Ali se lahko Intel Core Ultra CPU-ju zmanjša poraba?
orbika ::
Imam eno vprašanje. Ali obstaja možnost, da se procesorju Intel Core Ultra zmanjša poraba z 125 W TDP na 65 W? Gre za 245K procesor in bi ga želel odviti ali kako se temu pravi.
bbbbbb2024 ::
orbika je izjavil:
Obstaja, če tvoja matična plošča to podpira. Tam lahko nastavljaš profile oziroma limitiraš porabo. Če tega tam ni, ni ožno.
Ta limit v bistvu izvaja matična plošča, ne sam CPU.
orbika ::
Hvala. za odgovor. Brat ima to matično ploščo: H810M-X GEN5 WIFI 1851
https://www.asrock.com/MB/Intel/H810M-X...
Kje se to nastavi, če lahko prosim kdo pove?
Hvala vnaprej!
klinker ::
- Enter the BIOS: Restart your computer and repeatedly tap the Delete or F2 key as it boots up.
- Switch to Advanced Mode: Once the BIOS screen loads, check the top or bottom of the screen. If it says "Easy Mode", press F6 on your keyboard to switch to Advanced Mode.
- Use your mouse or arrow keys to select the OC Tweaker tab from the top navigation bar.
- Open CPU Settings: Scroll down and click on CPU Configuration.
- Locate the Power Limits: Scroll down toward the bottom of the page until you find the power limit values. Look for these specific terms:Long Duration Power Limit (PL1): This controls the sustained wattage your CPU can draw during long tasks.Short Duration Power Limit (PL2): This controls the maximum burst wattage allowed for short periods.
- Change the Values: Click on the current value for these settings (often set to "Auto") and type in your desired wattage manually.Example: If you want to limit your CPU to a strict power profile, you can set PL1 to 65 (65 Watts) and PL2 to 125 or 65 as well.
- Save and Exit: Press F10 on your keyboard, confirm that you want to save the changes, and select Yes to reboot your computer.
orbika ::
Najlepša hvala! Bom poročal, kako se je obneslo, oziroma, če deluje.
orbika je izjavil:
V biosu preveri, ce je odklenjeno spreminjanje frekvenc, napetosti, itd. Ce je, lahko znizas porabo, sam prej si kaj preberi o tem.
Nikonja ::
A je kakšen poseben razlog zakaj mora bit 65W ker to je prenizka moč za ta CPU in je velika šansa da boš imel zeloooo nestabilen računalnik.
Jaz imam "odvit" i7-10710U iz 65W na 25W in dela fanless. Samo hladilna rebra. Čisto silent pc.
klinker ::
Nikonja je izjavil:
Wtf...zakaj bi bil nestabilen? Samo boostal ne bo na max, to je to.
orbika ::
Nikonja je izjavil:
Samo toliko mi je rekel, da se računalnik izklaplja. Ima pa neko manjše ohišje ...
SLabo hlajenje? Boljši hladilnik al pa vodno hlajenje.
besame ::
V tem primeru je treba popraviti hlajenje. Včasih pomaga že menjava hladilne paste. Drugače pa naj vgradi večji hladilnik in/ali pusti ohišje odprto. Lahko tudi menja OS na linux, ker Windows se kar naprej ukvarja sam s sabo in po nepotrebnem segreva CPU.
orbika ::
Evo, da odgovorim. Menjali so mu matično za neko drugo in sedaj laufa. Ima 600 napajalnik, ohišje pa je neka kockasto. Ima cel kup montiranih ventilatorjev. To so urejali pri E-misiji.
besame je izjavil:
Pri Windowsih je dovolj, da ugasneš cel kup nepotrebnih services. Ti prišpara CPU in RAM.
Greš na XDA, prebereš malo člankov in ugasneš po željah.
Linux tudi ni več to, kar je bil včasih, ko ti je 800kB veliko monolitno jedro zagotavljalo vse. Plus, praktično nihče več ne zna prevesti lastnega jedra, čeprav bi bilo koristno, ko se Linux laufa na nekem VM clustru.
lepota linuxa je to, da imaš distribujo za čisto vsak namen. Od par 10MB mikro varjante do par GB relisa, k ma vse.
Če ne znaš prevedit jedra (nwm sicer zakaj bi to počel v tek časih) lahko vedno poprosiš AI, da to nardi za tebe>:D
2nd Gen Intel Core ULTRA - Arrow Lake (Serija 200) (strani: 1 2 3 )
11815079 (327) Mr.B
14th Gen Intel Core - Meteor Lake (strani: 1 2 3 4 5 6 7 8 9 )
41093626 (18211) Horzen
Procesorji Ryzen 7000 prispejo konec septembra (strani: 1 2 3 )
Oddelek: Novice / Procesorji
13225216 (17828) FlyingBee
Visoke temperature s procedorjem i7-10700 s custom coolerjem
232017 (1285) jamie1
AMD dopolnil drugo generacijo procesorjev Ryzen Threadripper (strani: 1 2 )
5822193 (20029) krneki0001
