kastracija, da se ob tem silnem povecanju hrane ne bomo se bolj mnozili. Ker to pocnejo zivali s kazerimi se primerjate. Vec kot je hrane bolj se mnozijo.
Že sedaj se globalno pridela več hrane, kot je je sploh potrebno, tako da ne vem od kod pobiraš neumnosti, da se bi s prehodom na manj živalske hrane ljudje še bolj množili. Kaj si to zmišljuješ? A to resno trdiš, da dajmo še naprej mučit in klat živali zato, da bo manj ljudi na svetu? Dafuq? In ti bi drugim razlagal, kako so narcisisti, zreli za Polje...
Pa dajte ze mir. Nic drugega niste kot modni trend, ki ne bo nicesar dosegel.
Jejte kar hocete ampak dokler tega ne znate jest brez jamranja in pametovanja po forumih je vec kot ocitno, da niti sami ne verjamete v to.
Clovek, ki nekaj pocne zase ne potrebuje potrditve kolektiva kaj sele, da bi mel potrebo po spreobracanju nevernikov.
OP je začel temo s konkretnim vprašanjem, mišljenim predvsem ostalim, ki so ali pa so kdaj bili vegi. Ker nekdo, ki nikoli ni bil, niti ne razume, kaj in zakaj OP sploh sprašuje.
Ampak nekateri mesojedci ne morete pustiti drugače mislečih na miru in ste hitro uleteli v temo pametovati veganom, kako nimajo pojma. In potem naj bi bili vegani tisti, ki so agresivni in nadležni in posiljujejo druge s svojim mnenjem :S
Unknown_001 ::
Begabt
kingsix ::
- spremenilo: kingsix ()
dexterboy ::
eric_cartman je izjavil:
Be vegan and dont be ass about it!!!
To je glavno pravilo. Če misliš vmes drugim težit zakaj niso vegani potem lahko pričakuješ, da se bodo tvoji strahovi uresničili. Če ne boš nobenemu težil, potem tudi drugi ne bodo videli problema v tebi.
Torej.. Če te kdo vpraša zakaj si vegan? Pač rečeš zaradi tega ker tebi tako paše in zaključiš debato. To je to..
Vse, kar je potrebno, je bilo napisano. Live in let other people live...
Unknown_001 ::
Ne zdaj so že začeli jamrat, da jih napadamo s tem ko jim rečeš naj neha vsiljevat svojo supreme logix. Ko zmanjka materiala za pizdenje čez druge si moraš novega zmislit.
Begabt
NikolormousB ::
Toliko pseudoznanosti, kot tukaj sedaj v dveh straneh, že dolgo nisem prebral. rofl.
Jp, ko pride do prehrane očitno tudi sicer izobraženi in razgledani ljudje izgubijo razsodnost. In potem celo od zdravnikov poslušamo, da "v raslinski hrani ni vseh esencialnih aminokislin" in podobne nesmisle.
Ne samo to. Med tem, ko on kosi travo in kida gnoj, bi lahko za hišo pridelal dovolj krompirja in pšenice, da nafutra celo vas.
Samo za informacijo. Krave molznice imajo dnevno potrebo po vodi 50 do 100 litrov. Krava letno potrebuje cca. 4 tone sena (suhe snovi) kar je donos na cca, 1/2 hektarja velikem travniku (če gre za slabše travnike lahko dobiš tudi samo 2 toni na hektar).
Po drugi strani pa stat.si pravi tole:
Povprečni pričakovani hektarski pridelek krompirja naj bi bil 27,9 tone
Povprečni pričakovani pridelek (koruze) naj bi znašal 48,1 tone na hektar
Povprečni hektarski pridelek jabolk naj bi letos tehtal 32,6 tone
In tako dalje.
http://www.stat.si/StatWeb/News/Index/5...
Če gledaš kalorije na hektar, imajo krave cca. 17x manjši donos kot krompir. Res se bolj splača cele dneve ukvarjati s kravami, ja.
Živinoreja je bila v preteklosti smiselna v zelo majhnem obsegu, pa še to samo takrat, ko kmetije niso mogle pridelati dovolj rastlin za preživetje. 1 krava, 3 prašiči in nekaj kokoši je lahko bistveno izboljšalo izkoristek zemlje. Danes, ko so hektarski donosi nekaj 10x višji kot pred 100 leti, te potrebe ni več.
Unknown_001 ::
A ti veš da gledaš v primeru koruze poaetke za CELO rastlino? Torej neužitno zelenje, plus plodovi? Od tuatih 48 ton je realno uporabnih le 10. Ostalo boš dal pa kam? Tist ostanek se da v silažo, za katero si menda že slišal čemu služi. Al bi to to preč vrgel?
Begabt
- spremenilo: Unknown_001 ()
K0l1br1 ::
Ne samo to. Med tem, ko on kosi travo in kida gnoj, bi lahko za hišo pridelal dovolj krompirja in pšenice, da nafutra celo vas.Saj za preživetje bi to bilo. Vendar krompir s klobaso, anyone? Z ocvirki? Krompir, ki ga skuhaš, posoliš, je prav fina zadeva.
NikolormousB ::
Unknown_001 je izjavil:
NinjaMig21
Saj pravim, super bi bilo, če se najprej izobraziš vsaj o osnovah. Neužitne dele koruze (in nasploh vseh rastlin) lahko uporabimo na 1000 načinov.
Pri koruzi konkretno lahko iz neužitnih delov delamo gnojila (rastlinska gnojila so ključnega pomena, ko iz kmetovanja izločiš živali), etanol, razne industrijske produkte, celo gradbeni material...
Unknown_001 ::
NinjaMig21
Pubec... kaj ko bi se ti kdaj za jezik ugriznil?
Begabt
NikolormousB ::
No, spet pridemo do tiste točke, ko si moramo naliti čistega vina. Danes živali zapiramo, mučimo in pobijamo izključno zaradi našega užitka. Tisti trenutek, ko daš v usta medium rare stejk se ti sladko jebe za okolje, za druge ljudi in za živali, ki so morale zaradi tvojega užitka trpeti celo življenje in na koncu umreti.
Če te moti tvoja neizobraženost, ne morem veliko pomagati. Lahko se samo potrudim pa ti razložim kako stvari v resnici stojijo.
- spremenilo: NikolormousB ()
Unknown_001 ::
O pizda ti matrna jst te bom pršu na dom iskat pa da ti pokažem kako strašno hudo je živalim. Mislm pa koga ti zajebavaš v glavo tulele ? Neki vlečeš trditve iz svoje riti in jih prodajaš ljudem ki so za razliko te stvari kdaj videli v praksi.
Begabt
frudi ::
@frudi a si ti mrbit pomislil da žival lahko poje tudi za človeka neužitni del rastline? Iz tega razloga lahko praktično zraven vzrediš kravo mlekarico itd.
S tem se lahko pokrije morda par % potreb po mesu in mleku. Ostalo pride iz industrijskih farm.
Kdo komu vsiljuje svojo logiko? Kdo te sili v temo o veganstvu? Resnica je, da si se ti sam odločil priti sem in sam si se odločil, da boš veganom težil, kako oni nimajo pojma. Preden še dalje jamraš o jamranju se zazri v ogledalo in nehaj projecirat. Pa preberi si, kar je bilo na prejšnjih straneh napisano o karnizmu in premisli, od kod izvira tvoja iracionalna sovražna nastrojenost ob sami omembi veganstva.
Čakte, a ko živali jedo živali, je ok, ko pa mi jemo živali, pa že ni več ok?
Živali nimajo izbire, ljudje jo imamo. Živali ne nosijo moralne odgovornosti za svoja dejanja, mi jo. Uživanje mesa je izbira, ravno tako kot neuživanje mesa. Uživanje mesa je ravno tako ideologija, kot veganstvo.
Imaš izbiro, ali boš jedel klobaso in ocvirke. Ti si se odločil, da se ti ne da poiskati in preizkusiti rastlinske hrane, ki bi ti morebiti bila prav enako okusna, kot živalska. V resnici je okus za hrano povsem stvar navade in ničesar drugega. Ampak lažje se je pretvarjati, da nimaš izbire in brez klobas in ocvirkov ne moreš preživeti, a ne? Trpljenje in klanje živali je majhna in sprejemljiva cena za tvoje 'prav fino' kosilo.
Sej je razumljivo, vsi smo bili tako vzgojeni in indoktrinirani, da dajemo več teže svojemu okusu, kot trepljenju živali, ki ga s tem povzročamo in nato iščemo izgovore, zakaj je naše ravnanje moralno opravičljivo. Ampak kot pravim, v resnici imamo izbiro.
Unknown_001 ::
Ne, moti me tvoja naivnost in bolesten neposluh za mnenje drugega. Ti nekaj prebereš na internetu ali nekje slišiš in to je zate sveto. Ti si zdaj "brihten" in se počutiš kompetentnega pametovat o stvareh ki jih poznaš SAMO v teoriji pa še to površinsko.
1. Nimaš občutka za razmerja
2. Preberi si temo od začetka do konca in nato povej kdo je začel s tem sranjem prepričevanja.
Begabt
frudi ::
V resnici rad vidim, ko ljudje postanejo tako iracionalno agresivni in napadalni, ko jih soočiš z resnico. To je dokaz, da nekje v njih prihaja do kognitivne disonance, do konflikta med njihovo moralo/vrednotami in zavedanjem, da s svojim vedenjem to moralo kršijo. In kot obrambni mehanizem, se ta konflikt preusmeri navzven, na tistega, ki jim je razkril resnico.
Še je upanje zate RaptorF16. To me veseli.
NikolormousB ::
Ja super se ima tale pujči. Lej, ko se kar po tleh vala od vseh užitkov pri klanju.
This.
Unknown_001 ::
Stari ti ne da si zabit ampak psiho.
Kaj naj rečem. Mi je žal ker si celotno sliko ustvariš na podlagi enega ekstremnega primera. Tako se z živaljo ne ravna in je pri nas prepovedano.
Tako je, če ti je internet edino okno v svet. Zato ti pa pravm da vsaj orid pogledat kako te stvari po pravem izgledajo preden se oglašaš.
Begabt
mzakelj ::
Drugače pa veste kako so nastali vegani ?
Vegan ni nič drugega kot len vegeterjanc, vegeterjanc pa je stari izraz za slabega lovca.
Pa če hočete muljiti travo ok. Samo pustite druge ljudi da jedo meso in ne najedajte. Ker v tem primeru vam obljubim da če bo kdo meni najedal, dobi kost od pujsa katerega sem ravno obral direktno v betico. Pa se potem cmerite kolikor hočete. Kaj za kurac nas briga če jeste samo mulj. Še bolje za nas. Več pujsa za nas.
frudi ::
Nedolgo nazaj so imeli še v Avstriji afere glede ravnanja z živalmi na njihovih farmah. To in še hujše se kot redna praksa dogaja po klavnicah in industrijskih farmah po vsem svetu. Od kod mislite, da pride večina mesa, mleka in jajc v Mercatorju, Tušu in Sparu? Iz malih kmetij s srečnimi kravami sredi prostranega pašnika? Če temu verjameš, potem ti imam za prodati par mostov.
Ah, žalitve, intelektualni domet preprostih ljudi, ko se počutijo ogrožene. Še en, ki svoje interne moralne konflikte projeciraš navzven.
mzakelj ::
Unknown_001 ::
Si bil tam? Ne
Si bil kdaj na kolinah? Ne
Ali razumeš da nismo potrošniki odgovorni za to, da je par mandeljcov z 2 letno šolo objestnih? Ne
Predpisi so jasni,koliko se jih pa držijo, je pa drug problem. Potem namesto da tule druge obsojate se zbunite, za rednejše inšpekcijske nadzore ravnanja z živino. Verjemi, bo več efekta. Vas podprem.
Če se zakol dela pravilno, žival nič ne trpi.
Begabt
RejZoR ::
Sladkor se v telesu zelo slabo oz. neučinkovito pretvarja v maščobe. Precej zanimiva se mi zdi zabloda, da je naše telo tako "neumno", da zaužite OHje pretvarja v maščobne zaloge, zaužite maščobe pa v glukozo.
O kristusove gate še eden, ki je na ušesih sedel pri biology class-u. And what if I told you da je telo že po defaultu en navaden potraten neučinkovit energetski stroj ki več kot 80% energije pretvori v toploto?
Seriously vsi povrsti FUCK OFF. I am done with this shit. Leglo oversensitive ljudi z diplomo iz internetsa.
Potraten? Možgani porabijo par vatov energije, pa delajo stvari, ki si jih super računalniki z več megavati porabe niti slučajno ne morejo "zamisliti". Da samega telesa kot "stroja" ne omenjamo. Glede na to da smo toplokrvni organizem, ki mora vzdrževati lastno telesno temperaturo 36,5°C pa še vseeno brez hrane zdržimo do 1 mesec, bi to težko klasificiral pod potratno. Da ne omenjamo kako hitro telo adaptira porabo in shranjevanje energije glede na vnos živil, da ima kar se da učinkovito porabo in zalogo. Če samo parkrat zazna pomanjkanje, ki odstopa od običajnega že začne spreminjat kako deluje, da je čim manj potratno in da si ustvari zaloge za potencialno hude čase, ki bi lahko sledili iz zaznanega.
GenZNPC ::
This.
Kje ti vidis kaj spornega jst nevem.
[D]emon ::
Kar nekaj mesnopredelovalnih podjetij v Sloveniji ima Halal certifikacijo (kar v praksi pomeni tocno to, za kar ti trdis, da je prepovedano). Zato ne prodajaj nebuloz.
frudi ::
Si bil tam? Ne
Sem bil na kolinah ja, niso mi ostale v lepem spominu, čeprav takrat še nisem vedel ničesar o veganstvu. In prav nič humanega ni na njih. Human zakol je itak en tak neumen oksimoron, s katerim skušamo zanikati realnost tega, kar počnemo - ubijamo zaradi užitka (okusa).
O ravnanju z živalmi v industrijskih farmah pa imaš dovolj napisanega in posnetega povsod po internetu. Ni skrivnost, kako se na njih ravna z živalmi. Ne moreš pa sam tja, itak da ne, niso kar odprte javnosti, da se lahko vsak Janez sprehodi po njih. Zadeva mora ostati čimbolj skrita od oči javnosti, sicer bi se javnost morala soočiti z resnico, kakšne grozote se izvajajo za njihove 'prav fine' klobase pa jajca.
GenZNPC ::
V osnovni soli k sm bil pr babici in dedeku na pocitnicah sem ze sam klal perutnino,
po pokazanju kako se vrat prereze prime za peruti, da ne flofota in obesit za noge gre to en, dva, tri.
Prerezes, obesis in pol das vodo vret, da se spuca.
Koline so lepse.
frudi ::
Ja a ste vi pusiji tle al kaj?
O, še več žalitev, kako zelo izvirno.
Koline so lepse.
Lepo zate.
Izživljanje nad živalmi v otroštvu in očitno pomanjkanje empatije sta dva od značilnih znakov psihopatije, čisto tako mimogrede.
reeves ::
Samo ne nasprotujemo, da se žival lepo vzredi in na primeren, neboleč način ubije.
Tako kot vsa ostala bitja, so tudi govedo in prašiči samo en člen v food chainu.
Vsako živo bitje na koncu konča kot hrana nekomu. Vključno z nami (če odštejemo kremiranje).
Glugy ::
In pol zgleda grdo pač ..k vse kar drugi hočejo tebi v dobri veri dat zavračaš. Vsi drugi veselo cmokajo okol tebe...ti si pa čudakec : )
Mislim da OP cilja na take situacije. Si prijazen, nevsiljiv, na kratko dogovoriš da tega pač ne ješ ; ampak več kot očitno te to vsaj mal potegne vn iz družbe. No razn če nisi kako posebej šarmaten in očarljiv; ampak to spet niso vsi ane.
RejZoR ::
Ta pujs je bil verjetno po halalau ubit. Se pravi prereže vrat in pusti da kri steče. Kar se pa ne dela in je v Sloveniji prepovedano. Tako da take slikce ne ganejo samo vegane ampak tudi mesojedce ker z takim načinom zjebeš meso in ni užitno.
This. Halal (in tud Kosher) način zakola bi moral v Evropi prepovedat kot tud prodajo tako pridobljenih izdelkov. Religija in kako to užali religijske fanatike gor al pa dol, taki načini so kruti in ne bi smel obstajat.
Looooooka ::
Si bil tam? Ne
Predlagam da se z 'resnico' soocis pri psihoterapevtu. Si kdaj probal nafutrat papagaja al pa zajca z zrezkom?
Pravega rastlinojedca bos zelo tezko navlekel na meso torej ni tle stvar 'okusa'.
In moras bit kr fajn ruknjen, da gres ljudem odrekat nekaj, kar jim je, po tvojih lastnoh besedah, okusno in vsec.
Res bos dober fotr.
Z zakolom pa nehajte morit. Nam je jasno, da mora za meso nekdo umret tko kot je to jasno vsem mesojedcem na tem planetu in nas ti govori preprosto ne bodo spravili ma vegansko dieto.
mzakelj ::
RejZoR ::
Si bil tam? Ne
Zdej pa mal nakladaš. Živali imamo za prehrano, ker smo OMNIVORI. To pomeni, da jemo vse in pri nčemer nimamo odličnega izkoristka. Ker nimamo ne encimov za popolno prebavo mesa niti dolžine prebavil (in encimov) za popolno prebavo rastlinja. Za razliko od rastlinojedov, ki se bojo počutil skrajno slabo če bojo jedli meso kot tud mesojedci, ki bi jedli samo zelenje. Naj folk že neha flancat o tem kako je človek samo rastlinojed.
Če je definicija ubijanja za prehrano pri ljudeh "iz užitka", pol za leva veljajo popolnoma enaka pravila. Pa ne vidim nobenih PeTA fanatikov tekat za tigri in levi in jih prepričevat kako so zlobni ker ubijajo iz užitka in da naj premislijo o veganstvu.
Jeba pri nas je samo v tem, da smo k instinktu za preživetje in samoohranitev primešali še moralno noto in overthinking stvari. Da ne boš mislil, da živali nimajo preferenc pri okusu. Še nisi slišal kako je medved poklal 30 luštnih ovčk in pojedel zgolj sočna jetrca, vse ostalo pa pustil? Ti ti medo, kako moraš ubijat iz užitka, za užitek! Kaj, a mu ne boš šel povedat vsega o svetem veganstvu?
frudi ::
Zakaj vegetarijanci ne morete ali nočete razumeti, da tudi vsejedci obsojamo mučenje živali. Vseh živali.
Verjamem, da obsojaš mučenje živali.
Na kar skušam opozarjati je to, da se živali ne da uživati brez nasilja nad njimi. Je nemogoče. Tudi če z živaljo ravnaš ne vem kako dobro, dokler je živa, na koncu jo je še vedno potrebno zaklati, česar si nobena žival ne želi. Sploh pa ne, ko je dosegla šele morda 10% svoje naravne življenjske dobe.
Kaj je humanega na zakolu? A pri ljudeh uporabljamo enako logiko? Če z otrokom 15 let dobro ravnaš in ga nato neboleče med spanjem vstreliš v glavo, je to ok? Sej je do tedaj živel dobro življenje in umrl brez bolečine. Zakaj je potem pri živalih drugače? Če jim priznavamo, da so sposobne inteligence in čustev, trpljenja in užitkov, zakaj jih je potem ok ubiti? In to zakaj - ker so nekomu boljšega okusa, kot rastlinska hrana.
Ljudje imamo izbiro. Ne rabimo ubijati živali za hrano, ne potrebujemo je za preživetje. Če uživamo meso, je to naša zavestna odločitev. Mislim, da je prav, da se vsaj zavedamo moralnih posledic naše odločitve.
| ⊘ | Kaj bi se zgodilo če bi vsi postali vegani :) ? (strani: 1 2 3 4 )Oddelek: Loža | 47669 (42728) | Netrunner |
| » | Moralni in ekološki vidiki prehranjevanja (strani: 1 2 3 4 … 17 18 19 20 )Oddelek: Loža | 191389 (158342) | razerznak |
| » | Kitajska študija, Avtor: Colin Campbell (strani: 1 2 3 4 5 6 7 8 )Oddelek: Problemi človeštva | 127523 (114323) | Smrekar1 |
