Forum » Problemi človeštva » Izrael vs. Palestina
Dober opis situacije.
https://www.aljazeera.com/opinions/2021...
Že spet ta patetična arabska propaganda.
Kot da ne bi bilo 3000 raket izstreljenih na izraelske civilne cilje.
Take bedarije so kvasili tudi nacisti o partizanih.
Bravo Izeael! Ne se pustit teroristom!
Prevod: "Bravo bully! Ne se pustit šibkim!"
Sicer pa tole pravi Irish ambassador:
- spremenil: LeQuack ()
Sakin ::
Koliko jokanja za prazen nič. Uganite kdo bo (spet) izšel zmagovalec iz tega spopada.
Na Nach Nachma Nachman Meuman!
Samo do leta 2013
Israel is the target of at least 77 UN Resolutions and the Palestinians are the target of 1.
as much as 40 percent of the total male Palestinian population... 8,000 Palestinian children have been arrested since 2000.
0 Israeli homes have been demolished by Palestinians and at least 48,488 Palestinian homes have been demolished by Israel since 1967. (View Sources & More Information)
At least 2,172 Palestinian children and 134 Israeli children have been killed by someone from the other side since 2000.
The majority of these [Palestinian] children were killed and injured while going about normal daily activities, such as going to school, playing, shopping, or simply being in their homes. Sixty-four percent of children killed during the first six months of 2003 died as a result of Israeli air and ground attacks, or from indiscriminate fire from Israeli soldiers.
Ben Dover ::
el_bahattee ::
Comandante je izjavil:
Ah daj, saj Palestinci niso neumni, in razumejo da bodo za vsako izstreljeno raketo iz Gaze dobili nazaj bombo. Opravicevati pobijanje civilistov z tehnolosko inferiornostjo je tudi mimo - sam Hamas je izjavil, da raketirajo zato, da povzrocajo teror med civilisti. Lahko bi z ostrostrelskimi puskami pokali vojake, pa raje obstreljujejo mesta. Seveda pod iranskim sponzorstvom.
Izraelci so seveda marsicesa krivi, ampak povracilnih ukrepov jim nekako ne gre zameriti. Ce se Hamas skriva po bolnisnicah, potem je to problem Hamasa. Da bi Izrael bombardiral legitimne bolnisnice kot take tezko verjamem. Da bodo ob bombandiranju mesta neizbezno nastadali civilisti je pa jasno.
Glavni bad guy je pri celotni zadevi Iran. Brez Irana bi zadeva ne bila tako problematicna.
Seveda niso neumni, ampk tu se gre za to, ali se boš uklonil in tiho trpel v okupaciji, zatiranju in kraji zemlje, ali pa boš posegel po radikalnejših ukrepih, kot je upor in vračanja nasilja z nasiljem. Ti dam preprost primer. Predstavljaj si, da z družino živiš v Gazi, neopredeljen do Izraela in Hamasa... potem pa ti nekega dne Izrael v nesorazmerni uporabi sile v letalskem napadu uniči hišo in ubije člane družine. Kaj bo tvoja reakcija? Verjetno se boš obrnil proti agresorju (Izraelu) in podprl radikalne skupine, ki bodo poskušale maščevati tvoje izgube, kajne? To je ta krog nasilja, ki ga omenjam.
Glede Hamasa ne razumem točno, kaj točno naj bi po tvojem zadeli z ostrostrelskimi puskami, če pa Izrael vglavnem bombandira iz zraka in tankov?
In glede Irana - tu nikakor ni glavni krivec. Izraelskemu PM situacija trenutno zelo ugaja, njemu se ne gre za civilne žrtve, ampak samo za to, da si napumpa javno podporo, zato zaenkrat zavrača premirje. Brez tega konflikta mu slabo kaže na političnem prostoru in nasplošno v karieri. Tudi Hamasu po svoje odgovarja konflikt, saj mu bo podpora pred volitvami spet zrastla.
Come to my center, you enter the winter.
el_bahattee je izjavil:
Predstavljaj si, da z druzino zivis v Gazi, neopredeljen do Izraela in Hamasa... potem pa te nekega dne obisce Hamas in te "prosi" za dovoljenje, da iz tvoje strehe izstreljuje rakete na Izrael. Si pa ja domoljub, a ne? Bos Hamasu rekel ne? Razumes kaksne so posledice?
Zadeve so tam izredno zakomplicirane.
Še en:
Muslimani so stoletja z ognjem in mečem na silo širili svojo vero, zdaj pa jočejo ko se jim dogaja isto? Naj se že enkrat sprijaznijo da Palestine ni več in bo večji mir v regiji.
Ben Dover ::
Kam pa bomo živino dali? V morje? Čeprav, EU rabi inženirje raketne znanosti..
- spremenilo: Ben Dover ()
Ti dam preprost primer. Živiš na vzhodu Poljske in si neopredeljen do Nemcev, Poljakov in Sovjetov. Nekega dne pride do vojne, ampak ostaneš neopredeljen in te pustijo pri miru. Nekaj let kasneje je vojne konec, pridejo Rusi in te obvestijo, da je tvoj dom zdaj del Sovjetske Zveze in da se moraš izseliti na Poljsko. Sicer imaš nekaj proti, ampak ko ti Rdeča Armada požge hišo in posili živino se vseeno izseliš in preseliš na zahod.
Vprašam, ker je to zgodba nekje 3 milijonov Poljakov, za katere nikomur ni mar. Zakaj ne? Mar oni ne štejejo? So kaj manj vredni od Palestincev?
Izrael tudi ne napada Gaze kar tako.
Število napadov iz Gaze v Izrael v posameznem letu
V letih 2018 in 2019 ni bilo omembe vrednih napadov Izraela na Gazo. Si takrat obsojal Hamasove napade na Izrael? Če ne, zakaj ne? In kakšna je sorazmerna uporaba sile za nekaj sto raketnih napadov letno?
- spremenil: Smrekar1 ()
Kolikor vewm, smo zaradi svetleče kovine, s križi hodili dol... Verjetno v Jeruzalem tudi iz drugih razlogov.
Cilj križarskih pohodov je bil odpreti Jeruzalem za krščanske romarje. Dokler ga niso zaprli in naredili mesto izključno za muslimane je bil mir. Nekaj je bilo še tega, da so hoteli nasilno zavojevati in si podjarmiti Bizantinsko cesarstvo - v imenu miroljubnega Alaha, kajpada.
Če bi rad branil Palestince raje ne odpiraj zgodovine.
Taki so težava samo na kitajskem ok potencialno še tisti na napačni strani v siriji in širnih sovjetskih prostranstvih.
lynxslo5 ::
Dejte vsaj preverit, kaj lepite iz youtuba. Tale stric oz. tovariš na posnetku ni noben irish abassador. To je Richard Boyd Barrett, poslanec skrajno leve stranke v irskem parlamentu. In če malo pogooglaš program njegove stranke, vidiš, da gre za trockistično-socialistično gibanje. Pa kaj je s temi levičarji? Trockisti podpirajo Hamas. Tukaj gre za podobno ljubezen kot pri paktu Ribbentrop-Molotov. Vemo, kam je ta pakt pripeljal svet. Če pa bi Hamas enkrat zavladal državi kot je Irska, bi pa najprej na kandelabre obesili ravno politike kot je Richard Boyd Barret in to ravno zaradi njihovega brezbožnega levičarstva.
- spremenil: lynxslo5 ()
Da trije ali štirje Križarski pohodi v različnih časovnih obdobjih so bili na ozemlje bljižnega vzhoda. Vsak slabši, potem se pa čudimo.
Ok ampak a kaj od tega kar je rekel ni res? Sem prilepi še un drug video kjer samo navaja citate od Izraelskih vodij/poslancev.
kunigunda ::
Zanimivo, pa glih krscani so v jeruzalemu najvec ne-krscanov pobil.
Dle ko se zadeve vlečejo, bolje je za Iran. Večja je gonja prot Izraelu ter večje je negativno mnenje Amerike.
Danes pričakujemo pozitivno potrditev prodaje orožja Izraelu v vrednost 760 milijonov $. Bomo videli če bo kongres danes to odobril. Biden je že.
PS. da ne bo pomote... Potrebna energija in čas priti iz 25% na 90% čistrega urana je minimalna... Da prideš na cca 20% je potrebno cca 90% časa od tu do 90% čistoti je minimalno... In zgolj zato ker Trumpi ni tega razumel in gledal samo posel, ter destibiliziral in ogorzil EU.
| » | Izrael uspešno ubranil svoj narod pred terorističnim konvojem (strani: 1 2 3 4 5 )Oddelek: Loža | 58323 (53406) | Gregor P |
| » | Izrael mora uničiti Islam, drugače bo Islam uničil Izrael (strani: 1 2 3 4 … 26 27 28 29 )Oddelek: Problemi človeštva | 71441 (46269) | poweroff |
| » | Izraelsko-arabska vojna se bije tudi na medmrežju (strani: 1 2 3 )Oddelek: Novice / Varnost | 16931 (13450) | Pšenični |
