Forum » Loža » Ancient Aliens
Ancient Aliens
Aston_11 ::
Ramon dekers je izjavil:
Marsikaj je dobro razloženo v dokumentarcu. Če je to zate BS, potem je zate še večji BS to, da so bile grobnice.
""In a pop culture with a short memory and a voracious appetite, aliens and pyramids and lost civilizations are recycled like fashions."
hja poglejmo fakte: piramide so bile zgrajene v določenem času.
Drugi fakt je da niso imeli strojev.
Tretje pa je da bi bilo fino dobiti podatke o številu prebivalcev Egipta. Potem se naredi statistiko kdo je delal na polju, kdo na piramidah in kdo je bil v vojski. Ok če jih je bilo 2 miljona na piaramida potem mogoče.
Če jih ni bilo 2 mio na piramidi, potem pa kaj?
Aston_11 ::
Bi bil zmatran - močno. Če bi mi Egipčan s sulico meril rit, verjetno kakšnega pametnega ugovora na temo lenobe ali podobnega ne bi imel. Povedati hočeš nekaj s tem. Kaj? Za bloke menda kažejo podatki, da so jih porivali po neprestrmi klančini, na vogalih pa dvigali s škripci na višji nivo. O tem menda obstaja ena tema na ST. Par ton blok - par ljudi na škripec. Nič posebnega.
Ramon dekers ::
ja ja klančina je bila že prej omenjena. "Piramida" okoli piramide. No to so le špekulacije, nič resnega.
"The most common theory for moving large blocks is to slide logs under the large stones to make mobility easier. The block would have been attached to large ropes with people pushing the block forward. At the same time several men would remove the last log uncovered by the stone. The end log that was removed would then be transported to the front where it would complete the cycle under the stone and the endless cycle would be repeated.
Moving the block was one thing but placing it into position was another. This idea has also left scientist baffled. The most common theory for placement of each stone is said to have a ramp that went around the pyramid's sides. Some have concluded that the ramp only touched one side of the pyramid. This might have been true, but the ramp might have had more material then the pyramid did and this would have made placement of each block difficult."
nothing new, move along
Aston_11 ::
Menda obstaja en sken te klančine, ki si ga niso znali razložiti. V bistvu znotraj piramide, ne pa še ena piramida okrog piramide.
Še vedno ne vem, kaj hočeš povedati.
Ramon dekers ::
kar podaj vire, da si ogledam zadeve in da ne bova govorila na pamet. Klančina je "piramida" okoli piramide, ki so jo kasneje porušili.
Preberi si zadnji stavek tistega kar sem pripopal.
Aston_11 ::
Bom poskusil poiskati. Ni pa bila omenjena zunanja rampa, temveč notranja krog in krog piramide in na vsakem vogalu je bil prikazan dvig s škripcem.
Ne gre tako preprosto, kot si mislite. Poleg tega, dela niso opravljali sužnji, ampak plačanci. In kako bos s skripci sestavil piramido, v kateri so izdelani predori, ki ciljajo tocno na določeno mesto v vesolju in za katere je bilo potrebno uporabiti specialne merilne tehnike? Glava Sfinge je npr. obrjena ob vsakem novem začetku precesije v ozvedje Leva, v najsvetlejso zvezdo Regelus. Vsakih 26000 let se z Sfinga z očmi poravna s to zvezdo. Naključje? Pa takih "nepomembnih stvari je se ogromno". Celotni Giza plato je v osnovi velika astronomska ura.
We are fine without wings.
Aston_11 ::
Evo link
To bo bolj težko, da se vsakih 26 tisoč let poravna s čimerkoli, ker se zemlja proti zvezdam ne nahaja v istem položaju, temveč se ozvedja premikajo. Isto, kot je bil Egipt enkrat žitnica, danes ni več, zvezde niso bile tam, kjer so danes. Verjetno so tudi to opazili, ne vem.
- spremenil: Aston_11 ()
Ramon dekers ::
Aston_11 ::
kolikor vem naj bi bili škripci izključeni? šlo naj bi izključno za vrvi in golo delovno silo.
Težko, da bi si ne bi pomagali z vzvodom, če so ga imeli na voljo.
Ramon dekers ::
Evo link
mi daš kakšno boljšo sliko? saj vem da bi les segnil tudi če je možno da bi imeli škripce, samo moje mnenje je da bi jo lažje naredili z več manjših kosov kot pa z manj kosovo po več ton težkih kamnov. Zakaj se za kitajski zid nihče ne sprašuje kako so ga delali?? Zato pa sem te prej vprašal da je pomembno koliko ljudi so imeli, ker Kitajci so jih imeli dovolj oz preveč že takrat.
- spremenil: Ramon dekers ()
Aston_11 ::
Tu jih je polno.
Za število ljudi ne bi vedel, les pa bi najverjetneje odstranili. Je celo nekaj animacij.
Vikking ::
Fakt: tudi rimljani niso imeli strojev, ter njihove zgradbe so bile prav tako zgrajene v določenem času. O rimljanih imamo nešteto zapisov kako so gradili itd... žal o egipčanih in njihove tehniki gradnje veliko veliko manj.
Fakt: 30.000 do 100.000 ljudi bi bilo dovolj za gradnjo v 25 letih. Imaš tudi teorijo ki pravi da je bila piramida delno že zgrajena od predhodnikov in jo je Keops le dokončal. Teorije ki pravijo o uporabi vrvi in škripcev, brez naklonine.
Ramon dekers ::
za rimljane se točno ve da so uporabljali škripce, cement,kakšno tehniko tudi več je zapisov, skratka nobene filozofije. Isto je pri kitajskem zidu, točno se ve komu je bil namenjen da se je delal iz dinastije v dinastijo, oz nadgrajeval, ampak tam so bili majhni kamenji in ogromno delavcev.
se pravi so imeli "žerjav" da so dvignili 2-5 in več ton težke bloke?
Tu jih je polno.
Limit-sky ::
Kaj bi naredil, če bi videl posnetek, kjer en (1) človek dvigne ali prestavi kamen (par ton) samo s pomočjp lesa in kamna. Ne, ni škripcev. Verjetno bi ga nekateri imeli za ETja.
Ramon dekers ::
teh posnetkov je neskočno, potem pa prikaže debelega človeka ki premika nekaj ton težko kocko in pazi to na betonskih tleh. Ja wau. In potem izjavi da so tako premikali kipe na velikonočnih otokih, tam pa je itak sama trava. Kaj pametnega in resnega ni nič tisto kar pa je so pa samo špekulacije.
Štiri zvezde v stirih ozvedjih Aldebaran-ozvezdje bika, Regelus- ozvezdje leva, Antares- ozvezdje skorpijona, Alrische ozvezdje rib..te zvezde ne spreminjajo polozaja ena do druge, so zato tudi znane kot štirje varuhi nebes.
Ne vem če se je ze omenilo, ampak če potegnes linijo recimo iz Cuzca do Gize platoja in se dalje, opazis da so na tej liniji marsikatera anticna najdbisca, kot recimo Machu Pichu, ozemlje dogonov v Afriki, Giza plato, Petro, Ur, Persopolis, Mohenjo Daro(kjer so odkrili neznano pisavo, ki je zelo podobna pisavi na Eastern Island), Khajuraho, Sukothai, Angkor wat, Eastern Island...
Aston_11 ::
PacificBlue je izjavil:
Ne vem, če govoriva o istem - jaz ne ppravim, da zvezde spreminjajo položaj ena proti drugi, temveč da zemlja spreminja položaj glede na vse zvezde. Trenutno sever (os) kaže proti severnici.
BigWhale ::
http://www.reshafim.org.il/ad/egypt/peo...
Egipcanov je bilo za tiste case kar precej. Ocena je, da jih je bilo okrog 1mio leta 3000 BCE. V novem kraljestvu jih je bilo ze 2mio. Vec kot dovolj, da zgradijo piramido, pa ne samo ene. :)
Aston_11 ::
Pacific - glede na najdišča - po mojem bolj podnebje vpliva na njihov geografski položaj. Na polih ne boš našel nič, ekvator je tudi rahlo pretopel.
Ramon dekers ::
BigWhale ::
Muslimani pa vse moseje gradijo z vrati obrnjenimi na vzhod, mar ne?
To nam pove, da so ljudje takrat opazovali zvezde in gradili hise tako, da so bile obrnjene proti zvezdam. Big deal. O neki hudi natancnosti se je tezko pogovarjati, ker obrniti hise tako, da gleda v doloceno smer ni tezko. Stirje kolicki, dve vrvici in z njimi naredis preprost instrument, ki ti omogoca da nevem kako veliko zgradbo poravnas z zvezdami.
Vsakih 26.000 let bodo te zgradbe spet poravnane z izhodiscno zvezdo? Seveda. Temu se rece precesija. Ce danes postavis zgradbo, ki ima vrata poravnana s Severnico bodo cez 5000 let ta vrata poravnana z Vego, cez nadaljnih 21.000 let bodo pa spet poravnana s Severnico. Pa sploh ni treba, da se ti sanja kaj je to precesija. Vse se bo kr avtomagically poravnalo. :)
Zakaj so dajali tako pomembno vlogo precesiji?
To je dobro vprasanje. In kako so sploh vedeli zanjo? 26.000 let je dolga doba.
Aston_11 ::
Egipčani so bili dovolj pametni za kaj tekega. Nenazadnje so pogruntali dolžino leta. Pa so res vedeli za 26.000 let ali je to samo domneva?
BigWhale ::
Sej pravim, da ne rabis vedeti za precesijo, da se ti stavba vsakih 26.000 let poravna z zvezdo. Sam stavbo mors postavit. :> In se bo kr sama vsakih 26.000 let poravnala s tisto zvezdo.
Truga ::
Jst bom dans pogledal s kero zvezdo so poravnana glavna vrata od stozic. Pol bom naredu youtube video o tem kako se vsakic 26 tisoc let poravna s to zvezdo, dodal se namige na prostozidarje in povedal da je vesoljc Jankovic v resnici zgradil terminal za vesoljske ladje, ki ga uporablja ko na stozicah ni eventov. To da vcasih not igrajo fuzbal pac ni relevantno.
Truga ::
Kaj ima vesoljski terminal s postavitvijo piramid?
Nic, saj to je tist. Piramide so gradili ljudje. Bile so v veliki meri grobnice/svetisca. Mozno da so bile nekatere postavljene tudi v kaksne druge namene.
Zdej pa kle berem da so jih v resnici uporabljali kot elektrarne, in da so jih gradili vesoljci, ker je slucajno na eni crti nekaj najdbisc. Ce potegnem nakljucno kjerkoli po zemljevidu bo sigurno gor 10 vecjih arheoloskih najdbisc, ker, ja, uganil si, ljudje so tam ziveli, in gradili svoje reci.
Kar pa se tice nacina gradnje, kot so drugi ze povedali, s pomocjo vzvoda lahko en clovek dvigne vec ton. Nisem sicer zivel v antiki, ampak mislim da se fizika od takrat ni spreminjala. Prav tako so bili to projekti, kjer je sodelovalo vec deset tisoc ljudi. Edino vprasanje tu je, kdaj zgradijo, ne pa ce lahko.
In se, piramida, glede na to da je vec ali manj polna, je najbolj osnovna, in najbolj stabilna oblika zgradbe. Ce se taka zgradba ne bi ohranila do danes, in ne bi bilo dokazov da so imeli prste umes ljudje, pol bi pa razumel da se tu navaja vesoljce. Tako pa je to samo sci-fi ki se prodaja v formatu "dokumentarcev".
jest10 ::
znova ta veliki čudež
Eni kot kaže namerno spregledajo ta posnetek, ki je bol že 10+ krat naliman
- spremenilo: jest10 ()
Ramon dekers ::
ma spet tega debuluha limate ko ima spodaj beton, mogoče so tudi avto ceste gradili ko so postavljali stone henge ter kasneje izbrisali da nihče ni vedel te taktike in da bodo ljudje mislili da so jih res postavljali na travi.
Sicer pa bi ga rad videl pri celem procesu, to je rezanju, klesanju,oblikovanju, tako kot v starih časih brez orodja samo les in kamen.
Ker un skedenj je tudi po betonu (in ne po travniku) premikal?
Ne pomaga samo slikce gledat pa ugibat kaj se dogaja... včasih je treba tud poslušat.
Ramon dekers ::
jp, 100% je bila trda podlaga, delal je po istem kopitu vseskozi, skedenj je bil itak samo lupina sem prepričan da je bila notri trda podlaga, les, beton... Sicer pa koga naj bi ti ali mi morali poslušati.
BigWhale ::
Pod unim skednjem je imel podlozene tri lesene plohe in na teh plohih je imel potem os, pod tisto betonsko klado je pa podlagal lesene hlode, ko jo je pokonci postavljal. Tiste manjse kamne je verjetno res premikal po betonu ampak tak isti princip bi lahko uporabili za gradnjo piramide, za premikanje blokov po sami piramidi.
PacificBlue je danes ob 12:58:17 izjavil:
Poglej si tale petnajstminutni del dokumentarca The releveations of pyramids, priporocam.
Ramon dekers ::
to lahko delaš samo na ravni površini, vemo pa da je ravnina idealni pogoj za delo, vsaj takšno.
Looooooka ::
Glede na odgovore v temi ne bi bil rad na otoku z nekaterimi ljudmi.Ocitno bi se sli takoj ubiti.Ker brez bagerjev in diamantnih zag clovestvo ocitno ne zna narediti nicesar.Pa ceprav smo kamne rezali pred diamanti in ceprav smo ze 500x videli, da se da z lesom in fizicno silo premaknit marsikaj.To da smo letos videli na 100.000 ljudi na cestah pa ocitno tud ni dovolj dobra "slika", da si ne moremo predstavljati teh 100.000 ljudi kako planirani vlecejo skale.Pa v par 100 letih se ocitno tud ne more najdt nekdo, ki mu je tok dolgcas, da pac vsak dan opazuje zvezde in si zapisuje polozaje.Ni cudno, da smo rabili vesoljce.Ocitno smo totalno nesposobni po naravi.
guest #44 ::
Sej smo že nekaj časa nazaj imeli temo kjer so odkrili tunele na obodu piramide s katerimi so rpevažal na na višino bloke.
Odnehite že enkrat.
Odnehite že enkrat.
Vidva si ne bi vsaj pogledala tist posnetek ki sem ga dal?
Bedarije govoriti je se najlažje.
- spremenil: PacificBlue ()
Torej. Povzetek...
Ko nekdo naredi nekaj (skoraj) neverjetnega so mu pomagal marsovci.
Ko nekdo poda eno dobro razlago kako je un naredil nekaj (skoraj) neverjetnega je pa full of shit.
Dajmo malenkost pamet v roke.
Ramon dekers ::
Torej. Povzetek...
Hja nevem kdo se je spomnil piramide, a ni enostvneje samo ležati tako kot je delal to jamski človek v Evropi in samo sexal. Hja tudi on je imel preveč časa, no bil je zaposlen z lovom in sexom
Zakaj? Zato ker so lahko. In zato ker so imeli faraoni čist en tak... zelo očiten god complex. Njim ni blo treba nič. Samo rečt 'nardite mi tole' in folk je šel delat. Kufu (Keops) se ni prav nič zmatral pri gradnji svoje piramide.
Ja... Martians did it! Zelo logična razlaga.
BigWhale ::
Hja nevem kdo se je spomnil piramide, a ni enostvneje samo ležati tako kot je delal to jamski človek v Evropi in samo sexal. Hja tudi on je imel preveč časa, no bil je zaposlen z lovom in sexom? zakaj so šli sploh v take podvige? Meni je bolj logična prva razlaga, nevem zakaj bi si oteževal življenje če ni potrebe.
Jamski clovek si je moral sproti loviti in nabirati hrano, ker hrane ni znal skladisciti. Egipcani so to ze znali. Po poplavah so hitro obdelali zemljo, pocakali na zetev in spravili pridelek. Pol so pa u spajzo hodil in ven jemal ce je cesa zmanjkal. Pa vsake tolk casa je su kdo na lov, da je novo zival uplenil. Hkrati so pa Egipcani ze gojili zivino, ki jim je sluzila kot delovna zivina in kot hrana.
Hm, mogoce so pa namest ljudi uporabljal zivino za vlect kamne naokrog?
Ramon dekers ::
No ja tu pride paradoks, jamski človek je bil na stopnji dojenčka, medtem ko je bil egipčan na stopnji 90 let starega dedka.
BigWhale ::
Kaksen paradoks? Jamski clovek je zivel od 100.000 BCE do 12.00 BCE. Tole zadnje je se kaksnih osem tisoc let pred Egipcani. Kaj ti zdaj ni jasno?
BigWhale ::
Ja, kaj je na tistem posnetku?
Axial precession %28astronomy%29 @ Wikipedia
Povsem mozno je, da so poznali precesijo in da so kak objekt orientirali tako, da je gledal v smer kaksne zvezde. To je pa tudi vse in ni nic posebnega.
Se ena stvar o blazno natancni gradnji piramid
Great Pyramid of Giza @ Wikipedia
Veliko piramido so narobe postavli, potem so jo pa z apnencem oblozili tako, da so mal popravili vogale. :)
| ⊘ | Kan. 15-letnik odkril, da so majevske piramide postavljene enako kot nek zvezdni sistOddelek: Problemi človeštva | 6455 (5897) | zee |
| » | Toplotna anomalija piramid v GiziOddelek: Znanost in tehnologija | 13624 (7040) | Unknown_001 |
| » | V bosni piramide (strani: 1 2 3 4 … 7 8 9 10 )Oddelek: Loža | 123667 (101131) | GizmoX |
| ⊘ | We come in peace... (strani: 1 2 3 4 5 )Oddelek: Loža | 51596 (45200) | Gandalfar |
| » | skrivnost gradnje piramide (strani: 1 2 3 4 )Oddelek: Loža | 58407 (48761) | Bellatrix |
