Forum » Programska oprema » IE7 - kako ukinit "shrink to fit" ?
Vajenc ::
Službeni HTML program mi najlepše prikazuje v IE. V novem IE7 pa imajo novost kjer je pri tiskanju avtomatsko na "shrink to fit" s tem pa mi okno natisne pomanjšano. Lahko grem sicer pod "print preview" in ročno nastavim na 100% ampak to ni to ;) Google mi ni dal odgovora. Se komu sanja kako izklopiti to vsiljeno avtomatiko?
StratOS ::
Zakaj pa nebi potem printal samo selection ( označeno ).
Če imaš framse lahko vsak frame posebej ...
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
Modri dirkač ::
V "print preview" naštimaš 100%, namesto "shrink to fit".
Kje je problem?
Kje je problem?
Everybody lies!
samomas ::
Here's a fix to default printing to 100% instead of "shrink to fit". Only problem is that it requires users to apply this.
users with ie7 need to install this hotfix
http://support.microsoft.com/kb/931768/...
the hotfix above contains several fixes, including
http://support.microsoft.com/default.as...
After applying the hotfix, u need to add the registry value. u can copy and paste this in command prompt to update it
reg add "HKLM\SOFTWARE\Microsoft\Internet Explorer\MAIN\FeatureControl\FEATURE_STF_Scale_Min" /v iexplore.exe /t REG_DWORD /d 100 /f
restart the browser and no more shrink to fit, unless the user manually specifies it. this is the way it should be by default in my opinion
In še povezava do Povezava do zgoraj omenjenega
Vajenc ::
Modri dirkač, preveč divjaš med vrsticami!
StratOS, to ne pomaga.
samomas, hvala za pomoč, tole bi verjetno res pomagalo. Bom pa počakal, če bo res naslednji avto windows update to imel included ;)
StratOS ::
Jaz ne vem, v čem je problem.
V print preview (IE7) lahko enostavno z selection ustvariš fokus in tudi z procentualno nastavitvijo, več ne potrebuješ.
Poglej opcije laid out on scrrn / selected on screen in ostalo ...
- zavaroval slike: volkec ()
Vajenc ::
Poglej opcije laid out on scrrn / selected on screen in ostalo ...Jaz te opcije nimam. Mogoče nimam up to date IE ?
Edit: in če je to potrebno naštimat vsakič preden printam mi to ne pomaga oz. je to podobno zamudno kot dajati vsakič znova na 100%.
- spremenilo: Vajenc ()
StratOS ::
Za info:
Uporabljam IE 7.0.5730.13
Glede štimanja boš pa moral vedno potem nastavljati, ker zgleda ni default opcije, mogoče se motim ...
| » | Moške hlače - ponovno (strani: 1 2 )Oddelek: Loža | 26949 (11046) | Kvinta |
| » | Printanje/pretvorba spletne strani v .pdfOddelek: Pomoč in nasveti | 1112 (938) | knesz |
| » | Sportsdirect prodaja določene obleke z napakoOddelek: Loža | 5492 (4805) | Šimpanz |
| » | pomoč pri tiskanjuOddelek: Pomoč in nasveti | 1181 (1133) | opeter |
| » | Internet Explorer 7 (strani: 1 2 3 )Oddelek: Novice / Brskalniki | 20182 (16152) | 3p |
