Forum » Loža » Folding@Home Slo-Tech team
njok ::
Po cem sklepas?
Skoda da se ne da spremenit, res je grd.
A se se komu dogaja, da se EM sesuje pri menjavi skina?
Gandalfar ::
kaj bi sam ene slikce gledal :>
pogledas lepo unitinfo.txt, ce zadeva se dela in zivis naprej :)
lopov ::
Ali pa pogledas FAHlog.txt in se sekiras nad pocasnim napredkom :) Brez heca, za remote nadzor linux masin preh SSH imam skriptico, ki mi lepo prebere zadnjih 5 vrstic in izpise rezultat za vse mlincke hkrati.
C_maniak ::
huh, poslušte to. mau sm paketek p909_vill_str0 in mi ga je končal sam do 83 % in naprej BP poslal
. ql
C_maniak ::
ma tale 3.25b version se ne obnese pr men. pa že z UDMonitorjem ni združljiva
je pa zdej en drug problem. sm šou pač nazaj na 3.24, dl-ja nov WU, se pojav en bluescreen
, pa ga zgleda ni v redu dokončal.
[14:12:02] Writing local files
[14:12:02] Extra SSE boost OK.
[14:12:04] .D.
[14:12:06] ing local files
[14:12:06] Completed 0 out of 250000 steps (0)
[14:12:51] ting local files
[14:12:53] Size of work/wudata_01.goe not what saved.
ja, SSE je vklopu, ampak pol po restaru in dl-ju novga paketa mi vklop pa sam 3D boost. pa nč nism nastavitev spreminju. WTF?
[14:12:04] .D.
ali3n ::
[18:39:09] Writing local files
[18:39:09] Completed 240000 out of 500000 steps (48)
[18:39:09] Extra SSE boost OK.
[18:43:04] Quit 101 - Fatal error: Too many box elem corrections 1
[18:43:04]
[18:43:04] Simulation instability has been encountered. The run has entered a
[18:43:04] state from which no further progress can be made.
[18:43:04] If you often see other project units terminating early like this
[18:43:04] too, you may wish to check the stability of your computer (issues
[18:43:04] such as high temperature, overclocking, etc.).
[18:43:04] Going to send back what have done.
[18:43:04] logfile size: 39004
[18:43:04] - Writing 39574 bytes of core data to disk...
[18:43:04] ... Done.
- "Rozi vidm." "S psom!"
C_maniak ::
Ne, sej priznam, da je bil bluescreen zarad nestabilnosti, kr zdej iščem mejo. RAM ni zdržal.
Ampak blem je bil v tem, da je enkrat vklopu SSE (prvič), 1x pa 3D boost (drugič).
Zgleda, da je problem odpravlen, kr dela BP z SSE.
In je fakin' hitrejš tole!!
Iz 8 min/frame na 6min/frame. Iz 15 h na WU na 10 h. Huh...
Fold on everybody!!
Fold on everybody!!
- spremenil: C_maniak ()
CaqKa ::
kako se forca sse? imam celeron566 pa mi ga je prej vklopil zaj pa sem šel gledat v log pa ni vklopljen.
Zheegec ::
CaqKa: -forceasm
Sicer pa pri nekaterih paketikih vklopi SSE, pri nekaterih paketkih@AMD pa 3DNow! - to je odvisno od paketka.
Janez Janša, 29.04.2014
tx-z ::
a kdo ve kako nardit, da bo EM3 skrit ko je neaktiven, tist klicaj k je zravn tega programa pa vedno skrit. Če to naštelam v nastavitvah taskbara, mi vedn zamenja k na nov zaženem al pa se nanov prjavm. EM3 mi nardi vedno skrit, tist klicaj pa skrit ko je neaktiven. A se da ta klicaj izklopt-sploh ne vem za kaj je?
tx-z
C_maniak ::
SEE ne obstaja tuki.
3D now boost (ne pojavlaj se posebi sam kot 3d boost, al pa 3d now): pač 3D now "pospešek". Pač neka funkcija, ki jo uporablja procesor. Naj ti kdo, ki se bolj spozna, natančneje razlož. Enako velja za SSE. Ne vem točn. Pohitri pač vso zadevo.
Glede EM pa ne vem, če se sploh da. Mogoč HideItX al neki podobnga. Najdeš ga na isti strani kot EM3.
Emmm, 20. smo že!
Emmm, 20. smo že!
Tody ::
če se ti da natančna navodila iskat (hint: na vhodu teme klikni vse strani in potem odklikaj na edit-finde on this page-- vstavi ključno besedo)EM3 se da skrit tako da mu obkljukaš hide. Zadevo je mal težje pridobit nazaj. 3D boost je za pentiume SSE pa za AMD procesorje, uglavnem je to da pohitri kodo in računanje.
Boky ::
Kolikor vem so SEE ukazi intelova pogruntavščina, ki so jo, če me spomin ne vara prvič vgradili v Pentium 3 proce, AMD pa jih je prvic vgradil v Athlon XP procesorje. 3D-Now pa je AMD-jev nabor ukazov, ki je bil prvč predstavljen v K6-II procesorjih.(naj me kdo popravi, če se motim)
C_maniak ::
@tody, kok mislš 3d now boost za pentiume, SSE pa z AMD-je? jez mam najvekrat glih 3d boost vklopljen, SSE je pa še zmeri izjema.
tx-z ::
kako pa pošlem en WU. Sm ga hotu poslat, pa je neki prekinl povezavo in zdej ma pod queue eno DONE, drugo pa WORKING. A morm počakat da še ta drugo konča pa pol pošlje al kaj?
pa še neki: prejšn WU mi je delu 13ur pa je vreden 57 točk, tega zdej pa bo delu 20ur pa je vreden 19.7 točk. A ni to čudn??
tx-z
c3R4R ::
A lohk vprašam kako veš, kok točk je vredn WU??
[mogoče mal neumesno vprašanje, ampak ne mi zamert]
Zaradi neurij imajo hrasti globje korenine.
C_maniak ::
če uporablaš EM ti tk piše tm.
drgač pa pogledaš ker WU ti obdeluje, ga poiščeš tuki in vidiš kuk pik je vredno.
tx-z ::
ok,sj mi je poslal..sm že na 186 mestu
sam še vedn pa ne vem, kako mi bo ta WU delu 1x več časa, pa 3x manj točk bom dubu. A se da nardit,da bi mel vedn isti protein?-bi velik točk dubu
tx-z
morphling1 ::
Kako lep pogled je na to statistiko vedno bolj barvasto postaja in imam občutek da bo Darko kaj kmalu tudi oranžen :)
Sploh je fenomenalno, da smo po dnevni produkciji že na dvajsetem mestu svetovno :)
Kaj naj rečem drugega kot fold on
Zheegec ::
Da bo jasno: SSE in SSE2 (in pa seveda MMX ter MMX+ ki jih pa podpirajo vsi novejši proci) so Intelova pogruntavščina, P4 ima oboje (SSE in SSE2), medtem ko ima AMD 3DNow! in pa 3DNow+ ter pa SSE. S Prescottom pride pa še 1 nov nabor ukazov.
Zoidberg ::
Aja samo nekaj kako se kaj držijo P3 za foldanje se sploh splača prklopit. Je pa 450 in bi laufal samo zato tako da nevem če naj priklopim ali ne.
Just keep on trying, keep on flying. I will be the light.
Zheegec ::
Če je 24/7 potem ni problema, še SSE bo malo pomagal...
Zheegec ::
Ti je caps lock zašteku?
AtaStrumf ::
He, He tale bratov Duronček je mal prej prilezel na 50%
. A se spomnete kdaj sem ga vklopil? Groza, tale WU mu pustim da dokonča pol pa izklopim k nima smisla. Pa gre za 933 MHz Durona, k drugače super laufa, tako da še zdaj težko verjamem da gre tolk počas. Kako je pol šele z raznimi Celiji pa P3, ki so še počasnejši od mojga Durončka?!? Saj to sploh nima smisla imeti vklopljeno, ali pač?
A je hitrost ista tudi z Thunderbird Athloni? Enga Athlona 850 MHz prodajam pa ga noben noče k je mal okrušen, pa razmišljam da ga ruknem v bratovo mašino namest tega Durona 900, pa raje Durona prodam k je kot nov, k sem ga kupil novega in samo enkrat inštaliral in pustil na miru. A se mi splača, ker s tem Athlonom je vse OK, ... zgleda da le ni vse tisto jedro.
ali3n ::
ataStrumf - Celeron Tualatin 1.2 dela en paketek pribl. slab dan...
Marjan ::
Jap, pa navijat se splača pri FAHu!
Npr:
Taulatin 1.2GHz - 1 frame = 10.5 min,
navit na 1.6GHz - 1 frame = 7.5 min
Paketek ima 100 frames. Torej razlika nanese 5 ur razlike samo pri enem paketku!!!
Zaključek:
Navijajte in laufajte FAH.
Npr:
Zaključek:
Zoidberg ::
No še noje poročilo P3 450Mhz en frame dela 47minut
. Ampak mi je vseen če laufa ker me ne moti pač bom na vsake toliko časa dobil en paketek več.
Eno vprašanje ali moram na drugem računalniku pod tisto še procesorja da 2 ali 1 če gre to za drugo kišto
lopov ::
Machine ID ti pride prav v primeru vecprocesorske masine, ko zelis poganjati hkrati vec FAH. V bistvu je vseeno, kaj bos dal (1, 2, 3 ali 4), default je pac 1.
Na dual Macu sem najprej poganjal 2 procesa, zdaj pa je aktiven samo se tisti z ID 2 in dela cisto lepo.
Hammer ::
Koliko časa vam dela paketek p910_vill_str0_rf protein vreden 57 pik? Meni ga naredi v 7h in pol
Sergio ::
Sporočam, da od sedaj naprej pod mano foldajo trije 2GHz+ računalniki. Ni veliko, je pa nekaj ;)
Tako grem jaz, tako gre vsak, kdor čuti cilj v daljavi:
če usoda ustavi mu korak,
on se ji zoperstavi.
Zheegec ::
Serverji (še?) delajo. Samo tale statistika je malo ()#$&
roCkY ::
Serverji delajo. Vsaj velika večina. Offline je zgleda le del, ki skrbi za statistiko. Tako je ne morjo računat zunanji neodvisni serverji saj ne morejo do podatkov.
Je pa tistle kar zanimivo. Vprašanje je le ali je vnaprej pripravljeno (pomoje je) ali pa se je nekdo trenutno mal pozabavov.
monster-x ::
Danes sem navil svoj proc iz 1,83 GHz na 2,31 GHz pa morm rečt, da Folding@Home naravnost poleti. Vendar pa sem ga sedaj "odvil", ker sem skoraj znoru, ko mi je komp friznu ko sem že skoraj spisal novico.
Zheegec ::
Lol Monster-X
A si pisal novico o poviševanju voltaže na navitih Athlonih brez česar se lahko zadeva sesuje, ali si pisal novico o hlajenju OC Athlonov?
tx-z ::
a je to kej narobe, če računalnik dela 24ur na dan, 7dni u tednu, pa tko naprej; s tem da je procesor neprestano na 100% ? -temperaturo pa bi mel od 43-50'C
tx-z
| » | Slotech Folding InstallerOddelek: Programska oprema | 2956 (2288) | rap3r |
| » | folding - WU - teamOddelek: Pomoč in nasveti | 1465 (1356) | zooXit |
| » | Malo Folding statistike (strani: 1 2 )Oddelek: Novice / Obvestila | 7299 (7299) | frenk |
| » | Kako v ekipo?Oddelek: Loža | 2024 (1737) | frenk |
| » | Vabilo k projektu Folding@homeOddelek: Novice / Znanost in tehnologija | 3381 (3381) | Phoebus |
