Prednosti grafičnih kartic AMD vs NVIDIA
17 / 29
PredatorX ::
iloveboobz je izjavil:
ti si izjavu 60% ipcja :)
PredatorX je izjavil:
Don't ask about Zen. We're still working on the slides.
Če te zanima novi patch
http://dresdenboy.blogspot.si/2016/02/n...
http://looncraz.net/ZenAssignments.html
Glede na tole bi pričakoval več kot +40% IPCja... vsaj 50-60%.
Jebote pejt še enkrat v šolo.
Ej, tvoje besede, ne moje.
Če pa piše to kaka druga verzija tebe, pa tako povej :)
GenZNPC ::
D3m je izjavil:
GenZNPC je izjavil:
Trend je danes dol, ne gor.
Ne ni bil en dan, ko ste že tulili OC.
Pr modrih in zelenih, noben ni rekel "OC Dream" must buy OC - kombo. Pa je vseeno tam.
Ampak si res izjavil, celo 2x.
skibidi
  • spremenil: GenZNPC ()
dzinks63 ::
Ajde ustavite konje, dovolj blamaže ste si privoščili, v tej temu puščam dokaj veliko svobode, toda tole je pa že preveč, pričakoval sem, da napredni člani foruma ločijo GPU in CPU, tale tema je namreč namenjena prvemu.
PredatorX ::
Če koga zanima VR.
1 petaflop za 16K/144Hz na oko.
http://wccftech.com/interview-amd-liqui...
Seprav sam 117 Fury X-ov.
GenZNPC ::
skibidi
GenZNPC ::
Če koga zanima VR.
AMD’s LiquidVR is designed for Direct3D11
skibidi
PredatorX ::
[GR] That's correct - LiquidVR features are currently exposed in DirectX 11. While developers are really excited about a new generation of APIs - DirectX 12 and Vulkan, it takes time for such technologies to be adopted, become mature and available to the mainstream. A lot of development in VR is currently done with mature engines (Unreal and Unity) built with DirectX11 technology, and it would've been a shame if fast-paced development in VR had been stalled waiting for DirectX 12 and Vulkan to mature. This is why in LiquidVR we focused on enabling better VR support with DirectX 11, to solve challenges immediately. The DirectX 12 API is much more powerful and flexible than DirectX 11 and in some ways there is less need for delivering exactly the same LiquidVR features. We're definitely looking at DirectX 12 integration and bringing further enhancements to it with LiquidVR.
Read more: http://wccftech.com/interview-amd-liqui...
GenZNPC ::
Kaj so delali do zdaj ?
skibidi
PredatorX ::
Nevem kaj misliš stem?
dejaj ::
GenZNPC je izjavil:
Če že bereš vsaj vredu preber in ne samo tisto, kar ti pade v oko. Potem pa nastanejo čenče, baba čula baba rekla!
Senitel ::
Saj je GameWorks VR tudi samo D3D11 (in OpenGL)... Tukaj je treba vedet kaj ta dva API-ja sploh počneta.
Prvo je podpora za Asynchronous Timewarp od Oculusa. S stališča GPU pomeni to en dodaten grafičen high priority kontekst. To lahko narediš v D3D11, ampak ju GPU ne more ločit, torej je tukaj API, ki to naredi eksplicitno. D3D12 ima to že vgrajeno.
Potem je tukaj kontrola dveh GPU-jev, kjer v D3D11 driverji fake-ajo vse skup in skrijejo dva GPU-ja v en D3D11 konttekst, ki pa nima pojma, da ima zadaj dva GPU-ja. Za VR je potrebna bolj natančna kontrola nad tem kar pomeni nadzor s strani aplikacije nad tem kaj se kopira iz enega GPU-ja na drugega in kdaj. To je spet nekaj kar ima D3D12 že urejeno (cross node sharing).
In other news Just Cause 3 bo dobil D3D12.
Alien123 ::
Zanimivo kako od nakupa nvidiinih kartic gre performans samo dol, ko pa pr amdjevih pa samo gor :D
AapocalypseE ::
Ta 970 v videu je stock, tako da me zanima kako bi se obnesla s 300MHz+ višjo frekvenco + še navit vram ;)
390 pa je itak že navita 290, tako da je pravilno primerjat stock 290 vs. stock 970 ali 390 z navito 970.
Bla bla bla trolasti amd fanboyčki...
Test je čisto pravilno narejen.
Stock vs. stock
PredatorX ::
AapocalypseE je izjavil:
Ja itak, tale digital foundry, ki pravi, da ni možno naviti R9 390/X... tdu navita GTX 970 se nemore kosati z R9 390 Gaming, Digital foundry je zelo skeptičen glede teh grafičnih kartic.
Pol pa Jays two cent omeni, da se R9 390/X navija najbolje od hitrejših GCNjev.
GenZNPC ::
Alien123 je izjavil:
V vseh igrah al kako?
skibidi
Buggy ::
dej poslusaj se rajs malo...uzaljen Nvidiotek! Zdej mal na debelo slino pozirate a ne, pred pol leta ste se pa po prsih tolkli in pluvali vsepovsod kjer se je le dal, po AMD-ju. Karma je prasica so ze vcasih rekli...tebe pa naj se ekstra strafne za brezvezno flejmanje :))
petrus ::
Prednost Radeon: IOMMU/AMD-Vi, s tem se je možno it takšne hece:
stati inu obstati
Buggy je izjavil:
nvidijaši se lahko še vedno tolčejo pr prsih praktično vsak drug AAA relis.
Najnovejše te dni je gears of war :)
GenZNPC ::
Ja jaz nevem kje je problem, na prste prestejem spile, ki preferirajo AMD.
So pa AMDjasi tolko zanimivi, da prve gameplaye po izidu kake igre, ki jih gledajo so posneti ravno z nvidijo.
lol
skibidi
PredatorX ::
Čeprav sem preigral vse GoW je tale port polom.
GenZNPC ::
Sklepam, da si igral tudi tega potem.
 Hehe
Hehe
skibidi
PredatorX ::
Dejno, GoW 1 je bil za XboX 360 + PC.
GenZNPC ::
skibidi
AapocalypseE ::
Haha ne me je**t hahaha
Ta DigitalFoundry se prav norca dela ali je grafika res na amd karticah toliko slabša?
In your face amdjčki trollasti :)):))
GenZNPC je izjavil:
Pa veš, kaj si limal?
Ali ti moram jaz obrazložiti? Če ti bom jaz se boš pogreznil od sramu.
Lahko ti dam namig.
To funkcijo je imel že Far cry 2.
  • spremenil: D3m ()
PredatorX ::
D3m je izjavil:
GenZNPC je izjavil:
Lahko ti dam namig.
čudo :D
GenZNPC ::
D3m je izjavil:
GenZNPC je izjavil:
Lahko ti dam namig.
Funkcija lepo in grdo ?
Potem pa gledamo frajme obeh ?
skibidi
Day-night cycle.
GTFO.
GenZNPC ::
Mhm in fpsji so isti, ne glde na kolicino, globino, dolzino in gostoto sence ?
Torej, ce zrendriras senco za vsako biljko bo isto fpsov, kot ce za nobeno.
Vprasam kako je stem ?
skibidi
Ti se kar zgovarjaj. Sem ti napisal na kratko.
Shame on you.
GenZNPC ::
Ti mi pa nisi odgovoril. fuj
skibidi
Kaj zdaj jokaš, ko deklica?
Sam si limal slike in pametoval. Nisi pa upošteval day-night cycle od igre.
GenZNPC ::
Nisem te vprasal nic v zvezi z day night ciklom, ampak:
A se ti zdi, da je za rendriranje tega frejma in kolicino, dolzino, gostoto senc potrebno enako casa?
Bolj enostavno ne morem vprasat.
skibidi
Smoke screen ala molnar.
Govoril sem.
Senitel ::
GenZNPC je izjavil:
Je kar tragično razmišljat v kakšen vrtec smo prišli ja... 10 let nazaj se je gledal kako se posamezne pixle renderira, danes pa glih da je še primerjava v istem špilu.
PredatorX ::
Sej drgač ma pa Far Cry primal inbuild benchmark.
http://www.computerbase.de/2016-02/far-...
R9 390 gaming je 21% hitrejša od GTX 970 gaming.. in še OC.
1329MHz boost core clock * 1.21 = 1608MHz
7012 MHz (effective) * 1.21 = 8484 MHz
Ajde, da vidmo do kam prpelš GTX 970.
Sej slika je jasna... ni več gameworks-a oziroma nvidia nima več prste vmes.
GenZNPC ::
Ma pa 980Ti G1 lepih 80fpsov v tistem linku, medtem ko fury x dipsa do 60.
skibidi
Alien123 ::
Bo treba nvidia malo drivere porihtat :D pa malo manj devse podkupit :D
GenZNPC je izjavil:
Pade do 60?
AapocalypseE ::
Ja in, če je up-to 5fps hitrejša fury x na zgornjem videu?
Vidite pa nena, da je 980Ti na 1215MHz?
Seveda, da ne, če ste amdjčki trollasti...
Aha. Torej je point nvidie, da jo kupiš in naviješ. Da faq.
sj point amdja je tut da naviješ, tweakaš, primerjaš driverje, kupuješ radiatorje....... >:D
to je vaš point. Mene OC ne briga.
  • spremenil: D3m ()
Napajalc ::
Poglej za koliko več obremeni CPU nVidia na posnetku. Manj FPS pa skoraj 100% večji load cpu, čiterji.
011011100111010101100010
:P
Damn. Jebemti sliko.
  • spremenil: D3m ()
better.
  • spremenil: D3m ()
Buggy ::
huh...kje bi bla tukaj sele GTX 770, ki je leta 2013 stala toliko kot R9 290 ....400$ release price, ce si pocakal se pol leta si jo pa dobil za polovicno ceno >:D
Za kupca R9 290 je to kot v naslovu pise vec kot ocitna prednost al kaj...se koga mika nakup Nvidie?
PredatorX ::
Point je da večina folka nenavija.
Folk kupuje "K" proce na H platah.... zelo malo folka je, ki se malce spozna na navijanje.
AMD ma komzole... konzole bodo do 2018 = win za GCN.
AMD Radeon R9 400 Series (strani: 1 2 3 4 … 118 119 120 121 )
6004957479 (814135) gddr85
AMD-jev tržni delež grafičnih kartic se je prepolovil (strani: 1 2 3 4 … 7 8 9 10 )
456119856 (106138) Trololololol
AMD Radeon R9 Fury X je tu (strani: 1 2 )
8035288 (22621) PredatorX
