Forum » Znanost in tehnologija » Scientists Invent 30 Year Continuous Power Laptop Battery
Luka Percic ::
2-3 leta?!
Sej najbrž iščejo investorje in pretiravajo, samo sliši se hudo.
The best part about these cells are when they eventually run out of power they are totally inert and non-toxic, so environmentalists need not fear these high tech scientific wonder batteries. If all goes well plans are for these cells to reach store shelves in about 2 to 3 years.
2-3 leta?!
Saladin ::
A je sploh kaka prenosniška baterija danes v serijski proizvodnji, ki lahko žene prenosnik ob polni obremenitvi en sam samcat dan? Ali morda teden dni?
Sedaj pa že kar naenkrat 30 let. Sej lahko napovedujejo - kar lahko pokažejo je kar velja (razen če "verjamete" ;))
St@jler ::
Lahko bi začeli s petimi leti, saj več tako ali tako prenosniki ne zdržijo, ali pa postanejo zastareli.
antonija ::
Ce je res to kar so rekli pol bos za sabo nosil kos radioaktivnega materiala.... ki bo seval vsaj 30 let beta delce (zelo hitre elektrone se mi zdi). Zdej ce bo pa kdo to polozil v svoj "lap" je pa njegva odlocitev :)
destroyer2k ::
antonija
Žav ampak ne bo sevala radioaktivne stvari.
Tule je celi članek.
Your next laptop could have a continuous power battery that lasts for 30 years without a single recharge thanks to work being funded by the U.S. Air Force Research Laboratory. The breakthrough betavoltaic power cells are constructed from semiconductors and use radioisotopes as the energy source. As the radioactive material decays it emits beta particles that transform into electric power capable of fueling an electrical device like a laptop for years.
Although betavoltaic batteries sound Nuclear they’re not, they’re neither use fission/fusion or chemical processes to produce energy and so (do not produce any radioactive or hazardous waste). Betavoltaics generate power when an electron strikes a particular interface between two layers of material. The Process uses beta electron emissions that occur when a neutron decays into a proton which causes a forward bias in the semiconductor. This makes the betavoltaic cell a forward bias diode of sorts, similar in some respects to a photovoltaic (solar) cell. Electrons scatter out of their normal orbits in the semiconductor and into the circuit creating a usable electric current.
The profile of the batteries can be quite small and thin, a porous silicon material is used to collect the hydrogen isotope tritium which is generated in the process. The reaction is non-thermal which means laptops and other small devices like mobile phones will run much cooler than with traditional lithium-ion power batteries. The reason the battery lasts so long is that neutron beta-decay into protons is the world's most concentrated source of electricity, truly demonstrating Einstein’s theory E=MC2.
Luka Veliki
Vem da si dal link toda zgleda da ne znajo vsi kliknati na link da bi prvo prebrali in kasneje govorili o tem.
Luka Veliki
- spremenilo: destroyer2k ()
Avby ::
Sam menim da tehnologija je že tako zastarela. To kaj uporabljamo. In čas bi že bil za nov "hranilnik" energije ki je bolj učinkovit od sedanjih baterijskih vložkov.
Sam morda stavim na vodikove "bombice" ki bodo napajale vodikovo celico in bodo se ob izpraznitvi preprosto zamenjale. Embalažo pa bi lahko ponovno napolnili. In pa seveda z razvojem pričakujem majnšo porabo elektronske opreme.
Ta dva faktorja bi lahko drastično povečala doseg energijskega vira in čas uporabe elektronske naprave med "polnjenji".
marsovcek ::
Kako ni radioaktivno, če deluje na principu beta sevanja in uporablja radioizotope? In po moji logiki rabiš za zadosten učinek dovolj veliko število beta delcev na časovno enoto, drugače povedano dovolj aktiven izotop.
Dandanes ljudi skrbi že zaradi elektromagnetnega sevanja, da bodo pa še naravovarstveniki "požrli" radioaktivne baterije se mi zdi pa malo za lase privlečeno.
Thomas ::
Hja, v bistvu smo o tem na tem forumu že govorili. Verjetno gre za baterije na osnovi izotopa niklja.
Če so RES uspeli premagati vse ovire in zgradili takole baterijo ... je to pomemben dosežek.
antonija ::
"As the radioactive material decays it emits beta particles that transform into electric power capable of fueling an electrical device like a laptop for years."
??? Beta delcev ne savajo zvecilni gumiji (zato McGuyver ni nikoli sezidal takih baterij v svojih dogodivscinah), ampak jih kar lepo radioaktivne snovi (ki jih v naravi konec koncev sploh ni tako malo).
Amapk ce jim je tole res uspelo potem jim kaksna nobelova ne uide, ker tole je pol portable powerplant
EDIT: Je pa po drugi strani res da beta delce ustavi ze tanka aluminijasta plosca; ce tisti radioaktivni material seva res samo beta delce v signifikantnih kolicinah potem bo ohisje brez problema zadrzalo sevanje.
- spremenilo: antonija ()
Thomas ::
Če gre za Nikel 63, o čemer sem bil govoril leta nazaj, potem je vse v redu. ČE.
WarpedGone ::
Nobene številke ne omenjajo razen "30 let". Ma kdo kakšno oceno velikostnega ranga moči, ki bi jo naj bila taka reč sposobna producirat? Če so to mikroW pol sorry brate, če so vsaj celi W bo mela nišno uporabnost, če pa so ranga par 10W je pa to že zmaga :)
Zbogom in hvala za vse ribe
.:noir:. ::
Thomas:
glede na to da ste se o tem ze pogovarjal, me pa zanima, kaksne ovire /so bile/so/ za izdelavo in delovanje take baterije?
Thomas ::
Nikelj 63 je izotop niklja, ki ga v naravi ni. Dobiš ga v posebnih jedrskih reaktorjih, z obsevanjem navadnega niklja. Naprimer.
Razpolovna doba je mensezdi 102 leti.
Za izdelavo teh baterij, bo treba postaviti veliko posebnih jedrskih reaktorjev. To pa jasno.
.:noir:. ::
torej se nam manjka le to, kaj pa tehnicna izvedljivost? Ce je bilo ze prej znano, bi lahko ze prej zacel graditi namenske reaktorje.
ubistvu me zanimajo podrobnosti...ce kdo kej ve. Antonija? Thomas?
antonija ::
Glede na to da je "funded by the U.S. Air Force Research Laboratory" bos dobil bolj mlao detajlov... Imas pa na googlu polno clankov o niklju 63 in kje vse se ze uporablja, pa lahko probas sam kaj potegnit ven.
Itak je pa tole text in ni nikjer nobene delujoce 30letne baterije za probat.
edge540 ::
In kak pol preprečiš nekomu da da gor pol kile plastičnega eksploziva pa ma umazano bombo (ajde bolj bogo ampak tu je tudi psihološki učinek)?
Razen če sem kompletno falil poanto. Dvomim da bi večje količine kateregakoli radioaktivnega materiala kar tako dali v roke ljudem.
Thomas ::
Zgodovina te v tem mnenju podpira. Predsednik Carter, je izdal prepoved razvoja plutonijevih baterij za srčne vzbujevalce.
username ::
Dvomim da bi večje količine kateregakoli radioaktivnega materiala kar tako dali v roke ljudem.Odvisno, koliko je "močan" (škodljivi del) sevanja. Nikjer pa ne piše, kako močno je dejansko sevanje.
I've got a solution for the rainforest: napalm the lot. (Jeremy Clarkson)
Thomas ::
Je kar preveč, da bi bilo povsem nenevarno. Žal.
aljazh ::
Torej bo military use only, tudi če zadeva uspe
Ko pa smo že pri baterijah, Epson naj bi razvijal brezžični polnilec baterij, ki bi Li-ion baterijo napolnil v 10-15 minutah. Je tole bolj realna zadeva, ki bi lahko ugledala luč sveta?
Thomas ::
Vseeno jaz ne bi odpisal tegale niklja. Bombe iz nje ne moreš delat, vodo pa lahko zastrupljaš na 100 načinov brez tega niklja 63.
Ne vem pravzaprav, kje smo. Razen to vem, da bodo Zeleni takoj dobili peno na usta, kakor hitro se bo o tem začelo govort.
edge540 ::
To je res da je beta sevanje v manjših količinah nevarno samo če material zaužijemo.. ampak po moje bo mnenje zelenih naredilo svoje, saj jih zadnje čase kar poslušajo
aljazh ::
Saj tudi litij je škodljiv, če ga zaužijemo, pa eksplozivne znajo tudi bit te Li-ion baterije. Pa zeleni kljub temu veselo uporabljajo mobilne telefone, prenosne računalnike, fotoaparate
Horsechoker ::
aljazh: Ključni besedi sta radioaktivnost in JE ;)
But I don't want to be dead. I want to be alive. Or a cowboy.
| » | V soboto zvečer je nad Slovenijo padal (rahlo) radioaktiven dežOddelek: Novice / NWO | 26247 (18783) | rusilec |
| » | Roboti popraskali ostanke jedrskega goriva v Fukušimi (strani: 1 2 )Oddelek: Novice / Znanost in tehnologija | 25675 (21385) | blay44 |
| » | Objavljeni prvi posnetki notranjosti reaktorskih stavb v FukušimiOddelek: Novice / Znanost in tehnologija | 9631 (5964) | D3m |
| » | Fukušima - jedrski incident stopnje 4 v teku (strani: 1 2 3 4 5 )Oddelek: Novice / Nova vsebina | 99220 (85825) | Pyr0Beast |
| » | Half-life of 24000 yearsOddelek: Problemi človeštva | 3804 (3098) | Pyr0Beast |
