Novice » RTV Slo » Resnična Resničnost: Linux
techfreak :) ::
Očitno nekateri le vedo, kaj je uporabno (OpenGL).
Sploh pa, kje bi bila fora MSja, če bi druge konzole uporabljali DirectX?
2. Če že delajo igre za konzole v OpenGL, zakaj potem ne morejo še za pcje kaj takšnega skupaj spraviti?
OmegaBlue ::
- spremenil: OmegaBlue ()
ozbolt ::
quote:
Originally posted by nehalem:
I think both the PS3 and the Wii use a version of OpenGL.
Not quite. PS3's OS uses PSGL, which is a customized version of OpenGL ES. Wii's graphics API is similar to Gamecubes, which, in turn, is OpenGL like I believe, but is not OpenGL (it's something completely different). OpenGL like means that Wii/Gamecube's graphics API behaves like OpenGL (setting the viewport, the rendering state machine, etc..)
Minor nitpick: When talking about OpenGL and DirectX comparisons, you compare OpenGL to Direct3D, not to the entire DirectX API.
360 has a Direct3D like API derived from Direct3D.
Kopirano z nekega foruma.
BigWhale ::
"Minor nitpick: When talking about OpenGL and DirectX comparisons, you compare OpenGL to Direct3D, not to the entire DirectX API."
To smo ze stokrat povedali.
Stoenkrat.
Stoenkrat.
smihael ::
Vlady, a si ti zm....
Na "buggy" Qtju je narjen Google Earth, Photoshop Imege Viewer, mal si uradnos stran poglej
BigWhale ::
Saj, jaz se vedno cakam na Vladijeva step-by-step navodila, ki pokazejo vsak pet Qtjevih bugov.
Glede na to, da jih je tolk, bi morala biti ta naloga trivialna. Preden jest keks napisem...
Vlady ::
Vlady, si zdrav?
klik!
Si zdrav ti? Wiki nikjer ne omenja openGL-a. Kar dobro si preberi. Komu boš verjel, enemu overview-u ali wikiju?
Uporablja neko okrnjeno oz. predelano verzijo openGL-a, ki pa to ni več openGL. Pač ker je open in zastonj, so ga vzeli in pošteno predelali.
"Lotereya - naibolee točnyj sposob učeta količestva optimistov"
- spremenilo: Vlady ()
Mavrik ::
Bo skupnost izjemno vesela kode v PS3 ASMju, da cela zadeva sploh lahko dela :P
Stipex ::
PS3 sicer ne uporablja ravno OpenGL(2). Za izrisovanje uporablja PSGL, ki pa je modificirana verzija OpenGL ES 1.
talmai ::
Well, OpenGL ES je "subset of OpenGL".
A ne bi blo to neumno, da bi šli vse z nule pisat?
PSGL ni OpenGL, je pa derivat njegovega okrnjenega derivata.
"Bit je kot določna popolnoma nedoločna." (M. Heidegger)
- spremenil: talmai ()
Mavrik ::
Kompliment ja. Ker je tolk dost alternativ zunaj :D
Vlady ::
Ja samo PSGL je 10x boljši in močnejši kot navaden openGL, lahko se primerja z DX10, če ga celo ne prekaša ponekod. Poleg tega pa PS3 večino dela preloži na HW, medtem ko pri openGL določene stvari še vedno dela SW. PS3 ima tudi drugo arhitekturo procesorja.
Naj še 1x napišem: openGL ni za igre, še posebi če je potreba po lepi hudi grafiki. Tisto kar je portano je že staro, in tud grafika ni ne vem kako huda.
talmai ::
Se čist strinjam, da je PSGL boljši, sej bi blo čudn če bi šli OpenGL derivat in nardil kej slabšega (doh). Ne more se primerjat z DX, lahko se kvečjemu z Direct3D (glej zgoraj). In tudi neumno bi bilo, če PSGL ne bi izkoriščal HW (halo?), sploh ker je hardware jako močan in ker je zadeva embedded.
Don't you get it? OpenGL ni consumer product za lene developerje. Je osnova, na kateri lahko potem gradijo ubijalske rendererje, tisti, ki to pač znajo in se tega lotijo.
Biješ se z mlini na veter. Jest sploh ne pravim da DX sux. Očitno ima v svoji ciljni publiki sposobne in zveste razvijalce (iz končnih izdelkov, ki jih uspejo v DXu narest).
Stipex ::
Vlady...
Nekdo, ki se zares spozna na to področje ne bo konstano pisal primerjave DirectX in OpenGL ampak Direct3d in opengl. Tudi po načinu izražanja zelo dvomim v tvojo strokovnost.
| » | Igre na Linuxu še vedno počasnejše kot na Windows (strani: 1 2 )Oddelek: Novice / Igre | 34762 (30411) | MrStein |
| » | Privzeta namestitev Ubuntuja brez Flasha (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 27125 (24978) | Icematxyz |
| » | ReactOS začenja znovaOddelek: Novice / Ostala programska oprema | 5621 (4462) | poweroff |
| » | Rusija bo razvijala svoj operacijski sistem (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 12478 (8772) | cryptozaver |
| » | Spet Linux vs Linux vs Linux vs Windows ... malo bolj podrobnoOddelek: Operacijski sistemi | 2533 (1957) | Jst |
