Forum » Igre » PES3
PES3
damirez ::
A ste jo ze kaj spiali in kasna se vam zdi? Men ni ql ker ni multplayerja pa se graficno je zahtevna pa se ne dela mi dobr na mx460 pol textaru manjka pa kr neki no uglavnem kr slika se mi zatakne pol morm pa alt-tab prtinsn da je kj sploh.
VuLc4n0 ::
jaz spilam in me nic ne moti. ce primerjam z fifo je fifa en kup dre*a
Na GF FX 5600 nima nobenih problemov, sicer je pa že patch zunaj.
http://christinalake.cjb.net
flipflop ::
Boljša od fife,škoda ker niso prava imena (se odpravi s "popravkom"),pa joypad rabiš za igranje,ker je s tipkovnico sux.
damirez ::
Men je frend posodu FX5600 pa mi je tud normaln delala zdej pa z mojo MX460 mi pa ne patud demo mi ni bom se patch nalozu pa povem. Igralnost rula sam kje je god damn multiplayer?
damirez ::
Kje pa dobim patch ker ga ne najdem mislm ta path da bo delala za mojo graficno in ne tist patch za imena tizga ne rabm men je sam pomembn da igram.
VuLc4n0 ::
klik
- Fixed so that the settings of "Setting.exe" will be reflected accordingly.
- Fixed the problem of game running too fast in the full screen mode.
- Fixed the problem of the game stopping when switching to "Window mode".
- Fixed the problem of the game stopping when only Spanish is installed, and when trying to change the language sound.
- Fixed the portions of the game stuttering during the match.
- Fixed the problem of changing the player call name, when there is only one language installed.
- Fixed so that the game can be played through the finals in a multi player mode.
- Fixed the shadow effect of the player on the pitch.
- Cleared the line when the game screen fades out (happened rarely)
- Fixed the problem of the schedule becoming incorrect after the 7th week of the 3rd season in the Master League mode.
iration ::
Jah, tist kar rabiš, dobiš tam, kjer si dobil PES3, ane?
Tudi jaz bi imel kakšno pravico rad v življenju. Npr. pravico do tega, da delam
12 ur na dan in sem za to nagrajen s strani delujočega ekonomskega prostora, ne
pa kaznovan s strani Salmoneličevih gremlinov. - NavadniNimda
iration ::
Hmm, dobiš zraven patcha. Works fine here.
VuLc4n0 ::
KLIK
Evo dva lepa gola. Prvega sem daj jaz, v naslednjem napadu pa računalnik
----> fajla daš v mapo SAVE, v igri morata biti plac 2 in plac 3 prosta (pri shranjevanju)
Have phun
Have phun
- spremenil: VuLc4n0 ()
thramos ::
Men pa noce applyat patcha. Pozenem, pol pa napise "the game is not properly installed"
A kdo kej ve o tem?
A kdo kej ve o tem?
VuLc4n0 ::
Na URADNI strani piše da moreš met not original DVD.
Vrži špil dol pa ga ponovno namesti, potem bi moralo iti
b4d ::
MEni je ful carski, sam imam problem dela mi ful počasi, potem pa kr naenkrat dobi med igrco turbo hitrost. Imam pa Athlona 2400+ in radeona 9500 pro 128mb, torej v tem ni problem. Bi morda patch to rešil? Pa kje dobit tisto, ko patchaš sej veste...
b4d.sablun.org
b4d ::
Ja patch že že, sam ni to dovolj ko imaš varnostno kopijoi narjeno! Kje dobit TISTO?
b4d.sablun.org
b4d ::
Uglavnem tisti, ki imate probleme z:
Čudnim premikanjem izbire v menujih:
-izklopite V-sync
Štekanje:
- Low grafika, pa anti- aliasing in druga sranja izklopite, sej ne zgleda tako lepo, samo dela na 1024x...
-izklopite V-sync
Štekanje:
b4d.sablun.org
sc5899 ::
A se dobi kaki path da bi mi to delalo normalno na GF MX 440? ( s temi pathi do 1301 )!
Gor sem si naložil path 1301 pa bi rabo še eno stvar?
Ima kdo to ali da vsaj link ali kako ? Insert CD
Hvala za odgovor!
Hvala za odgovor!
VuLc4n0 ::
jao s spraševanjem o crackih na tem forumu ne boste nič dosegli... oz. dosegli boste zaklep teme
tu se lahko še kaj naučite
ABX ::
AMD 2.0Ghz/GF 440Mx
640*480 Med
Teče dokaj solidno.
Katastrofa.
640*480 Med
Teče dokaj solidno.
Katastrofa.
Bevcan ::
AMD 2.0/radeon 9000 64mb/256mb dela lepo na 1024*768 medium.
Ta igra je res čudna. SLičal sem za ljudi, ki jim na boljši konfiguraciji dela slabš. Res škoda da je pri tako odlični igri predelava taka katastrofa.
b4d ::
Res je slabo scriptana za PC, ampak koga to briga, glavno, da se jo da igrat normalno!!!
b4d.sablun.org
VuLc4n0 ::
Men špil dela brez problema vse na high pa resoluciji 1024x768 (zaradi monitorja
Igra teče ceu čas normalno, se ne zatika...
mam pa:
p4 3ghz
geforce fx 5600
512 mb rama
mam pa:
p4 3ghz
geforce fx 5600
512 mb rama
damirez ::
2004: Igramo lepe spile, vecinoma multiplayer, ker se to pac spila zdej, samo PES3 NIMA PODPORE ZA MULTIPLAYER!!! WTF!
Tak spil je pol grd avtomaticno, edin ce bom spilal prot compu?
VuLc4n0 ::
Če špil nima podopore za multi player še ne pomeni da je zanič...
EDIT;
tud max payne ni mel podpore za multi player pa je bil fenomenalen ...
EDIT;
damirez ::
Slabo primerjavo si dal... Kaj ko bi bil Q3 samo single player si predstavljaj. Pri fuzbalu ni vecjiga filinga kot igra prot frendu. Sej spil je zakon sam kaj ko morem 1ga zvecer najdt da prid k men da spilava pes3.
VuLc4n0 ::
to vem da sm dau slabo primerjavo sam se v tistem trenutku nism nič drugega spomnu
Redman ::
Strinjam se z damirezam da je škoda ker ni online opcije ker potem bi bil špil fenomenalen. Sam je pa tut proti kompu zelo dobr špilat ker je vsaka tekma poglavje zase. Res pa da ko bo multi(upajmo da v pes4)bo potem igra dobila še eno dimenzionalo več.
damirez ::
Ane res bi sedl, da bi mal tko zvecer spilal med sabo. Drugac tud 1na1 je vsaka tekma poglavje zase. Jest neznam prevec dobr samo ko imam sanso je to skoraj 100% gol. Mam frenda, ki to spilo ze 5 let spila ze isspro pa ma 10x vec sans sam gole iz 100% pozicij ne zadane iz 0,000001% pozicije pa kr zadane. :)
b4d ::
Sej kadar bo če bo, bomo. Drugač pa se nekaj šušlja o izdelavi modula za net igranje s strani nekih rusov al irancev. upajmo.
b4d.sablun.org
Alexius Heristalski ::
Kateri joypad uporabljate? Moram si enega kupiti, prosim za predloge!
- spremenil: Alexius Heristalski ()
Ethan ::
Hello!
Imam converter za PS2 Dualshock in igra kar leti.
Na začetku sem igral z tipkovnico potem pa sem nabavil dual shock 2 in ko se navadiš na njega , postane igra še toliko bolj zanimiva.
A je kdo iz okolice Nove Gorice, ki bi imel kaj časa za par tekem?
Lp, Andrej
p.s. Igram na 5 zvezdic in zadnje čase kar zmagujem. :)
Lp, Andrej
I feel the need, the need for speed!!
Ethan, kje si dobil konverter za PS Dual Shock 2? Jaz bi rad imel to kombinacijo, ker je menda najboljša. Sicer pa razmišljam o Logitech Rumblepadu.
jRk0 ::
jaz mam Thrustmaster Fire Storm Dual Power 2.
ful dober joypad, sploh za tako ceno!
pa se force feedback ma in to vse za 8k sit :)
Ethan ::
Hi Alexius!
Kupim sem prek neta. Mislim, da je na strani
www.lik-sang.com. - pod pc stuff.
Cena je okrog 15 USD ter 5 USD poštnine. Dobiš pa nekje v 5 delovnih dneh. Če kupiš samo to , ne plačas carine ( skupaj znesek ne sem presegat 6.000 Sit). Imajo pa več vrst konverterjev (kar poglej). Jaz sem kupil tistega, kjer lahko priključiš 2 dual Shocka . Dela vse tudi vibra , res cool.
p.s. Zdaj na 5 zvezdic težavnosti že vse zmagujem, ter na manual.
Še zmeraj čakam koga iz NG za kako tekmo.
lp;Ethan
lp;Ethan
| » | Minecraft (strani: 1 2 3 4 5 6 7 8 )Oddelek: Igre | 84718 (12288) | Gagatronix |
| » | SurvariumOddelek: Igre | 3610 (1852) | oo7 |
| » | RaceRoom Racing Experience (RRRE) Free2PlayOddelek: Igre | 4202 (1952) | Jst |
| » | Dishonored 2: Darkness of Tyvia (strani: 1 2 3 )Oddelek: Igre | 27230 (17134) | ahac |
| » | Valve & STEAM & On-Line gaming (strani: 1 2 )Oddelek: Igre | 10022 (8444) | Tilen |
