Posodobitev biosa (težava z navodili)
2
Miha20 ::
Bios Update of the MS 7501 mainboard PCB 3.1.
The execution of the update optimises the speed of the CPU fan.
+++Instructions to update your system bios +++
1. Unzip the downloaded file into a created folder at the last available partition of your harddisk.(FAT partition D: e.g.)
2. Afterwards restart your PC with the Application-/ Support-CD.
3. At the MS Windows CD-ROM-Bootmenue choose "Boot from CD-ROM".
4. After that select "MS-DOS Prompt" in the Application-/Support-CD Startmenue .
5. Finally execute the flash.bat file which can now be found at Partition C: into your specified folder.
6. Now start the update procedure by pressing any key.
7. After the bios update please reboot your system.
Please be aware, that you noticed the original bios settings before starting the update, because some values may have changed afterwards.
Information:
To extract all files press the "Extract"-Button. The files will be extracted to the folder specified in the "Folder"-Field. This folder will be created, if it does not exist.
Important:
For any errors, caused by the execution of this update, we don´ t accept any responsibility for damage or lost of data.The customer agrees with that fact by executing the update. Tukaj je že prvi in drugi korak nerazumljiv posodabljam zarado težave z bus speedom in nastavitve ventilatorjev in senzorjev temperature so čist fail. imam plato MSI: MS-7501 VER 3.1
N 1996 Za pomoč se že vnaprej zahvaljujem.
zakaj bi rad updejtal bios ?!
Miha20 ::
zaklenjega mam in mi je bus speed vrglo na 169MMhz pa ga nemorem nastavit nazaj na 200Mhz, po nemških forumih sm gledu da je to edina rešitev
  • spremenil: Miha20 ()
naredi si dos usb kjuč -- to lahk nardiš z hp usb format utility
skopiraj kar maš v ZIPu na kjuč
bootaš iz kjučka
vtipkaš v dos konzolo flash.bat in slediš navodilom.
Grizzly ::
1. Pojdi na spletno stran proizvajalca matične plošče in poišči ustrezen bios
2. Bios prenesi na svoj računalnik (običajno je v zip datoteki program za flashanje in datoteka z biosom)
3. Naredi boot floppy ali boot usb ključek - gor skopiraj program za flashanje in datoteko z biosom
4. (lahko si narediš tudi paketno bat datoteko, kamor vpišeš ukaz za flashanje)
5. Resetiraj računalnik in bootaj v dos! Nikoli ne flashaj v winsih, saj je ta možnost najmanj varna!!!
6. Počakaj, da se flashanje konča. Ne resetiraj in ne izklopi računalnika, tudi če freezne!!!
7. Resetiraj, pojdi v bios in izberi default nastavitve, nastavi boot priority, shrani
Miha20 ::
Sm potegnu ta program dol in kva morm zdj narest?
1. sm šu na podporo za ta računalnik in je posodobitev biosa in jo dol potegniv
Grizzly ::
Miha20 je izjavil:
Dobiti moraš še program za flashanje biosa. Če tega že imaš, nadaljuj pri točki 3. Torej zrihtaj boot ključek ali karkoli, s čimer lahko bootaš računalnik. Na ključek (oziroma karkoli boš že uporabil) skopiraj bios in program.
Pozabil sem še napisati: Naredi backup trenutnega biosa (med točko 5 in 6). To narediš z istim programom kot updataš. V primeru da se flashanje ne konča uspešno, daš nazaj backup.
  • spremenil: Grizzly ()
Miha20 ::
Kateri program moram skopirat?
program za flešanje je seveda priložen zipu :)
Miha20 ::
Pol use kar je u zipu noter
a morm na fraj skupirat k mam izbiro 32 bit 64bit 2 mape
mihec87 ::
Miha20 je izjavil:
CLEAR CMOS ne prime?
Miha20 ::
 mapa
mapa
Nevem kaj moram izbrat
CLEAR CMOS kaj je to? bios je zklenje z posodobitvijo se ga pa odklene kukr sem brau po tujih forumih za to plato
Miha20 ::
nisem edini ki imam to težavo
vrži ven cmos bataerijo za 30 sekund in jo daj nazaj noter..
mihec87 ::
Oz resimo kaj pomeni zaklenjen
-zaklenjen z kodo ki je nimas oz si jo pozabil
- starejsi bios nima opcije te nastavitve
Miha20 ::
Z baterijo sm poskušal brez uspeha, medion ma zaščitene proti navijanju dela matične msi z temi biosi posebi za medion
Good Guy ::
Poženi msi live update kateri ti sam poišče in pofleša bios.
http://goo.gl/7ItKpU
Naj računalnik dela za vas^^
če je to od mediona plata, potem ne flešat biosa iz msi strani !
Grizzly ::
mihec87 je izjavil:
- Če imaš nastavljeno geslo, vzami CMOS baterijo ven(ploščata baterijica, kot je v nekaterih urah), malo počakaj in jo daj nazaj. Ta možnost bo bios vrnila na privzete nastavitve. Po vklopu računalnika boš moral v bios in nastaviti datum/čas, boot priority itd.
- Če starejši bios nima opcije, poglej ali jo ima novejši. Ponavadi proizvajalci ob izidu novega firmwara objavijo tudi izboljšave (release notes, changes ali karkoli že piše na spletni strani).
Ena ob možnosti je tudi, da tvoja strojna oprema ne podpira možnosti, ki jo ti želiš. Zaradi tega je morda zaklenjena.... je prikazana v biosu, vendar je ne moreš izbrati. Tega morda niti posodobitev ne reši, tako da se prej prepričaj.
Good Guy ::
iloveboobz je izjavil:
program avtomatsko zazna motherboard in temu primeren bios. Če le te plate ni potem ne bo bios updata
Miha20 ::
Bios sm potegniu iz sistemske podpore za moj računalnik iz medionove strani
Temperature so fail pr biosu piše popravek nastavljanje ventilatorjev, na forumih sm prebrav da updata pomaga bus speed in ga lohka štelaš, ubistvu imam zastarev bios
če je oem plata, je program itk nebo zaznal :)
Good Guy ::
načeloma mi je zazanlo in posodobilo še vse do zdaj. če pač ne gre, nima kaj za zgubit
Miha20 ::
Ima gdo skype lohka hitro rešim s telefonom imam kamerco in da bo videl ves in povedal če ne bo prav?
Kere datoteke dam na usb 32 bit al 64?
Miha20 ::
http://www.medion.com/gb/service/start/... iz te strani sm ga prenesu
bol bo kul.
Miha20 ::
katero mapo nej skopiram na usb
Grizzly ::
Miha20 je izjavil:
Odvisno kaj je v mapi. Jaz na tvojem mestu bi dal za vsak slučaj na usb kar obe mapi. Bolj je vprašanje katero mapo potem uporabiti - to pa je spet odvisno od vsebine mape.
Kaj točno je notri v mapi? Program za update biosa ali sam bios?
Načeloma je pri novejših računalnikih tako, da ne moreš flashat biosa, ki ni za tvojo plato (večina ima to zaščito), tako da težko da boš kaj pokvaril, razen če prenesel z neke tretje strani.
Miha20 ::
dejansan ::
Poglej kateri operacijski sistem imaš 32 ali x64 in potem izberi ustrezno mapo.
dejansan
Hayabusa ::
Če boš flashal iz winsev potem bootaj v safe mode.
Miha20 ::
32bitni sistem, procesor x64
A pol zberm 32bitno mapo?
Hayabusa ::
Da, 32bitno mapo.
Miha20 ::
a najprej zaženem program hp-usb al dam najprej datoteke gor?
dejansan ::
prvo moraš narediti boot usb ključ,...
kaj se zgodi če v windowsih klikneš na ta afuwin?
dejansan
Miha20 ::
http://shrani.si/f/E/11R/2pIxSNmt/hp.pn... lahko kdo mapiše kva morm nard napiše kva morm nardit
dejansan je izjavil:
tole
Hayabusa ::
Miha20
Iz linka, ki si ga dal včeraj https://slo-tech.com/forum/t595726/p429...
DRIVER ->
BIOS UPDATE MS 7501 PCB 3.1
Version: 3.0D
klik na Details:
Afuwin
http://www.ami.com/Support/amibiossuppo...
  • spremenilo: Hayabusa ()
Hayabusa ::
Hmm, ta navodila so zmedena
Če gledaš kaj je v medion mapi, tam ni nič takega da bi lahko iz te vswebine bootal iz ključka, flash.bat v 32bit vsebuje
Afuwin.exe A7501MLN.30G /p /b /n /c /L0 /reboot
torej win ami bios flasher s stikali, zakaj bi potem bootal v dos ?
4. After that select "MS-DOS Prompt" in the Application-/Support-CD Startmenue.
Botaj v winse -> safe mode in tam flashaj.
Miha20 ::
win 8 mam na računalniku
pusti vseskupaj, da neboš nakoncu plate zabricku.
Miha20 ::
cd sm suport disk sm najdu in kaj je safe mode?
posodobitev je skoraj nujna skoraj saj 2,2 ghz teško shajam z navijanjem pa tud ne dosežem kaj dosti
če ti bo proc delu 15% hitrej, pa kr neboš več težko shajal ? :))
Miha20 ::
če je treba lohka rud win wisto dam nazaj gor
nebo absolutno nič pomagal.
Nisi pa povedal od kdaj se ti to dogaja in če si menjal proc ali je prišel z plato..
Miha20 ::
usakič se navijanje resetira :(
o kaken navijanju in resetiranju ti sanjaš ?
Miha20 ::
prišel verjetno s plato s posodobitvijo se pa menda odpravi te neušečnosti
procesorja
pa je garancija glih potekla k sm opazu za kak mesec
Miha20 ::
ko procesor navijem in restartam računalnik se nastavitve množilnika resetirajo
seveda se resetirajo, če pa nimaš black edition proca.
dejansan ::
po tem kar si zgoraj prilepil, lahko da ti bo pustilo flashati bios iz winsow.
Naredi tako kot piše, zapri vse programe, če si kaj navijal daj nazaj na default nastavitve pa probaj, seveda na lastno odgovornost.
Če ti bo pa pomagalo pri tvojem "problemu" je pa vprašanje
dejansan
2
[WINDOWS 8] Vprašanja in težave (strani: 1 2 3 4 … 27 28 29 30 )
Oddelek: Operacijski sistemi
1490525296 (90977) jedateruk
Windows 7 problem pri nalaganju
251843 (1715) Han
Težava niprave frekvence procesorja (strani: 1 2 3 )
10211161 (9911) Miha20
Kako oz. s katerim programom nadgraditi BIOS? (strani: 1 2 )
8810786 (10244) mtosev
MSI želi odpisati BIOS, prihaja UEFI (strani: 1 2 )
Oddelek: Novice / Matične plošče
7725334 (22779) Jst
