Imate rajši Win 7 kot Win 10? Imamo rešitev.
1 2
3
4
111111111111 ::
krneki0001 je izjavil:
Napišeš batch skripto v command promptu ali poweshellu, jo zalaufaš in mašina dela brez problemov dalje, samo nič več vneto ne brska po diskovju. In konec, zadeva urejena.
Da bi pa zaradi tega šel na polizdelke kot so recimo razni ubuntuji, kbuntuji, zbuntuji in žnjbuntuji ter podobna šlamarija na stopnji XP-jev, mi pa na kraj pameti ne pride.
Če si pa nesposoben, pa samo po forumih jamraš, je pa drugo.
Lahko prosim kar tule prilepiš svojo batch skripto, da ne boš samo po forumu jambral.
krneki0001 ::
@ECHO OFF
COLOR 1F
SET V=1.7
TITLE Windows 10 TNBT: The Next Big Tweak v%V% (x64)
REM ======================= Registry tweaks =======================
ECHO.
:regstart
set /p registry="Apply registry tweaks? y/n: "
if '%registry%' == 'n' goto servstart
if /i "%registry%" neq "y" goto regstart
:reg0start
set /p reg0="Replace Utilman with CMD? y/n: "
if '%reg0%' == 'n' goto reg1start
if /i "%reg0%" neq "y" goto reg0start
reg add "HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\utilman.exe" /v "Debugger" /t REG_SZ /d "cmd.exe" /f > NUL 2>&1
:reg1start
set /p reg1="Disable Quick Access as default view in Explorer? y/n: "
if '%reg1%' == 'n' goto reg2start
if /i "%reg1%" neq "y" goto reg1start
reg add "HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced" /f /v "LaunchTo" /t REG_DWORD /d 0 > NUL 2>&1
:reg2start
set /p reg2="Show computer shortcut on desktop? y/n: "
if '%reg2%' == 'n' goto reg3start
if /i "%reg2%" neq "y" goto reg2start
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\HideDesktopIcons\NewStartPanel" /v "{20D04FE0-3AEA-1069-A2D8-08002B30309D}" /t REG_DWORD /d 0 /f > NUL 2>&1
:reg3start
set /p reg3="Show file extensions? y/n: "
if '%reg3%' == 'n' goto reg4start
if /i "%reg3%" neq "y" goto reg3start
reg add "HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced" /v "HideFileExt" /t REG_DWORD /d 0 /f > NUL 2>&1
:reg4start
set /p reg4="Disable lockscreen? y/n: "
if '%reg4%' == 'n' goto reg5start
if /i "%reg4%" neq "y" goto reg4start
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\Personalization" /v "NoLockScreen" /t REG_DWORD /d 1 /f > NUL 2>&1
:reg5start
set /p reg5="Enable classic control panel view? y/n: "
if '%reg5%' == 'n' goto reg6start
if /i "%reg5%" neq "y" goto reg5start
reg add "HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\Explorer" /v "ForceClassicControlPanel" /t REG_DWORD /d 1 /f > NUL 2>&1
:reg6start
set /p reg6="Hide indication for compressed NTFS files? y/n: "
if '%reg6%' == 'n' goto reg7start
if /i "%reg6%" neq "y" goto reg6start
reg add "HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced" /v "ShowCompColor" /t RED_DWORD /d 0 /f > NUL 2>&1
:reg7start
set /p reg7="Disable Windows Update sharing? y/n: "
if '%reg7%' == 'n' goto reg8start
if /i "%reg7%" neq "y" goto reg7start
reg add "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\DeliveryOptimization\Config" /v "DownloadMode" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\DeliveryOptimization\Config" /v "DODownloadMode" /t REG_DWORD /d 0 /f > NUL 2>&1
:reg8start
set /p reg8="Remove Pin to start? y/n: "
if '%reg8%' == 'n' goto reg9start
if /i "%reg8%" neq "y" goto reg8start
reg delete "HKEY_CLASSES_ROOT\exefile\shellex\ContextMenuHandlers\PintoStartScreen" /f > NUL 2>&1
reg delete "HKEY_CLASSES_ROOT\Folder\shellex\ContextMenuHandlers\PintoStartScreen" /f > NUL 2>&1
reg delete "HKEY_CLASSES_ROOT\mscfile\shellex\ContextMenuHandlers\PintoStartScreen" /f > NUL 2>&1
:reg9start
set /p reg9="Classic vertical icon spacing? y/n: "
if '%reg9%' == 'n' goto reg10start
if /i "%reg9%" neq "y" goto reg9start
reg add "HKCU\Control Panel\Desktop\WindowMetrics" /v "IconVerticalSpacing" /t REG_SZ /d "-1150" /f > NUL 2>&1
:reg10start
set /p reg10="Remove versioning tab from properties? y/n: "
if '%reg10%' == 'n' goto reg11start
if /i "%reg10%" neq "y" goto reg10start
reg add "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer" /v NoPreviousVersionsPage /t REG_DWORD /d 1 /f > NUL 2>&1
:reg11start
set /p reg11="Disable jump lists? y/n: "
if '%reg11%' == 'n' goto reg12start
if /i "%reg11%" neq "y" goto reg11start
reg add "HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Advanced" /v "Start_TrackDocs" /t REG_DWORD /d 0 /f > NUL 2>&1
:reg12start
set /p reg12="Remove telemetry and data collection? y/n: "
if '%reg12%' == 'n' goto reg13start
if /i "%reg12%" neq "y" goto reg12start
reg add "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Device Metadata" /v PreventDeviceMetadataFromNetwork /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\DataCollection" /v "AllowTelemetry" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Policies\Microsoft\MRT" /v DontOfferThroughWUAU /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Policies\Microsoft\SQMClient\Windows" /v "CEIPEnable" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\AppCompat" /v "AITEnable" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\AppCompat" /v "DisableUAR" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\DataCollection" /v "AllowTelemetry" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-c..lemetry.lib.cortana_31bf3856ad364e35_10.0.10240.16384_none_40ba2ec3d03bceb0" /v "f!dss-winrt-telemetry.js" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-c..lemetry.lib.cortana_31bf3856ad364e35_10.0.10240.16384_none_40ba2ec3d03bceb0" /v "f!proactive-telemetry.js" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-c..lemetry.lib.cortana_31bf3856ad364e35_10.0.10240.16384_none_40ba2ec3d03bceb0" /v "f!proactive-telemetry-event_8ac43a41e5030538" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKLM\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-c..lemetry.lib.cortana_31bf3856ad364e35_10.0.10240.16384_none_40ba2ec3d03bceb0" /v "f!proactive-telemetry-inter_58073761d33f144b" /t REG_DWORD /d 0 /f > NUL 2>&1
:reg13start
set /p reg13="Apply Internet Explorer 11 tweaks? y/n: "
if '%reg13%' == 'n' goto reg14start
if /i "%reg13%" neq "y" goto reg13start
reg add "HKCU\SOFTWARE\Microsoft\Internet Explorer\Main" /v "DoNotTrack" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Internet Explorer\Main" /v "Search Page" /t REG_SZ /d "http://www.google.de" /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Internet Explorer\Main" /v "Start Page Redirect Cache" /t REG_SZ /d "http://www.google.de" /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Internet Explorer\Main" /v "DisableFirstRunCustomize" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Internet Explorer\Main" /v "RunOnceHasShown" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Internet Explorer\Main" /v "RunOnceComplete" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\Main" /v "DisableFirstRunCustomize" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\Main" /v "RunOnceHasShown" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\Main" /v "RunOnceComplete" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKCU\Software\Policies\Microsoft\Internet Explorer\Main" /v "DisableFirstRunCustomize" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKCU\Software\Policies\Microsoft\Internet Explorer\Main" /v "RunOnceHasShown" /t REG_DWORD /d 1 /f > NUL 2>&1
reg add "HKCU\Software\Policies\Microsoft\Internet Explorer\Main" /v "RunOnceComplete" /t REG_DWORD /d 1 /f > NUL 2>&1
:reg14start
set /p reg14="Disable Cortana, Bing Search and Searchbar? y/n: "
if '%reg14%' == 'n' goto reg15start
if /i "%reg14%" neq "y" goto reg14start
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\Windows Search" /v "AllowCortana" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Search" /v "CortanaEnabled" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Search" /v "SearchboxTaskbarMode" /t REG_DWORD /d 0 /f > NUL 2>&1
reg add "HKCU\SOFTWARE\Microsoft\Windows\CurrentVersion\Search" /v "BingSearchEnabled" /t REG_DWORD /d 0 /f > NUL 2>&1
:reg15start
set /p reg15="Change Logon screen background with accent color? y/n: "
if '%reg15%' == 'n' goto reg16start
if /i "%reg15%" neq "y" goto reg15start
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\System" /v "DisableLogonBackgroundImage" /t REG_DWORD /d 1 /f > NUL 2>&1
:reg16start
set /p reg16="Disable Windows Error Reporting? y/n: "
if '%reg16%' == 'n' goto reg17start
if /i "%reg16%" neq "y" goto reg16start
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows\Windows Error Reporting" /v "Disabled" /t REG_DWORD /d 1 /f > NUL 2>&1
:reg17start
set /p reg17="Disable automatic Windows Updates? y/n: "
if '%reg17%' == 'n' goto reg18start
if /i "%reg17%" neq "y" goto reg17start
reg add "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update" /v "AUOptions" /t REG_DWORD /d 2 /f > NUL 2>&1
:reg18start
set /p reg18="Disable Hibernation? y/n: "
if '%reg18%' == 'n' goto servstart
if /i "%reg18%" neq "y" goto reg18start
reg add "HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\Power" /v "HiberbootEnabled" /t REG_DWORD /d 0 /f > NUL 2>&1
ECHO Done...
REM ======================= Removing services =======================
ECHO.
:servstart
set /p services="Apply services tweaks? y/n: "
if '%services%' == 'n' goto schedstart
if /i "%services%" neq "n" if /i "%services%" neq "y" goto servstart
:serv0start
set /p serv0="Disable tracking services? y/n: "
if '%serv0%' == 'n' goto serv1start
if /i "%serv0%" neq "y" goto serv0start
sc config DiagTrack start= disabled > NUL 2>&1
sc config diagnosticshub.standardcollector.service start= disabled > NUL 2>&1
sc config TrkWks start= disabled > NUL 2>&1
sc config WMPNetworkSvc start= disabled > NUL 2>&1
:serv1start
set /p serv1="Disable WAP Push Message Routing Service? y/n: "
if '%serv1%' == 'n' goto serv2start
if /i "%serv1%" neq "y" goto serv1start
sc config dmwappushservice start= disabled > NUL 2>&1
:serv2start
set /p serv2="Disable Windows Search? y/n: "
if '%serv2%' == 'n' goto serv3start
if /i "%serv2%" neq "y" goto serv2start
sc config WSearch start= disabled > NUL 2>&1
del "C:\ProgramData\Microsoft\Search\Data\Applications\Windows\Windows.edb" /s > NUL 2>&1
:serv3start
set /p serv3="Disable Superfetch? y/n: "
if '%serv3%' == 'n' goto serv4start
if /i "%serv3%" neq "y" goto serv3start
sc config SysMain start= disabled > NUL 2>&1
:serv4start
set /p serv4="Disable Windows Defender? y/n: "
if '%serv4%' == 'n' goto schedstart
if /i "%serv4%" neq "y" goto serv4start
sc config WinDefend start= disabled > NUL 2>&1
sc config WdNisSvc start= disabled > NUL 2>&1
reg add "HKLM\SOFTWARE\Policies\Microsoft\Windows Defender" /v "DisableAntiSpyware" /t REG_DWORD /d 1 /f > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Windows Defender\Windows Defender Cache Maintenance" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Windows Defender\Windows Defender Cleanup" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Windows Defender\Windows Defender Scheduled Scan" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Windows Defender\Windows Defender Verification" /Disable > NUL 2>&1
del "C:\ProgramData\Microsoft\Windows Defender\Scans\mpcache*" /s > NUL 2>&1
ECHO Done...
REM ======================= Removing scheduled tasks =======================
ECHO.
:schedstart
set /p schedules="Disable unnecessary scheduled tasks? y/n: "
if '%schedules%' == 'n' goto winappstart
if /i "%schedules%" neq "n" if /i "%schedules%" neq "y" goto schedstart
schtasks /Change /TN "Microsoft\Windows\AppID\SmartScreenSpecific" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Application Experience\Microsoft Compatibility Appraiser" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Customer Experience Improvement Program\Consolidator" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Customer Experience Improvement Program\KernelCeipTask" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Customer Experience Improvement Program\UsbCeip" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\DiskDiagnostic\Microsoft-Windows-DiskDiagnosticDataCollector" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\NetTrace\GatherNetworkInfo" /Disable > NUL 2>&1
schtasks /Change /TN "Microsoft\Windows\Windows Error Reporting\QueueReporting" /Disable > NUL 2>&1
ECHO Done...
REM ======================= Removing Windows default apps =======================
ECHO.
:winappstart
set /p winapps="Remove windows default apps? y/n: "
if '%winapps%' == 'n' goto odrivestart
if /i "%winapps%" neq "n" if /i "%winapps%" neq "y" goto winappstart
powershell "Get-AppxPackage *3d* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *bing* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *zune* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *photo* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *communi* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *solit* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *phone* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *soundrec* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *camera* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *people* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *office* | Remove-AppxPackage" > NUL 2>&1
powershell "Get-AppxPackage *xbox* | Remove-AppxPackage" > NUL 2>&1
ECHO Done...
REM ======================= Disable / Remove OneDrive =======================
ECHO.
:odrivestart
set /p onedrive="Disable OneDrive? y/n: "
if '%onedrive%' == 'n' goto hoststart
if /i "%onedrive%" neq "y" goto odrivestart
reg add "HKLM\Software\Policies\Microsoft\Windows\OneDrive" /v DisableFileSyncNGSC /t REG_DWORD /d 1 /f > NUL 2>&1
ECHO Done...
REM ======================= Blocking Telemetry Servers =======================
ECHO.
:hoststart
set /p hostsblock="Block Windows telemetry servers? y/n: "
if '%hostsblock%' == 'n' goto finish
if /i "%hostsblock%" neq "n" if /i "%hostsblock%" neq "y" goto hoststart
copy "%WINDIR%\system32\drivers\etc\hosts" "%WINDIR%\system32\drivers\etc\hosts.bak" > NUL 2>&1
attrib -r "%WINDIR%\system32\drivers\etc\hosts" > NUL 2>&1
FIND /C /I "vortex.data.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 vortex.data.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "vortex-win.data.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 vortex-win.data.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "telecommand.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 telecommand.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "telecommand.telemetry.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 telecommand.telemetry.microsoft.com.nsatc.net>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "oca.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 oca.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "oca.telemetry.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 oca.telemetry.microsoft.com.nsatc.net>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "sqm.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 sqm.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "sqm.telemetry.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 sqm.telemetry.microsoft.com.nsatc.net>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "watson.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 watson.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "watson.telemetry.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 watson.telemetry.microsoft.com.nsatc.net>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "redir.metaservices.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 redir.metaservices.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "choice.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 choice.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "choice.microsoft.com.nsatc.net" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 choice.microsoft.com.nsatc.net>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "df.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 df.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "reports.wes.df.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 reports.wes.df.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "services.wes.df.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 services.wes.df.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "sqm.df.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 sqm.df.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "watson.ppe.telemetry.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 watson.ppe.telemetry.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "telemetry.appex.bing.net" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 telemetry.appex.bing.net>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "telemetry.urs.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 telemetry.urs.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "telemetry.appex.bing.net:443" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 telemetry.appex.bing.net:443>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "settings-sandbox.data.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 settings-sandbox.data.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
FIND /C /I "vortex-sandbox.data.microsoft.com" %WINDIR%\system32\drivers\etc\hosts
IF %ERRORLEVEL% NEQ 0 ECHO ^0.0.0.0 vortex-sandbox.data.microsoft.com>>%WINDIR%\system32\drivers\etc\hosts
attrib +r "%WINDIR%\system32\drivers\etc\hosts" > NUL 2>&1
:finish
CLS
ECHO.
ECHO Installation complete.
ECHO Press any key to exit.
PAUSE > NUL
prowb ::
paraboŁa je izjavil:
Zaradi službe sem bil prisiljen migrirati na win10 in je zadeva porazna. Clean instal s ssdjem mi dela počasneje kot na drugem laptopu leto in pol stara sedmica. Da ne omenjam težav z zvokom, ikonami, blue screen of death al whatever je že to kljub najnovejšim driverjem. Grafični vmesnik mi je ogaben, UX tudi, v to na kakšne načine poizkuša M$ vdreti v zasebnost se sploh ne bom spuščal. Reklame, xbox, bloatware appi...skratka porazno.
Resno razmišljam o prehodu na linux.
Zanič računalnik. Nekaj crkuje. Ali ram ali disk ali pa plata sama. Začni gledat, da boš mašino dal popravit, ker to niso simptomi da je nekaj narobe s sistemom, ampak z računalnikm.
Do sedaj sem postavil nekje čez 200 win10 na različne računalnike. Od najnovejših do celo 11 let starih (kjer win10 tudi brez problema delujejo), pa se je samo na enem to dogajalo. V končni fazi se je ugotovilo, da je plata začela crkovat in da je kontroler odletel.
Možno, da je enostavno treba počakat par dni, da se navlečejo vsi updejti in ostala krama... potem načeloma kar dela ;)
krneki0001 ::
Delat mora takoj. BSOD v desetki pomeni prej hardwerski kot programski problem.
trnvpeti ::
Pravljice,
zadnje case se vsi(ne samo na 10, ampak tudi 8 in celo 7) igramo lovljenje miške in mačke.
Mačka je cisto podivjala, postavlja razne ovire, prisile.
Miške se(ali pa tudi ne) pa poskušajo temu izognit na razne načine.
In zaradi te igrice prihaja do razno raznih problemov.
Najbolj zagreti seveda teh stvari sploh ne vidijo.
krneki0001 ::
A to praviš, da so pravljice to, kar on govori da se njegov računalnik sesuva?
trnvpeti ::
tvoja pravljica, da je bolj problem hw(da ne bo pomote, je tudi lahko hw problem) kot pa programski problem(zadnje case pobesnela macka dela veliko napak)
zelo glasne frekventne miške(prodane duse/ne razmisljajo/...) prepricujejo ostale miške("neposlusne"/vsaj razmisljajo/...), da je vse ok in da pac imajo probleme one
  • spremenil: trnvpeti ()
krneki0001 ::
Lej, lahko je tudi programski, vendar če so pogosti BSOD-ji, potem bo verjetno HW. Lahko kak ram, disk ali pa sama plata. Še posebaj če vse deluje zelo počasi.
trnvpeti ::
vecinoma so programski problemi, deluje pocasneje kot je,...
in tudi bsod so bili zaradi programskih napak
potem se bsod zaradi hw
politika macke(poskusanje onemogocanja 3rd party programja) se odraza ze navzdol(8,7)
se veliki igralci(lenovo,dell) se bunijo
_cista zmeda_
in miske prepricujejo druge miske...
Cervantes ::
Sem imel iste probleme z desetko, že zamenjal kup hw, pa isto.
Nazaj na sedmico... fixed.
Updates disabled.
paraboŁa ::
@nebivedu očitno si precejšen fanboy desetice, da je takoj hw vzrok in ne sw. Nisem rekel, da laptop dela izredno počasi, a vseeno opazno počasneje od 7ke. Laptop je skoraj nov, hw je ok. Zagotovo nisem edini s takimi problemi in sedmica mi je vse update prenesla sama, tu sem jih potegnil dol s hp strani in bi moralo delovati tako kot se šika, ne pa da po nepotrebnem zgubljam čas še s tem.
Precej uporabno orodje v boju proti komunikaciji sistema z MS pa je tole https://www.safer-networking.org/spybot...
  • spremenilo: paraboŁa ()
krneki0001 ::
Večinoma res delam z Lenovo T, W in X prenosniki. Pa razen enega, ki je imel plato zanič (še je delovalo, samo vsake toliko je mrknil) ni nobenih problemov. Driverjev pa ni treba nalagat iz lenovo strani. So vsi driverji že v desetki. In še noben ni deloval počasneje kot s sedmico (pa to velja tudi že za 8.1). Še posebaj, če si dal SSD disk notri.
Lahko pa da imajo kakšni HP-ji probleme, vendar do sedaj še nisem naletel na takega, kjer bi windows 7 hitreje deloval od 8.1 ali 10.
trnvpeti ::
iz prve roke, Lenovo(ups) notebook, w8.1(orig) deluje hitreje kot na w10
isto lahko recem se za kaksno drugo znamko
krneki0001 ::
trnvpeti je izjavil:
Se zelo očitno nismo razumeli. 8.1 in 10 delujeta hitreje od windows 7.
trnvpeti ::
spet neumnost
ze w10 dela obcutno pocasneje od w8.1
krneki0001 ::
spet neumnost
Jaz o jabolkah, ti o hruškah. Oboje deluje hitreje od sedmice.
In ne, ne deluje povsod 10 počasneje od 8.1. Na mojih domačih mašinah ne. Optimizirana desetka, ven pometane vse smeti in spyware, ter izklopljena večina servisov, ki jih ne potrebujem. Proti 8.1 ogromna razlika.
Mašina je pa 2x xeon X5690, 132GB rama, 2x 480GB SSD v stripingu, 2x 3TB za podatke, GTX960 grafika.
trnvpeti ::
seveda lahko macka s svojimi update-i, kjer je obcutno dvignila(ali pa spustila) nivo popravkov na cisto drugo raven , priredi podatke na svoj nacin
mat xxl ::
Kaj pa program DWS, ki vsaj očisti neko zatečeno stanje in počisti neželene MS update ali ni OK ?
trnvpeti ::
w81 in w10 sta ze dokaj optimizirana, w7 ni
in w7 se lahko se optimizira
 na svojem sw
na svojem sw
fosil ::
Kar se telemetrije tiče, win10 pri določenih domenah ignorira hosts file.
Tako da blokiranje domen s hosts ni učinkovito.
Tako je!
trnvpeti ::
in pri naslednjih posodobitvah(ne samo win, ampak tudi antivir), bo(kot je že dosedaj) MS uporabil se neuporabljene trike/prijeme/....
111111111111 ::
@nebivedu: hvala za skripto. :) Bom najprej zagnal na virtualki, da mi nisi kakšnega lepega presenečenja noter napisal. :)
Drugače pa lepo na routerju blokiraš vse živo in spuščaš mimo eno po eno. :)
trnvpeti ::
na routerju ne bos mogel kaj veliko blokirat, ker se bo tisto, kar hoces blokirat, spreminjalo
bos moral biti kr dober fw majster in se veckrat igrati igrico
krneki0001 ::
111111111111 je izjavil:
Popravi iz
:regstart
v
:regstart
if /i "%registry%" neq "y" goto reg0start
Tukaj se ti bo drugače zaciklalo, ker boš z regstart samega sebe klical.
mihor ::
Spet se tu poraja vprašanje, zakaj? :) Je dosti bolje namestit GNU/Linux namesto viste 10.
trnvpeti ::
to se ne vprasas, ce si ze kupil winse(vstavi verzijo po potrebi)
update-i ocitno niso vec namenjeni za miske ampak samo za macke
mihor ::
Vsak se enkrat opeče, jaz sem se celo 3x (prvič, zadnjič in nikoli več) pred 15 leti z Win ME ;((
prowb ::
Mi tukej o povprečnih kištah i3/i5 mogoče celo kak core2 vmes, povprečen ssd in pa kake 4gb rama ;)
krneki0001 ::
prowb je izjavil:
Sej to je povprečna mašina. 5 let stara.
Rias Gremory ::
Pozabu si dodat /s nakonc.
Ne trolat, če ni treba.
R1710 ::
Zakaj pa sem moral jaz za T iskat driverje? Device manager je bil ves v rumenih trihotnikih...
Kar se tiče Windows 10 pa je smeh in žalost. Brezveze debatirat, vsak ima svoj pogled, sem pa 2x imel upanje in bil 3x pošteno razočaran. Verjetno bom dal na T Mint oz. Debian, MS office pa v emulator.
Poln kurac imam Windows OS.
krneki0001 ::
Za kater model T prenosnika si moral iskat driverje za windows 10? In kateri build windows 10.
Če imaš build 1511 od windowsov, ti preprosto ne morem verjeti. Build 1511 ima namreč vse driverje za T4(1,2,3)0 in T5(1,2,3)0 vključene (sprobano na vsaj 50 prenosnikih T510, nekaj T520 in dvema T530 in ene 10 komadih T410, ki pa ima v bistvu isti hardware, samo drug ekran in malo je stisnjeno vse skupaj).
Razen za intelov AMT nimaš driverjev, kar pa posodobiš, ko si priklopljen na net in klikneš z desnim gumbom na "PCI device" v device managerju in izbereš update drivers.
Rias Gremory je izjavil:
Kakšno trolanje neki. To je mašina, ki jo z dvema xeonoma, 48GB rama in quadrotom dobiš že za 1k evrov. To pa res ni drago, glede na to, da stane povprečna mašina nad 400€, če ne več.
R1710 ::
T420, Windows 10 - 1511, naloženi v začetku marca letos.
Ni naložil fingerprint scannerja, card slota in media driverja - rumeni trikotniki v device managerju. Neznana naprava, konec.
V bistvu media driverja niti ni imel Lenovo na svoji strani.
  • spremenilo: R1710 ()
krneki0001 ::
Včeraj sem isti build (1511) nalagal na T510i in T530. Na T510 samo za AMT ni postavil gor driverjev, vse ostalo je bilo naloženo. Na T530 pa še nvidie ni našel, vendar je pa takoj po priklopu na net potegnil prave driverje dol za oboje.
R1710 ::
Zdaj ali zajebavaš, ali pa nimaš pojma.
Za fingerprint scanner potrebuješ program, ki nikoli ni bil del update, kako si to zrihtal?
Kaj storiš s neznano napravo USB\VID_0BDB&PID_1911&REV_0000? Pa to PCI\VEN_1180&DEV_E823&SUBSYS_21CE17AA&REV_05? in še to PCI\VEN_8086&DEV_1C3D&SUBSYS_21CE17AA&REV_04?
Windows tega ne propozna, kako bo to rešil update?
Kako rešuješ bluetooth indikator (led)?
Za zadnjo prosim za rešitev, sam je še nisem našel. Na Debian Linux distribucijah dela.
krneki0001 ::
1. Ericsson F5521gw - za to kartico moraš za vsak sistem poiskat driverje, če bi imel gobi2000 pa bi imel driverje že v windows 8.1 in 10. Meni že od 8.1 najde usb 3g Huawei 173e sam brez da bi moral driverje ročno nalagat.
2. Ricoh PCIe SDXC/MMC Host Controller
Potegni dol Lenovo system update, pa dobiš driverje.
https://support.lenovo.com/si/sl/docume...
Lahko pa ti povem trik - vstavi SD kartico, pa počakaj in poglej kaj naredi, ko jo zazna. Na nekaterih mašinah(W540) je potem sam poiskal in inštaliral driverje.
3. AMT - lahko si naložiš tele driverje. imajo celo AMT Serial over Lan
http://support.lenovo.com/en_US/detail....
Tukaj imaš pa še eno stran, kjer naložiš custom bios za tvojo mašino in imajo odstranjen "white list", da lahko potem vse kartice notri vstaviš, poleg tega odklene višje hitrosti rama AES in intel vbios.
http://www.thinkwiki.org/wiki/Custom_BI...
krneki0001 ::
A imaš indikator za BT stalno prižgan?
https://forums.lenovo.com/t5/Windows-10...
Lahko pa odpremo temo triki z Lenovo T modeli, pa začnemo pisat vanje kaj in kako, pa limat linke z driverji, predelanimi biosi in podobno.
Svojemu T510i, ki je v osnovi mašina s samo I3 procesorjem, sem predelal bios, da podpira vse proce, razen 4 jedrnih. Vstavil sem vanj I5 najmočnejši, kar se je dalo dobiti in zadeva deluje brez problemov. Dodal sem mu še serijsko za windowse kar v bios, tako da ni treba več vpisovat serijske, jo inštalacija sama najde. Odstranil sem "white list" da podpira vse kar se dobi na mPCIe vodilu.
Uglavnem, ogromno se da s T modeli početi.
R1710 ::
V debato sva šla z razlogom;
Sicer pa raje vidim počasnejši zagon računalnika, classic shell, Win+E odpre My Computer, kot pa "hitrejši" windows 10.
Kar se tiče BT;
 ON
ON
 OFF
OFF
Se da izklopit LED z hotkeyem? Tega namerno ne uporabljam.
krneki0001 ::
Ja, naj bi delovalo s hotkeyem.
V bistvu je za BT kar driver od windows 7, pa so dodali da deluje v win 10, kar pa ni res in malo zajebava.
R1710 ::
Meanwhile on Linux;
 ON
ON
 OFF
OFF
To me odvrača od Windows okolja. Linux me je že v par zadevah presenetil in se vedno bolj nagibam v to smer. 90% programov, ki jih uporabljam, teče na obeh OS-ih.
krneki0001 ::
Ne krivit MS za slabe driverje, ki jih je Lenovo sproduciral. Zato so forumi, da se pove kaj in kje se dobijo pravi driverji. Jih naložiš in stvar mora delovati pravilno.
mat xxl ::
Pejte v svojo temo z temi problematičnimi Lenovimi .... to, kar nabijate zadnjih 10 postov nima nobene veze z naslovom teme..... naj admini prestavijo zadeve v svojo temo ...... Lenovo in težave z gonilniki ali kaj takega....
R1710 ::
Kakorkoli, bluetooth ni prižgan, tisti LED indikator BIOS prižge. Izgleda pač debilno. Hotkey (in disabljanje on-screen buttons) ne pomaga.
krneki0001 ::
Katero wifi kartico imaš notri? (ponavadi je combo varianta wifi in BT skupaj v eni kartici).
R1710 ::
Maš PS.
Cervantes ::
Ker mi je slo na živce nonstop siljenje prehoda na win10, sem pobrisal nekatere update.
Zdaj imam mir, automatic upate sem onemogočil.
Čisto konkretno me zanima, kaj s tem izgubim.
jest10 ::
S tem izgubiš teženje>:D
Rias Gremory ::
@Cervantes
https://ubuntu-mate.org/
https://getfedora.org/
Come, we haz cookies.
Cervantes ::
Joj, ne mi z Linuxom.
Sem že pred leti soprogi namestil OpenOffice namesto Worda, rajši ne povem, kaj je bilo potem.
Pomembno je, da sem preživel in sem še vedno z vami.
8-O
R1710 ::
Linux + Wine == MS Office. Preveč komplicirano?
1 2
3
4
[Windows 10] Vprašanja in težave (strani: 1 2 3 4 … 141 142 143 144 )
Oddelek: Operacijski sistemi
71511875471 (61770) mtosev
Prenosnik LENOVO R61i piskanje
133487 (3247) markolino
If stavek ping
Oddelek: Programiranje
122605 (2070) AndrejO
Windows 7 Installer (64-bit) - težave
Oddelek: Programska oprema
153671 (3061) fr!Xy
IE7 - kako ukinit "shrink to fit" ?
71496 (1496) StratOS
